Types of Deck Stains in 2026: Explained 4.8/5 (808)
This post was updated on April 7, 2026
Hi, I’m Scott Paul, a seasoned exterior restoration contractor and business owner with over 30 years of expertise in exterior wood care. This article is one of my favorites because it breaks down all the different deck stains available, giving you the insights you need to make an informed choice. If you’re researching wood and decking stains, this is a must-read. Learn more about me here.
✅ What Are the Different Types of Deck Stains? (Quick Answer)
Deck stains are categorized by how much pigment they contain and how they interact with the wood. The four main types are:
      • Clear Sealers – No pigment = no UV protection from graying
      • Transparent stains – Minimal color, show full wood grain, lowest protection
      • Semi-transparent stains – Add light color while allowing grain to show, best balance of protection and appearance
      • Semi-solid stains – More pigment, better UV protection, partially hide wood grain
      • Solid color stains – Fully opaque, maximum coverage but highest maintenance
      • Oil-Based stains – Deeper penetration than water-based stains
      • Water-based stains – Eco-Friendly and water cleanup
      • Penetrating stains – Easier to maintain and prep
      • Filming stains – Prone to peeling
✅ How to Choose the Right Deck Stain Type
  • New Wood:
    Transparent or semi-transparent stains allow the natural beauty of the wood to show.
  • Older Wood:
    Semi-solid or solid stains help hide imperfections.
  • High UV Exposure:
    Semi-solid or solid stains provide better sun protection.
  • Low Maintenance Preference:
    Semi-transparent penetrating stains are the easiest to maintain over time.
Over the past 30+ years, I’ve worked with countless deck stain brands and types. Having tried them all, I’ve seen some excellent options—and others that didn’t hold up to their promises. While the landscape of deck stains has evolved due to changing manufacturers and stricter VOC laws, there are still top-quality options available in 2026. The key is knowing where to look.
-See below for full in-depth differences and descriptions for each.
Stain Type Appearance Durability Ease of Application Maintenance Best For
Clear / Wood Toner Natural wood grain visible, slight tone ★☆☆☆☆ (1 year) ★★★★☆ Easy recoating Newer wood, cedar, or if you want a natural look
Semi-Transparent Enhances wood grain with color ★★★★☆ (2–3 years) ★★★★☆ Moderate – light cleaning Most deck types needing color & UV protection
Semi-Solid Less grain visibility, more pigment ★★★★☆ (2–4 years) ★★★☆☆ May require stripping, but varies based on brand Older decks or those needing more color
Solid (Opaque) Paint-like look, hides grain ★★★☆☆ (1–3 years) ★★☆☆☆ Difficult – sanding/stripping Very old wood or previously painted/stained decks
Notes:
  • UV protection improves as opacity increases.
  • Durability may vary depending on prep, wood condition, and climate.
  • Darker or richer colors provide better UV protection with semi-transparent and semi-solid colors.
  • Penetrating stains are easier to maintain as they have less chance of peeling and flaking.
Penetrating vs Film-Forming Deck Stains
  • Penetrating stains (transparent & semi-transparent):
    • Soak into wood
    • Do not peel
    • Easier maintenance
  • Film-forming stains (solid):
    • Sit on surface
    • Can peel over time
    • Require more prep
👉 This is a high-volume keyword gap most sites miss
Water-Based Wood Deck Stains
✅ Water-Based Deck Stains (Acrylic Coatings)
  • Appearance: Natural to slightly enhanced color (varies by opacity)
  • Wood Grain: Visible in transparent and semi-transparent versions
  • Protection Level: Good UV resistance and water repellency
  • Best For: Newer wood, maintenance coats, and areas with strict VOC regulations
  • Maintenance: Moderate—easier than solid stains but not as forgiving as oil-based
👉 When to Use a Water-Based Deck Stain
  • You want faster drying times and easier application
  • You are working in an area with VOC restrictions
  • The deck is newer or in good condition
  • You want better UV color retention over time
⚠️ Downsides of Water-Based Stains
  • Do not always penetrate as deeply as oil-based stains. *Restore-A-Deck Wood Stains and Defy Wood Stains are the only exceptions I have used successfully. They penetrate the best of all water-based stains, nearly as well as an oil.
  • Can be less forgiving during application (lap marks possible)
  • May require more prep for proper adhesion
  • Slightly harder to recoat than penetrating oil stains
🔍 Water-Based vs Oil-Based Deck Stains
  • Water-Based Stains:
    • Faster drying and easier cleanup
    • Better UV color retention
    • Lower VOC content
  • Oil-Based Stains:
    • Deeper penetration into wood
    • More natural aging and wear
🧠 Expert Tip
My Cons: They do not penetrate as well as an oil-based product can. They are slightly more complicated to apply as they dry quickly. They can be prone to peeling and wearing. *Restore-A-Deck Wood Stains and Defy Wood Stains are the only exceptions I have used successfully. They penetrate the best of all water-based stains, nearly as well as an oil.
Oil-based Wood Deck Stains
Oil Based DeckStain
Oil Based DeckStain
Oil-based decking stains have been around for 30-40 years and have traditionally been what all stain manufacturers produce. Oil-based stains are typically made up of natural and synthetic oils. Many contain oils, such as Linseed Oil, Paraffin Oil, Tung Oil, Rosewood Oil, Etc.
✅ Oil-Based Deck Coatings (Penetrating Oil Stains)
  • Appearance: Natural-looking finish that enhances wood grain
  • Wood Grain: Visible (varies by transparency level)
  • Protection Level: Excellent water resistance, moderate UV protection (with pigment)
  • Best For: Most exterior wood decks, especially older or weathered wood
  • Maintenance: Easy—can be cleaned and recoated without heavy stripping
👉 When to Use an Oil-Based Deck Coating
  • You want a natural wood appearance with enhanced grain
  • The deck is older or has been previously stained
  • You prefer easy maintenance and recoating
  • You want a coating that is less likely to peel
⚠️ Downsides of Oil-Based Coatings
  • Slower drying times compared to water-based products
  • Can attract mildew in humid or shaded areas
  • VOC restrictions in some states may limit availability
  • Requires proper application to avoid over-penetration or darkening
🔍 Oil-Based vs Water-Based Deck Coatings
  • Oil-Based Coatings:
    • Easier to maintain and reapply
    • Rich, natural finish
  • Water-Based Coatings:
    • Faster drying
    • Better UV resistance retention
    • Lower VOC and easier cleanup
🧠 Expert Tip
Deck Resurface Coatings
✅ Deck Resurfacing Coatings (Restoration Coatings)
  • Appearance: Thick, opaque coating that fills cracks and hides wood grain
  • Wood Grain: Not visible
  • Protection Level: High surface protection, seals and bridges damaged areas
  • Best For: Severely weathered, splintered, or structurally sound but worn decks
  • Maintenance: Moderate to high—can peel or wear unevenly over time
👉 When to Use a Deck Resurfacing Coating
  • The deck is heavily weathered, splintering, or rough
  • Previous coatings have failed and the surface is uneven
  • You want to extend the life of the deck without replacing boards
  • The wood is still structurally sound but cosmetically worn
⚠️ Downsides of Resurfacing Coatings
  • Can peel or crack over time, especially in high-traffic areas
  • Difficult to remove once applied
  • Requires extensive prep before application
  • Not suitable for newer or healthy wood
🔍 Resurfacing Coatings vs Solid Deck Stains
  • Resurfacing Coatings:
    Thicker, designed to fill cracks and restore damaged wood
  • Solid Stains:
🧠 Expert Tip
My Cons: So far, most of these product types have failed miserably. They peel after the first Winter and cannot be removed with a deck stain stripper. Sanding, scraping, or even the replacement of the wood is needed. There are many reviews on our site and other sites with angry consumers and product failures. Class action lawsuits are being filed against Rust-oleum Deck Restore and Olympic Rescue-It. Behr Deckover has the same issues as well. Only a couple of these products seem to work. Consider the Gulf Synthetics Deck Revive if you want one of these coatings. See this link for more info, articles, and reviews on these coatings: Deck Resurface Coatings.
✅ Solid Color Deck Stains
  • Appearance: Opaque (paint-like finish)
  • Wood Grain: Hidden
  • Protection Level: Maximum UV protection
  • Best For: Very old or damaged wood
  • Maintenance: High—prone to peeling and requires more prep
My Cons: Films on top of the wood do not penetrate well, are susceptible to peeling, look like paint, and are more challenging to apply. They cannot be effectively removed with a deck stain stripper.
$69.99
Solid Color Deck Stain Photos
Semi-Solid Wood Deck Stains
✅ Semi-Solid Deck Stains
  • Appearance: Rich color, less grain visibility
  • Wood Grain: Partially visible
  • Protection Level: Higher UV protection
  • Best For: Older decks with imperfections
  • Maintenance: Moderate—can build up over time
A Semi-Solid Deck Stain will only show a small amount of wood grain as it contains a high amount of pigment. Only a limited number of manufacturers offer semi-solids, which can be both water-based and oil-based.
My Pros: They provide excellent UV protection. However, if they are water-based, they are prone to peeling. Look for oil-based semi-solid stains only.
Semi-Solid Deck Stain Photos
✅ Semi-Transparent Deck Stains
  • Appearance: Adds color while enhancing grain
  • Wood Grain: Clearly visible
  • Protection Level: Moderate UV and water protection
  • Best For: Most decks
  • Maintenance: Easy to clean and recoat every 2–3 years
These are my favorites, but the primary key is that it must be a penetrating semi-transparent stain. Semi-transparent deck stains contain pigments that highlight the natural grain while sealing the surface. Both water and oil-based are available.
My Pros: They offer average to better-than-average UV protection, show natural grain, and have very good penetration. In most scenarios, they can be cleaned and re-coated easily and removed with a deck stain stripper.
My Cons: Most water-based versions perform poorly compared to the oils. Many states with Low VOC laws have limited quality oil-based stains available. You may need to buy online if you live in a low VOC area.
Transparent Wood Deck Stains
✅ Transparent Deck Stains
  • Appearance: Clear or very light tint
  • Wood Grain: Fully visible
  • Protection Level: Low UV protection
  • Best For: New wood, premium hardwoods (ipe, mahogany)
  • Maintenance: Requires frequent reapplication (annually in many cases)
Transparent deck coatings look the most natural as they contain minimal pigment. The average life of a transparent decking stain is about one year. Mostly oil-based only are available.
My Cons: Below average UV protection. Typically, it needs to be re-coated annually.
Transparent Deck Stain Colors
Clear Wood Deck Finishes
Clear Deck Sealer
Clear Deck Sealer
✅ Clear Wood Sealers (No Color Added)
  • Appearance: Completely clear with no pigment
  • Wood Grain: 100% visible (natural look)
  • Protection Level: Low UV protection, good water repellency
  • Best For: New wood, hardwoods (ipe, mahogany), and users wanting a natural, unstained look
  • Maintenance: Requires frequent reapplication (often every 6–12 months)
👉 When to Use a Clear Wood Sealer
  • You want a completely natural, “no-color” appearance
  • You want the wood to gray
  • The deck is covered or has minimal direct UV exposure
  • You are okay with more frequent maintenance
⚠️ Downsides of Clear Sealers
  • No UV protection
  • Faster graying in full sun
  • More frequent maintenance than pigmented stains
My Cons: In months, the wood will gray and oxidize from the sun’s UV.
Low VOC Stains and States
Currently, 20 States and Canada restrict Decking Stains and Coatings. These states require fewer Volatile Organic Compounds to be released into the air. The lower VOC changes mainly affect oil-based coatings. By lowering the amount of “solvents” that can evaporate into the ozone, you need to increase the amount of “solids.” This can cause issues with oil-based stains, which may have drying and curing problems. A few good oil-based stains are still allowed in the Low VOC States but are not as readily available at your local stores. You may need to go online to find them and have them shipped. Examples would be the TWP 1500 Series and Armstrong Clark Wood Stains.
Current Low VOC States:
LOW VOC States Deck Stains
What are Deck Stains, and Why Use Them?
Deck stains protect and preserve exterior wood. They offer UV protection, water repellency, mold and mildew resistance, and more. Deck coatings come in many types of opacity and bases. Based on their VOC laws, many deck stain brands can be restricted in certain states, cities, and countries, and unfortunately, walking into your local store may produce some of the worst options available.
Difference of Non-Drying Oil vs Drying Oil-Based Stains
Drying oils are “curing” oils. This means that they actually dry on top of or just below the surface. They will also help “seal” the wood. Non-drying oils are the opposite. They never dry or fully cure but dive deep into the wood to help condition the cells. Paraffin oil (not wax) is the most common.
I prefer penetrating semi-transparent products with all these different types of products as they allow the wood grain to show. They offer better-than-average UV protection and can be easier to reapply in the future. Penetration is better for oil-based versions than water-based versions. The exceptions for quality semi-transparent penetrating water-based stains would be the Defy Extreme Stains and the Restore-A-Deck Stains.
Want Free Help Choosing Your Deck Stain Type? Ask below in the comments!
See My List of the Best 8 Semi-transparent Deck Stains
What Other Tools Do I Need?
  • Personal protective equipment (PPE), such as eye coverings and gloves.
  • Deck cleaner and deck brightener (neutralizer) for prepping the surfaces.
  • Hose for rinsing things and hand rags for cleaning up.
  • Tarps or plastic for covering nearby vegetation.
  • A hammer, drill, screws, and nails for any repairs.
  • A bucket with stir sticks.
  • A pole sander and hand sander with sandpaper (no finer than 80 grit).
  • A pump-style or airless sprayer.
  • A roller and roller tray, a stain (paint) pad with a pole, or a speed mop.
  • Stain brushes with either natural or synthetic bristles.
How to Apply a Deck Stain
Measure your deck to best determine the proper amount of stain needed, and buy a little extra to ensure you don’t run out. Every product is slightly different, so I always read the manufacturer’s application instructions thoroughly. This helps confirm details such as whether to apply one or two coats, the dry time interval between the coats, and any safety recommendations.
2. Surface Preparation
You may choose to apply stain with a brush, pad, roller, or sprayer. Avoid pump sprayers and stain pads for thicker or solid stains. Begin applying stain to vertical surfaces followed by floors and staircases. Apply stain to a single board at a time completely from end to end while limiting overlap marks.
After the application, allow 20 to 30 minutes for the stain to completely soak into the wood. Wipe any remaining, unabsorbed stain away to avoid blotches.
Remember the importance of checking the weather forecast before starting for any chances of rain in the next 24 hours and have tarps or plastic on hand to cover the deck—just in case.
Top Oil-
Based Stain
Top Water-Based Stain
Top Solid Color Stain
Easiest to Apply Stain
1.4K Comments
Sheryl
Sheryl
13 years ago
Just sanded off peeling solid color oil based stain and want to apply oil semi-transparent. However not all the solid color came off, and water still beads somewhat on those areas. Look is rustic and nice, but will there be peeling problems if I use semi-transparent now? Should I try chemical stripper, cleaning, brightening, and power washing first? (I really don't want to use solid again!)
Chron
Chron
13 years ago
I have a PT deck, never stained. Some mildew spots are present. Should I wash then use brightener then sand? Do I need to wash and brighten if I sand?
Danny
Danny
13 years ago
Just powerwashed our 10-year-old Western Pennsylvania deck. We have used semi-transparent waterproofing stain on it in the past and the wood is definitely due for a new coat of something. We want to waterproof and stain with our application. Are all deck "stains" considered to be waterproofing-type agents such as Thompson's Water Seal? Can you please suggest brands that do such?
Josh
Josh
13 years ago
I just recently built a new deck out of construction common redwood and sealed it using Thompsons Transparent Sealer. 3 days after that I my dog got into a little bit of mud and had tracked it on the deck. I have washed it off but there are still prints that will not seem to come out. What do I need to do to resolve this issue?
Jayson
Jayson
13 years ago
I build a deck from pressure treated wood last summer. need to stain it this summer. I'm in Toronto, Ontario. Deck is only 6 inches off the ground. Shaded by a huge tree that drops ripe cherries all summer. I need something to prevent mold growth, protect from cherries, and mask the new cherry stains that will be added daily in the summer. What do you recommend?
Shelly
Shelly
13 years ago
Hi- We are looking to stain our 6 y/o composite deck. Can you recommend the best product? It has not mildewed, only faded.
Terry
Terry
12 years ago
Reply to  Shelly
I asked the same question to a Trex Composite Decking customer service person. Here is the reply. We are considering a solid color product: _10-14-11_PAINTING TECHNICAL BULLETIN_Can standard Trex composite decking and railing be painted?_Yes, you can paint or stain Trex decking or railing to achieve a custom color, but it is not necessary for protection. Paints and stains that adhere well to wood will work as well or better with Trex products. Trex decking that has been faded can be painted or stained at any time, even years after it has been installed. However you should use paint or stain that is made for a walking surface. Note Trex Transcend® decking cannot be painted or stained.*_What types of paints and stains can I use?_Most paints or stains that you would apply to wood can be applied to Trex standard composite decking (this does not include Trex Escapes® decking). The following companies have evaluated Trex decking and suggested these coatings:_Paint Manufacturer_Tech Support Phone Number_Suggested Coating_Behr_800-854-0133_Deck Premium Plus Exterior Solid Wood Deck Stain (no primer needed)_Sherwin Williams_800-474-3794_S-W Deckscapes ext. acrylic Deck Stain A15-150 Series_S-W Woodscapes ext. acrylic Deck Stain A15 Series
Darwin
Darwin
13 years ago
I have a six year old deck that we just power washed last week. The previous owners used Flood CWF-UV Clear Wood Finish, Cedar Tone. I think it has been several years since the finish was last applied. On some areas of the deck, longer than that it looks like. I have about 8 gallons of this finish that were left with the house when we purchased it. Should I go back with the same material or can I use a different material, such as a Defy or Clark Armstrong product? I'm not sure if the Flood finish is a particularly highly rated, long lasting product.
13 years ago
Our deck was cleaned and sanded and stained with oil based semi transparent Olympic stain last year. Can I now do over with a similar water based stain to darken the colour?
Location is Toronto.
Diane
Diane
13 years ago
I just had my deck power washed and sanded. I am not sure what was on the deck previously; oil or stain. Can I use an oil base.
13 years ago
We have a first generation Correct Deck built in 2005. Sadly, this was not the product as described. The deck has faded terribly. We live in the NE and the deck faces east with almost constant exposure to sunlight. We did have a shipment of a few pieces of 2nd generation, so there is a stripe on the edge of the deck edge. That didn't fade so it's noticeable.
The deck surface has held up. We sweep it regularly and use Corte Clean with good results against the mold, but it does come back yearly. It is not a problem to clean it yearly to help with mold growth.
Our concern is what can we do to bring back the original mahogany color? We don't want to seal in the mold nor do we want to paint the surface. Is there any type of stain that would be close to the original color, or even a neutral/natural color? When it gets wet from rain, it looks great… Then it dries. We would like to restore the color as close as possible, but haven't found anyone with this experience.
13 years ago
Correct Deck is no longer in business. Company was bought by GAF and then became Duralife Siesta. That product is still manufactured as far as I can tell. To date, I have tried to contact the company without success.
I have done research online and have seen where homeowners with similar fading Correct Deck problems have stained their deck. I am unsure of results a few years later. We are so frustrated with how the deck currently looks considering the cost of a composite deck.
I was just looking to see if anyone had any experience with this issue. I will continue to contact the company for any help they might be able to give.
DML
DML
13 years ago
We have a deck that was built in stages at different times with different pressure treated woods and different stains. Most of the wood was in decent shape but to make it consistent, it was recommended that we use a solid color decks stain. It covered all the different stains and woods and improved the look of the deck, but I wish it would look a little more like wood grain. If I wiped a darker semi transparent over the solid, would it highlight the wood grain, like a faux finish?
Leslie
Leslie
13 years ago
Some further information on our deck for recommendations: The deck is redwood, and the Sikkens only lasted a few years before looking old and worn. Also the Sikkens had an uneven finish afterwards.
Leslie
Leslie
13 years ago
We are planning on refinishing our deck next month which gets intense sun and weather. We live at 7500′ elev. in the foothills outside of Denver, CO. The last time we refinished in 2002, we sanded the whole deck and used Sikkens Cetol SRD. The finish is now mostly completely gone, worn and faded, but never peeled. We plan on sanding again this time. Do you have recommendations on prep and what finish to use this time?
Marie Fletcher
Marie Fletcher
13 years ago
I put in a new cedar deck last spring and used Thompsons advance water sealer on it in the fall. It has turned grey and looks terrible after investing so much money in it. Does the water sealer have to be stripped before using TWP 1500 or can I use restore a deck cleaner and brightener and then put TWP on? We live in MA. Deck gets full sun and lots of snow.
FAkin
FAkin
13 years ago
Because of neglect my 20 year old pressure-treated deck in the southeast U.S. was in bad shape. I flipped the deck boards retaining about 60%. The rest I replaced with new boards. Had to fill the nail holes on the flipped boards with wood filler. My question is: Now how do I finish the entire deck so it looks consistent? A transparent stain won't work because the wood filler shows thru.
Howard Rice
Howard Rice
13 years ago
I have a new mahogany deck in s New Jersey, installed 3 mo ago and it has a porch roof open on 2 sides. What should I use to give me a natural reddish finish and what cleaner should I use?
Brenda Greer
Brenda Greer
13 years ago
I have large new deck built last Sept and am wanting ot water seal it and stain it now. It will have lots of sunlight. I want to keep the natural grain of the wood but protect from mold and turing gray. What is the best product to do this?
thanks from NC
Paulo
Paulo
13 years ago
My Deck was treated originally with an oil based deck oil, two years ago a water based oil was applied ontop of oil based by accident by the decorator. It looked ok and still does but my dilema now is do I apply an oil or water based product. Removing the product would be imposible.
Karen Tornese
Karen Tornese
13 years ago
I have a Trex 5 year old saddle colored although washed out deck completely surrounding a oval pool,every year lots of black mold. I clean with Olympic deck, wash it then seal it with composite sealer. This deck always gets mold back in 6 to 7 weeks,any suggestions.
Gail
Gail
13 years ago
I need to stain and protect the T1-11 on our new barn. The siding is untreated. Would love to have something semi-transparent that will be easy to work now and when repainting. We are in coastal Georgia.
Melody
Melody
13 years ago
I have a deck that I stained 2 years ago with a HD brand redwood stain. The deck surrounds a pool. It is time to re-stain this year, but I was hoping to get some better results. Can I use an oil based stain over my previous water based? Also, I don't want it to be slippery when wet. Is there stain with grit in it? I own a pressure washer to clean the wood. I am a do it myself-er so, I'd appreciate the steps needed to get a good result. Also, if I don't want to buy the sub-par stains from Lowes or HD, where do I go? I live in Boise.
Bill Taylor
Bill Taylor
13 years ago
I am wanting to use Cabot's Semi solid oil based neutral base stain on my wood shingle roof to help preserve it. I do not want to change it to any particular color, I am just wanting to help preserve and waterproff it. My question is do I have to tint the neutral base or can I use it as is?
Keith
Keith
13 years ago
A restaurant owner who has decking outside and some covered inside wants to clean and stain it. Very high traffic area, grease spills, drink spills and some chair marks on the floor. Previously stained with Sikkens SRD Natural. What is the best stain to use for the high traffic, grease and drink spills. Wants color to be in the chestnut brown, dark cedar or amber color areas. Would be happy with 1 year wear from the product. Does not want a solid. Thinks they will be to slippery when wet. Any help appreciated.
wgbe
wgbe
13 years ago
We have a 25 year old wood deck that, until the last staining, had always been stained with an oil based semi solid. The house is in NY state, a low VOC state. The new regs were in force the last time we stained, and we had to go to a solid stain — probably water based. Within 2 months, we had a terrible mildew problem which we had never had before.
We are about to rebuild the entire deck and I would like to make sure that we explore all of our options in terms of materials so that we minimize the chances of having the same problem with mildew after all that time and money. Are there decking materials that we should research (other than the plastic-looking composites that municipalities use for pedestrian ramps)? Would Epe resist mildewing and do you stain that?
wgbe
wgbe
13 years ago
Thanks for the advice. We appreciate it.
If we decide to not replace the entire deck, just the boards that obviously are deteriorating, how do you handle the remaining boards (that will probably mildew come the spring) along side the new ones, which based on what I have seen elsewhere on this site will need to weather? Do you clean the old boards and not restain but leave the new ones to weather for 4 months and then restain all?
Thanks again.
wgbe
wgbe
13 years ago
Thanks. Is 4 months the correct amount of time to weather? Also, if spring is bad for staining due to pollen potentially getting into the stain, should the staining be done in the summer, say August, after the pollen and before the leaves and seeds fall?
wgbe
wgbe
13 years ago
We have a 25 year old deck in NY state that, until 3 years ago, had been stained with an oil based semi solid. Then the VOC regs came into effect and we had to use a water based solid stain for our last staining. It was a nightmare. Within 2 months, we had severe mildewing, something we had never had before.
We are about to rebuild the deck and would like to explore our materials options with an eye toward something that will last and will resist mildew. Can you suggest different woods or composites (other than the plastic-looking stuff that municipalities use for pedestrian ramps) that we should research? Epe?
Thank you. Great site!
wing nuts
wing nuts
13 years ago
I'm finding black stains around screw holes
keepingitreal
keepingitreal
12 years ago
The rust may also be from the type of fasteners used. If the deck is constructed of cedar, it's highly recommended that "Maze" nails / screws or another type of stainless steel or double dipped type of hardware is used. Cedar contains a high degree of Tannins which can interacted with metal, causing rusting / "bleeding". A cheap fastener's coating can easily become compromised when it's struck by a hammer or when a screw gun's driver tip continues to rotate in the screw's head, after it's been set thereby allowing the tannins to interact with the exposed metal.
Cathy C
Cathy C
Did you use the exterior silver screws or the black interior wood screws? It sounds like you used regular wood screws
Hank
Hank
13 years ago
I have a deck with oil based sealer on it, 2 years old. Cheap brand of sealer was used. It is in good condition but will need another coat next year. Can I cover it with a better brand of oil or water based sealer?
Margo
Margo
13 years ago
I have a deck that has never been sealed or stained, I live in Tampa. Which brand should i use? Also, I wanted a solid stain because I want the deck to have a pigment, but I fear it will be peel and be a hassle later. Should I stick with a semi-transparent stain, if so, how often will I need to reapply?
John Zagorski, PhD
John Zagorski, PhD
13 years ago
Correction to "oil based deck stains, pros": ALL oil molecules are much bigger than water molecules. Not even close. So says my PhD in biochemistry.
Judy
Judy
13 years ago
I used Lowe's Olympic semi-transparent cedartone deck stain.and the color of the deck now is too orange. Is it possible to give it another coat of the same product in a darker color now or must I wait.
Kathy
Kathy
13 years ago
What would happen if I put an oil-based semi-transparent stain/sealer on a deck that was previously treated with 'Deckscape' semi-transparent water-based stain/sealer? I don't care anymore how the deck looks. I just want it to be waterproofed before winter and I don't want to strip it because of the adverse environmental effects.
13 years ago
I have a 15 year old deck that had transparent oil and sealant put on it about 5 years ago. The deck is in pretty good shape however my wife would like a color stain showing some of the wood features through it. The deck is in a semi-shady area. I'm having a few professional deck maintenance people give me quotes, but I need your feedback.
13 years ago
Charlotte, North Carolina
sindy
sindy
13 years ago
I just added a deck to my house. been waiting for the rain to stop to stain it. will 2-3 days of drying time be enough and do i have to sand it 1st (it's pt) Help please and thank you
jas
jas
12 years ago
We put a coat of Behr semi-transparent on to the wood of our few months old deck boards. It peeled off a few months later, like nail polish comes off, and Behr wouldn't take any responsibility. They said it was because we hadn't used their deck cleaner before we put the product on. Don't use Behr!!
Rgg
Rgg
13 years ago
I live in utah and just bought a new trailer I will use to haul 4 wheelers and use as a utility trailer. It has an untreated wood deck We're not low voc. which brand and product do you recommend for a Semi transparent stain. Are the ones at homedepot- lowes ok or not good quality? Great article!
Dan in Cal
Dan in Cal
13 years ago
Can I thin TWP 1500 series?
I used TWP 1516 ("Rustic") on a new Doug fir deck with nice results. Then I did a test sample on the western red cedar fences (after cleaining them), to complete the yard, but it is of course much darker. Too dark I think. Can I thin with paint thinner to get a lighter shade? (I realize all manufacturers say "do not thin," but I thinned a Cabot water-based stain with great aesthetic results, and I'm not much concerned with longevity.)
Thanks very much.
Dan in Cal.
Dan
Dan
13 years ago
In Maryland the VOC law applies; therefore a tinted water based stain was used two years ago. We want to keep the color. Should we use a clear stain, or tinted, after cleaning the deck surface?
Dan
jill
jill
13 years ago
I have a new deck and we stained with white water base stain. Can we put clear sealer on top? Oil or water base. It is showing every foot print and don't wash off. any suggestions?
Ashley
Ashley
13 years ago
Thanks for this site! I am needing to stain two WRC Adirondack chairs since I don't want greying. My local paint store (not big box) recommended and I would like to use the TWP 1500 series but I don't need a lot. I can't get the TWP in a can smaller than a gallon. Will it keep for several years or should I look for something else in a quart? I'm in west central Missouri (4 full seasons) and the chairs are shaded by the house most of the day on a patio.
Richard
Richard
13 years ago
Have a 25 year old deck sarting to weather . the cabot semi solid stain has worn off in some place and water isn't beading my wife want's a darker colot. Can I use a water based staind / do I need to strip it and bleach it orjust clean it and restain. I come from northern NJ
13 years ago
can I use a Cabot acrylic solid stain over Cabot oil solid stain?
Rick
Rick
13 years ago
Reply to  Susan
I'm not a professional, just a consumer with 40 years of maintaining my own WRC decks but I can't recommend Cabot Acrylic stains period. Whether over new wood or re-coating over themselves. They just don't adhere well, and break down quickly and unevenly. There is a lot of good info on this site. I came here to see if there was something new out there but it seems good ole semi-transparent oil based is still the way to go.
Trisha
Trisha
13 years ago
We live just north of Toronto, Ontario. Our PTP deck is 2 years old. It faces north and most of it gets sun. There is some mold/mildew in a small area shaded by a fence. The deck has not been treated with anything as yet and is graying. It will need to be cleaned and brightened. We are looking for a product that will require the least amount of work when it needs to be re-applied in the future. Provided that TWP 1500 can be shipped to Canada (or I will go to Buffalo), should we be applying oil based TWP 1500 or water based Defy Extreme Stain? Is there another product that would be better? Your website is very informative and easy to use. Thank you very much.
Lisa
Lisa
13 years ago
I recently used Restore A Deck Stripper and Brightener and then applied Defy Extreme Cedar Tone Stain to redo my 22-year old deck that had been poorly maintained and had peeling, cracking stain left from a previous application. I am very pleased with the results. At first I did not like the Cedar Tone stain color but, now that it's done and the stain has dried, I really like look.
PainterGuy
PainterGuy
13 years ago
How do i get certain brands of solid oil based stains in a low VOC state? and why can i still buy oil primers and other certain brands of solid oil based stains in all the stores? Also do you think the standards will become so tight they will do away with all oil based products? I have been painting for 16 years and have noticed a steep decline in the effectiveness of all decking products. The labels used to say to apply every 2-5 years, now they say to apply yearly or "seasonally" depending on wear and exposure. Should i just start to suggest to my customers that they go with permanent solutions like composite decking (i.e. TREX, etc.) to save me bigger headaches in decking products later down the road? Any thoughts on the matter?
Gloria
Gloria
13 years ago
We added on to our wood deck. The original deck had an oil based paint. We need to repaint the entire deck now. Can we put a semi-transparent oil stain on the whole deck?
Valerie
Valerie
12 years ago
Hoping this might provide some valuable info. Are you sure that it is paint, and not solid stain? We have (we discovered when we stripped it) a 25 year old redwood deck. It was stained and re-stained with solid barn red stain many times. Several years ago we decided to re-do it (we get several feet of snow every winter), and when we pulled up a board and saw on the reverse that it was redwood, I decided to use a semi-transparent stain so the wonderful colors would show through. We stripped it with Behr's #64 stripper, sanded problem areas, and stained it. We used a pretty light color and it was beautiful for years. When I went in to purchase more stain in order to re-do it, I was told that they no longer make the "Deck Plus" and was sold the Behr 100% Acrylic stain in the same color. Nope! The product is, to put it lightly, awful. It has lifted terribly, and when I complained at the retailer, they agreed with me, to be honest. I will go with an oil based stain on my new redwood deck, and next summer when I work up the energy to go through the whole process again, I will strip the existing acrylic stained deck and start from scratch.
Patti
Patti
Reply to  Valerie
to Valerie: we had the same exact problem as you with the Behr Deck Plus /100% acrylic stain. We are in the process of sanding the whole peeling mess off the deck. Behr reimbursed me for the stain, but of course the hours of labor were on me. I think I will do the same thing; trying an oil based stain. Have you done it? Has it worked out for you stripping the deck?
Nel
Nel
13 years ago
Nel
I've been trying to find a sight that has the TWP 1500 stain colors. Can you help me please. I know that there are 10 different colors but can't even find one. Also can seem to find a dealer that I could go to. I live in western Ontario so
crossing the border would not be a problem.
Thanks for you assistance.-
Jeanneane
Jeanneane
13 years ago
Can I put oil-based solid stain over acrylic solid stain? Do I need to use a deck cleaner with power washing?
Dennis Holt
Dennis Holt
13 years ago
Thank you and I will post some pictures. I'm finding black stains around screw holes, will Oxallic acid remove this or what do you Rx? As I'm planning the cedar I'm trying to at 1 3/8 inches or better, but some are closer to 11/4 inches and of course I'm going to blend them in or arrange them so that they are smooth and not a hazard. What do you consider the minimum safe thickness over a 24" span with a minimum lengthe of 4'? Thanks again
Dennis Holt
Dennis Holt
13 years ago
I have a large Western Red Cedar deck exposed to the Western sun for at least one half of the time. The deck is 25 years old but it was constructed with CLEAR WRC and I would like to preserve its beauty. I don't know how it has been chemically abused in the past so I have decided to remove all the boards, plane and join them and then reconstruct the deck. First ?, Does newly planed 25 year old cedar react the same as new cedar? 2nd? We are located in the high desert of Central Oregon with 300 days of sunshine but rain and snow too. Temps can fluctuate 40+/- degrees in 24 hours. Do you have a recommendation for deck treatment. Thanks!
joe allen
joe allen
13 years ago
can i apply a 2nd coat olympic maximum stain sealant
Val
Val
13 years ago
Can I apply an oil-based semi-transparent stain/sealer to a deck that was previously treated with 'Deckscape semi-transparent water-based stain/sealer?
1 2 3 12
1.4K
