🏆 Top Deck Stain Picks Summary
Top Oil-
Based Stain
Top Water-Based Stain
Top Solid Color Stain
Easiest to Apply Stain
*Free Shipping Included
✅ How I Rate Deck Stains
  • Ease of application
  • Wear and tear after 2 years
  • Oil-Based:
    • Deep penetration
    • Easier maintenance
  • Water-Based:
    • Better UV color retention
    • Faster drying
1. TWP 100 Series
2. Armstrong Clark Wood Stain
3. TWP 1500 Series
4. TWP Pro-Series Semi-Solid
3. Defy Extreme Stain
  • Durability: 2–3 Years
My Test Deck Stats
Deck Square Footage: 2100
TWP Cedartone Natural 101
5.00out of 5
5.00out of 5
5.00out of 5
My Test Deck Stats
UV Exposure: 50% Full Sun
Light Walnut
$51.99
My Test Deck Stats
Deck Square Footage: 600
UV Exposure: Full Sun
 Semi-Transparent Cedar
TWP Semi-Solid Stain
  • Durability: 3 Years
  • Maintenance: Moderate
My Test Deck Stats
When Tested: August 2023
Deck Square Footage: 800
UV Exposure: Deck in full sun
TWP Semi-Solid Cedar Mulch
$79.99
5.00out of 5
$314.95
$93.99
$394.95
TWP 1500 Series Rating
  • Maintenance: Easy
My Test Deck Stats
Deck Wood Type:  Cedar
Deck Square Footage: 400
1501 Cedartone
$69.99
$264.95
$315.00
$329.00
  • Durability: 1.5–2.5 Years
  • Maintenance: Easy
My Test Deck Stats
Chesnut
$110.00
Defy Extreme Stain Review
  • Durability: 2 Years
My Test Deck Stats
Cedartone
$59.99
$269.99
Ready Seal Wood Stain Review
  • Durability: 1-2  Years
My Test Deck Stats
Natural Cedar
Cutek Extreme Oil
  • Type: Penetrating Oil
My Test Deck Stats
Deck Square Footage: 1000
How Many Years Tested: 1 Year
Walnut
Cutek Extreme Oil
CUTEK-Extreme Premixed-Sample
Semi-Solid Deck Stain Review
Best Deck Stain for Old Wood
✅ Deck Stain Types Explained
Transparent Stains
Transparent Deck Stain
Semi-Transparent Stains
Semi-Transparent Deck Stain
Solid (opaque) Stains
Solid Color Deck Stains
2. Long-Term Durability
3. Deck Condition
4. Climate Concerns
  • Over-applying stain
  • Skipping prep
✅ Best Deck Stain FAQs
Quick Tip:
What is a deck stain?
⏳ Durability & Maintenance
🎨 Appearance & Color
🛠 Application & Usage
🆕 New Deck Questions
  • Smooth wood: Wait ~3 months
  1. Deck Location: Michigan
  3. Wood Type: Cedar
  4. Mold/Mildew?No
5 348
4 28
3 4
2 2
1 5
0 2
30.9K Comments
Becky
Becky
5 days ago
I live in Ohio. What would be the best solid stain to redo my two year old deck it doesn’t hold stain well
Paula
Paula
8 days ago
I have a 46 year old deck that I treat with an oil stain each year and it turns black by the next summer. I just cleaned it as best as I could and I want to find a stain that won’t turn black. I think the Armstrong Clark sounds best to try for the age of my deck. Please advise
22 days ago
For a new treated lumber deck what is your opinion of products like TotalBoat Clear Penetrating Epoxy Wood Sealer?
Teresa
Teresa
25 days ago
Most of the products that you recommend are not available for sale in my area (Minneapolis MN). TWP used to be offered at a local high end paint store but they no longer carry it and only the semi transparent version is available at Fleet Farm here. I have ordered samples from TWP for their semi solid version and also some from Armstrong. My deck gets full sun and I was thinking that a semi solid would be the best choice but I am concerned about peeling. Will the stains that have a higher pigmentation ie semi solid be more apt to peel due to full sun for most of the day? Also wondering what your thoughts are about PPG which is available here. BTW my deck us Cedar and has a LOT of knots in it which I was trying to cover with a semi solid stain
Thanks!!!
John Organ
John Organ
1 month ago
I installed some cedar 1×4 trim around my windows and doors on my house a couple of years ago. I did not put any coating of any kind on it so it is just raw. Some of it has lost some of it rich color and is faded or bleached out a little bit by the sun. I want to bring back that consistent natural Warm cedar color to it and then apply a protective clear coating. What products do you recommend?
Sue Scott
Sue Scott
1 month ago
Thank you for all this info… i need help in Buffalo NY area… I have a cedar outdoor shower built on a pressure treated deck this year I would like to stain with a semi transparent stain for the cedar without orange tones and showing the grain. I need a stain and sealer for my shower which is used late April-October on average. What is the best product to use that with last without reapplying every 2 years . I can drive to Pennsylvania to buy product if needed.
Also, when should I ? Stain and sealer the pressure treated wood. The deck and shower were completed September 2025
Thank You
The Bakers
The Bakers
1 month ago
Large 13 year old pressure treated pool deck in southern IL, full sun. We have days of upper 90s as well as snow/ice. Mold/mildew non-issue. We used Restore-A-Deck in 2020 and loved the look/color, but felt longevity wasn’t any better than cheaper stains. I used Ready Seal in ’23, but felt it faded quickly. This particular deck hasn’t had an oil base, and I am thinking this year of using Armstrong Clark semi-transparent with hopes of being able to clean and recoat as needed in a year or two. We’ve always used semi-transparent and have been scared of using a semi-solid for fear it will wear like paint with colored patches mingled with worn-off patches and not sure how to recoat with that issue so have stayed away. Maybe we should re-consider. What, in your opinion, would work best for us? All info greatly appreciated.
Larry
Larry
1 month ago
I have a 12×34 deck of pine I want an oil based stain where I can see the grain. I want a true light brown color. I can’t find it! It’s either too yellow or too orange. Do you have any suggestions
cliff
cliff
2 months ago
Live in SE Florida, putting a 6″x 24′ Cypress tongue and groove ceiling in my pergola. Above the cypress will be fiberglass insulation and a roof. I’m concerned about the humid weather in SE FL. Perhaps TWP 1500 semi-transparent, cedar or red cedar color. Since the cypress will be new…do I still need to brighten the wood after sanding with 80 grit?
Johnny spain
Johnny spain
2 months ago
Freshly sanded deck of old stain . Bare wood now . What’s next step ? Deck wash or stain ?
Johnny spain
Johnny spain
2 months ago
80 grit was last grit used . Have finer if needed
Pat Rogers
Pat Rogers
2 months ago
I have an older painted or solid stained deck that is in the mountains of East Tennessee. It does get all sad in the rain lots of wind, high wind, and I’m looking to change the color of the solid stain. That’s on it and really needs your recommendation. I’m wanting to do dark handrails and a lighter color on the floor Naturally would love to have something that would last longer than two or three years. I’ve already prepped a lot of it, but haven’t decided on the solid stain color or what product to use.
1 261 262 263
30.9K
