Thompson’s WaterSeal Waterproofer Plus Clear Wood Protector Review 2.5/5 (272)
Hi, I’m Scott Paul
As a leading exterior restoration contractor and business owner with over 30 years of experience in exterior wood decking, I’ve worked extensively with a variety of products to protect and enhance wood surfaces.
My review of Thompson’s Water Seal is rooted in decades of hands-on testing and my professional experience as a wood restoration contractor. My goal is to provide you with honest insights and guide you toward the best deck stain options to ensure your project’s success.
For more about my background and expertise, feel free to read more about me here.
6.125 Overall Rating Thompsons WaterSeal
Thompson's WaterSeal
Thompson’s WaterSeal Wood Finish is a widely available water-repellent product designed to protect exterior wood from moisture while adding light color. It is commonly sold as an easy-to-use solution for homeowners looking to seal and protect decks, fences, and other outdoor wood surfaces.
From my experience restoring decks since 1993, Thompson’s WaterSeal products are more of a basic sealer than a true deck stain. While they can provide short-term water protection, they typically lack the UV resistance and long-term durability needed for consistent performance on a deck.
Overall, Thompson’s WaterSeal can be used for temporary protection, but it is not one of the better choices for long-lasting deck staining results.
🔹 Thompson’s WaterSeal Wood Finish – Quick Verdict
  • Best For: Short-term water protection and quick projects
  • Not Ideal For: Long-term durability and UV protection
  • Type: Water-based wood sealer with light pigment
  • My Overall Rating: 6.125/10
Thompson’s WaterSeal is easy to use and widely available, but from my experience, it does not hold up well long term and requires frequent reapplication.
If you have any experience with this product, we’d love it if you shared your Thompson’s WaterSeal reviews and photos in the comment area below.
Key Takeaways from Our Thompson’s Water Seal Review
  • No UV protection – The stain grayed within months, failing its primary job of preserving wood.
  • Good water resistance, but short-lived – Initially repels water well, but loses effectiveness by the 2-year mark.
  • Mold and mildew issues – Encourages black mold growth over time, making maintenance a hassle.
  • Easy to apply – Applies smoothly with a sprayer or pad, with no overlap marks.
  • Not recommended – Fails in key areas like UV protection and long-term durability—better alternatives exist.
Thompson’s WaterSeal Clear Waterproofer Ratings & Reviews (Out of 10)
How I Rated Thompson’s WaterSeal
My Thompson’s WaterSeal review contains an 8-step process and the final average score. Each step is on a scale of 1-10.
  1. The appearance of Thompson’s WaterSeal after Application
  2. Preventing UV Graying
  3. Peeling or Wearing
  4. Cost Per Square Foot
  5. Preventing Mold and Mildew
  7. Color Shifting
  8. Ease of Reapplication
  9. Thompson’s WaterSeal Final Score
8-Step Review of Thompson’s WaterSeal Clear Wood Protector
This Thompson’s WaterSeal clear waterproofer did not alter the appearance of the wood. After it was fully dry, we tested its ability to repel water, and water did bead on top of the finish and did not absorb into the wood.
2. Preventing UV Graying at 2-Year Mark: 1
As far as we can tell, Thompson’s WaterSeal product does not prevent UV graying. This is a huge disappointment, as preventing UV graying is the number one reason to stain your exterior wood and decking.
3. Wear/Tear and Peeling: 8
The Thompson’s WaterSeal clear waterproofer penetrates deep into the wood. There was no peeling or wearing. We would have given it a 10 if the product still repelled water, but at the 2-year mark, it did not.
4. Cost per Square Foot: 9
Thompson’s WaterSeal Waterproofer Plus Clear Wood Protector is a very inexpensive product with exceptional coverage. Unfortunately, the saying “you get what you pay for” applies here, as Thompson’s WaterSeal product offers no UV protection.
5. Preventing Mold/Mildew/Algae: 2
After 2 years, the entire deck was covered in black mold. It seems that the oils used in Thompson’s WaterSeal Waterproofer Plus Clear Wood Protector feed and promote the growth of mold spores.
6. Ease of Application: 8
Since this is a clear product, it applies exceptionally easily without the need to backwipe. Just apply it with a pump sprayer or stain pad. This finish does not show overlap marks.
7. Color Shifting (Darkening) After 2 Years: 7
This product darkens in color because there is a good amount of mold growing in the finish.
8. Difficulty of Reapplication: 6
A heavy cleaning would be needed to remove the graying and mold from the surface.
Thompson’s Water Seal Clear Waterproofer Overall Score 6.1
Thompson’s WaterSeal Waterproofer Plus Clear Wood Protector: A Clear Disappointment
The Thompson’s WaterSeal Waterproofer Plus Clear Wood Protector falls short of expectations. While it claims to protect exterior wood, it offers zero UV protection, which is critical for preventing graying and preserving the natural beauty of your deck or other wood surfaces.
My Verdict
Any finish that lacks the ability to prevent UV graying simply cannot be recommended for decks or exterior wood. If you’re looking for a product that truly protects and enhances your wood surfaces, we suggest exploring better alternatives.
Thompson’s WaterSeal Clear Waterproofer Photos and Results
Product Information
  • Cost: $39.99 per gallon
  • Stain Type: Clear water repellent
  • Available Colors: Clear
  • Application Temperature: 45-95 degrees F
  • Coats Required: 1
  • Coverage per Gallon: 200-300 square feet
  • Application Tools: Sprayer, pad, brush, roller
  • Dry Time: 48 hours
  • Cleanup: Mineral spirits
  • VOC Compliance: 250 compliant in all states
  • More Info: Product Data
  • Manufacturer: Thompson’s
About Our Test Deck
  • Deck Wood Type: Teak
  • Deck Square Footage: 400 square feet
  • UV Exposure: Full sun
  • How Many Years Tested: 2 years
  • Stain Color Used: Clear
All products tested, and the results are from our experience. We offer no guarantee of similar results. Consider that results may differ due to different wood types, exposure to UV radiation, and natural weathering.
Thompson’s WaterSeal FAQs: Oil vs. Water-Based and More
Is Thompson’s WaterSeal Any Good?
Our overall experience with Thompson’s WaterSeal Waterproofer Plus Clear Wood Protector was disappointing, and we would not recommend it. Its inability to prevent UV graying is too harmful to your deck’s wood.
What’s Better Than Thompson’s WaterSeal Waterproofer?
Restore-A-Deck Semi-transparent Stain and Armstrong-Clark Transparent Stain are excellent alternatives to Thompson’s WaterSeal Waterproofer Plus Clear Wood Protector.
$51.99
How Long Does Thompson’s WaterSeal Last?
Thompson’s WaterSeal Waterproofer Plus Clear Wood Protector claims to last up to 4 years when applied correctly. In our experience, it held up well but no longer repelled water after 6-12 months.
Is Thompson’s WaterSeal Waterproof?
Thompson’s WaterSeal Waterproofer Plus Clear Wood Protector is made to waterproof exterior wood.
Can You Use Too Much Thompson’s WaterSeal?
Yes: Applying too much Thompson’s WaterSeal clear waterproofer will significantly increase the time it takes to dry, and it may not dry properly.
Does Thompson WaterSeal Protect Wood?
Thompson’s WaterSeal Waterproofer Plus Clear Wood Protector is intended to protect wood, as the name would indicate, but our testing produced dismal results. It does a very poor job of preventing black mold and UV graying, which are very harmful to the wood.
Is Thompson’s WaterSeal Water- or Oil-Based?
Thompson’s WaterSeal Waterproofer Plus Clear Wood Protector is an oil-based product.
How Do You Use Thompson’s WaterSeal Waterproofer Plus Clear Wood Protector?
This product is easy to apply with either a stain pad or a pump sprayer.
Does Thompson’s WaterSeal Contain Silicone?
No, this Thompson’s WaterSeal product does not contain silicone.
Does Thompson’s WaterSeal Come in Different Colors?
This particular product is clear, but they also make Thompson’s WaterSeal Waterproofer products that include Thompson’s stain in different colors.
How Many Coats of Thompson’s WaterSeal Do I Need?
In most cases, you will only require one coat.
Can Thompson’s WaterSeal Be Used on Stained Wood?
No, Thompson’s WaterSeal Waterproofer Plus Clear Wood Protector cannot be applied over stained wood, regardless of whether the stain was oil- or water-based.
Does Thompson’s WaterSeal Darken Wood?
Our review of Thompson’s WaterSeal Waterproofer Plus Clear Wood Protector found that it did darken wood over time due to the large amount of black mold that grew in the finish.
How Long Does Thompson’s WaterSeal Take to Dry?
The Thompson’s WaterSeal dry time is approximately 4-24 hours before it is considered safe to walk on.
At What Temperature Can You Apply Thompson’s WaterSeal?
The application temperature for Thompson’s WaterSeal products is between 45°F and 95°F.
🔹 Thompson’s WaterSeal Wood Finish – Pros and Cons
Pros
  • Easy to apply with minimal effort
  • Widely available and affordable
  • Provides short-term water repellency
  • Good for quick projects or temporary protection
  • Can be used on multiple exterior wood surfaces
Cons
  • Very limited UV protection
  • Short lifespan compared to higher-quality stains
  • Requires frequent reapplication
  • Does not penetrate deeply into the wood
  • Not suitable for long-term deck protection
🔹 Best Wood Types for Thompson’s WaterSeal
  • Decks needing temporary protection
  • Fences or low-traffic wood surfaces
Not Ideal For:
  • Full sun decks – will fade quickly
  • Decks needing long-term durability
  • Hardwoods (IPE, Cumaru, etc.) – not effective
  • Apply thin, even coats
  • Do not over-apply
  • Best used in low to moderate exposure conditions
Maintenance is frequent with products like Thompson’s WaterSeal.
  • Reapply every 6–12 months depending on exposure
  • Clean and brighten before reapplication
  • Monitor for water absorption and fading
  • Expect shorter lifespan compared to true stains
From my experience, these types of sealers require constant upkeep to maintain protection.
🔹 Who Should Use Thompson’s WaterSeal?
You should consider Thompson’s WaterSeal if:
  • You want a quick and inexpensive solution
  • You need short-term water protection
  • Your project is low priority or temporary
  • You are not concerned with long-term durability
  • You want long-lasting protection
  • Your deck is exposed to full sun
  • You prefer a stain with better UV resistance and longevity
🔹 Thompson’s WaterSeal Wood Finish – Final Thoughts
Thompson’s WaterSeal Wood Finish is a basic water-repellent product that provides short-term protection but lacks the durability and UV resistance needed for long-term deck performance.
From my hands-on experience, products like this require frequent reapplication and do not hold up well compared to higher-quality stains that penetrate and protect the wood more effectively.
If you are looking for a quick, temporary solution, Thompson’s WaterSeal can work. For most deck owners, however, investing in a better-quality stain will provide far better long-term results and easier maintenance.
481 Comments
Marc
Marc
7 months ago
Don’t use this. Applied it per the instructions. The stuff is still sticky going on the 4th day. Do not recommend.
Dorothy DeJager
Dorothy DeJager
Don’t waste your money on this product. We prepared my large deck. Applied the Thompson water seal transparent on the deck in May of last yr. I spent alot of money on this product. Now that it is spring the stain is almost off, now need to rent a sander to get the rest of it off. This product is awful does not even seem to soak into the wood. I am so glad that I didn’t do my front deck with this product.
Jim Skewis
Jim Skewis
Waited 1&1/2 years to treat new deck. Did all prep work applied in August come spring deck is peal and looks terrible . Can not get through on Thompsons phone line or email. Not happy
Kate Russell
Kate Russell
We didn’t like how red (almost pinkish) after applying the Thompson’ seal and stain in cedar to our new fencing. We did not over appy and followed directions. Thought it might tone down after a day, but it’s still hard to look at. So now we need to spend more money to find some other product to redo the whole fence to get a more true cedar look. Really disappointed!!
Craig Battuello
Craig Battuello
6 months ago
If you apply Thompson’s clear water seal will applying a new coat every year within the year of coating each time / each year,maintenance natural color of wood, and serve as a water proofer ? I have just applied the Thompson’s to a 7 Layer plywood outdoor work table.top.
Or can I recoat over the top with mineral oil now that the Thompson’s dried.
It has been raining and the water is beading up uniformly on the table top now.
After it drys out again, re coating with mineral oil oil a good solution?
Last week I put on two coats of Thompson’s to the new plywood, allowing it to dry three days between coats.
Scott thanks for your help, I am working with an older cedar fence, that I cleaned with bleach and water mix. Used a natural ready seal stain on it and everything I am trying is coming out a darker brown then I want. Trying to get to a color close as I can get to new install. Used Thompson wether seal, everyone right garbage. Going to take a board off that I cleaned to store and put different sample stains on it maybe I’ll get lucky. Thanks again.
1 4 5 6
481
