TWP 100 Pro Series Wood & Deck Stain Review 2026 4.7/5 (93)
Hi, I’m Scott Paul, an exterior restoration contractor and business owner with over 30 years of experience in exterior wood decking. My review of the TWP 100 Series Wood and Deck Stain is based on my background as a wood restoration contractor and hands-on field testing. See my full credentials and testing stats here.
TWP 100 Pro Series is one of the best-known penetrating oil-based deck stains on the market and has been an industry staple for many years. From my experience restoring decks since 1993, this product performs best on older or weathered wood where deep penetration is key. It does not form a film on the surface like many newer stains, which makes it much easier to maintain over time. The tradeoff is that UV resistance and color retention are slightly lower than some newer hybrid or semi-solid stains. Overall, TWP 100 is a very good choice if you want an easy-to-maintain, penetrating oil stain for an older deck.
I always appreciate hearing from you, so feel free to leave a comment below and share pictures of your completed projects.
Quick Verdict - TWP 100 Series
  • TWP 100 Pro Series is a penetrating oil-based semi-transparent stain best suited for older, weathered wood, earning an overall rating of 8.63 out of 10.
  • The stain does not form a surface film, so it will not peel or flake, making reapplication easier than most film-forming stains.
  • On a 700 square foot pressure-treated pine deck in full sun, TWP 120 Pecan retained about 80% of its color after 2 years of testing.
  • TWP 100 is not recommended for new wood or hardwoods like Ipe or Cumaru, which are too dense for proper penetration.
  • Deck floors typically need recoating every 18 to 24 months, requiring only a cleaner and brightener, with no stripping or sanding needed.
TWP 100 Series Review
My Take: TWP 100 has always been one of my go-to stains for older decks. It penetrates extremely well and is very forgiving when it comes time to recoat, but it will fade faster than some newer formulas in full sun. TWP 100 consistently ranks among the best deck stain options, and you can see how it compares to other top products in my full guide.
TWP 100 Series Description
TWP 100 “Total Wood Preservative” Deck Stain is a contractor-grade formula designed to protect and maintain all exterior wood surfaces.
The TWP 100 Series penetrates deeply into the wood without building up a surface film, which lets the natural wood grain show through with clarity and warmth. It is formulated to defend against the four major causes of wood degradation: wood rot, water, sunlight, and mildew.
How I Rated TWP 100 Series
My TWP 100 Series review uses an 8-step process. Each step is scored on a scale of 1 to 10, and the final score is the average.
  1. Appearance After Application
  2. Preventing UV Graying
  3. Peeling or Wearing
  4. Cost Per Square Foot
  5. Preventing Mold and Mildew
  6. Ease of Application
  7. Color Shifting
  8. Ease of Reapplication
I prepped the deck with the Gemini Restore Kit and applied TWP 120 Pecan after a few days of drying. This deck was originally stained with TWP 101 Cedartone, and the customer wanted Pecan this time for its slightly browner tone. The overall appearance was excellent.
2. Preventing UV Graying at the 2 Year Mark: 8
The TWP 120 Pecan retained about 80% of its original color after 2 years of full exposure to the elements, the same result as the first time I tested it.
3. Wear/Tear and Peeling: 9
Very minor to no wear. TWP penetrates well into the wood grain, so this was expected.
4. Cost Per Square Foot: 8
A 5-gallon pail of TWP 100 Pro Series costs about $220. We used 6 to 7 gallons on the 700 square foot deck, for a total stain cost of about $300, or roughly $0.43 per square foot.
No mold or mildew. There was some green algae along the edge of the deck near the house.
6. Ease of Application: 9
I used TWP’s recommended “wet on wet” method. We lightly pump sprayed the first coat on the floor, then applied the second coat with a pad applicator for an even appearance. The railings were stained with a pad and brush. A team of two completed the 700 square foot deck in a few hours.
7. Color Shifting (Darkening) After 2 Years: 9
8. Ease of Reapplication: 9
Reapplication will be easy. One Gemini Restore-A-Deck Kit will be enough to clean and brighten the deck before recoating. No stain stripper will be needed, since the TWP has faded lightly and evenly over the last two years.
My Overall Score for TWP 100 Series at 2 Years: 8.63
TWP is one of our most commonly used stains. We have applied the TWP 100 Series to thousands of decks and rarely encounter issues. It is easy to apply and just as easy to reapply when the time comes. While a few other stains come close, TWP remains one of the best options in our experience.
Note: We do not use TWP 100 on brand new wood. On wood less than 4 months old, it can struggle to penetrate, which is something we have seen with many stains on new wood. The manufacturer recommends waiting 4 to 12 months to let the wood weather. We strongly advise waiting, and applying only one coat on wood that is 4 to 12 months old.
5.00out of 5
5.00out of 5
5.00out of 5
5.00out of 5
TWP 100 Series Product Information
Buy TWP 100 Series Deck Stain
  • TWP Help: TWP Stain Help
  • More Info: TWP 100 Series
  • Cost: About $45 per gallon, $220 per 5-gallon pail
  • Stain Type: Oil-based semi-transparent
  • Available Colors: 100 Clear, 101 Cedartone, 102 Redwood, 105 Cape Cod Gray, 106 Prairie Gray, 115 Honeytone, 116 Rustic, 120 Pecan
  • Application Temperature: 45 to 95 F
  • Coats Required: 2 coats applied “wet on wet.” Only 1 coat on new, smooth wood.
  • Coverage Per Gallon: 150 to 250 sq. ft.
  • Application Tools: Sprayer, pad, brush
  • Dry Time: 2 to 12 hours
  • Cleanup: Mineral spirits or paint thinner
  • VOC Compliance: 550 VOC compliant, available in 36 states
  • Product Data Sheet: TWP 100 Product Data
TWP 100 Series Test Deck Stats
  • Deck Wood Type: Pressure-treated pine
  • Deck Square Footage: 700
  • UV Exposure: Full sun
  • Years Tested: 2
  • Stain Color Used: TWP 120 Pecan
Pros and Cons of TWP 100 Pro Series
Pros
  • Excellent penetration into older, weathered wood
  • Does not peel or flake because it does not form a surface film
  • Very easy to reapply with minimal prep
  • Enhances the natural wood grain without a heavy surface coating
  • Proven track record over many years of real-world use
Cons
  • Color fades faster in full sun exposure
  • Not ideal for hardwoods like Ipe or other exotic woods
  • Not ideal for brand new wood
  • Limited availability in some states due to VOC restrictions
Best Wood Types for TWP 100
  • Cedar: Excellent penetration that enhances the natural grain
  • Pressure-Treated Pine: Works very well after proper weathering (4 to 12 months for new lumber)
  • Redwood: Good absorption and a natural look
Not Recommended For:
  • Hardwoods (Ipe, Cumaru, etc.): Too dense for TWP 100 to penetrate properly
See my guide to staining a new deck for more on new wood.
TWP 100 Application Tips
  • Apply only to clean, properly prepped wood
  • Apply thin, even coats and do not over-apply
  • Apply the second coat “wet on wet,” before the first coat dries
  • Back-brush if needed for uniform coverage
  • Wipe up any stain that has not absorbed after 20 to 30 minutes
  • Avoid staining in direct midday sun or on hot boards
See how to prep a deck for step-by-step instructions.
TWP 100 Maintenance and Recoat Tips
  • Recoat deck floors every 18 to 24 months, depending on sun exposure
  • No sanding or stripping is typically needed
  • Use a deck cleaner and brightener before reapplying
  • Apply a light maintenance coat before the stain fully wears off
From my experience, staying ahead of maintenance with TWP 100 keeps your deck looking consistent and avoids major prep work later. See my guide to deck cleaning and brightening.
TWP 100 Series Stain Photos: Real World Testing
Below are examples of TWP 100 Series applied to different wood types and how it performs over time. These are from actual field applications and testing. As with any stain, results vary depending on prep, wood condition, and exposure.
Who Should Use TWP 100?
  • Your deck is older or has weathered wood
  • You want a stain that is easy to maintain long-term
  • You prefer a penetrating oil over a surface film
  • You do not want to deal with peeling or stripping in the future
Compare TWP 100 to other top options in my best deck stains guide.
TWP 100 Pro Series FAQs
How long does TWP 100 last?
TWP 100 typically lasts 18 to 24 months on deck floors, depending on sun exposure and weather. Vertical surfaces such as railings and siding usually last longer because they get less direct sun and no foot traffic.
Does TWP 100 peel or flake?
No. TWP 100 penetrates into the wood and does not form a surface film, so peeling is not an issue when it is applied correctly. If it is over-applied and left sitting on the surface, it can get sticky or shiny, so always wipe up excess that has not absorbed.
TWP 100 is an oil-based penetrating semi-transparent stain. Clean tools with mineral spirits or paint thinner.
It is not ideal for new wood. TWP recommends letting new wood weather for 4 to 12 months so it can absorb the stain. On wood that is 4 to 12 months old, apply only one coat, and always clean and brighten first.
TWP 100 holds up well in full sun and will not peel, but the color fades faster than newer semi-solid formulas. On my full sun test deck, it kept about 80% of its color after 2 years. If your deck gets intense sun all day, plan on recoating closer to the 18 month mark or consider TWP’s semi-solid colors for longer color retention.
How many coats of TWP 100 do I need?
Apply 2 coats “wet on wet” on most weathered wood, meaning the second coat goes on before the first coat dries. On new, smooth wood that is 4 to 12 months old, apply only 1 coat, since the wood cannot absorb a second coat.
How much TWP 100 do I need for my deck?
TWP 100 covers 150 to 250 square feet per gallon, depending on how porous the wood is. Older, weathered wood absorbs more stain. On my 700 square foot test deck, we used 6 to 7 gallons for two coats.
How long does TWP 100 take to dry?
TWP 100 dries in 2 to 12 hours depending on temperature, humidity, and how much the wood absorbs. Apply it when temperatures are between 45 and 95 F and no rain is expected for at least 24 hours.
How do I prep my deck for TWP 100?
Clean the wood with a deck cleaner, then apply a wood brightener to neutralize the cleaner and open the wood pores. I use the Gemini Restore-A-Deck Kit. If the deck has an old film-forming stain or a different brand of stain, strip it first. Let the wood dry for a few days before staining.
Do I need to strip TWP 100 before recoating?
No. Because TWP 100 fades evenly and does not peel, you can usually recoat after a simple cleaning and brightening. No stripper or sanding is needed if you stay on a regular maintenance schedule.
Can I apply TWP 100 over another brand of stain?
I do not recommend it. Different stain formulas may not bond or absorb properly over each other. Strip the old stain with a deck stain stripper, brighten the wood, and then apply TWP 100 to bare wood.
Can I use TWP 100 on Ipe or other hardwoods?
No. Ipe, Cumaru, and other exotic hardwoods are too dense for TWP 100 to penetrate properly. Use a stain made specifically for hardwood decks instead.
What colors does TWP 100 come in?
TWP 100 is available in 100 Clear, 101 Cedartone, 102 Redwood, 105 Cape Cod Gray, 106 Prairie Gray, 115 Honeytone, 116 Rustic, and 120 Pecan. The clear has minimal UV protection, so a tinted color will last longer.
Final Thoughts on TWP 100
TWP 100 has been around for a long time and remains a solid choice for many deck owners. While there are newer products with improved UV resistance, such as TWP’s semi-solid colors, this stain still stands out for its penetration and ease of maintenance.
*All products tested and results are from our experience. We offer no guarantee of similar results. Results may differ due to wood type, UV exposure, and natural weathering.
My TWP 100 Pro Series Review Video
1.3K Comments
Jeff Devore
Jeff Devore
TWP 100 series stain
Pressure Treated Southern Yellow Pine
Used Gemini 2 part cleaner
Andrew
Andrew
Nemo
Nemo
Reply to  Andrew
Michael Bongiovanni
Michael Bongiovanni
Reply to  Andrew
Gary
Gary
Reply to  Andrew
Carrie kosenko
Carrie kosenko
Donald H. MacMullen
Donald H. MacMullen
Donald H. MacMullen
Donald H. MacMullen
Chris Charleston
Chris Charleston
donald h. MacMullen
donald h. MacMullen
TWP-101 Cedartone
Colleen Preston
Colleen Preston
1 month ago
I need to redo my deck and I can’t figure out whether it is worth paying the extra price for the Semi-solid Pro Series rather than the 100 series. I am a 70-year old woman and going to do the work myself. My deck and walkway are around 616 sq feet. I also need advice on the best color. I’d like to stay as close to the natural color as possible so the areas I’m not staining don’t stand out too much. I also need help on the color. I rolled on a semi-solid stain several years ago, and this is what the deck looks like now. I don’t care if the coverage/color is uniform – I really just need to protect the wood as well as possible.
Deck-10-26
Catherine Van Hoesen
2 months ago
I just hd a new redwood fence installed 7 weeks ago. I wish to match a dark brown trex deck, but still show wood grain a bit. I really want a darkish brown tone. What product should I buy?
2 months ago
It has lightly rained in the 6 weeks the wood was supposed to to dry out. How long should I wait before applying the TWP?
Stephen Andrews
Stephen Andrews
4 months ago
best stain for high UV exposure?
do you recommend sealing the ends of fresh cut KDAT deck boards, if so with what?
The Schulers
The Schulers
4 months ago
Is TWP 100 the best oil stain for 40 year old redwood deck that has recently been sanded? Plus, do you have a color in mind that won’t look too orange or too yellow? We are looking to keep it light and natural looking. Our farmhouse is tannish in color.
Thanks from northern Montana!
John T. Lowe
John T. Lowe
5 months ago
What’s your go to for staining a new deck with 5/4 deck boards?
Daniel R
Daniel R
5 months ago
i used several behr products on my deck, they have all peeled or worn. What can i do and use to fix it?
Jamie
Jamie
6 months ago
Recently stripped my PT deck
Previous stain was messmers UV plus. Impossible to get all stain out especially around knots. Is TWP semi a good choice for a new stain in this instance ?
Michael Tharp
Michael Tharp
I live in California. Probably not available right?
Annette Brown
Annette Brown
I bought the TWP 100 pro series in rustic and I am not liking it I thought it would be more brown is there anyway I can add too it to make it more brown?
MEGAN
MEGAN
We have a 5 week old deck (16×6 ft)in a wooded location with multiple black walnuts trees adjacent to the deck. The area is moist, cool and is mostly shaded by the black walnut trees. Our deck installer recommended treating the wood right away, not to wait 4-12 months. I am concerned that falling black walnuts will stain the deck, making it difficult to get an even stain coverage with semi-transparent stain next spring. What would you recommend? Thanks for your help.
Barbara Harcrow
Barbara Harcrow
I was thinking of buying the TWP 100 oil wood stain in clear for my teak deck, but it says that the clear does not have UV protection. I would like to keep the natural color of the teak. Do you recommend a different brand or a color that would not darken it? Also does the Gemini Restore A Deck Kit remove the old Penofin oil any better than the Restore-a-Deck. The RAD works better than others I have tried, but I am still having to scrub to remove the old oil. I have not used the stripper yet. That may be the route I have to go. I have about 1500 sq ft of decking and it is a big job. Thank you for any info.
Laura
Laura
I live in Central Oregon at 3000’ and have a new cedar fence completed in December 2024 that needs an oil based stain. I’ve heard Rodda performs well in the Pacific Northwest high desert.
We have used Sikkens (now ProLuxe) on our deck and been happy with it.
Would TWP do better?
thanks for your help
Laura
DANIEL
DANIEL
Hello!
What can I do to fill up cracks in my 25 year old pressure treated deck?
I used a coat of Cedar tone TWP-100 about four years ago (which is now faded) and want to improve this deck.
I may want to go over it all with a darker solid stain, too.
Is there some type of filler you would recommend?
Remy
Remy
Best stain I have ever used!
Xavier
Xavier
Last year, I stained my deck after cleaning it (using a solution of oxiclean) and power washing and light sanding. Then I applied 2 coats of TWP1500
It went well and I was satisfied with the final results
I would like to apply a coat as a “refresher” this spring, but without power washing though
How should I gently clean it before applying this 1 refresher coat?
Scott Paul…thank you for all your tips and responses! I am building a new outdoor fence in Southwest Louisiana out of Spanish Cedar…I was going to use Australian Timber Oil until I read your reviews about it…ie, they changed the formula years ago… what would you recommend for an outdoor spanish cedar fence in a humid climate?…I’m guessing TWP… ?? Your tips generally refer to stains…but I want a clear coating… what TWP product would you recommend with a clear natural finish? …thanks in advance – JP
Scott…thank you kindly for your reply and info! I will use TWP 101 Cedartone stain. As for as weathering, I have a question…the Spanish Cedar I’ll be using is being cut today at the mill…it is close to my house. The raw boards will be cut to a smooth surface but they will be technically “New Rough Sawn Wood” without the rough surface…do I need to still ‘weather the wood’ for 3 months because its a smooth surface or is it OK to stain immediately because its fresh cut, literally today? 4/10/25 SW Louisiana is humid and gets a lot of rain. I had planned on staining my side of the fence and painting the other side on my neighbors side…I saw in another post, you mentioned not to stain/seal both sides due to trapping moisture…can I stain the top and front of each horizontal board…paint the back side…but leave the bottom of each board raw unstained/sealed. These will be horizontal fence boards… thank you so much for your reply!!! – JP
Ok, thanks again Scott!
Phillip
Phillip
**Had to repost to include pics.
Hi Scott, need a little guidance if you don’t mind. I started to stain this red cedar fence about a year ago. The darker side has 5 coats of TWP 100, the lighter side has 1 coat. Both sides seem to have weathered over time. I could not get the stain to look even, hence the different coloration. I need to get this looking in uniform and fresh. What steps do you suggest?
1
2
3
4
Phillip
Phillip
Thanks for your response Scott. I will get to work on it! Just wanted to add the Stain on the fence is the TWP 101 Cedartone not the clear. Would you suggest going back with the same?
Phillip
Phillip
Phillip
Phillip
What steps should I take?
IMG_4320
IMG_4323
IMG_4322
IMG_4321
Melanie
Melanie
Would you use this product to protect outdoor wood furniture? And if not, what would you recommend? Thanks
Tom Tierney
Tom Tierney
What is the best stain for a new deck?
Susan Savely
Susan Savely
Hello from ALASKA…looking to re-due our decks for the 4th time in 20 years. They have slightly molded due to the wet weather and long months of deep snow. We rinsed and brushed as much of the dark mold off with a mixture of DAWN liquid detergent and powder Borax, and it really cleaned most of it very well! If I use a hand scrub brush it even turned out better, but it is a lot of work for my back and arms. ( this was all before I read your posts about deck cleaners)
In 2020 we used Superdeck, SEMI TRANSPARENT STAIN, Oil Based with Moderate Hide, colored Weathered Gray. {its a light gray blue}
We would like to go more of a two tone wood look, a bit medium driftwood adding some darker Gibraltar Gray highlights to match the trim on our home and shops. We don’t mind if some of the old color shows through, we’d love several tones if possible.
We have replaced all the wood that was starting to get punky with new boards..
Please what would you suggest? We do have a power washer also.
I have attached 2 pics, one of not so clean, one of a very clean small area.
Thank you very much..
Susan Savely
Susan Savely
THANKS!! Please what brand of Stain would you use? and, if we use a solid stain, can we brush it on, to leave some of the original color to get a deck to look somewhat like the pic attached?
thank you so very much
screenshot-2022-12-16-at-2-06-48-pm
Ok, what about a specific weather proof brand of stain please.
Really appreciate your help! we’ll look through the cleaners and stains and order when we decide.
Xavier
Xavier
Hello
My deck is 8 years old (PT) and has been stained 3 times already with TWP 100 Dark oak
I power washed it yesterday afternoon (Saturday 07/06) – I only used a cleaning solution (oxiclean) + power wash and not a stripper since I’m planning to use the same stain. I have a few questions though:
1) I’ve read I should wait at least 48 hours before staining it…..But with the current weather in Michigan, there is rain every 2 or 3 days. Looking at the weather forecast, I could probably stain on Monday afternoon (which will give the 48 hours) Is it long enough?……If I can’t do it that day, it should be raining the day after (Tuesday). Should I protect the deck with tarps to prevent it to get wet again from the rain?
2) The power washer I used isn’t very powerful (electric – 1700psi) with a wide tip. But I find the wood to be a little bit “dull/fuzzy”. Should I quicky sand with a pole sander and a 80 grit?
3) Assuming I want a richer color, could I also go with TWP semi-solid even though I didn’t use a stripper? Or should I stick with TWP100?
4) Where can I find a photo gallery of the TWP100 colors and also the semi-solid ?
Xavier
Xavier
what are the risks if I don’t strip and use the semi-solid?
I understand stripping when you switch from different brand, but in this case, it’s still TWP
Any link for a photo album? I’d like to see what Seafoam or Stonehenge look like
Xavier
Xavier
OK, thank you…..I think I will use TWP100 again then
How long does it take once stained (2 coats) to fully dry and rain won’t affect it?
Xavier
Xavier
OK, so assuming I stain Tuesday in the afternoon and it rains the day after (Wednesday), it will be fine, correct?
Xavier
Xavier
I’ve just learned I can’t get TWP100, and it will be TWP1500 instead, which takes longer to cure
Since I rinsed off the deck on Sunday morning around 9:00am, I think I have to wait 48h and stain Tuesday in the morning. Is this correct?
Assuming weather forecast is right (🤔) it should have time to cure properly (or at least enough) before the (heavy) rain on Wednesday
Xavier
Xavier
How soon after staining can I put back furnitures, flower pots, etc…?
Xavier
Xavier
I was able to stain last Saturday, and it had more than 30 hours to dry before it rained
My wife is now (Wednesday) moving some furnitures to power wash and stain the 2nd section. But when moving some patio chairs, looks like some “rusty water” from the frame dripped on the new stained section. She tried to rinse it off asap with the garden hose, but apparently it’s still visible….Is there something specific to do? Or is it going to disappear on its own?
Rust-stain
Rick
Rick
Live on the intercoastal waterway and have a 360′ long boardwalk; used the Cedartone, but would going to a dark oak tone provide any greater protection against UV? I’m re-staining about every third season. Thank you for your consideration.
IMG_1150
Conniea
Conniea
Last spring we applied TWP 100 to treated pine decking that had been untreated for approximately 4 years. We did a light sanding to clean up then did a powerwash clean after a couple of weeks. It was perfect all summer and fall, but now that it has wintered, the stain has come off of the boards in spots that appear to have knots or a ‘harder’ grain in the areas that catch the most sun (shaded part still looks great). I will say that the stain did not seem to penetrate these areas as well when we initially stained…..but maybe didn’t penetrate at all. We sanded off Behr water base stain on cedar railings and posts then power washed same as decking and all the railing still looks great. I do not detect any peeling of any kind at this point. Is it OK to power wash and recoat this spring? If OK, do we need to do 2 coats or just one? Do you think it will do the same thing every year in these areas that do not penetrate very well? Thanks for any direction you can give us.
Timmy Keenan
Timmy Keenan
Hi, I recently finished replacing all of my old deck boards with new pt pine deck boards which I finished in the late summer. This process took me a little over a year to accomplish due to several factors: I had to cut the deck boards off due to the fasteners failing(screw heads stripped out and screws that broke off), only working on it when I had days off, trying to keep the deck functional by only doing a few rows of boards at a time so that my dogs could get out to the yard and the fact that I don’t work as fast as I used to. Based on varying opinions I decided to let the deck ‘weather’ until this spring to finish the deck. My family likes the look of the TWP 100 Dark Oak so that’s what I plan on using. The deck is 360 square feet One flight of stairs is 26 square feet another flight of stairs is 72 square feet totalling 458 square feet. Someone that works in the stain business suggested that I seal the underneath also which I didn’t think of. I’m not sure if this a good idea or not as far as the sealer recommendations go but do think that it would deter those pesky wood boring bees for a while so if I do the underneath I would need more TWP 100. Since the pt boards have been exposed and gotten weathered I’m thinking they need to be cleaned with something before putting the TWP 100 on and possibly sanded. There are a few products recommended on this site that would probably work to clean the wood. I’m not sure which one to go with for my situation or if I should sand it also. Any suggestions would be appreciated!
Carla
Carla
Last year I stripped and stained our Redwood deck and used TWP rustic. Husband was not pleased with how it weathered (he liked the oily look and water beading of whatever stain the previous owners used). He also feels that it faded too much. For the sake of time, we have decided to just recoat with TWP this year. I used the TWP restore a deck cleaner and brightener and plan to restain- Husband wants to use the Redwood stain color over the Rustic color from last year- will we have issues doing this?
Diana Viney
Diana Viney
Hi there,
I have prepped my 25 yr old cedar deck by stripping most areas with the restore a deck stripper and also used the twp stripper. Brightened using Restore a deck product last week. I replaced a few rotting boards with kiln dried cedar from local Seattle lumber yard. The new boards were exposed to the brightener product. Should i apply only one coat of the twp 100 series to the new deck boards? And two coats to all others? Would the cleaner/brightener product remove the mill glaze that i see referred to in other new wood posts? This will be my first time using an oil based product since my nightmare with penofin stain 12 years ago. Slightly shy about using the twp in September in Seattle. I will do my best to apply correctly ( not overapply!) so that it gets a full cure despite shade on north side of deck and high humidity in this region. Any tips appreciated! Thanks, Diana
KHen
KHen
Hey there, we have a cedar deck. It’s been neglected for about 5 years so the wood was really grey. I sanded all the railings and added Dalys sea fin ship and shore penetrating waterproofing sealer to harden and condition the wood. I’d like to now use TWP cedar tone over to finish. Do you see any issues there! Thank you!!
Stella searcy
Stella searcy
Second coat needed?
What is the best stain for a deck exposed to the winter elements here in the northeastern US? It is a deck constructed of Amish rough cut lumber. How often should it be stained? How many coats should be applied each time. Thank you
Silvano Brecevic
Silvano Brecevic
Hi. I live in Port Huron Michigan. I have a pressure treated 2 tiered deck that is 50 percent in the shade for most of the day. With snow cover post winter I do get a bit of mildew that burns off in the spring and summer heat. I used a clear PU coating last year and it faded as well as flaked off. I am looking for a light or clear stain that is very UV resistant and has an Algicide component to it. I can spray or roll or rag on and am not concerned whether it is water based or solvent based. My main concern would be to get the maximum number of years with little fading or flaking. I can sand prep etc. please advise.
Cynthia
Cynthia
I just applied one coat of Sherwin-Williams water-based transparent wood stain on new deck wood9 mos. old.. Now I read that it fades & peels after 2 years…not what I want! Whata to do now? Should I strip it with Restore A Deck stripper that biodegradable, then apply TWP 100 Pro-Series that has 9.2-9.8 rating. Need guidance! Thanks,
Sara
Sara
My husband is in the midst of re sanding deck as we speak. It’s about 15-17 years old. After sanding do you recommend washing or treating with anything before start staining I think we are gonna go with the TWP 100. What is the wet on wet application ? Has spent over a week sanding don’t want to pick wrong stain after all of this. We normally have pressure washed and then stained but felt it was time to give a good re sanding.
Janine
Janine
We are refinishing a cottage dock. The wood is pressure treated about 20 old. It has been sanded, removing old treatments, and are looking for a wood treatment that will give it moisture and more life without building a film or sheen that will be slippery. We would like a bit of colour, but not a solid colour/stain. Confused re differences with the attributes of stains vs oils in the research we’ve done. Suggestions would be appreciated.
tdub
tdub
New cedar fence 6 yrs ago installed in November. Let it sit until the next summer, prepped and stained using this. 5 years later still looking good. Certain parts now starting to show bare wood and some green on a few panels in spots but overall I’m very surprised by the results. Have nothing to compare it to since this is the first time staining my fence but can’t imagine another of this type of stain that would last longer but I’m always looking!
In the next couple years I’ll be looking at restaining and probably looking at their semi solid with hope I could get 10 years.
My fence is 300 ft long and 6 ft. tall. It took dozens and dozens of hours of prep and work.
Pressure washing, cleaning, waiting to dry, staining, waiting to dry, covering with tarps during rain, etc…I tried different methods but ended up brushing the entire thing. Can’t say that brushing made any difference compared to spraying but it did give me more control.
Even if you spray you still need to brush at some point.
Bottom line is it was a lot of work but the results were and still are incredible. I can’t comment on using this on decks but if you do the right work you won’t be disappointed in the results on fencing.
Walter
Walter
I am about to undertake (for the first time) the cleaning, brightening, and staining of a boat dock. The decking is pressure treated #1 pine. The storage room is T-111 siding and was NOT replaced. It is about 6 years old and never been stained. I have been looking at a number of different products and the more I read, the more confused I get. Is it better to use water based stain or oil base? I want something that will last. I don’t want to have to do this all over again in a year or two. Also, some companies say to stain the wood within a couple weeks of installation. On this forum, however, I see it suggested to let new wood weather for 4 to 6 months. What am I to believe?
Jim Kempf
Jim Kempf
Greetings Scott,
I like your website and I can use all the help that you can provide. However, I have tried several times to register for the help forum without success. After I have input my user name (3-15 characters), email address, robot puzzle, click on agree to allow for you to send me an email …. then click enter …. I get a message on the screen telling me that I am using illegal characters (I think in my user name). Which does not allow me to register. I have tried different user names such as JHK49 and harvey …. I get the same message. Any help for this would be appreciated.
Jim Kempf
Jim Kempf
Greetings from southwest Georgia. I have recently had my pressure treated pine deck replaced (1000 horizontal sq. ft.) and now the next step is to get it sealed/stained. On my old deck I used a product called OneTime Wood, it worked OK but I thought I would try something different this time around. After reading many reviews and “expert” opinions I finally found your website which seems to know more about stains than the others. My concerns are UV protection since I live in the (hot/humid) south and just about the whole deck is in direct sunlight most of the day …. which of your top stains will provide the better UV protection? Ease of application is important to me since at 74 years old I am only good for about 4 hours a day …. and getting up/down isn’t as easy as it once was. Of your top stains, which is the easiest to apply ie. roller, brush, spray, rag? I am planning to use an oil based semi-transparent stain. I saw that you rated TWP 100 and TWP 1500 stains at 8.5 ….. What did you not like about those stains? For the Armstrong Clark stain you did not show a rating as you did for the TWP, why not? Also, if you have any thoughts/suggestions about this next investment for my deck, please feel free to express.
Tony
Tony
Thank you for creating this resource. Which product do you think would be better for my new PT deck- TWP100 or TWP1500? From what I’ve read here, I’m pretty sure it’s between these two. For reference, we live at 6500 feet altitude in Colorado with 8+ hours of full sun exposure, with very low humidity. Is there a better product you know of for this application? Also, I know you recommend ~6 months for the PT to fully dry, however, does that also apply for very dry climates like mine, with full exposure? Thank you!
Tony
Tony
Lois Chance
Lois Chance
My deck and porch were just stained for the second time with TWP 100 series but porch is still tacky 5 days later while deck has dried. Weather is in high 70’s and low humidity What do you recommend to fix issue.
William Blaylock
William Blaylock
I have a 3 month redwood fence. Do I need to wait 4 – 6 months before applying, and is it acceptable to use a pump sprayer?
Hap
Hap
Where can I buy the stain in Cincinnati Ohio
Gary
Gary
I am new to this site. I have a pressured treated deck that will be a year old in July of 2023. What do you recommend to stain the deck with? Thank you.
Gary
Gary
What is your opinion on Penofin vs TWP100?
pjh01
pjh01
Can this product be obtained in a solid color (IE: Barn Red ?) I’m looking for a good Siding product for T-111, which will match an existing structure on the property. Located in Eastern PA. If not can you make a recommendation? Thanks
Randy Martin
Randy Martin
I live in Oregon and have been using TWP 100 series for many years, applying every 2 years to 27 year old cedar deck. About a year ago we noticed deck to stop beading up water after only 1 year since application. Since the wood is so old, should we be putting 2 coats of TWP 100 series on? Thank you very much!
Randy Martin
Randy Martin
Thank you Scott! But does a second coat help or harm? Much appreciation.
Randy Martin
Randy Martin
Scott, thank you again.How does one determine the porosity of a 27 year old cedar detck that has just had a fresh sanding and one coat of TWP 100 series? There is a shine film on the cedar that does not get much traffic, but no shine film on the heavy traffic cedar. Would you recommend 2nd coat test on a portion of the heavy traffic cedar decking? Other thoughts appreciated!
Brett
Brett
Does the higher amount of solids in the TWP 1500 help it perform better than the 100 in anyway?
There is review of the 1500 in 2022 on this site that says it is the best even though they are rated the same overall.
Is there a reason I should use one over the other?
Also, can I add a mildewcide to either for extra protection?
Brett
Brett
I’m using it on Douglas fir wood soffits and covered patio ceilings so most of it doesn’t get direct UV. I’m more concerned with mold and mildew since I already have a problem with it 1 year after moving in to a new house. PPG cetol SRD was used on it.
Would I be better off using Restore-a-deck with better mildewcide? Or TWP 100 or 1500?
Kirsten Logan
Kirsten Logan
Hi there,
We will be having a new red cedar, horizontal tongue and groove fence installed in a couple of weeks. Unfortunately, TWP is not VOC compliant in NJ as I know it is your top pic and gets great ratings in general. I have researched quite a bit and Consumer Reports rates Behr as very good/their pick. But I have seen lots of complaints as well. The company that we are working with is a firm believer in BM Arborcoat and has never had an issue. I was thinking semi-transparent Stonehedge. We are having our fence stained before it is put in place because we have a narrow lot and don’t want to bother the neighbors once it is in place. So, it won’t be weathered for 4 months unfortunately. Any help you can provide would be greatly appreciated. Thank you!
Chadd Sewell
Chadd Sewell
I used TWP golden pecan on a very weathered wooden fence. I pressure washed it the wood and then applied 1 coat of TWP and 3 years later still very happy. FUNNY Thing, I Came across this review because, I bought Rocksolid 20x,around the same time; but went with the TWP instead. I was going to use up the gallon of 20X on small wheelchair chair ramp but I don’t have the primer suggested, and now I am having second thoughts on the 20X rust-O which I had high hopes for. TWP I felt I would give credit, where credit is due.
Cheryl Mack
Cheryl Mack
I have a 22 year old deck in pretty good condition. So happy to have found your website about 6 years ago – TWP is the only product I’ve ever used (after perhaps 5 or 6 different products needing to be redone nearly every year!) that has lasted and worked beautifully!
Last year we had to redo our steps and a few boards with new cedar. Now I need to stain the new boards after weathering approximately 10-11 months.
I know I need to clean/brighten the new wood, and clean the old wood, then stain it all. Should I use the same cleaning products on the entire deck (I usually just wash with dish soap and water and reapply TWP when necessary)? Should I strip the old decking even if I’m using the same color stain (TWP 120 Pro Pecan)?
And anything different if I decide to change the color?
Cheryl Mackinnon
Cheryl Mackinnon
Just wanted to say thanks for your excellent guidance. It took me a while to get to it, but I did just what you said and the deck turned out great!
Carol McKee
Carol McKee
My little deck is 140 sf pressure-treated lumber (pine?), Central Florida. Originally coated 6 years ago with Thompson’s Water Seal(?) or some other useless stain/sealer. It’s finally peeled off enough to tackle again and have pressure-washed- mostly bare wood now except for a few small areas which I have sanded enough to blend, if not completely removed. I’m 72 yo (old and tired) and don’t need the deck to look perfect. Cost is an issue. I’m leaning towards the RAD bc of the short drying time and easy cleanup.
Will it be a disaster to use either TWP (oil based) or Restore-A-Deck without all the prep work? At this point I just want to be able to slop it on with a pad and be done with it.
Carol McKee
Carol McKee
It’s somewhat weathered but not actually gray and comes up to a rich “natural” color after a good rain. Six years of dead pecan tree leaves must’ve protected it. Color resembles new PT lumber. Pics show leftover previous finish.
Forgot to mention pressure wash was with water only, two weeks ago. Which product(s) do I need to use? Both cleaner and brightener?
Rick
Rick
Why did my cedartone CWP stain applied to western red cedar develop black splotches and spots in some areas which are shaded and near the house?
Suzie
Suzie
What is the difference between TWP 100 and 1500? What is the best TWP to use on a 5yr old cedar deck that I will clean first with your suggested Gemini product. Previously stained with oil base
Kelly
Kelly
I have a deck around my salt water pool. Will this stain hold up?
Ryan
Ryan
New deck 12 months old in Michigan
Ryan
Ryan
Which one to use on a new deck….12 months old…in Michigan
Jennifer
Jennifer
My pressure treated deck is only a month old and my contractor is wanting to stain… I am in Georgia where it is getting quite hot but I’m wondering if it’s really ready. Is there a TWP product that works on new pressure treated wood?
FCH
FCH
We put in a deck about 6 years ago using treated wood. We live near Seattle in Washington state. We have not been happy with the stain we have used and have not been able to get an even coverage even after pressure washing. We plan on sanding the deck and using TWP stain. The deck is 17′ x 32′. Should we use any other product to make sure this stain penetrates? Any other advise you can give us would be appreciated. (Right now it is raining so the picture would not be helpful, but let us know if you need one.
Larry
Larry
We live in Ohio a couple of miles inland from Lake Erie. Deck is on the east side of house. Replaced about 1,000 sq ft of ptw last September. Considering TWP semi-transparent. Would 100 be a better choice than the 1500? Clean and brighten? Would probably be at least another month before I and Mother Nature both get in the mood. Thanks
Bud
Bud
Reply to  Larry
you can get TWP 100 in West Virginia or Kentucky if you are willing to travel
Great information here, this really is the best online source out there for staining expertise. We’ve read the reviews and wanted to know your opinion on our plans to apply semi transparent stain to not only our PT decks, but also our shed and fence.
Standard pine fence and T 111 shed has been stained over several years ago with semi transparent. Our smaller PT deck has been stained years ago with semi transparent. Our larger PT deck has never been stained post install 3 years ago.
Torn between Restore A Deck and TWP 100. They are very close in score w/ a slight edge to Restore A Deck. I saw your TWP 100 testing was performed in full sun, whereas Restore A Deck was half sun. Our larger deck, shed and fence will be in mostly full sun. The smaller deck has very little sun (north facing).
Was hoping to simplify and only use one stain for all. Leaning toward TWP 100 but can also see the value in the Restore A Deck being a little better w/ mildew prevention. Our larger deck has developed small black specs of mold even though it’s primarily in the sun.
Would appreciate any thoughts you have on what stain would work best for the above.
Scott
Scott
I live in the desert southwest and I am wondering if I need to oil the wood before I apply a 100 series product. The wood has been outside for 1.5 years now and is starting to show the little cracks of dryness.
Thomas BRANDOW
Thomas BRANDOW
What is recommended for redwood desk?
Kim
Kim
Thank you for this useful information! Planning to stain our new pressure treated pine deck that has been weathering 7 months. Still debating the merits of oil-based vs water-based. It is a large deck that comes out over a walk-in basement, and it will be a big project prepping and staining. The question is should we stain underneath the boards at the same time as we do the top surface, or can they be done at separate times? Can the boards be sprayed from underneath? (I understand we will need to clean/brighten first)
Brian
Brian
I am replacing my vinyl siding of my house with non treated cypress siding. What would you recommend to preserve and maintain natural look the longest? I have considered a light tint transparent stain/sealer as well. I live on the southern Gulf Coast in blistering sun and high humidity. Thanks.
Tyler
Tyler
Would you suggest using TWP over regular (not pressure treated) pine tongue and groove for an exterior porch ceiling or would an oil based poly be better? Thanks.
Dean G
Dean G
I have a cedar panel garage door that is in need of renewing. Used Sikkens Cetol SRD originally when new. Have never really been happy with it. What is the best product to remove it to prep for a new stain product? Would like to use something else to refinish the door. Is TWP 100 a good choice for vertical application (obviously not a deck). Live in Colorado so 100 is banned but 1500 is not. If TWP is a good choice, should I be concerned about the difference of 100 vs 1500 for Colorado exterior conditions or not as overall results may be the same? I can get 100 in Wyoming and have a friend that can help me out with that depending on your remarks. I would welcome suggestions for other products that you may have experience and think would be a better solution.
Dean G
Dean G
Ok – here are pictures of both doors. I will be doing some minor repair of the base boards but otherwise it is ready to strip and restain. Your recommendations will be appreciated. Thanks
Dean G
Dean G
Assuming the stripper and brightener do the job, should I do a wet on wet application for the doors or stick with one coat?
Dean G
Dean G
Sorry one last note: I intend on using the TWP 1501 stain (cedartone).
John Andrick
John Andrick
Does the clear provide UV protection and prevent graying
John Andrick
John Andrick
randy oconnor
randy oconnor
i just had new western cedar picket fence stained, after all the correct prep, ageing, powerwashing, was using honeytone 1515, after i went thru several samples ordered from twp, ordered 10 gals, more than enough, first bucket the professial used, looked like baby **** yellow, second bucket come out beautful golden honey color, whats up with that?!, spent 9 grand on the fence, and half of it is ruined, and of course its on the roadside, we live on a corner lot. I know they ll be a reason for it,
Paul J Georgas, Jr.
Paul J Georgas, Jr.
How can I get a samples of Cypress stained with TWP100 105 Cape Cod Gray and 06 Prairie Gray
Aleisha
Aleisha
Hi! We have a two year old pressure treated deck that has never been stained. At the advice of a paint store employee, we purchased Benjamin Moore Restore to prep the deck for stain (wish I read this article and the comments ahead of time and purchased the TWP prep kit). We also pressure washed it. Couple of questions:
1) do you recommend we do anything else to prep it, like sanding? There are a couple of stains that are lingering.
2) what type of TWP should we use? (We live in upstate NY)
3) two coats?
Thanks for your help!
Nancy Eden
Nancy Eden
We want to re-coat a deck that is in very rough shape. What would you suggest? We used a Pittsburgh Paint product 6 or so years ago. It’s mostly gone. Should we use a solid stain or paint product? What brand?
Sherri
Sherri
We used Cabots Semi Transparent srain and seal on our deck. We finished about 6:15pm last night, and it is raining this morning . Will this cause problems?
Sarah
Sarah
I am looking to refinish some cypress columns around my home. I would like for them to match our gable or repeat their current finish but am having a hard time judging what is on either of them. Also weighing in ease or reapplication and overall longevity. Any ideas?
Atlanta
Atlanta
Should you wait several months for new pressure treated pine split rail fence with this stain, too? This wood is rough cut and seems very dry and “thirsty.”
Bill
Bill
Do I need to wait for a number of days with low humidity before staining with water base semi-transparent stain? Old finish has been sanded off.
Greg
Greg
Can I get deck stain in sage green tones?
Lynne
Lynne
Hi, I’m in WA state outside Seattle, planning to stain a long cedar fence bordering 3 neighbors. Part shade in back; shade and sun on sides; sides under Douglas fir trees. Built in 2004. It was stained once about 16 years ago using clear; my husband says the stain and protection “is long gone.” Don’t know what former product was used. We have some mold issues, lichens/moss, etc. clinging but it’s in mostly good shape. Planning on using TWP 100 in clear as neighbors are not staining the fence on their side and I am concerned about colored stain ending up on their side from our painters/slat openings. I know no UV protection with that.
Do I still need to strip, clean, brighten? Or can I skip the stripping? (and what products for all this?) How to remove the mold? Thanks for such a helpful site!
Steve friedman
Steve friedman
I used Gemini restore a deck on a pressure treated deck and railings. Wood was 3 months old. Than used twp 205 cedar. Ihave always used 205. Not 100. Now I have tannin and mold and mildew. Stained 3 months ago. What shield I do now. Thanks.
Bob mladucky
Bob mladucky
Can I add anti skid to a semi solid stain to get some slip resitance
Katie
Katie
My unopened TWP 120 stain is full of clumps like this I think I got a defective batch? I tried mixing in the clumps but they won’t go away and don’t want to risk ruining my deck after all the prep work I did.
Katie
Katie
You were right I purchased a drill mixer, used the stain and it turned out great. Thank you for quick answer and giving me piece of mind.
Jeff
Jeff
My new pressure treated covered deck is a year and has never been stained. I power washed it pretty thoroughly because it had lots of stains from everyday use and then I used a brightener and now waiting two days it to dry. Tomorrow I plan on rolling with (3/4″ nap) one coat of TWP 100 Pecon then spraying my railings.
1.) My understanding is that I should only apply one coat of stain is this correct?
2.) Should I apply a 2nd coat of stain next year or just wait until the entire deck needs to be refinished? In other words is there any advantage to staining again quickly?
3.) The deck still gets rain and snow blown on it so should I look into applying a sealer after staining for waterproofing? I’m worried about the wood expanding when it freezes and thaws.
4.) The ceiling of my deck is pine tongue and groove (shingled roof, little to no sunlight). I already sanded it with 180 grit then plan on using one coat of TWP CLEAR 120. Is this a good plan and is there anything else I should be doing to it? Will it need two coats?
5.) How good will unused stain last for in the can opened and unopened?
6.) Will rolling stain on deck and ceiling then spraying railings give me best result or is there a preferred method?
Cheryl
Cheryl
Can you use this on 5 month old cedar fence?
David and SPENCER
David and SPENCER
We are in coastal North Carolina and have installed a new wood fence of Severe Weather EcoLife-treated pine from Lowe’s. We want the natural wood color to remain unchanged over time. Should we use the TWP Pro Series 101 or another product now for the initial preservative coating? How dry does the wood need to be for proper finishing? We are having a fairly consistent tropical afternoon rain daily. Your thoughts.
Bill Bowers
Bill Bowers
is a wood cleaner AND brightener just as good as SEPARATE cleaner and later a separate brightener only
Deborah A Clouser
Deborah A Clouser
If I use the “wet on wet” application method, when would I apply a second coat?
Nadie VanZandt
Nadie VanZandt
I stripped and sanded my deck and I am wondering if it is necessary to use a wood brightener before staining the deck. I plan to use TWP 100 PRO- Series for the stain.
KATARINA
KATARINA
I was wondering if you can help me choose a right product for older cedar siding on the house. We are in Seattle, siding has been painted with solid color few times, but paint usually only last for a couple of years or so and then starts peeling.
thelilpups
thelilpups
Hi guys,
Love all the videos you have added. So after stripping and sanding my deck, I will be doing a final round of prep – being cleaning and brightening with the RAD products, per your suggestions. After 4 days of drying we will apply TWP101 Cedartone which we have previously purchased from you affiliates. Since we have stripped and sanded the deck, you have already advised us to only put on one coat this season and a second coat next season. Your TWP video here shows a two step process: Wet on wet pump spray on then use a pad applicator. Would that work for one coat or is that considered two coats?
Thanks in advance!
Lee
thelilpups
thelilpups
Thanks, glad to confirm that. We are now in a heat wave with full sun so it may be a couple weeks but I will post pictures. BTW, I get a total score of 8.63 for TWP based on your ratings.
Robin
Robin
need recommendation for white semi-transparent stain for unfinished wood deck that has weathered 12 months
Robin
Robin
Cabot & Valspar list semi-transparent and semi-solid white as an option. Lowes says they can color match. How do they do that? We want to do the deck surface in a darker stain and the roof wood supports in a white stain. New wood weathered 12 months & just cleaned with OxyClean. Central Indiana. Your recommendation?
Robin
Robin
Actually, I just found your review on FLOOD stain that looks good!
Kristin
Kristin
Can I use TWP on Ipe? We have a MASSIVE ipe deck, full sun and by a pool. We have tried a few different brands- I lived penofin the first year, but it seems like they changed something in formulation and it’s not as good. We did superdeck exotic as well. Nothing holds up for even a full summer. We are in Massachusetts. Debating on trying two or deckwise ipe oil- also thought about a marine grade teak oil.
Just finishing up washing it this weekend, and will need to apply a brightener(and recs for this?) Before applying a new oil.
Kristin
Kristin
Thanks. I read the reviews on exotics, and have heard so many things from different sources. May have to try restore.
Annalee
Annalee
I have used super deck exotic hardwood stain in natural on my hardwood deck & over the years reapply on my mahogany wood & over time I lost the many color variations & became a solid brown. This year I pressure washed it & removed most of the old stain. Some areas that were protected would not budge &remain brown. I can live with that if I have to because furniture will hide this area. What do I do know & what would be the best protection &keep the many shades of the mahogany wood thank you for your help
Jen
Jen
have an old fur deck. It is about 18 in L. It has one side that has a built in bench. Orig from 1987sh. It was we think painted or what looked like paint. We had to replace about 10 or so floor boards two years ago. Now beautiful nice silver gray. No stain or anything on them. We just had to replace 33 floor boards. The railings and bench only minor replacements but the trim under the benches is still fully painted (powerwashed 2x, sanded bench and railings as could). So, my question. 1) Can we stain floor b/c some is brand new and some is a few years old? 2) Or should we wait 4-6 mo for new wood to get seasoned then stain in fall? 3) Or wait a full year and refinish next spring? 4) We were told that we probably need to use solid or semi perm stain (like paint) on the bench and railings/trim b/c we cannot get all of the prior paint out. You agree? So we’ll end up w/ a 2 toned deck hopefully – Transparent stain deck floor and then solid white trim, railings and bench. Should we wait on it all – we powerwashed the deck entirely. Also we have a man who can do this but I fear having someone claim they can do this and not be skilled at doing it well as not all paint jobs are created equal esp when you look at this deck all the time. Would love your take. Also what treatment(s) or stain do you recommend for the flooring and then the white trim, railings etc? He used water to powerwash as didn’t want to use chemicals on new wood if he could avoid.
Robert Christiansen
Robert Christiansen
I have an approximately 600 sq.ft. treated deck in the Chicago area. It has been refinished three times in the last 20 years with semi-transparent stain first then two solid color stains with thorough cleaning between coats. The deck is now peeling and down to bare wood in some areas. I would like to re-coat with TWP 1500. I plan on power washing the deck and using a cleaner.What are your recommendations
Richard Douglas
Richard Douglas
What is the best stain for a pressure treated pool deck. Pool is chlorine. Deck is 5 years old and I sanded the deck floor boards with 100 grit. I live in western NY. Just need the proper product that will last the longest. Don’t really care about wood grain. Last product was solid color and peeled off. Thanks for your help.
Matt Henry
Matt Henry
I stained my deck about 5 years ago with twp 102. I need to restain it. What do you recommend? Sand 60 than 80 grit and use Gemini cleaner and brightener after. They area covered by gazebo help up pretty good as seen in 2nd picture do I have to use a stripper for that area?
Matt Henry
Matt Henry
Ok so use the Gemini stripper and brightener for the area that held up well like in 2nd picture than do I need to rinse it off with a pressure washer? After thats done do I use Gemini restore a deck kit for entire deck?
Let it dry for minimum 48 hour than restain with twp102 2 coats wet on wet
Matt Henry
Matt Henry
Angel
Angel
I have a 5 year old deck and stairs of pressure treated pine. First year thompson’s water seal, terrible. 2 years ago pressure washed and used WoodRX. Has not worn very well. Will pressure washing alone take this off in order to apply TWP 100? If not, what else is needed?
Angele
Angele
Here it is
Angel
Angel
Thank you, so pressure washing alone will not remove residue? And what PSI on the pressure washer?
Jon
Jon
My pressure treated pine deck is approximately 8 months old and I’m in NJ. I’m looking to use TWP 100 and I wanted to do two coats but what I’m reading says to only apply one coat. What’s the reason for only one coat?
Jason adams
Jason adams
I am repainting our 40 year old house. We have always used cwf flood clear but we’re looking at TWP clear. Want it to stay close to same color. Which one would be better? We have cleaned it. Sending pic not cleaned on right. Please send suggestions
Lilian Lonsdale
Lilian Lonsdale
Where do you find this stain
John Keith
John Keith
I’m in Northern Illinois and have almost used up my 1500 TWP supply.
It’s been more than two years since I applied the last coat and I’m not
certain I prepped it right. Since I’m stripping, sanding, and brightening
anyway, is now the the time to switch to TWP 100? This is a 20+ yr old
PT deck and the installer seems to have used varying degrees of quality
wood. Thank you.
1.3K
