This post was updated on April 16, 2026
Hi, I am Scott Paul, a leading exterior restoration contractor and business owner with over 30 years of experience in exterior wood decking. My Best Deck Stain reviews and help tips are based on my history as a wood restoration contractor and actual hands-on testing, all designed to present you with the top deck stain choices. See here for more info about me.
Elevate Your Deck with the Best Wood Stains & Sealers
Whether preparing for a DIY deck-staining project or looking for the perfect stain to share with your contractor, I’ve got you covered. I have rounded up the eight best deck stains available in 2026, including oil-based stains, water-based stains, and semi-transparent and solid options.
✅ What Is the Best Deck Stain? (Quick Answer)
The best deck stain for most homeowners is a penetrating semi-transparent stain that offers durability, easy maintenance, and natural wear without peeling. Top-performing stains consistently come from brands that focus on deep penetration and UV protection.
👉 Best for most decks:
- Semi-transparent penetrating stains
- Oil-based or high-quality water-based options
Scott’s Expert Guide to Choosing the Best Deck Stains
- Wood Condition: New, weathered, or heavily worn
- Desired Look: Natural grain showing vs solid color
- Maintenance Preference: Easy recoat vs long coverage
- Climate: Sun exposure, moisture, temperature swings
My Recommended Best Deck Stains and Sealers at a Glance
Click on the link and jump straight to the review:
- Top-Rated Deck Stain: TWP 100 Pro Series Stain Review — This deep-penetrating, long-lasting, semi-transparent stain is oil-based, easy to apply, and withstands the elements for up to 3 years.
- Recommended Semi-Transparent: Restore-A-Deck Semi-Transparent Wood Stain Review — Restore-A-Deck’s UV-resistant, semi-transparent stain can be applied to damp wood, which means we can prep your deck and apply the stain in one day.
- Leading Semi-Solid: TWP® Semi-Solid Pro-Series
- Oil-Based: TWP 100 Pro Series Semi-Transparent
- Best Water-Based: Restore-A-Deck semi-transparent deck stain
- Recommended Solid Color: Restore-A-Deck Solid Color Wood & Deck Stain
- Best-Applying: Armstrong-Clark Wood Stain — This long-time favorite is a hard-working, deep-penetrating option that goes on easily and allows for simple maintenance.
- Excellent Semi-Solid Wood: TWP Pro Series Semi-Solid Stain — TWP’s semi-solid stain goes on quickly, holds color well, and offers maximum UV protection and a variety of color palettes to choose from.
- Outstanding Wood Preservative Deck Stain: TWP 1500 Series Semi-Transparent Stain — TWP’s 1500 Series consistently ranks as one of my top options for deck stains, thanks to its deep-penetrating formula, UV- and mold-resistant properties, and long-lasting color.
- Recommended for Mildew: Defy Extreme Semi-Transparent Wood Stain — Defy’s water-based Extreme Wood Stain offers rich, penetrating color and an infusion of zinc oxide Nano-particles that prevent damage from UV rays, mold, and mildew.
- Best Deck-Resurface Coating: Gulf Synthetics Deck Revive
Is There a #1 Rated Best Deck Stain or Sealer?
✅ Deck Stain Types Explained
- Transparent/Clear Sealers: Natural look, less protection
- Semi-Transparent Stains: Best balance (most recommended)
- Semi-Solid Stains: More color, moderate maintenance
- Solid Color Stains: Maximum coverage, higher maintenance
Transparent Stains
As the name suggests, transparent stains are clear or very lightly tinted stains that help seal and protect wooden decks while still allowing the wood grain to show through.
Solid (opaque) Stains
2. Long-Term Durability
3. Deck Condition
4. Climate Concerns
- Film-forming coatings on older decks
- Over-applying stain
- Choosing based on color alone
- Skipping prep
- Not preparing your deck: Failing to clean your deck or remove old, flaking, or peeling stain from your boards can prevent a fresh coat of stain from adhering properly. See my Deck Cleaning Guide for best results!
- Over-applying stain: You may think more stain equals more protection from moisture, mildew, and sun damage, but that’s not always the case. Too much stain can prevent the product from penetrating your deck boards. As a result, it may form a film on top of the wood that peels or flakes off over time. See my How to Stain a Deck tips for the best results.
From: $41.99 | From: $47.99* | From: $65.99* | From: $69.95* |
*Free Shipping Included
✅ How I Rate Deck Stains
- Durability in real-world conditions
- Ease of application and maintenance
- Resistance to peeling and wear
- Overall long-term performance
- Wear and tear after 2 years
- Oil-Based:
- Deep penetration
- Easier maintenance
- Water-Based:
- Better UV color retention
- Faster drying
1. TWP 100 Series
2. Armstrong Clark Wood Stain
3. TWP 1500 Series
4. TWP Pro-Series Semi-Solid
5. Ready Seal Wood Stain
3. Defy Extreme Stain
- Scott’s Pro Tip: My most used deck stain in the past 30 years! We have used the TWP 100 Series on many 1000s of decks.
My Test Deck Stats
Deck Square Footage: 2100
Consumer Star Ratings:
- Scott’s Pro Tip: My favorite deck stain to save time and money. We prep and stain on the same day.
My Test Deck Stats
UV Exposure: 50% Full Sun
- Scott’s Pro Tip: Regarding ease of application and performance, the Armstrong Clark stain is one of my top stains. We love their semi-solid colors and performance.
My Test Deck Stats
Deck Square Footage: 600
- Scott’s Pro Tip: My favorite penetrating semi-solid wood and deck stain soaks into the wood and provides excellent UV protection.
My Test Deck Stats
When Tested: August 2020
Deck Square Footage: 800
UV Exposure: Deck in full sun
- Scott’s Pro Tip: My favorite current penetrating semi-transparent oil-based stain is the TWP 1500 Series. Michigan switched to low-VOC, so I now use it on the majority of decks that I restore.
My Test Deck Stats
Deck Wood Type: Cedar
Deck Square Footage: 400
- Scott’s Pro Tip: My new favorite IPE and Hardwood Deck stain is the first stain I have ever seen last more than one year on exotic hardwoods.
My Test Deck Stats
Stain Color Used: Chesnut
- Scott’s Pro Tip: The Defy Extremes is one of my top choices when using a water-based semi-transparent wood stain.
My Test Deck Stats
Stain Color Used: Cedartone
- Scott’s Pro Tip: Ready Seal Stain is not my favorite since it requires annual recoating, but I do like that it applies easily. Ready Seal does not cure fully and can rub off the wood on clothing.
My Test Deck Stats
Scott’s Pro Tips: Although CUTEK® Extreme is more expensive than many penetrating oils, the performance was very solid. There was no peeling or significant wear, and the coating should be easy to maintain, as it fades naturally and can be refreshed without stripping.
My Test Deck Stats
Deck Square Footage: 1000
How Many Years Tested: 1 Year
Stain Color Used: Walnut
Semi-Solid Deck Stain Review
- Consumer Star Ratings:
My Best Deck Stain FAQs:
What Is the Easiest Deck Stain to Maintain?
Penetrating semi-transparent stains are the easiest to maintain because they do not peel and can be reapplied without heavy prep.
Solid stains retain color longer, but penetrating, semi-transparent stains are easier to maintain.
Typically every 2–3 years depending on exposure.
Penetrating semi-solid stains are best for older wood and decks that are dried out.
What is a deck stain?
Deck stain is a type of finish applied to the wooden boards of your deck. Generally speaking, deck stains come in three types —transparent, semi-transparent, and opaque —and are available in a wide range of colors to suit your taste.
The deck stain must be tinted to protect it from UV graying. I prefer semi-transparent stains, as they do not mask or cover the wood but highlight the grain while providing UV protection.
My favorite deck stains have been penetrating semi-transparent and semi-solid stains. These stain types allow the wood grain to show, and if they truly soak into the wood grain, reapplying is easier down the road.
What deck stain types can be cleaned and recoated as needed?
Penetrating deck stains are not prone to peeling, and we can clean and reapply them as needed. Deck stains that dry or film on top of the wood are much harder to maintain and prep when reapplying.
Absolutely! Deck stains are wood stains and work very well for wood fences, vertical wood siding, and log cabins. They last even 2-3 times longer on vertical wood.
The waiting period before staining a new deck can depend on the material used to build it. Take a closer look at our recommended time frames based on deck material:
- New, smooth wood decks: Wait at least 3 months before applying stain.
- Rough-hewn wood decks: No wait time is needed; you can apply stain as soon as the wood is clean and dry.
- Kiln-dried or KDAT wood decks: Wait 1-2 months before applying stain.
For more information, check out this guide on how long to wait before applying stain to your deck.
The most popular deck stain colors of 2026 include:
- Cedar tones
- Brown tones
- Honey tones
- Redwood tones
The best way to apply a deck stain can vary based on the product used, but my personal favorite applicators include flooring brushes and stain pads. Learn more in this guide to the best deck stain applicators.
What’s the difference between a deck stain and deck paint?
Deck stain and deck paint are similar in that they add color to a wooden deck. However, deck stain typically penetrates into the fibers of wooden deck boards and often results in a more natural final product. On the other hand, deck paint is typically thicker and creates an opaque layer of color over the wood.
Both water- and oil-based deck stains can provide rich color and long-lasting protection against moisture and UV damage. However, there are some differences between the two stains.
For instance, oil-based stains may offer advanced protection against warping or cracking and last longer than water-based stains. However, water-based stains are generally more environmentally friendly and easier to apply and clean up. Many water-based stains also feature additives to prevent fungal damage or wood rot. Learn more in this guide to the differences between water—and oil-based stains.
The 3 best deck stain brands for decks in full sun are TWP, Restore-A-Deck, and Armstrong Clark. The TWP 100 Pro Series semi-transparent penetrating deck stains in darker tints are best for most decks. TWP also has a semi-solid penetrating deck stain that works well in full sun. Restore-A-Deck has semi-transparent and solid deck stains for full sun. Armstrong Clark is a high-quality oil based deck stain.
- Deck Location: Michigan
- Wood Type: Cedar
- Mold/Mildew?No
I am here to help you find the best wood deck stain for your situation! Just post a comment below with answers to these questions.
TWP Natural Effect Top Coat 1 Gallon - Step 2
Pennsylvania (philly)
Full sun
10 year old deck
No mold
Stained it three years ago and simply needs new coat
Prepped it with deck cleaner and pressure washer
Amy, did you use a semi-transparent stain previously?
I think so, I could see the wood through the stain.
SOUTHEAST PENNSYLVANIA
FULL SUN UNTIL AFTERNOON. TREES AT WEST SIDE OF DECK.
PRESSURE TREATED PINE 2X6 CONSTRUCTION
BLACK MOLD, SUN DAMAGE, GREEN MOSS GROWING
BEHR SEMI SOLID PEELED, STRIPPED, THEN SUPERDECK TRANS. GRAYED IN 6 MONTHS THEN NEGLECTED FOR 5 PLUS YEARS
Real Big, make sure thoroughly and brighten the wood first. I would suggest Defy Extreme or TWP 1500 Series for this deck. If you have any other questions, just ask. :)
Seattle area
25+ yr deck
Fir (I think)
Have pressure washed yearly
Last used Cabots 2 yrs ago.
Peeling, moss each winter
Cedar color stain where it's not worn
Barb, make sure to clean and remove the Cabot with a deck stain stripper and an wood brightener. I assume you have alot of moisture so I would go with a product that penetrates very well and does not promote mold growth.
Defy Extreme Stain
Eastern South Carolina
full sun on majority of the deck, some mildew issues closest to the house (small area)
pressure treated, kiln dried pine and bamboo privacy screen surrounding the deck which we want sealed/stained also
deck surrounds an above ground pool
deck is one year old and has not been stained or previously sealed
Carrie, make sure to clean and brighten this one year old deck to prep. For this deck I would look at one of the TWP Stains or the Defy Extreme.
Fred:
Eastern PA (Phila area)
1/2 full sun; 1/2 shade
Cedar decking
no mold problem
previous stains peeled/disappeared
Fred, I would look at the Armstrong Stain or TWP 1500 Series for your cedar deck.
Southeastern PA
Afternoon full sun
Cedar – 8 yrs old
No mold issues
Refrehsing
G Boone, For PA I would look at the Defy Stains for Hardwoods/Cedar or the TWP 1500 Series.
Oregon – Willamette Valley
South facing
Pressure treated I believe (has grooves underneath) 16 years old. Has been 4 yrs since it has been treated.
Moss,mildew
Have used penofin – works well but turns grey quickly – probably within a year.
Hannah, Penofin is a very good looking stain. Maybe go with one of their darker colors for longer UV protection otherwise I would look at TWP stain products.
Deck Location State: Vancouver, BC, Canada
Full Sun, Partial Shade, Full Shade: Partial Shade
Wood Type: Cedar
Mold or Mildew Issues: No
Reason for Previous Stain Failure: Algae and darkening
The deck has now been sanded down and looks great again. I'm waiting for dry weather to stain it. What is best in our climate? I don't want anything that can peel and I'd like to see the natural wood grain and perhaps enhance the cedar colour — love the way it looks when wet!
Rose, make sure to use a wood deck cleaner and brightener to prep your wood after the sanding. This will help your stain to penetrate better. I am not sure what you can buy locally in BC, Canada. If buying online, I would look at Defy Hardwood Stain or Armstrong.
Deck Location State: OREGON (Eugene Willamette Valley)
Partial Sun (Shade 70%)
Wood Type: Building it soon. Western Red Cedar or TimberTech Earthwood Evolutions (if we can't find a stain that works)
Mold or Mildew Issues: Yes
Reason for Previous Stain Failure: Other decks in this area: tried many products none worked with PT Hemlock. This time used Western Red Cedar. Will take suggestions on other woods though.
Comments: Not a lot of snow here, but lots of rain and cloudy days. Lots of contractors are pushing us to use TimberTech Earthwood Evolutions but I think in our environment it might get mold and fungus also and would need almost as much maintenance but no one can really prove this one way or another.
Jeff, not sure on the TimberTech wood. If you go with brand new WRC then I would look at this product for applying the first coat: TimberOil Brand
San Jose, CA
1/3 mostly shade, 2/3 mostly sun
1000 sq ft, Redwood
Reason: Previous home owner used Behr Redwood semi and it was pealing badly in mostly sun areas after couple years on floor boards and top railings (flat surfaces)
Currently sanding back to remove old stain and trying to decide best option for semi-solid.
Austin, for a semi-solid stain I would go with the Armstrong Clark Wood Stain. Great colors and applied easy. They have a Sequoia Color that would look real nice on the redwood.
Deck Location: Central Virginia
Sun Exposure: Morning Full Sun, Afternoon Full Shade
Mold or Mildew Issues: N/A, New
Reason for Previous Stain Failure: N/A, New
I would prefer a low VOC even though it is not required in our area of VA.
Rachel, TimberOil Brand is great for new wood. It is low VOC as well.
Northeastern Indiana
Part sun/part shade
some small mildew areas – very close to a woods
red cedar – 25 years old
The deck is structurally very sound, but the stain never seems to last. I would like not to have to clean/restain every year, perhaps every two years?
Kris, make sure to prep properly and remove any old stains. I would use the TWP 1500 Series in one of the medium colors or the Armstrong Clark in the semi-solid colors.
Eastern Pennsylvania
Morning Shade and afternoon sun
Ipe – about 1 year old
Mold not an issue, but it does get wet
Initially finished with Penofin Verde (Rosewood)
Liked the deep, rich dark color of initial finish and just doing annual maintenance. Had the deck powerwashed and a lighter Armstrong Clark stain was used that we didn't like. It is getting restained/finished. Wondering what to use.
Bob,
Lighter stains will always fade faster, especially on IPE. Armstrong in the Mahogany color will outlast any stain on IPE and can be cleaned and recoated annually. I would also look at the IPEOil finish.
Deck Location: Bryan, TX
Full sun
Mold or Mildew: None noticed
Reason for Previous Stain Failure: Never stained
This is a double level deck that is 3 years old and never had any stain or anything applied to it. Now wood is cracking and plitting in places and of coure gray. It is around my above ground pool on the upper deck at edge level and around the pool on the lower deck at about 3ft. down with some water splash on it also. I have cleaned the deck with Olympic deck cleaner and pressure washed it. Nice and clean now but I am wondering if it needs a deck brightner and also which stain/sealer would you recommend. Thanks.
Yes you should brighten the wood. It will help the stain perform better.
For your TX pool deck, you should look at the Defy Extreme Stain or TWP Stains
Hamilton, Ontario, Canada
Morning sun on half, full shade on the other half
New white cedar. buillt last fall but has not been treated yet
no mold or mildew
8 months old
no stain yet
Kelly, you are limited to what can be bought in Canada. If you want to buy on the Internet then I would look at the Defy Hardwood Stain or the Armstrong Clark Wood Stain. Locally you would probably be limited to Penofin.
Here is an example deck:
1.Deck Location State: Georgia
2.Full Sun, Partial Shade, Full Shade: Full Sun
3.Wood Type: Pressure Treated Pine
4.Mold or Mildew Issues: Yes
5.Reason for Previous Stain Failure: cleaned a couple times over last 6 yeras, Never stained.
Also have a cedar fence 2700 cubic feet going to stain. cleaned two weeks ago.
Dave, I would look at the TWP 100 Series for both the deck and the fence. It will work very well in your area.
Pittsburgh, Pennsylvania
Full sun
i believe pressure treated pine
no mold or mildew
deck is approx. 20 years old and my dad has stained every two – three years but looking to see what the best stain is out there now.
Kristin- What stain have you used in the past? I would look at TWP 1500 Series.
i believe he used Behr deck stain for a semi-transparent. lowes and home depot suggested either Deck restore or olympic maximum.
Kristin, I would stay away from Lowes and Home Depot when it comes to decking stains. They do not offer the best choices.
I am a General Contractor, who specialize in Fire & Water Damage Restoration and advanced deflooding & drying technology. I trusted BEHR advertising and purchased BEHR Premium Semi – Transparent Stain NO. 5077 at Home Depot to restore the decks on my own property and it failed within 6 months and peel off within 2 yrs. It is absolutely the worst product I have used in my 33 yrs. in business
Del, I feel bad for you and anyone who has ever used Behr\’s Deck Stains. Thanks for your post.
I would like yur recomendation.
My decks are located in Montrose Colorado/Western slope
Full sun/partial shade. Cold snowy winters/avg80-95* summers
Red wood deck
Mold /mildew
2 Yr. old Behr 5077 Semi-transparent Redwood stain/ peeling and wearing off/ complete failure
WHICH STRIPPER, BRIGHTNER, STAIN DO YOU RECOMMEND? Is TWP 100 better than 1500 for my area.
Behe can be difficult to remove. I would look at HD80 or Rad Stripper to remove followed by a wood brightener. TWP would be a good choice and either the 100 Series or the 1500 Series would work well.
My decks are located in Montrose Co.
Full sun/partial shade. Cold snowy winters/ avg. 80-95% summers
Combination of cedar railing and redwood deck?
Mold and mildew
BEHR redwood stain 5077 peeling and wearing off / complete failure
Which stripper,brightner,stain do you recommend?
Del, is the Behr a solid or semi-transparent stain?
Semi-transparent stain / 2 coats
Del, Behr can be a very difficult product to remove. You may need to do some sanding.
1 – Pennsylvania
2 – morning shade, afternoon sun
3 – Ipe
4 – no mold, a little mildew
5 – Woodtux – darkened too much. Totally stripped deck over a year ago, and allowed the ipe to weather – open up the pores. Now ready to stain again (after using EFC-38 and citralic to neutralize). I know nothing will last longer than a year, but I’m looking for something that will look fairly good for a year – without darkening.
Suzanne, I would look at the Armstrong Clark in the Mahogany color.
State: Illinois
Partial Shade to Full Shade
Mold and Mildew – Yes!
Mold and Mildew and lack of moisture protection
Full shade and partial shade can be prone to mold issues. I would look at the Defy Extreme Stain as it offers excellent UV and mold protection.
Our deck is about 5 years old. We live in NY and it is pressure treated pine and we stained it(about 4 years ago) with a semi transparent Cabots. Well it faded away(partial sun) and I recently power washed and cleaned it so i think it is okay for restaining now. Wish i could show a pic here somewhere so someone could confirm it is okay for restaining. I think me and my wife are going to get the TWP 1500. Thanks,
Beau, you can add a new post in our forum section with pictures of your deck: Deck Stain Forum
1. Location: Livingston, TX, temps ranging 18 degree winter, 102 degree summer
2. Full Sun – 1000 sq. ft a lot of splintering and cracking, Covered 400 sq. ft,
3. Pressure treated pine
4. Some mold or Mildew
5. Reason for failure: stained with solid Behr premium over 4 years ago. Failed in full sun areas within a year.
6. Age of decking – 10 years
Steps taken thus far:
Power washed yearly, concentrating on removal of stain.
Within the month of April:
1. Power washed, most stain removed. Stain remains in deep crevices and knot holes.
2. Boards flipped where necessary
3. Nails removed where backing out and replaced with screws
I had decided to use Synta Deck Restore or Armor Renew. However, I have not found reviews for Armor Renew except on their own website. Fortunately, I found your site when researching one more time before purchasing and covering the wood completely with either of these products. I have researched until I am at my wits end! Your recommendations, please.
Denise, going with a product such as Synta is not going to end your maintenance. All product will eventually fail. The Synta is more of an alternative to replacement for a deck that is beyond normal maintenance. It will peel or fail eventually just like any other coating. Problem is that it is much harder to fix when it does fail.
In our opinion it is better to use a semi-transparent penetrating stain and just clean and reapply every so often.
Perhaps my deck is not in need of replacement. Your recommendation for the brand/brands that will best suit my needs in our climate.
Denise, look at the Armstrong Clark in one of the semi-solid colors. This will be a better alternative.
[…] looking for better stain alternatives for their deck restoration. Our most popular article, “What is the Best Deck Stain” has quickly become the number one article on the web for asking questions and getting […]
Hello
1. Location: Southwest VA (Roanoke)
2. FULL SUN—-no shade
3. White Pine-Kiln Dried Wood
4. No Mold or Mildew
5. Reason for Faliure-Olympic Stain- Pealed off after one year….then sanded and restained. Peeling up again. Also, what do you do about pine sap.
Very dissappointed. New deck and looks very old now. Flooring is splotchy.
Mark-
Which Olympic did you use? The water-based or oil-based version?
I used Used oil based version.
Mark-
Sanding may be one of the issues the stain has been peeling. You really want the wood to be very absorbent. I would use the Armstrong Clark Stain. Make sure you remove the Olympic first.
1.Location – Central Pa.
2. Mostly Sun – some part in afternoon shade
3. Pressure Treated – floor 20 yrs old – railings 8 yrs (reduced size of deck) stained & sealed periodically
3. Mold-Mildew – Minor One End Only
5. Reason for Previsous Stain Failure – Only Issued Does not last more than 2 yrs.
Nancy, the best decking stains will only last 2-3 years at best on a horizontal surface floor. Since decks need to be recoated very few years, it is advisable to use a product that is easy to maintain. I would use TWP 1500 Series for PA.
1.Deck Location State: Fairifeld, CA
2.Mostly full sun…some areas are in shade
3.Wood Type: Redwood
4.Mold or Mildew Issues: No
5.Reason for Previous Stain Failure: Turned gray/dark brown in less than a year with some warping and cracking.
Lisa,
I would look at Armstrong Clark Wood and Deck Stain. It is a great product and is even made in your area. Make sure to clean and brighten the wood first.
New Hampshire
Part Sun/Partial Shade
Wood Type: Redwood Cedar; new installation
Mold or Mildew issues: present on previous unstained PT deck
No previous stain applied; using deck cleaner and brightener first
Scott, Good with the cleaner and brightener first. I would only apply one coat to this new cedar deck. TimberOil Brand
1. Northern new jersey
2. Full sun
3. Pressure treated pine ( I think)
4. Not yet, but it is by a pool
5. New deck built two weeks ago. Attached to an above ground pool.
Looking for a stain that will wear well near water.
Alison, pool chlorine can break down stains faster then normal. In addition new wood is less absorbent. This means your will need to restain this deck sooner then normal. best to choose a stain that is easy to clean and recoat as needed.
TimberOil Brand
Armstrong Clark
Any experience with Benjamin Moore's Arbor Coat?
Yes and it was not good. See her for a review:
Benjamin Moore Arborcoat
1. Michigan
2. Partial Sun (Half day as it is a east facing Deck)
3. Pressure Treated Lumber
4. No mold/mildew issues
5. No previous stain applied (I just purchased the house and was told the deck is approx. 3 years old)
Alex, Prep first with a Restore-A-Deck Kit then stain with TWP 100 Series for a deck in Michigan.
1.Deck Location State: Connecticut
3.Wood Type: Pressure Treated Pine ,six months old
4.Mold or Mildew Issues: no
5.Reason for Previous Stain Failure: new
Eric,
Lightly clean and brighten this 6 month old deck. I would only apply one coat this year then a maintenance coat 1-2 years down the road. Too much stain on a newly installed deck will not absorb well.
Defy Extreme
TWP 1500
Two decks in our pool area in Dallas, Texas. One new pressure treated wood from Home Depot. The second is old wood with no evidence of stain, but sanded and treated with Behr's 2in1. No mold and wood is new, and now looks new. Assume pine. Full sun.
Edgar,
The new deck needs to be cleaned and brightened as well. Behr\’s cleaner is not a very good choice (contains bleach) but it is too late now. I would reclean both decks with a sodium percarbonate based wood deck cleaner followed by the wood brightener.
As for a stain, Look at an oil based stain such as TWP, Armstrong Clark, or TimberOil Brand.
1.Deck Location State: New Jersey Monmouth County
2.Full Sun
4.Mold or Mildew Issues: little not much
5.Reason for Previous Stain Failure: seemed it didnt fully dry correctly, peeled and wore off way to quick. I used Cabots for the past few applications, and never had issues, however the last application in 2010 was aweful and thisis the problems I had
Cabot has changed their formulas numerous times in the past years. It is not nearly as good as it used to be back prior to 2008.
Strip off all the old Cabot Stain so you have a new fresh surface. For deep penetration and proper drying, I would look at Armstrong Clark Wood Stains or TWP 1500 Series.
When you refer to strip you mean the flat surfaces and the top of the hand rails where the problems exist correct? Because the spindles are fine. What stripper product do you recommend and how difficult is it to strip it? I allowed 1 year of non treatment and in order to wear off most of the existing product. Please advise thank you
It is almost impossible to strip just the horizontals as the stripper will run down the verticals from over spray and drips and start to remove the stain. Best to just do it all. Cutting corners just makes it harder.
Stripping difficulty varies greatly depending on the brand of stain, type of stain, and how many coats you are removing. I would look at one of the powdered deck stain strippers as they are more cost effective.
RAD Stain Stripper
HD80
Northern Jersey
Full Sun
Western Red Cedar
New deck & pergola
Eric, I would look at the Armstrong Clark Stain in the Amber Color. It will look beautiful on your new Western Red Cedar!
Northern Jersey
Full Sun
Western Red Cedar
New
Just one coat one new wood is suggested for most brands. I would look at TimberOil Brand, Armstrong Clark, and Defy Stains.
Deck Location State: Colorado
Wood Type: old redwood
Reason for Previous Stain Failure: came off in two years.
I had previously sanded it down to wood, done the cleaner and pretreatment. Nothing seems to work for more than a year on the floor boards while the vertical surfaces seem fine.
Matt, what brands did you use before? did they peel or just fade rapidly?
Sherwin WIlliams oil based cuprinol. It peeled. Thanks.
Matt,
Strip off the any remaining Cuprinol first with a wood deck stripper. Where do you live? Need a little more info to suggest a brand.
Fort Collins. So 5000' elevation.
Matt, Very high UV index means quicker stain failure. I would use Armstrong Clark in one of their semi-solids colors for maximum protection against UV fading.
we also have a redwood deck at 7800 feet in Durango Colorado. Tried various stains and they just fade away. Deck is mostly in full sun — Is TWP 100 OK in Colorado? Is Armstrong Clark better? thanks Pat
Of course no mildew here!
Pat, you can use the TWP 100 Series for Colorado. I would try that.
Hi, since a lot of this info is a couple years old, I thought I'd better check and see if recommendations are same.
Denver, CO
Full sun, extreme heat but low humidity
Somewhat high traffic since it is at back door
Might be redwood, prob 10+ yrs old! not refinished in many years but evidence of some kind of sealant
Plan is to replace a couple of boards and try to rent a standing power sander that is belt rather than rotary
What stain and/or sealant would be best? Have there been formula changes, or would you recommend TWP for me, too?
TWP 100 for CO.
If I am replacing a few boards, do I have to wait to treat them? So I should only cover the old wood?
Go ahead and to all but you will need to touch up the new boards in a year.
OK, thanks. Now if I preferred to use a water-based product, you'd recommend Defy Extreme?
As I am doing a lot of research online about this, I'd like to ask you about two other products out there in the cyber world and a wood question.
1. My brother is a timber framer and is interested in a product called LifeTime Wood Treatment from a company called Valhalla in BC. Are you familiar with this and if so, what do you think?
2. Another Canadian source – Steve Maxwell ("Canada's Handiest Man") likes teak oil. Thoughts?
3. I am reasonably sure my deck is redwood but not positive. There is no green tint on the ends of the planks, and it is a bit pinkish. How do I know for sure? (That experienced brother lives in another state!)
thank you! This is the best info anywhere.
Barbara
1. Sounds like a gimmick product. Probably helps from rotting and decay but will do nothing for exposed wood areas when it comes to UV graying, dirt, mold, etc.
2. Teak oil offers minimal UV protection and no mold protection. Mainly used for teak furniture and other exotic hardwoods.
3. Without seeing the wood it is hard to say what it is. Probably Cedar or Redwood.
1. Sequim Washington
2. Covered with the exception of stairs, winter time rian and snow blows on the decks
3.fir or hemlock sun wood
4. not that Iam where of
5. age and wear
Kenneth, I would look at the Defy Extreme Stain or Defy Epoxy.
1. Houston, Texas (Harris County)
2. mix – half deck in full sun other half in shade
3. Pressure-Treated Pine
4. Yes
5. New Deck
Deck construction finished a week ago and they started to stain (water-based Benj Moore, w/o sealer), but the contractor had never stained a deck before and several errors compounded into a mess. Would like to know best method/materials to strip and then best stain & sealant to use.
Kevin,
I am not sure a stain stripper will work on Benjamin Moore when it its just applied, especially the water based Arbor Coat. I am thinking you will need to sand it all off to fix. In the contractors defense, I would guess the issue is more the choice of stain and lack of proper prepping.
Once it is all off I would look at Armstrong Clark or TimberOil Brand for maximum penetration.
Hi, We are building a new deck in Hinckley Ohio (just south of Cleveland).
Deck Location State: Ohio
Full Sun, Partial Shade, Full Shade: Partial Shade – West Facing Deck
Mold or Mildew Issues: We expect that this will be an issue but hope to find a product to limit
Reason for Previous Stain Failure: None, this is a new deck
Bob, for new wood we really like products that are easily applied and that can penetrate well. I would look at the TimberOil Brand.
New deck (9 mo. old)
Northern Wisconsin
Full Sun
Full Sun and harsh winters. What stain would you recommend?
Never been stained. Thanks
Paul, clean and brighten the wood with the proper cleaners prior to staining as your wood has turned slightly gray in the past 9 months.
I would suggest TWP Stains
1.Deck/FENCE Location State: Northern Virginia
5.Reason for Previous Stain Failure: New Fence installed May2010, waited until end of summer to clear coat with Thompsons Water Sealer. By Summer 2011 all GREY. APR2012 power-washed deck and fence. Looking to keep natural wood color in tact with minimal maintenance.
Jennifer-
Northen VA is low VOC. Thompson\’s is a useless product in our opinion. For the fence I would look at Armstrong Clark or TWP 1500 series. You will get close to 4-6 years with either.
Decks always need to be done every 2-3 years with a quality wood stain. Lighter colors will fade faster then darker colors. Both Armstrong and TWP can be cleaned and re coated easily in the future.
Seattle Washington
Partial shade
cedar Mold Yes, to the point of becoming slick. Pine trees near by 2 years old pickets and rails have done ok. But high traffic areas of deck have worn off.
Gregg,
Being that you are in such a wet climate I would suggest a penetrating water based stain:
Defy Stain for Hardwoods and Cedar
Central Florida (not beach)
Full Sun
Pressure treated Pine and cedar (pickets)
Mildew
1 and 1/2 years old Partial blotchy uneven stain (Sikkens SRD Semi solid) that needs to be removed. Rest of deck is not stained or painted. Want to use translucent light colored one coat very durable/easy to recoat stain. Thanks!
Christain-
I would use HD80 or Restore-A-Deck Stain stripper to remove the SRD. Make sure to use the wood brightener as well.
Light colors or tints will fade faster from the UV. The richer or more pigment you have, typically the longer the stain will last. It is always best to choose a stain that is easy to maintain in the future:
TWP 100 Series
Deck Location State: Middle Georgia on a Lake
Full Sun, Partial Shade, Full Shade: Full Sun on the Decking, Partial Shade and Full Shade on Different Parts of Deck Flooring under the Double Boat House Roof
Mold or Mildew Issues: Some
Reason for Previous Stain Failure: Has not yet been stained.
What would you recommend?
Any stains available from any stores (rather than online) that you would recommend?
Ken,
I am not sure what would be available locally in your area of Georgia. Most higher end stains will not be found at your Home Depots and Lowes. Have you visited in paint store or lumber yards to see what is available? If so, we could suggest the best of them.
In my opinion it does not make sense to limit yourself to locally available stains if it saves you money and headaches down the road.
Deck Location State: Scottsdale AZ
Partial Shade
Wood Type: Heart Redwood
Mold or Mildew Issues: no, new construction
Robert, New redwood decking with intense AZ sun. Scottsdale is a LOW VOC area as well. I doubt you will have any mold issues.
Armstrong Clark in one of the semi-transparent colors would be my choice.
Sun Exp: Covered deck on west and north sides of house. West gets afternoon sun, north very little sun
Wood Type: Northern white cedar tongue and groove
Mold Mildew: No. Framing is pressure treated pine put up last June with no sign of mold or mildew on it at this time..
No Previous Stain: We want to use a semi-transparent stain and plan to stain the sides as well as the tops and bottoms. We want to avoid problems up front by choosing the right stain. Thanks
Pat, Massachusetts is a low VOC state. Make sure that you use a stain that penetrates well. Here are a couple of suggestions for your project:
TWP 1500 Series
NE Tennessee Moutains (light snow, seasonal thunderstorms, high humidity very hot summers
Wraparound gets all sun/shade exposures, mostly sun under trees
Mixed, some cedar, some Pressure-treated pine
Mildew, algae & moss (especially on north & shady sides)
25 year old deck, never treated, completely rotten, now being replaced with new construction of pressure-treated pine. Need to know how to prep raw wood and seal from the get-go.
Pam, All new exterior wood decking should be cleaned and brightened to prep. We really like the powdered concentrated cleaners. They work well and are much more cost effective. Restore-A-Deck Kits are our favorites.
As for new PTP, it should dry for 1-2 months prior to the prepping and staining. May of the stains will have difficulty penetrating into new wood. Using a stain that contains paraffin oil will penetrate new wood much better. I would look at:
or
TimberOil Brand (not cabot’s version)
New Mexico mountains (snow in winter and intense summer sun)
1/2 Full sun and 1/2 under a porch
Redwood
No Mildew
10 year old deck. Blotchy, stain worn out in the sunny areas
Myrle, lots of snow and intense UV index! You have very harsh conditions for a deck. Prep first to get the old stain off. I would use TWP 1500 Series.
Warren, Ohio
Full sun
Some mildew
Used Sherwin Williams waterborne semi transparent which has peeled and suffered a lot in the high traffic areas as well. Within a couple months of applying, there was white stuff coming up through the stain also.
SW Deckscapes is an acrylic semi-transparent water based stain or basically a thin paint. It does not penetrate very well and will be prone to peeling. I would suggest a penetrating oil-based stain such as TWP, Armstrong Clark, Timber Oil, Penofin.
Make sure to remove the Deckscapes prior to application of the new stain. This can be done with stripping, sanding, or combination of both.
Cleveland, Ohio__Full Sun__Pressuer treated pine__Some mold on the bottom boards and spots on the spindals__Uneven to heavy coats of TWS honey gold, some peeling as well
