Thompson’s WaterSeal Waterproofer Plus Clear Wood Protector Review 2.5/5 (273)
Hi, I’m Scott Paul
As a leading exterior restoration contractor and business owner with over 30 years of experience in exterior wood decking, I’ve worked extensively with a variety of products to protect and enhance wood surfaces.
My review of Thompson’s Water Seal is rooted in decades of hands-on testing and my professional experience as a wood restoration contractor. My goal is to provide you with honest insights and guide you toward the best deck stain options to ensure your project’s success.
For more about my background and expertise, feel free to read more about me here.
6.125 Overall Rating Thompsons WaterSeal
Thompson's WaterSeal
Thompson’s WaterSeal Wood Finish is a widely available water-repellent product designed to protect exterior wood from moisture while adding light color. It is commonly sold as an easy-to-use solution for homeowners looking to seal and protect decks, fences, and other outdoor wood surfaces.
From my experience restoring decks since 1993, Thompson’s WaterSeal products are more of a basic sealer than a true deck stain. While they can provide short-term water protection, they typically lack the UV resistance and long-term durability needed for consistent performance on a deck.
Overall, Thompson’s WaterSeal can be used for temporary protection, but it is not one of the better choices for long-lasting deck staining results.
🔹 Thompson’s WaterSeal Wood Finish – Quick Verdict
  • Best For: Short-term water protection and quick projects
  • Not Ideal For: Long-term durability and UV protection
  • Type: Water-based wood sealer with light pigment
  • My Overall Rating: 6.125/10
Thompson’s WaterSeal is easy to use and widely available, but from my experience, it does not hold up well long term and requires frequent reapplication.
If you have any experience with this product, we’d love it if you shared your Thompson’s WaterSeal reviews and photos in the comment area below.
Key Takeaways from Our Thompson’s Water Seal Review
  • No UV protection – The stain grayed within months, failing its primary job of preserving wood.
  • Good water resistance, but short-lived – Initially repels water well, but loses effectiveness by the 2-year mark.
  • Mold and mildew issues – Encourages black mold growth over time, making maintenance a hassle.
  • Easy to apply – Applies smoothly with a sprayer or pad, with no overlap marks.
  • Not recommended – Fails in key areas like UV protection and long-term durability—better alternatives exist.
Thompson’s WaterSeal Clear Waterproofer Ratings & Reviews (Out of 10)
How I Rated Thompson’s WaterSeal
My Thompson’s WaterSeal review contains an 8-step process and the final average score. Each step is on a scale of 1-10.
  1. The appearance of Thompson’s WaterSeal after Application
  2. Preventing UV Graying
  3. Peeling or Wearing
  4. Cost Per Square Foot
  5. Preventing Mold and Mildew
  7. Color Shifting
  8. Ease of Reapplication
  9. Thompson’s WaterSeal Final Score
8-Step Review of Thompson’s WaterSeal Clear Wood Protector
This Thompson’s WaterSeal clear waterproofer did not alter the appearance of the wood. After it was fully dry, we tested its ability to repel water, and water did bead on top of the finish and did not absorb into the wood.
2. Preventing UV Graying at 2-Year Mark: 1
As far as we can tell, Thompson’s WaterSeal product does not prevent UV graying. This is a huge disappointment, as preventing UV graying is the number one reason to stain your exterior wood and decking.
3. Wear/Tear and Peeling: 8
The Thompson’s WaterSeal clear waterproofer penetrates deep into the wood. There was no peeling or wearing. We would have given it a 10 if the product still repelled water, but at the 2-year mark, it did not.
4. Cost per Square Foot: 9
Thompson’s WaterSeal Waterproofer Plus Clear Wood Protector is a very inexpensive product with exceptional coverage. Unfortunately, the saying “you get what you pay for” applies here, as Thompson’s WaterSeal product offers no UV protection.
5. Preventing Mold/Mildew/Algae: 2
After 2 years, the entire deck was covered in black mold. It seems that the oils used in Thompson’s WaterSeal Waterproofer Plus Clear Wood Protector feed and promote the growth of mold spores.
6. Ease of Application: 8
Since this is a clear product, it applies exceptionally easily without the need to backwipe. Just apply it with a pump sprayer or stain pad. This finish does not show overlap marks.
7. Color Shifting (Darkening) After 2 Years: 7
This product darkens in color because there is a good amount of mold growing in the finish.
8. Difficulty of Reapplication: 6
A heavy cleaning would be needed to remove the graying and mold from the surface.
Thompson’s Water Seal Clear Waterproofer Overall Score 6.1
Thompson’s WaterSeal Waterproofer Plus Clear Wood Protector: A Clear Disappointment
The Thompson’s WaterSeal Waterproofer Plus Clear Wood Protector falls short of expectations. While it claims to protect exterior wood, it offers zero UV protection, which is critical for preventing graying and preserving the natural beauty of your deck or other wood surfaces.
My Verdict
Any finish that lacks the ability to prevent UV graying simply cannot be recommended for decks or exterior wood. If you’re looking for a product that truly protects and enhances your wood surfaces, we suggest exploring better alternatives.
Thompson’s WaterSeal Clear Waterproofer Photos and Results
Product Information
  • Cost: $39.99 per gallon
  • Stain Type: Clear water repellent
  • Available Colors: Clear
  • Application Temperature: 45-95 degrees F
  • Coats Required: 1
  • Coverage per Gallon: 200-300 square feet
  • Application Tools: Sprayer, pad, brush, roller
  • Dry Time: 48 hours
  • Cleanup: Mineral spirits
  • VOC Compliance: 250 compliant in all states
  • More Info: Product Data
  • Manufacturer: Thompson’s
About Our Test Deck
  • Deck Wood Type: Teak
  • Deck Square Footage: 400 square feet
  • UV Exposure: Full sun
  • How Many Years Tested: 2 years
  • Stain Color Used: Clear
All products tested, and the results are from our experience. We offer no guarantee of similar results. Consider that results may differ due to different wood types, exposure to UV radiation, and natural weathering.
Thompson’s WaterSeal FAQs: Oil vs. Water-Based and More
Is Thompson’s WaterSeal Any Good?
Our overall experience with Thompson’s WaterSeal Waterproofer Plus Clear Wood Protector was disappointing, and we would not recommend it. Its inability to prevent UV graying is too harmful to your deck’s wood.
What’s Better Than Thompson’s WaterSeal Waterproofer?
Restore-A-Deck Semi-transparent Stain and Armstrong-Clark Transparent Stain are excellent alternatives to Thompson’s WaterSeal Waterproofer Plus Clear Wood Protector.
$51.99
How Long Does Thompson’s WaterSeal Last?
Thompson’s WaterSeal Waterproofer Plus Clear Wood Protector claims to last up to 4 years when applied correctly. In our experience, it held up well but no longer repelled water after 6-12 months.
Is Thompson’s WaterSeal Waterproof?
Thompson’s WaterSeal Waterproofer Plus Clear Wood Protector is made to waterproof exterior wood.
Can You Use Too Much Thompson’s WaterSeal?
Yes: Applying too much Thompson’s WaterSeal clear waterproofer will significantly increase the time it takes to dry, and it may not dry properly.
Does Thompson WaterSeal Protect Wood?
Thompson’s WaterSeal Waterproofer Plus Clear Wood Protector is intended to protect wood, as the name would indicate, but our testing produced dismal results. It does a very poor job of preventing black mold and UV graying, which are very harmful to the wood.
Is Thompson’s WaterSeal Water- or Oil-Based?
Thompson’s WaterSeal Waterproofer Plus Clear Wood Protector is an oil-based product.
How Do You Use Thompson’s WaterSeal Waterproofer Plus Clear Wood Protector?
This product is easy to apply with either a stain pad or a pump sprayer.
Does Thompson’s WaterSeal Contain Silicone?
No, this Thompson’s WaterSeal product does not contain silicone.
Does Thompson’s WaterSeal Come in Different Colors?
This particular product is clear, but they also make Thompson’s WaterSeal Waterproofer products that include Thompson’s stain in different colors.
How Many Coats of Thompson’s WaterSeal Do I Need?
In most cases, you will only require one coat.
Can Thompson’s WaterSeal Be Used on Stained Wood?
No, Thompson’s WaterSeal Waterproofer Plus Clear Wood Protector cannot be applied over stained wood, regardless of whether the stain was oil- or water-based.
Does Thompson’s WaterSeal Darken Wood?
Our review of Thompson’s WaterSeal Waterproofer Plus Clear Wood Protector found that it did darken wood over time due to the large amount of black mold that grew in the finish.
How Long Does Thompson’s WaterSeal Take to Dry?
The Thompson’s WaterSeal dry time is approximately 4-24 hours before it is considered safe to walk on.
At What Temperature Can You Apply Thompson’s WaterSeal?
The application temperature for Thompson’s WaterSeal products is between 45°F and 95°F.
🔹 Thompson’s WaterSeal Wood Finish – Pros and Cons
Pros
  • Easy to apply with minimal effort
  • Widely available and affordable
  • Provides short-term water repellency
  • Good for quick projects or temporary protection
  • Can be used on multiple exterior wood surfaces
Cons
  • Very limited UV protection
  • Short lifespan compared to higher-quality stains
  • Requires frequent reapplication
  • Does not penetrate deeply into the wood
  • Not suitable for long-term deck protection
🔹 Best Wood Types for Thompson’s WaterSeal
  • Decks needing temporary protection
  • Fences or low-traffic wood surfaces
Not Ideal For:
  • Full sun decks – will fade quickly
  • Decks needing long-term durability
  • Hardwoods (IPE, Cumaru, etc.) – not effective
  • Apply thin, even coats
  • Do not over-apply
  • Best used in low to moderate exposure conditions
Maintenance is frequent with products like Thompson’s WaterSeal.
  • Reapply every 6–12 months depending on exposure
  • Clean and brighten before reapplication
  • Monitor for water absorption and fading
  • Expect shorter lifespan compared to true stains
From my experience, these types of sealers require constant upkeep to maintain protection.
🔹 Who Should Use Thompson’s WaterSeal?
You should consider Thompson’s WaterSeal if:
  • You want a quick and inexpensive solution
  • You need short-term water protection
  • Your project is low priority or temporary
  • You are not concerned with long-term durability
  • You want long-lasting protection
  • Your deck is exposed to full sun
  • You prefer a stain with better UV resistance and longevity
🔹 Thompson’s WaterSeal Wood Finish – Final Thoughts
Thompson’s WaterSeal Wood Finish is a basic water-repellent product that provides short-term protection but lacks the durability and UV resistance needed for long-term deck performance.
From my hands-on experience, products like this require frequent reapplication and do not hold up well compared to higher-quality stains that penetrate and protect the wood more effectively.
If you are looking for a quick, temporary solution, Thompson’s WaterSeal can work. For most deck owners, however, investing in a better-quality stain will provide far better long-term results and easier maintenance.
484 Comments
E.C
E.C
24 days ago
Do NOT buy this product. We followed the instructions and it did not last even a full year on my deck. It chipped and peeled off the deck wood even though the deck had little traffic or use. We had to buy another gallon of it and we applied it again. Again, it still did not hold up on my deck. I would not recommend this product to anyone, nor will I ever buy it again. I give it a 1 star and that is being generous. Don’t waste your money on this product.
Marc
Marc
9 months ago
Don’t use this. Applied it per the instructions. The stuff is still sticky going on the 4th day. Do not recommend.
Dorothy DeJager
Dorothy DeJager
Don’t waste your money on this product. We prepared my large deck. Applied the Thompson water seal transparent on the deck in May of last yr. I spent alot of money on this product. Now that it is spring the stain is almost off, now need to rent a sander to get the rest of it off. This product is awful does not even seem to soak into the wood. I am so glad that I didn’t do my front deck with this product.
Jim Skewis
Jim Skewis
Waited 1&1/2 years to treat new deck. Did all prep work applied in August come spring deck is peal and looks terrible . Can not get through on Thompsons phone line or email. Not happy
Kate Russell
Kate Russell
We didn’t like how red (almost pinkish) after applying the Thompson’ seal and stain in cedar to our new fencing. We did not over appy and followed directions. Thought it might tone down after a day, but it’s still hard to look at. So now we need to spend more money to find some other product to redo the whole fence to get a more true cedar look. Really disappointed!!
Can you put polyurethane on top of Thompson water seal clear to keep it from fading or peeling. Second question. Can you put polyurethane on wood fence after cleaning with bleach and water mixed to keep the lighter color. Thank you
Scott, Bob again don’t really see any good reviews for an oil base clear fence stain. If you had any ideas about one that works would help. Curious cleaned fence. Bleach water mix. Can I use just polyurethane on fence instead of stain. Will give me the clear look I am looking for. Thank you.
Sara G
Sara G
I used Thompsons water sealer, and I am very dissappointed. IT comes off, it discolors, now I am hoping it will melt more ontop, of the stain, but I fear I may have to remove it all, and start again… I can’t believe this, its a 400 sq ft deck.
Thanks for answering last question about Thompson water seal clear stain. Basically everyone saying stuff is crap. ? Since it is water based, can I get this off using a 50/50 mix of bleach and water. And start over and re-stain with a oil base clear product .
Using Thompson Clark water seal. Why is it so brown when I put it on fence. Will it lighten up when it dries. Worried I read it will get darker over time
Maxine
Maxine
Can you still buy this product
Denis Clarke
Denis Clarke
don’t confuse Thompson’s water seal with Thompson’s water seal waterproofer plus. the water proofer plus is an excellent product and yes with uv protection. it’s oil based and deeply penetrates into the wood. doesn’t sit on the surface like a stain. there is nothing to peel or wear .I just clean and reapply every two years and deck looks great
Kelly
Kelly
I’m water pooling a shade structure over a koi pond How long does it need to cure so it for it to be safe if it rains so it doesn’t hurt the fish
Will applying Thompson’s clear water seal to rough red cedar affect it’s insect repellant qualities?
Dinah Johnson
Dinah Johnson
I think I used to much it’s been 4 days and it won’t dry what can I do?
Dorothy Rodgers
Dorothy Rodgers
Want to know since Tho
psons is no good for decks whether to use paint or is there any preservative good! It takes a lot of time to do things right and since we have been dealing with CHINA, I lost all my respect! Everything we get is from China and yes all is TRASH!
Ed Schmidt
Ed Schmidt
I have interior wood Latvia’s that look dry! What do you recommend?
Randy Marshall
Randy Marshall
I am doing a small outdoor project using 1/2″ plywood and would like to know the best sealer to use on the surface and sides. The plywood will be exposed year round. The plywood does have some small knots on both sides and some small voids on the edges. I need to do both sides. I guess what I am asking is, what do I do to make my project water proof? Since the rest of the project is natural unstained cedar it would be nice to have the plywood be cedar color or a brown color.
I was going to use Thompson Water Sealer but after reading this article that is not going to happen so i need something different but still economical.
Comments / suggestions would be most welcomed.
Randy Marshall
Calgary, Alberta
Canada
Leon Carroll
Leon Carroll
It used to be one of the best products on the market until the EPA made them change the their formula. It is now fair at the very best. I would not use it or recommend it to anyone.
Doug
Doug
Water Based Nightmare!!
Seems that not too many have good results with this product. I have used it for the last 9 years on my deck and redo every 3 years. The deck does get dirty from the crap from the trees and the dirt in the air. I pressure wash the seams between boards and use bleach to clean the boards before re-applying Thompson’s Clear Sealer. BUT – since everything is now ‘safe for the environment’ I can only get the water based version of this product. I did about 100 sq feet with the oil based stuff I had left over from last sealing and the rest (500sq feet) with the new water based crap. And it is very crappy looking compared to the oil based product.
I guess I will live with this until midsummer and hope that it all fades. Otherwise I will go get a sander and refinish the entire surface. Maybe I can still get the oil based product in the states..
Melissa Hair
Melissa Hair
We were told to wait at least a year before staining our new deck with Thompson’s Water Seal and Stain. We stained last fall. This is what it looks like less than 7 months later. We applied a thin coat of stain to dry deck boards. Not very happy with the results and not real sure how we can fix this horrible mess. Suggestions appreciated.
Debora Baird
Debora Baird
Used this on several items. Looks awful after one year.
Cheryl Houseknecht
Cheryl Houseknecht
Why won’t this dry? I used it on a bench which must dry for people to sit on but now I have to sand it back down so I can use something else on it. Not happy at all with this product!!!!!! I got it at Lowes and I am not sure if it is not any good or not but it looks milky and it should be clear. I will never buy this again.
Rose Ford
Rose Ford
Put the sealer on my deck used cedar and it’s coming off within a year and a half. What went wrong?
Rose Ford
Rose Ford
So what sealer/stain is quality and do I need to sand the deck. I need to know what steps to take to redo my deck. Thank you so much for your input.
Rose ford
Rose ford
Dewey
Dewey
Spent several days cleaning my 300 sq ft deck with pressure washer. Let the deck dry for about a week (no rain). Bought a gallon of Thompson’s clear and sprayed on with a pump sprayer. The Thompson’s gunked up about an hour after it was applied. Hour or two later there was a chalked substance on the surface of the wood. Used a steel brush to remove it. Wood surface has yet to dry completely after 3 days and is so slick, slippery you can hardly walk on it. The wood is now very dark as if it had been a fire. Thompson’s solution is to take sealer back for a refund. Junk.. Anyone know what to do next?
Dewey
Dewey
The surface is so slick that you can’t walk on it. Also, when I go out to cook on the deck, I have to wear booties to prevent tracking up my hardwood and rugs inside.
Dewey
Dewey
Thank you Einstein! Your product is the worst!
Dewey
Dewey
I thought you were Thompson’s.. I truly apologize. Thanks for your suggestion.
Diane Litster
Diane Litster
we applied the product a week ago and it will not dry, very sticky, stepping on it sticks to the shoes and we ended up with the sticky shoe prints through my dinning room floor. We cannot get it off my floor. I’ve since returned the product got my money back. But now i have damage to my floors. I am very very disappointed in it. I will not recommend this product. In order to get my deck back I am going to have to buy paint thinner to remove it they the store manager said. And it will take a lot I imagine. Grrr I am not a happy camper with this product.
Rich W
Rich W
Was very disappointed with “Thompson’s WaterSeal Waterproofer Plus Clear Wood Protector” This was the “Clear” version of the product, with no Tint or Stain.
I have a video of the application but was limited to a snapshot of the video, due to upload size limitations. Even from the attached snapshot, you can see the product turned my wood much darker than the original color. Definitely, NOT CLEAR.
I power washed the wood over a week ago, and following the direction on the can, made sure the wood was dry, the can was well shaken, and it was above 50 degrees. The attached picture was a second attempt, done with a hand roller as shown in the Thompson’s site video applying the product and using a minimal amount of the product. This is 36 hours after I applied the product, and I do not see it lightening up any, to match my original wood color.
As you can “clearly” see (sorry for the pun) the wood is a much darker color than my original wood color. I also did another attempt and used a small sprayer to apply the product and ended up with the same outcome.
If you need to be a professional painter to use this product, they shouldn’t sell it to the layperson.
David Shortliff
David Shortliff
Is 2 coats of Thompson’s WaterSealer/Advanced on a decks bettwr than I coat?
Dan Holmes
Dan Holmes
We had a New 14′ x 12′ deck built in November 2020. We sealed it in March 2021 with Thompson All in One Stain and Sealer Honey Gold. It is now Going into July 2021 and i have black streaks dots and spots all over where the sun hits. Tried to use Valspar Deck cleaner today with no such luck on the black coming off, or the streaks. It now has a white bleach look. I’m lost at what to do next!
Dan Holmes
Dan Holmes
Thank You. I kind of figured that is what i was going to have to do. I have been searching for the best stain, cleaner and brightener to use. No more Being Cheap!
Greg
Greg
Looked good first summer. Winter and snow came and in the spring at least 50% was gone. Two years 90% gone. Very dissatisfied.
Lori Patton
Lori Patton
Can you reapply the clear watersealant a year later with out removing the previous application?
Missie
Missie
Why won’t it work with a sprayer. I tried 2 different sprayers and all the different tips. It seems to be to thick. What do I do to make sprayer work???
Barbara Weisser
Barbara Weisser
Very dissatisfied with Thompsons product. Peeling and white color when wet. I now have to remove what is left on porch before re staining with oil base stain. because Thompsons did not last for two years my porch became weather damaged and the color is uneven. Again, VERY dissatisfied😠
Bill
Bill
Applied water seal last summer, it began peeling and flaking over the winter, now this spring I will have to redo the whole deck. I’ll find another product and hope for better results. I will not recommend this product.
Reply to  Bill
I’m in the same boat. Very disappointing.
David Mccall
David Mccall
Reply to  Bill
I’ve used this product for several years. It looks good after applying but doesn’t last. I apply every spring. Starts flaking in winter and looks horrible by spring. I would change product but I would have to restain the vertical slats to match the planks. I reapply every spring to the horizontal planks and touch up the rest of the deck. It would be best to avoid this product from the start.
Kim Wendel
Kim Wendel
Reply to  Bill
Mine also started flaking about 3 weeks later. I worked so hard on staying my deck and I am very disappointed.
Debbie
Debbie
I used this last year. Completely pressure washed the whole deck and waited a week to be sure it was dried before I applied the stain. Went on good, looked good. Dried quickly. It rained about a week later and noticed it repelled good, but it left water rings. Got thru the winter and half of the stain has peeled up everywhere by spring. I couldn’t believe it. Will not use this product again. Deck paint would have held up better. Very disappointed.
Tish Karpoy
Tish Karpoy
Hi
I want to seal a pew for outdoor use.
Do I need to sand the pew first? It’s an old church pew, already stained.
Brent Larson
Brent Larson
Is this review of the Thompsons water-base or oil-base sealer? I have an oil-based thompsons clear that now I’m worried about using on my new fence.
Cheyenne
Cheyenne
Last spring I sanded my deck to bare wood and fully cleaned and dried it before applying Thompson’s WaterSeal Semi-Transparent. No issues with stickiness, looked great for awhile, but it’s now ten months later and half of it has peeled off. Looks awful, no protection. Guess I get to do it all again, with a different brand this time. 🙁
Ben Terry
Ben Terry
I sealed my deck about 5 days ago with Thompsons clear. I dont see how your sprayers didn’t work. Mine worked fine. It was all dry in about 2 days like the can said. No stickiness what so ever. I think the only thing I can think of is people are way oversmdoing the amount if its not dry after weeks or using. The only concern I have is that little water rings are left behind where the water was sitting after my sprinklers went off. I hope after a rain the whole deck doesn’t look like that. I’ve used this product before with no problem. Did the ingredients change?
Lori
Lori
Reply to  Ben Terry
I stained my new deck 3 years ago with Thompsons water sealer and I loved it. It looked great and no issues with being sticky. One month ago I had to stain my deck so I bought the same brand and color of water sealer. I did all the prep just like the bottle said, and I let the deck dry for 4 days. This time after using Thompson’s water sealer I am very disappointed. The deck is sticky, so sticky my shoes stuck to the stairs and i fell down.
I really injured my leg and back. I don’t let anyone out on my deck. I need to hire someone to remove Thompson’s water sealer and apply a different brand. After calling the company they said we can refund your money as long as you have your bill. I got my money back but now I have a bigger problem and it’s going to cost me a lot because I am unable to do the work after injuring myself. STAY FAR AWAY FROM THIS PRODUCT.
I WILL NEVER EVER BUY THIS PRODUCT AGAIN…
Ray
Ray
Can you paint over it
Carlie Strutt
Carlie Strutt
2 WEEKS AND STILL NOT DRY! We had our porch redone by a company and they used this product. We were told to not walk on the porch and use our back door for 2 days. We’re now going on week 2 of this issue. The porch remains sticky. What a nightmare.
Ty A
Ty A
Can u apply it 2 days after applying Cabot stain on your deck?
Gary
Gary
Sikkens offers clear coat for over their stains[cetol maintenence]
Does Thompson waterproof honey stain peel?
Mary
Mary
How long does it take to dry? Its been 24 hours and is still wet and oily.
Reply to  Mary
Try wiping the excess off Mary, the wood will only absorb so much and the rest will just sit there.
Wendy
Wendy
Product is crap don’t waste your time or money! Wish I had of read the reviews first!!
Wendy
Wendy
I am only giving them a one star review because I can’t post with a no star ! we have always used their water sealer and when I reached out to customer service for a problem no one returned my emails even though it says they will get back to you in one business day!!! And I couldn’t get through on the phone so a product is only good if a company stands behind it very disappointed . Will not buy it again.
Sandi
Sandi
Looks lovely when dry but don’t use this product unless you want to be mopping puddles up off your deck every day. Water just sits on the deck now and creates a slipping hazard
Alvin Wilkins
Alvin Wilkins
I put Thompson water sealer on my deck 10’x42′ it repelled water for the first year and everytime it rained you could see the oil coming to the surface and it cupped up almost all of the 5/4 deck boards and most of them began to squeak had 3 screws in each joist , had to screw 2 more screws in to stop squeaks graying and molding after 1st year this stuff is crap will never use again
THow
THow
Does Thompson’s water seal and the others need UV light in order to cure properly?
Kathleen Weidman
Kathleen Weidman
This product ran down wooden columns colllecting on concrete patio floor. Right now it is still not completely dry. What is the best way to get it off the concrete?
Diana Lovitt
Diana Lovitt
Daughter and son on law in NOLA, used a Thompsons water sealant in April, in July their deck is still super sticky.
Grace
Grace
Sealed my whole deck , low and behold we had a thunderstorm and it rained 3 hours later .. will I have to reapply?
Grace
Grace
I sealed my deck , but as my misfortune we had a thunderstorm and it rained .. it only had 3 hours drying time . Will I have to reapply ?
Brian
Brian
Last summer I applied Thompson waterseal in the cedar tone to a cedar deck. This spring it has mostly flaked off or is flaking. Would not recommend this product
Jody
Jody
Will this particular product leave a sticky residue
Angie
Angie
Reply to  Jody
No it doesn’t. Just make sure it’s clean and dry and use a staining pad to apply evenly. I’ve only used Thompson’s water seal and my fence looks as good now as it did 16 yrs ago. I touch up a section every year for my own personal preference. Dries quickly.
My deck, same.
Wendy
Wendy
Reply to  Angie
So glad you had good luck with it. Maybe it’s OK on a fence but definitely not on a deck even though we had no rain it didn’t dry and now when you walk in onto the hardwood floors it leaves foot prints !!So frustrating as I have tried to contact a company multiple times and nobody returned your emails
Rodger
Rodger
Reply to  Wendy
This is what’s happening to us. It’s dry because water beads up on the deck, but when we walk on the deck some kind of residue is on our shoes/socks/feet and it gets on our hardwood. We may nave to have deck shoes only allowed for the deck…
Wendy
Wendy
Reply to  Rodger
Ugh so much work for nothing 😣 even my dogs leave foot prints! I am going to try dawn dish soap as a degreaser fingers crossed
Reply to  Jody
I have used this product many times and it has never left a sticky residue.
484
