TWP Stain Review 2026: TWP 100 vs 1500, Colors, and Where to Buy 5/5 (19)
Scott Paul has applied TWP stain on more than 10,000 deck restorations since 1993 and re-tests both the TWP 100 and TWP 1500 on real decks every two years. The ratings and advice on this page come directly from that hands-on experience.
TWP Stain — Quick Summary
  • Full name: Total Wood Preservative (TWP)
  • Two main formulas: TWP 100 Pro Series (35 states) and TWP 1500 Series (all 50 states)
  • Type: Oil-based, semi-transparent, penetrating
  • Durability: 2 to 3 years on decks
  • Our rating: TWP 100 — 8.69/10 | TWP 1500 — 8.5/10
  • Not recommended for wood less than 4 months old
TWP Stain Reviews
TWP Stain Reviews
TWP Wood Deck Stain Reviews
In reviewing some of the top stains on the market for 2026 we could not overlook TWP stain. It is a registered EPA wood preservative that offers excellent protection from UV graying, wood decay, and water infiltration. TWP uses select mildewcides that naturally resist fungal growth to help eliminate wood rot. The semi-transparent oil-based formula penetrates deeply into wood pores without extreme surface film accumulation. It emphasizes and enhances existing wood grain beauty with color depth and warmth.
Our TWP Stain review 2026 shows that this stain goes beyond the TWP claims of being the number one wood preservative. Top contractors and professionals prefer wood stains that penetrate into the wood surface and can be easily maintained and reapplied without sanding. This makes wood maintenance easier, cheaper, more effective, and less frequent. Most TWP stained surfaces will last 2-3 years before a recoat is needed. The excellent UV-absorbing pigments eliminate wood discoloring and graying, which is a common problem with exterior wood surfaces.
In our two-year test, the TWP 1500 and 100 Series showed no color darkening from UV exposure or mold — an outcome we consider excellent for any oil-based stain.. In addition to excellent color retention, TWP Stain applies easily enough that your typical do-it-yourselfer can get professional-like results. We also found in most cases TWP Stain is not affected by rain after an hour or two of stain absorption. We noticed that the natural and synthetic oils in TWP showed very little fungal growth at the 2-year mark as well as no peeling, flaking, or chipping.
Another plus to the TWP Stain review 2026 was the fact that as well as this stain performs it still remains a low VOC oil-based formula and is compliant in all 50 states. TWP Stain scored well in all tests in overall protection, longevity, compliance, and final finish results.
TWP 100 vs TWP 1500: What’s the Difference?
TWP 100 Pro Series TWP 1500 Series
VOC Level Higher VOC Low VOC
States Available 35 states All 50 states
Penetration Slightly deeper Very good
Dry Time 4 to 6 hours 6+ hours
Colors 10 10
Best For Unrestricted states VOC-restricted states
The TWP 100 and TWP 1500 are the same product family with one key difference: VOC content. TWP 100 uses a higher-VOC formula that penetrates slightly deeper and dries faster. TWP 1500 is the low-VOC version required in states with stricter air quality regulations. In our real-world testing over two years, both products performed nearly identically for UV protection, mold resistance, and ease of reapplication. If TWP 100 is available in your state, use it. If not, TWP 1500 is an excellent substitute, not a downgrade.
Where Is TWP 100 Available?
TWP 100 Pro Series and TWP Semi-Solid Pro Series cannot be sold or used in the following states and regions due to VOC regulations: California, Colorado, Connecticut, Delaware, Illinois, Indiana, Maine, Maryland, Massachusetts, Michigan, New Hampshire, New Jersey, New York, Northern Virginia (DC metro area), Ohio, Pennsylvania, Rhode Island, Vermont, District of Columbia, and parts of Arizona. They also cannot be shipped to or used in Canada.
If you live in any of these areas, use the TWP 1500 Series instead. TWP 1500 is compliant in all 50 US states. Neither the 100 nor the 1500 series can be used in Canada — for Canadian customers, TWP 200 Series is your option.
See this for more in-depth TWP Reviews
TWP 100 Series Reviews
5.00out of 5
5.00out of 5
5.00out of 5
TWP 1500 Series Reviews
$69.99
$264.95
$315.00
$329.00
How to Apply TWP Stain: 6-Step Overview
Applying TWP stain correctly is the single biggest factor in how long it lasts. In our experience on 300+ decks per year, poor prep causes more early failures than the stain itself.
  1. Wait for dry conditions. Apply when temperatures are between 45°F and 95°F and no rain is forecast for at least 24 hours. Avoid direct midday sun on the wood surface.
  1. Clean the deck first. Use a dedicated deck cleaner such as the Restore-A-Deck Cleaner Kit. This removes dirt, graying, and old residue that blocks penetration.
  1. Brighten the wood. Apply a wood brightener after cleaning to restore the wood’s pH and open the grain. This step is not optional — it directly improves how deeply the stain penetrates.
  2. Allow 24 to 48 hours of drying time. The wood must be fully dry before staining. Staining damp wood is the most common application mistake.
  3. Apply wet on wet. Spray or brush on the first coat, then immediately apply the second coat while the first is still wet. This is TWP’s recommended method and produces the most even penetration.
  4. Back-brush or pad any puddles. Any spots where the stain pools and does not absorb within 30 minutes must be wiped or worked in with a stain pad. Dried puddles will peel.
Pro tip: Do not apply TWP to new wood less than 4 months old. New wood is too smooth and dense for proper penetration. Wait at least 4 to 12 months, then clean and brighten before staining.
Is TWP Stain Right for Your Deck?
TWP stain is best suited for cedar, pressure-treated pine, and redwood decks that have been weathered for at least 4 months and are in structurally sound condition. It works on both previously stained wood and bare wood, as long as the surface is properly cleaned and prepped. TWP is not ideal for new smooth wood, exotic hardwoods like IPE or Cumaru, or any surface with existing film-forming coatings that have not been fully stripped.
If you are in a VOC-restricted state and want an alternative to TWP 1500, Armstrong Clark Wood Stain is VOC-compliant in all 50 states and performs at a similar level. In our testing, Armstrong Clark rated 8.5 to 9 out of 10 and is our primary recommendation when neither TWP 100 nor TWP 1500 suits the situation. See our full Armstrong Clark review for a side-by-side comparison.
TWP stain is not available at Home Depot or Lowe’s. Purchase directly at TWPStain.com or through our TWP Stain Product Page for the best pricing and to ensure you get the correct formula for your state.
TWP Stain Dealers
TWP 100 Series Deck Stain Photos
TWP 100 Pro-Series Review Video
TWP Stain — Frequently Asked Questions
Add each question as an H3 with the answer as a paragraph below it. This structure is what both Google Featured Snippets and AI systems extract most reliably.
What is TWP stain and what does TWP stand for?
TWP stands for Total Wood Preservative. TWP stain is an oil-based, semi-transparent penetrating stain that protects exterior wood from water, UV rays, mold, and wood rot. It is EPA-registered and comes in two main formulas — TWP 100 Pro Series and TWP 1500 Series — depending on your state’s VOC regulations. TWP is manufactured by Gemini Coatings, which acquired the brand from Amteco.
What is the difference between TWP 100 and TWP 1500?
TWP 100 Pro Series is the original higher-VOC formula, available in 35 states. TWP 1500 Series is the low-VOC version compliant in all 50 states. Both are oil-based, semi-transparent, and EPA-registered. In our two-year testing, both perform nearly identically for UV protection and mold resistance. The practical differences are that TWP 100 penetrates slightly deeper and dries a bit faster. If TWP 100 is allowed in your state, it has a slight edge. If not, TWP 1500 is not a meaningful downgrade.
How long does TWP stain last on a deck?
TWP stain typically lasts 2 to 3 years on a horizontal deck surface with normal sun and weather exposure. Vertical surfaces like railings and fences can go 3 to 4 years before needing a maintenance coat. Longevity depends heavily on UV exposure, wood species, and proper prep before application. In our testing on full-sun cedar decks, TWP retained about 80% of its original color after two years.
Can you apply TWP stain to new wood?
TWP should not be applied to new wood less than 4 months old. New pressure-treated or smooth-milled wood is too dense for the stain to penetrate correctly, which leads to surface buildup and early failure. The manufacturer recommends waiting 4 to 12 months. When the wood is ready, clean with a deck cleaner, apply a wood brightener, allow 48 hours to dry, then apply a single coat of TWP.
How do you reapply TWP stain without stripping?
One of TWP’s biggest advantages is that it can be recoated in most cases without stripping. If the existing finish has faded evenly with no peeling or mold buildup, clean the deck with a Restore-A-Deck cleaner and brightener kit, allow 48 hours of drying time, and apply one maintenance coat. Full stripping is only required if the old stain has worn unevenly, if there is significant mold staining, or if a different product was applied over the TWP.
Is TWP stain sold at Home Depot or Lowe’s?
No. TWP stain is not available at Home Depot or Lowe’s. It is sold directly through TWPStain.com and through specialty online retailers including The Sealer Store. Buying direct from TWPStain.com is typically the most affordable option and ensures you get the correct formula for your state’s VOC regulations.
127 Comments
Jadar
Jadar
8 months ago
I first used TWP via a recommendation . Researched and tried them. I have not been disappointed . Ease of application is great. Each time I have used was in a sun drenched area and it held up well. This time I will be in a sun drench with snowy ,cold conditions and I believe this stain will not let me down . Customer support and tutorials are helpful and sets them apart from others.
Bill Geers
Bill Geers
If I use the TWP 100 Series to stain my deck, do you recommend that I then also apply a sealer? Thanks!
Eric
Eric
Can TWP 100 series be reapplied over itself when the deck needs to be recoated after two or 3 years? Or does it need a complete sand down to bare wood every time?
Becky
Becky
I have a one year old deck with pressure treated wood that I need to stain but just noticed a little mildew (I think) on the vertical posts. Will I need to sand or can I just clean those before staining. Also, is the 1500 series semi-transparent and can I buy it in Tennessee?
Mauricio Perez
Mauricio Perez
I just Applied TWP to my parota wooden front door, when is it convinient to reapply? (maintenance)
Gary
Gary
I have heard that Twp101 cedar tone is discontinued. Is that true ?,and if so is there a replacement? Thank you
Gary
Gary
I am in Michigan and I could only find it at ace and now they are telling me it’s no longer in their warehouse
Gary
Gary
I live in Michigan
Gary
Gary
Great, thank you very much
Mauricio Pérez
Mauricio Pérez
¿Can I use TWP 100 series (clear) to treat and protect a Parota Wood Door? This principal entrance door is not Varnished and its Permanently exposed to sunlight and sometimes rain (not much rain) this door was previously treated with linseed oil (Flaxseed oil). Thank You for your answer.
Trannum
Trannum
Staining cedar, with twp 120 pro series pecan. Wood has been stripped and pressure washed. I gave 3/5 day dry time. Why would the knots in the wood be green. Algae ?
Alakar
Alakar
I used the TWP 100 Redwood stain on a new western red cedar fence in 2014. It has held up incredibly well. I’m finally needing to restain the fence after 9 years. I’m in south-eastern Wisconsin so I don’t get the kind of sun as someone in the south gets and it is on a fence, but 9 years is pretty incredible for any kind of finish to last.
KThompson
KThompson
The low-VOC 1520 formula worked great for me on redwood as long as I had previously treated the wood with Boracare to prevent rot, mold and wood-boring insects. The color lasted for a couple of years.
But the low-VOC formula failed pretty badly when applied to ipe. The first light rain washed it off. There went my hard work preparing the ipe. The regular VOC 120 formula performed much better on ipe, much more rain resistant. This isn’t the manufacturer’s fault. It is due to environmental regulations (separate issue and don’t want to debate it), putting low-VOC on ipe is a waste of time and money IMO. I want to save others from what I had to go through with the low-VOC formula on ipe.
Larry Loar
Larry Loar
I live in the South West part of Ohio. I was able to clean my deck with the Gemini products that are recommended. I’m resealing with the same TWP 1500 that I used the last time a couple of years ago. From what I read on the can on the TWP 1500, I need to wait at least 2 days for the deck to dry and I need 2 days before it may rain. If I remember from what I read, I need to seal it within 2 weeks of the cleaning. I’m wondering what happens if I’m not able to seal it before the 2 weeks are up? Do I have to re-clean it again? It seems like the weather forecast is rain about every 4 days, for the moment\. This is usually the dry part of the year. Thanks for your suggestions!
Carla
Carla
We have old pine boards under roof as our outdoor porch flooring in Louisiana. We pressure washed and are ready to put a sealer. What item and color do recommend? We like the rustic look.
Carla
Carla
So once the old stain is removed, which TWP do you suggest and what color ??
Rick Baggett
Rick Baggett
Just built a new deck and love the new Southern Yellow Pine look. Can walk on it barefoot in full sun with 90 degree GA weather. Can I use the clear product after a couple of months? Will just a good pressure washing of the dirt be enough prep for a new deck? Thanks
Jack Watson
Jack Watson
I have used TWP 100 series on my 400 sq ft deck in Oct. 2019 and May 2021 after a complete sanding and repair in Oct 2018. I loved your Dark Mahogany stain. Am I correct that color is no longer available? I/2 my deck gets direct Reno, NV sun throughout the day. The other 1/2 gets only gets the indirect sunlight. Is Dark Mahogany available anywhere (one of your stores)?
What would you propose as a substitute TWP Color? I loved the dark mahogany after having more of a lighter (i.e. redwood) color for 10 years before changing to the superior TWP and Dark Mahogany. Sad to not see Mahogany in your latest color listings. Need a quick answer please!
Anna
Anna
What is the best transparent/semi-transparent stain for brand new cedar fence? How long should it weather before it is stained? Currently it is four weeks old.
Joy T.
Joy T.
I have a 20 year old deck to which I have been applying BEHR or DUCK or Olympic. Lasts one year. Wood is grey/dark brown, even though it has been UV protected. For the railings, I am now using Spar Varnish (Man-o-war) with UV. Election is 7,000 ft, so the sun is very strong (Nevada).
I think TWP 100 would be a better choice than Behr. The wood is old – will cleaning still be necessary? I have been washing the deck with TSP before applying the Behr, Duck, etc.
Your advice appreciated!!
betty
betty
what is your opinion about hemp seed oil for decks?
Dave Czar
Dave Czar
I have a three year old deck that I stained with Behr premium semi-transparent Oil based stain, I am not happy at all with the performance of this stain, it’s total junk. Anything would be better than this stuff. Given that it is an Oil based stain what product would you recommend? and what would be the best preparation for the new stain? Thanks!
Dave Czar
Dave Czar
This is the deck and the hand rail it was prepped with the recommended behr deck prep before staining
Dave Czar
Dave Czar
Thanks a lot!
Carla
Carla
How long does it take for the 1500 series to dry at 70 degrees with little or no humidity
Carla Rogers
Carla Rogers
H0w soon after washing deck can I apply stain. This is the third time I have stained my deck with this product over about 8 years.
Gale
Gale
Can I put other stains over this?
Pravin Bhagwan
Pravin Bhagwan
How do I spread stain big deck
J Hummel
J Hummel
it says 2-3 yrs before recoat and yet some other name brand products say 15+ yrs on siding. I’m sure the latter is marketing hype but what is realistic? Is 2-3yrs on decking the same as 2-3 yrs on siding? I have used twp before and I thought results were amazing. Just gathering more info for a commercial client.
J Vickoren
J Vickoren
My clear stain looked milky when opened. Is something wrong with it. It may have been inadvertently left outside in Georgia freezing temps.
Cheryl
Cheryl
I recently had a deck built using KDAT pine. I have read that I should not wait and do not need to wait longer than 1 month to stain it. Does that hold true for TWP stain and which TWP product should I use?
Robin
Robin
I have a Weathershield Cedar-toned PT wood deck on the east side of my MN house, installed late October of 2019. What would be a good product to use on it?
I wood like to keep it pretty much the same color.
Robin
Robin
Any idea of what color to use on top of the cedar tone? I don’t want it to turn orangey or yellow. Are sample sizes available?
Robin
Robin
Will the cedar tone color it is now go away when it is cleaned and brightened? or how will colors look over it? Should I use the 100 series? Is there a color you reccomend that would work best over it?
Donna
Donna
Thinking of staining my deck with TWP semi-transparent 1504 black walnut. Ordered a sample and love it but a friend said the dark stain would make the deck too hot to walk barefoot in. Is this true?
What product do you recommend for redwood?
Reply to  David
The 100 series or the 1500 series?
Northern Minnesota. On the Canadian border.
Lee
Lee
We have a lot of pine tree sap on our 3 yr old wood deck that was stained with TWP natural color two years ago. What is the best way to remove/clean the deck to get rid of the sap?
Donnelly
Donnelly
I just used the brightener onthe deck, it us already dry. How long do I have to wait before I stain in with the 1500 series stain.
Donnelly
Donnelly
I power washed my deck two days ago. Is it necessary to use a cleaner/brightener on the deck as well before staining?
Donnelly
Donnelly
Hiw long do zi need to wait in between coats for the 1500 series stain.
Donnelly
Donnelly
How long of a drying time do you need on the 2500 series stsin.
i have used TWP stain for the last three years and every year i have to restrain my deck. It is in direct sunlight but it does not last and keep it’s color.
Robert H Jeffers
Robert H Jeffers
I applied TWP last summer, my customer is asking me to apply a 2nd coat. Will a 2nd coat adhere?
Robert H Jeffers
Robert H Jeffers
Clean how? Deck wash again?
Robert H Jeffers
Robert H Jeffers
What fo you recommend?
Soapy water,
Just power washing
Or chemicals?
Paul
Paul
I am going to use TWP Cedartone to stain new cedar rustic channel siding used to enclose a car port to make a garage. The entire house has 22 year old cedar channel siding that was last stained with TWP Cedartone about 5 years ago. Location –
My questions:
1) Do I need to wait, beyond the 10-14 days to allow the cedar to acclimate to the area, before staining?
2) Do I really need to stain all surfaces of the siding before installing?
3) How close of a color match do you think the new cedar will be to the existing cedar?
Thank you for your time; I appreciate it……….Paul
Paul
Paul
So I don’t have to wait if using the rough-sawn side of the channel siding, thereby not requiring any prep?
bernard beneteau
bernard beneteau
Stained our deck, (cedar), with twp 8 yrs ago. Stain on the top of deck is pretty much wore off. I’m assuming a deck wash would be adequate to restore it, however, railings and spindles still has some of the old stain on them. My question is, can I just use a deck wash on spindles and railings then re-stain on top of these areas using a twp stain. The stain has faded considerably. Long and short of it, can use twp on top of old twp assuming it is properly cleaned.
Ashley Dickson
Ashley Dickson
Just refinished deck with this product today. It has bee 2 hours and parts are still ‘shiny’ – how long should I give the stain to absorb and how to proceed wiping off the shiny areas?
Leona Arnold
Leona Arnold
Who sells this product in the Sudbury, Manitoulin Island, Ontario area?
Chris Pisano
Chris Pisano
Just finishing a new 1200 sq. ft. deck using bee grade redwood here in Sacramento California. Local lumber supplier recommends Penofin. We are looking for a clear finish to let the natural colors show thru. What’s the best product?
Chris Pisano
Chris Pisano
Reply to  Chris Pisano
As I mentioned I am just completing my Redwood deck installation. Thanks for the quick response. Great web site. Another question. Just this morning black mold blotches appeared. I am taking your advice on waiting 4+ months for the deck to season before applying finish. What should be done about the mold during this time?
Edith
Edith
Will this stain be good for extrem hot weather in the south
Karen G
Karen G
We are in the process of having a brand new cedar fence installed in Central Texas. Am I correct to assume that this product ( TWP Deck Stain) would also be the best for a new cedar fence to keep it looking great and protecting it?
Karen G
Karen G
The fence is rough. Should I stain it right away? The installer wants to stain it asap
Karen G
Karen G
David L Jordan
David L Jordan
My deck was finished with Rust-oleum RESTORE. Bad move. I have used an acrylic remover and got up most. However there are spots like cement that are not going to come up. I will have to use a solide stain, but which one and will it stay down over the old spots that did not come off??
Erick
Erick
Since TWP does not make a solid stain would you say Flood is the best performing solid stain for vertical siding? If not, which product do you recommend from testing results? Thanks!
Erick
Erick
Found it at local PPG store. Thanks. I applied TWP 1500 in 2015 on my all cedar home. Love the look and performance of stain. Just thinking of a change in color. Attached are photos of my home in TWP 1500 Rustic Oak. Awesome product!
Erick
Erick
Thanks, I agree. Was thinking semi-solid or solid would stretch out time between maintenance coats.
Anne
Anne
We have sanded our entire deck to rid it of colored stain that flaked every year. We are looking for a CLEAR protectant that will keep the wood looking clean and fresh like it does now after sanding. The deck faces South and we live in Southern Michigan. We have worked so hard to get that flakey Behr stain off. We want something with good performance.
Cindy
Cindy
Should you pressure wash a deck
Cindy
Cindy
What prepping products should I use? I am probably going to use either the TWP 100 or the Defty Extreme stain.
Diann
Diann
Where do you buy this deck stain?
127
