Hi, I’m Scott Paul, a seasoned exterior restoration contractor and business owner with over 30 years of expertise in exterior wood care. This article is one of my favorites because it breaks down all the different deck stains available, giving you the insights you need to make an informed choice. If you’re researching wood and decking stains, this is a must-read. Learn more about me here.
✅ What Are the Different Types of Deck Stains? (Quick Answer)
Deck stains are categorized by how much pigment they contain and how they interact with the wood. The four main types are:
- Clear Sealers – No pigment = no UV protection from graying
- Transparent stains – Minimal color, show full wood grain, lowest protection
- Semi-transparent stains – Add light color while allowing grain to show, best balance of protection and appearance
- Semi-solid stains – More pigment, better UV protection, partially hide wood grain
- Solid color stains – Fully opaque, maximum coverage but highest maintenance
- Oil-Based stains – Deeper penetration than water-based stains
- Water-based stains – Eco-Friendly and water cleanup
- Penetrating stains – Easier to maintain and prep
- Filming stains – Prone to peeling
✅ How to Choose the Right Deck Stain Type
- New Wood:
Transparent or semi-transparent stains allow the natural beauty of the wood to show. - Older Wood:
Semi-solid or solid stains help hide imperfections. - High UV Exposure:
Semi-solid or solid stains provide better sun protection. - Low Maintenance Preference:
Semi-transparent penetrating stains are the easiest to maintain over time.
Over the past 30+ years, I’ve worked with countless deck stain brands and types. Having tried them all, I’ve seen some excellent options—and others that didn’t hold up to their promises. While the landscape of deck stains has evolved due to changing manufacturers and stricter VOC laws, there are still top-quality options available in 2026. The key is knowing where to look.
Scott’s Steps To Understanding Deck Stains
- Watch my video that explains the different deck stains available
- Water-Based Deck Stains
- Oil-Based Deck Stains
- Deck Resurface Coatings
- Solid Color Stains
- Semi-Solid Deck Stains
- Semi-Transparent Deck Stain
- Transparent Deck Stains
- Clear Deck Sealers
- VOC Laws and what does that mean?
- Read Common Deck Stain Questions
- My Best Deck Stain Suggestions
-See below for full in-depth differences and descriptions for each.
| Stain Type | Appearance | Durability | Ease of Application | Maintenance | Best For |
| Clear / Wood Toner | Natural wood grain visible, slight tone | ★☆☆☆☆ (1 year) | ★★★★☆ | Easy recoating | Newer wood, cedar, or if you want a natural look |
| Semi-Transparent | Enhances wood grain with color | ★★★★☆ (2–3 years) | ★★★★☆ | Moderate – light cleaning | Most deck types needing color & UV protection |
| Semi-Solid | Less grain visibility, more pigment | ★★★★☆ (2–4 years) | ★★★☆☆ | May require stripping, but varies based on brand | Older decks or those needing more color |
| Solid (Opaque) | Paint-like look, hides grain | ★★★☆☆ (1–3 years) | ★★☆☆☆ | Difficult – sanding/stripping | Very old wood or previously painted/stained decks |
Notes:
- UV protection improves as opacity increases.
- Durability may vary depending on prep, wood condition, and climate.
- Darker or richer colors provide better UV protection with semi-transparent and semi-solid colors.
- Penetrating stains are easier to maintain as they have less chance of peeling and flaking.
Penetrating vs Film-Forming Deck Stains
- Penetrating stains (transparent & semi-transparent):
- Soak into wood
- Do not peel
- Easier maintenance
- Film-forming stains (solid):
- Sit on surface
- Can peel over time
- Require more prep
👉 This is a high-volume keyword gap most sites miss
Water-Based Wood Deck Stains
✅ Water-Based Deck Stains (Acrylic Coatings)
- Appearance: Natural to slightly enhanced color (varies by opacity)
- Wood Grain: Visible in transparent and semi-transparent versions
- Protection Level: Good UV resistance and water repellency
- Best For: Newer wood, maintenance coats, and areas with strict VOC regulations
- Maintenance: Moderate—easier than solid stains but not as forgiving as oil-based
👉 When to Use a Water-Based Deck Stain
- You want faster drying times and easier application
- You are working in an area with VOC restrictions
- The deck is newer or in good condition
- You want better UV color retention over time
⚠️ Downsides of Water-Based Stains
- Do not always penetrate as deeply as oil-based stains. *Restore-A-Deck Wood Stains and Defy Wood Stains are the only exceptions I have used successfully. They penetrate the best of all water-based stains, nearly as well as an oil.
- Can be less forgiving during application (lap marks possible)
- May require more prep for proper adhesion
- Slightly harder to recoat than penetrating oil stains
🔍 Water-Based vs Oil-Based Deck Stains
- Water-Based Stains:
- Faster drying and easier cleanup
- Better UV color retention
- Lower VOC content
- Oil-Based Stains:
- Deeper penetration into wood
- More natural aging and wear
🧠 Expert Tip
My Cons: They do not penetrate as well as an oil-based product can. They are slightly more complicated to apply as they dry quickly. They can be prone to peeling and wearing. *Restore-A-Deck Wood Stains and Defy Wood Stains are the only exceptions I have used successfully. They penetrate the best of all water-based stains, nearly as well as an oil.
Oil-based Wood Deck Stains
Oil Based DeckStain
Oil-based decking stains have been around for 30-40 years and have traditionally been what all stain manufacturers produce. Oil-based stains are typically made up of natural and synthetic oils. Many contain oils, such as Linseed Oil, Paraffin Oil, Tung Oil, Rosewood Oil, Etc.
✅ Oil-Based Deck Coatings (Penetrating Oil Stains)
- Appearance: Natural-looking finish that enhances wood grain
- Wood Grain: Visible (varies by transparency level)
- Protection Level: Excellent water resistance, moderate UV protection (with pigment)
- Best For: Most exterior wood decks, especially older or weathered wood
- Maintenance: Easy—can be cleaned and recoated without heavy stripping
👉 When to Use an Oil-Based Deck Coating
- You want a natural wood appearance with enhanced grain
- The deck is older or has been previously stained
- You prefer easy maintenance and recoating
- You want a coating that is less likely to peel
⚠️ Downsides of Oil-Based Coatings
- Slower drying times compared to water-based products
- Can attract mildew in humid or shaded areas
- VOC restrictions in some states may limit availability
- Requires proper application to avoid over-penetration or darkening
🔍 Oil-Based vs Water-Based Deck Coatings
- Oil-Based Coatings:
- Easier to maintain and reapply
- Rich, natural finish
- Water-Based Coatings:
- Faster drying
- Better UV resistance retention
- Lower VOC and easier cleanup
🧠 Expert Tip
✅ Deck Resurfacing Coatings (Restoration Coatings)
- Appearance: Thick, opaque coating that fills cracks and hides wood grain
- Wood Grain: Not visible
- Protection Level: High surface protection, seals and bridges damaged areas
- Best For: Severely weathered, splintered, or structurally sound but worn decks
- Maintenance: Moderate to high—can peel or wear unevenly over time
👉 When to Use a Deck Resurfacing Coating
- The deck is heavily weathered, splintering, or rough
- Previous coatings have failed and the surface is uneven
- You want to extend the life of the deck without replacing boards
- The wood is still structurally sound but cosmetically worn
⚠️ Downsides of Resurfacing Coatings
- Can peel or crack over time, especially in high-traffic areas
- Difficult to remove once applied
- Requires extensive prep before application
- Not suitable for newer or healthy wood
🔍 Resurfacing Coatings vs Solid Deck Stains
- Resurfacing Coatings:
Thicker, designed to fill cracks and restore damaged wood - Solid Stains:
🧠 Expert Tip
My Cons: So far, most of these product types have failed miserably. They peel after the first Winter and cannot be removed with a deck stain stripper. Sanding, scraping, or even the replacement of the wood is needed. There are many reviews on our site and other sites with angry consumers and product failures. Class action lawsuits are being filed against Rust-oleum Deck Restore and Olympic Rescue-It. Behr Deckover has the same issues as well. Only a couple of these products seem to work. Consider the Gulf Synthetics Deck Revive if you want one of these coatings. See this link for more info, articles, and reviews on these coatings: Deck Resurface Coatings.
✅ Solid Color Deck Stains
- Appearance: Opaque (paint-like finish)
- Wood Grain: Hidden
- Protection Level: Maximum UV protection
- Best For: Very old or damaged wood
- Maintenance: High—prone to peeling and requires more prep
My Cons: Films on top of the wood do not penetrate well, are susceptible to peeling, look like paint, and are more challenging to apply. They cannot be effectively removed with a deck stain stripper.
Solid Color Deck Stain Photos
Semi-Solid Wood Deck Stains
✅ Semi-Solid Deck Stains
- Appearance: Rich color, less grain visibility
- Wood Grain: Partially visible
- Protection Level: Higher UV protection
- Best For: Older decks with imperfections
- Maintenance: Moderate—can build up over time
A Semi-Solid Deck Stain will only show a small amount of wood grain as it contains a high amount of pigment. Only a limited number of manufacturers offer semi-solids, which can be both water-based and oil-based.
My Pros: They provide excellent UV protection. However, if they are water-based, they are prone to peeling. Look for oil-based semi-solid stains only.
Semi-Solid Deck Stain Photos
✅ Semi-Transparent Deck Stains
- Appearance: Adds color while enhancing grain
- Wood Grain: Clearly visible
- Protection Level: Moderate UV and water protection
- Best For: Most decks
- Maintenance: Easy to clean and recoat every 2–3 years
These are my favorites, but the primary key is that it must be a penetrating semi-transparent stain. Semi-transparent deck stains contain pigments that highlight the natural grain while sealing the surface. Both water and oil-based are available.
My Pros: They offer average to better-than-average UV protection, show natural grain, and have very good penetration. In most scenarios, they can be cleaned and re-coated easily and removed with a deck stain stripper.
My Cons: Most water-based versions perform poorly compared to the oils. Many states with Low VOC laws have limited quality oil-based stains available. You may need to buy online if you live in a low VOC area.
Transparent Wood Deck Stains
✅ Transparent Deck Stains
- Appearance: Clear or very light tint
- Wood Grain: Fully visible
- Protection Level: Low UV protection
- Best For: New wood, premium hardwoods (ipe, mahogany)
- Maintenance: Requires frequent reapplication (annually in many cases)
Transparent deck coatings look the most natural as they contain minimal pigment. The average life of a transparent decking stain is about one year. Mostly oil-based only are available.
My Cons: Below average UV protection. Typically, it needs to be re-coated annually.
Clear Wood Deck Finishes
Clear Deck Sealer
✅ Clear Wood Sealers (No Color Added)
- Appearance: Completely clear with no pigment
- Wood Grain: 100% visible (natural look)
- Protection Level: Low UV protection, good water repellency
- Best For: New wood, hardwoods (ipe, mahogany), and users wanting a natural, unstained look
- Maintenance: Requires frequent reapplication (often every 6–12 months)
👉 When to Use a Clear Wood Sealer
- You want a completely natural, “no-color” appearance
- You want the wood to gray
- The deck is covered or has minimal direct UV exposure
- You are okay with more frequent maintenance
⚠️ Downsides of Clear Sealers
- No UV protection
- Faster graying in full sun
- More frequent maintenance than pigmented stains
My Cons: In months, the wood will gray and oxidize from the sun’s UV.
Low VOC Stains and States
Currently, 20 States and Canada restrict Decking Stains and Coatings. These states require fewer Volatile Organic Compounds to be released into the air. The lower VOC changes mainly affect oil-based coatings. By lowering the amount of “solvents” that can evaporate into the ozone, you need to increase the amount of “solids.” This can cause issues with oil-based stains, which may have drying and curing problems. A few good oil-based stains are still allowed in the Low VOC States but are not as readily available at your local stores. You may need to go online to find them and have them shipped. Examples would be the TWP 1500 Series and Armstrong Clark Wood Stains.
Current Low VOC States:
What are Deck Stains, and Why Use Them?
Deck stains protect and preserve exterior wood. They offer UV protection, water repellency, mold and mildew resistance, and more. Deck coatings come in many types of opacity and bases. Based on their VOC laws, many deck stain brands can be restricted in certain states, cities, and countries, and unfortunately, walking into your local store may produce some of the worst options available.
Difference of Non-Drying Oil vs Drying Oil-Based Stains
Drying oils are “curing” oils. This means that they actually dry on top of or just below the surface. They will also help “seal” the wood. Non-drying oils are the opposite. They never dry or fully cure but dive deep into the wood to help condition the cells. Paraffin oil (not wax) is the most common.
I prefer penetrating semi-transparent products with all these different types of products as they allow the wood grain to show. They offer better-than-average UV protection and can be easier to reapply in the future. Penetration is better for oil-based versions than water-based versions. The exceptions for quality semi-transparent penetrating water-based stains would be the Defy Extreme Stains and the Restore-A-Deck Stains.
Want Free Help Choosing Your Deck Stain Type? Ask below in the comments!
See My List of the Best 8 Semi-transparent Deck Stains
What Other Tools Do I Need?
- Personal protective equipment (PPE), such as eye coverings and gloves.
- Deck cleaner and deck brightener (neutralizer) for prepping the surfaces.
- Hose for rinsing things and hand rags for cleaning up.
- Tarps or plastic for covering nearby vegetation.
- A hammer, drill, screws, and nails for any repairs.
- A bucket with stir sticks.
- A pole sander and hand sander with sandpaper (no finer than 80 grit).
- A pump-style or airless sprayer.
- A roller and roller tray, a stain (paint) pad with a pole, or a speed mop.
- Stain brushes with either natural or synthetic bristles.
How to Apply a Deck Stain
Measure your deck to best determine the proper amount of stain needed, and buy a little extra to ensure you don’t run out. Every product is slightly different, so I always read the manufacturer’s application instructions thoroughly. This helps confirm details such as whether to apply one or two coats, the dry time interval between the coats, and any safety recommendations.
2. Surface Preparation
You may choose to apply stain with a brush, pad, roller, or sprayer. Avoid pump sprayers and stain pads for thicker or solid stains. Begin applying stain to vertical surfaces followed by floors and staircases. Apply stain to a single board at a time completely from end to end while limiting overlap marks.
After the application, allow 20 to 30 minutes for the stain to completely soak into the wood. Wipe any remaining, unabsorbed stain away to avoid blotches.
Remember the importance of checking the weather forecast before starting for any chances of rain in the next 24 hours and have tarps or plastic on hand to cover the deck—just in case.
I have an old deck and I am not sure of the wood type and what stain was used previously. I did a pressure wash cleaning and it looks like this now. I am in Connecticut and what kind of stain is better for this. Also do I need to sand it
You need to strip and then brighten this for prep down to the bare wood: https://www.deckstainhelp.com/product/restore-a-deck-stripper-brightener-kit/
Once that is done, you can use a penetrating stain for the best results.
I am trying to restore a deck that has been neglected over the years. Attached is a photo where I used RAD Stripper but not the brightener yet. There are some areas that the stain did not release so I’m going to try the booster next as well. Can the experts tell me what type of wood this is? Should I sand it after brightening?
It is a hardwood deck, and it looks like you removed most or all of the old stain. You are mistaken for the dark areas to be old stain when it is the wood grain itself. The stripper raises the pH balance of the wood, darkening it. Brightening neutralizes this and lightens the wood. No matter what, your wood type is going to be reddish brown since it is a hardwood.
What would you recommend for an older pool deck-I honestly don’t know much about the wood. I have already power washed.
Do you have a picture you can add in the comments?
What is the best product for restoring a 12 yr old composite deck?
See here: https://www.deckstainhelp.com/staining-composite-decks/
Hi Scott, I appreciate all your work you’ve put into this site – it’s been super helpful. My deck is 25+ years old, cedar, and it hasn’t been stained in over 10 years. It is south facing in Northern IL. I don’t know what stain was last used, but there are currently no signs of it anywhere on the deck boards. After reading almost every article on here, I’m leaning toward a semi-solid stain (not sure on a good color with bluish-gray siding). My plan is to do a light powerwash, then a cleaner/brightener rather than stripper/brightener. Should I use a belt sander on the whole deck at some point in this process? Do these deck boards seem beyond saving? I’ve replaced some bad ones, but for the most part everything is still solid. Thanks for any tips.
Clean and brighten for prep while pressure washing. No need for the stripper. You may need to sand some splinters when down. Semi-solids would a great choice for this older deck.
We are building a deck in central Florida with pressure treated pine. How long should we allow the wood to weather, assuming no big storms? Which stain would be best for our semi tropical climate? And do we need to seal it too?
See here about new wood:
You do not and cannot apply a sealer over the top of a deck stain. No need as deck stains are sealers as well.
My contractor wants me to purchase a rubber type stain (wood deck around swimming pool)
I see texerized – is that the same? How do I confirm that the stain I purchase will be correct ?
I have never heard of a rubberized deck stain.
I have a large deck and this summer I noticed the paint peeling off. I believe this deck was installed 10 years ago but I don’t know if it was stained at the time (it was there when I moved).This is in Perth, Ontario, so cold snowy winters. I called a company to refinish the deck and replace rotten woods. They powerwashed, replaced some boards, flipped other boards up side down, sanded, and are about to paint. They were about to apply a “Behr Premium DeckOver” paint, but I noticed its reviews were pretty bad, that it peels off in not time. I was hoping for something that I don’t need to maintain that often; my main concern is not necessarily the looks of it, but to keep it in good shape and that it lasts a long time with the least amount of maintenance possible. This work wasn’t cheap and I’m not looking forward to doing it for a long time.The picture shows how it looks now; there’s some leftover paint from how it was before, the lighter bards are new pieces, and the darker ones are “cleaned” or flipped and sanded. What kind of paint would you recommend for my case?
You want a solid color deck stain. Not paint or any Behr products. See here:
I live in CT and have been using Ready Seal which I discovered about 5 years ago to stain my wood railings. It doesn’t last very long though. I had to redo it after two years. I also stumbled upon TWP stain as well applied to my front stairs which seems to last longer (no pics of that). After 2 years these railings below I sprayed with Jobmax solution housewash to kill the black algae and mold, rinsed then reapplied when they dried and they looked good. I tried that this year and the solution didn’t do anything. So after research i used Defy wood cleaner and wood brightener. The cleaner is basically a stripper? Because it removed all the old stain. It turned the wood and dirt into a jelly like consistency after scrubbing with a med/hard bristle brush. It cleaned everything down to the bare wood. I mixed it according to the instructions, 3/4 cup powder to 1 gallon of warm water. Then used the brightener immediately after and the wood looks like fresh cut new again.
My question is, is there an easier way to do this? I just want to remove the light dirt and brighten the starting to gray spots. I don’t want to to this entire scrub/strip process every two years.
I also am switching over from Ready Seal to TWP in hopes it will last longer. Can I use it over Ready Seal with a light sanding or do I need to strip completely?
You will have to strip and brighten if switching to TWP. Only use a deck cleaner if you plan on recoating. They are not designed to just clean off dirt. There is no easy way to just clean dirt off a deck stain without having some potential removal of the deck stain coating.
So what’s the difference between a stripper and the Defy wood cleaner I used? It basically stripped the old finish off it seems. As a side note on vertical surfaces TWP seems to last a LONG time and about 3 years on horizontal surfaces which is about double the time of Ready Seal. I’m switching over to TWP as I run out of Ready Seal. It’s a superior product.
Different chemicals in each product between a stripper and a cleaner. Cleaners can remove old coatings if that old coating is deteriorated.
TWP is much better than Ready Seal when it comes to UV protection
I live in southwestern Pa.
Have a two story PT deck. I have just replaced all the decking boards on the upper deck with KD treated lumber. I have started to do the same on the lower deck underneath. Because of the size of the decks I would like to use a product that will last so I’m not working on these decks yearly. The decks face southeast so they receive full sun, rain , snow through out the year. We had some rot on the lower deck where it was not covered by the upper deck. Not sure if I can use an oil product on the lower deck due to the humid weather we have here in south western Pa and being close to the ground / dont want mold or mildew to rot the deck. Any suggestion are welcome-
Wait until spring. Clean and brighten the new wood. Strip and brighten the old wood that has old stain on it. Use a penetrating stain after:
Hi. Thanks for all the info. Really helpful as I begin a project. Going to put in new deck boards, either cedar or PT. The large deck is completely exposed, all day in the sun, rain, snow in 4 seasons. Do you have a suggestion for semi transparent variety in these conditions? Would transparent hold up? Contractor is going to apply stain to old current framing that is staying. Should this be done in a different stain? Thanks!
Use semi-transparent for all. These are the best options: https://www.deckstainhelp.com/best-semi-transparent-deck-stain-reviews/
What is the semi transparent color used in above picture, that best stain 2024. Or if you don’t which one I am referring to, the first three photos under semi transparent?
That is IPE wood. You cannot get regular pine or cedar wood to look like those pics. The stain used is Armstrong Clark in one of their 3 hardwood colors.
Recently moved into a house with a neglected deck. Don’t believe it is cedar but maybe some kind of spruce. Is it beyond saving or can we sand and get something like twp 1500 on it?
You can save this without issues. Can you send a close up of the stain on the floors? Trying to see if a solid stain or semi-transparent. Need to know to determine prep and what stain type to use.
This is the stain the old home owners had
Hey Scott, I dont know why my phone won’t let me reply, but the stain is Behr premium semi transparent waterproofing stain and sealer from 4 years ago
Please send a picture of a close up of the stain on the floor, not the bucket. Behr lies about their opacity with their stains and many times it looks like a solid stain, not semi-transparent.
Here you go
Use the Restore A Deck Stain stripper with both additives and pressure washing to remove it:
Sand if needed to remove stubborn spots. Brightener after.
Once prepped, use a penetrating semi-transparent stain:
Thompson’s water sealer and Flood penetrating wood finish have been recommended for restoring my deck. Yellow pine, no coating left, well cleaned back to wood. Which of those or which other preserving finish would you reccommend? Thank you
Neither, very poor or useless products. You can use the search bar to find reviews on the site for both. Best to use one of the brands in our article. https://www.deckstainhelp.com/the-5-best-deck-stain-reviews-and-ratings/
Do you have any experience, or know, about the Sun Frog deck products. They’re designed for the Pacific Northwest? I’ve used it in the past and wonder how it’s holding up.
Sorry but nothing on our end with these products.
pictures – wood is wet from power washing, not quite that shiny…
Good job on prep. Hopefully you did not over sand. See for tips: https://www.deckstainhelp.com/why-sanding-a-deck-can-be-an-issue/
What about Benjamin Moore Woodluxe Water based semi-trans? It purports to be a ‘premium’ stain and has ‘advanced’ penetrating formula that older water-based stains did not. I just spent the last 3 weekends stripping, cleaning and power washing and then sanding (drum sander and then hand belt + oribital sanders) my PTSWYP deck to remove years old stain to get it to a decent bare wood surface and am agonizing to determine which is best option – stain, or just seal, water based or oil, etc. I have been waffling back and forth between oil and water and am now leaning towards a premium water based stain as long as it provides good penetration to minimize flaking and have all the pros of water based
Benjamin Moore has never made a quality wood or deck stain. They try but keep failing. I would stay away from their brands. There are only 2 water based stains that I have seen actually penetrate fully. Defy Extreme and Restore-A-Deck Stains.
Thanks for the sanding information, I had not come across that before. I had already went through 4 pads @ 80grit and 2 pads @100 grit supplied with the drum sander I rented. Now going back over with my hand belt sander using 36grit to tackle the worst of the pits and ridges I made from power washing, and 2nd over with 80. Next will be brightener (have already stripped and washed/neutralized before sanding.)
I’m waffling back over to oil based (over water) after reading this your blog, but still with a color stain (natural cedar tone). I like the idea that oil based seems to be superior to water based and I like the idea of it having a sheen (will probably go semi gloss or gloss). I’m thinking high VOC should not be too problematic since it’s an outdoor deck. I have not seen many options in the stores near me for different OB stain brands, mostly big box having behr and BM and Rust-Oleum.
What’s the general opinion about oil based tinted stain versus a clear oil based sealer only?
You cannot have a shine for a deck stain, that leads to peeling and makes removal when it fails very difficult.
Clear sealers will gray in a matter of months: https://www.deckstainhelp.com/will-a-clear-sealer-prevent-graying-on-deck/
Thanks again for the tip, based on this I think we will try to get the TWP 1500 semi-trans as we are in NE PA. Waiting for a window of dry and sunny days (that I can also etch out free time to do it!) – looking forward to not having to strip and sand again!
TWP makes great stains. We have been using them for 30 years.
I have applied two coats of TWP 1500 to raw wood floor and now I would like to apply something that gives it a slight SHEEN. Could you recommend a product that might do this (not Marine Spar Varnish because Im afraid that will flake and peel)?? Thank you
You cannot do this. You cannot top coat over a deck stain and you cannot add a shiny coating to any exterior flooring. This will lead to product failure and peeling. It will also become a huge pain to fix by heavy power sanding.
Ok. Thank you . Would it add aything to put a third coat over it?
No. Adding to much stain means it cannot penetrate fully and that leads to premature failure. It is not supposed to have a shine.
Ok. Thank you so much
Hi, I have a 16 year old cedar deck. It gets morning sun, no mold or mildew. Last October I washed it with oxiclean, sanded and stained with Cabot semi-solid. The stain did not last the winter. I had used it in the past but never get more than 1 year of good results. I live in Maine. What do you recommend? Thank you
You have two options. Heavy stripping and sanding down to the bare wood so you can use a proper penetrating semi-transparent stain:
or prep and recoat for a solid stain:
Thank you. I will go with the second option and solid stain. Do you think the RAD coastal gray will blend/cover any stain that is still intact after the prep or should I stay with the Cabot and go to solid instead of semi-solid?
The RAD solid stain will cover it but you will need the 2 coats.
