This post was updated on April 7, 2026
Hi, I’m Scott Paul, a seasoned exterior restoration contractor and business owner with over 30 years of expertise in exterior wood care. This article is one of my favorites because it breaks down all the different deck stains available, giving you the insights you need to make an informed choice. If you’re researching wood and decking stains, this is a must-read. Learn more about me here.
✅ What Are the Different Types of Deck Stains? (Quick Answer)
Deck stains are categorized by how much pigment they contain and how they interact with the wood. The four main types are:
- Clear Sealers – No pigment = no UV protection from graying
- Transparent stains – Minimal color, show full wood grain, lowest protection
- Semi-transparent stains – Add light color while allowing grain to show, best balance of protection and appearance
- Semi-solid stains – More pigment, better UV protection, partially hide wood grain
- Solid color stains – Fully opaque, maximum coverage but highest maintenance
- Oil-Based stains – Deeper penetration than water-based stains
- Water-based stains – Eco-Friendly and water cleanup
- Penetrating stains – Easier to maintain and prep
- Filming stains – Prone to peeling
✅ How to Choose the Right Deck Stain Type
- New Wood:
Transparent or semi-transparent stains allow the natural beauty of the wood to show. - Older Wood:
Semi-solid or solid stains help hide imperfections. - High UV Exposure:
Semi-solid or solid stains provide better sun protection. - Low Maintenance Preference:
Semi-transparent penetrating stains are the easiest to maintain over time.
Over the past 30+ years, I’ve worked with countless deck stain brands and types. Having tried them all, I’ve seen some excellent options—and others that didn’t hold up to their promises. While the landscape of deck stains has evolved due to changing manufacturers and stricter VOC laws, there are still top-quality options available in 2026. The key is knowing where to look.
Scott’s Steps To Understanding Deck Stains
- Watch my video that explains the different deck stains available
- Water-Based Deck Stains
- Oil-Based Deck Stains
- Deck Resurface Coatings
- Solid Color Stains
- Semi-Solid Deck Stains
- Semi-Transparent Deck Stain
- Transparent Deck Stains
- Clear Deck Sealers
- VOC Laws and what does that mean?
- Read Common Deck Stain Questions
- My Best Deck Stain Suggestions
-See below for full in-depth differences and descriptions for each.
| Stain Type | Appearance | Durability | Ease of Application | Maintenance | Best For |
| Clear / Wood Toner | Natural wood grain visible, slight tone | ★☆☆☆☆ (1 year) | ★★★★☆ | Easy recoating | Newer wood, cedar, or if you want a natural look |
| Semi-Transparent | Enhances wood grain with color | ★★★★☆ (2–3 years) | ★★★★☆ | Moderate – light cleaning | Most deck types needing color & UV protection |
| Semi-Solid | Less grain visibility, more pigment | ★★★★☆ (2–4 years) | ★★★☆☆ | May require stripping, but varies based on brand | Older decks or those needing more color |
| Solid (Opaque) | Paint-like look, hides grain | ★★★☆☆ (1–3 years) | ★★☆☆☆ | Difficult – sanding/stripping | Very old wood or previously painted/stained decks |
Notes:
- UV protection improves as opacity increases.
- Durability may vary depending on prep, wood condition, and climate.
- Darker or richer colors provide better UV protection with semi-transparent and semi-solid colors.
- Penetrating stains are easier to maintain as they have less chance of peeling and flaking.
Penetrating vs Film-Forming Deck Stains
- Penetrating stains (transparent & semi-transparent):
- Soak into wood
- Do not peel
- Easier maintenance
- Film-forming stains (solid):
- Sit on surface
- Can peel over time
- Require more prep
👉 This is a high-volume keyword gap most sites miss
Water-Based Wood Deck Stains
✅ Water-Based Deck Stains (Acrylic Coatings)
- Appearance: Natural to slightly enhanced color (varies by opacity)
- Wood Grain: Visible in transparent and semi-transparent versions
- Protection Level: Good UV resistance and water repellency
- Best For: Newer wood, maintenance coats, and areas with strict VOC regulations
- Maintenance: Moderate—easier than solid stains but not as forgiving as oil-based
👉 When to Use a Water-Based Deck Stain
- You want faster drying times and easier application
- You are working in an area with VOC restrictions
- The deck is newer or in good condition
- You want better UV color retention over time
⚠️ Downsides of Water-Based Stains
- Do not always penetrate as deeply as oil-based stains. *Restore-A-Deck Wood Stains and Defy Wood Stains are the only exceptions I have used successfully. They penetrate the best of all water-based stains, nearly as well as an oil.
- Can be less forgiving during application (lap marks possible)
- May require more prep for proper adhesion
- Slightly harder to recoat than penetrating oil stains
🔍 Water-Based vs Oil-Based Deck Stains
- Water-Based Stains:
- Faster drying and easier cleanup
- Better UV color retention
- Lower VOC content
- Oil-Based Stains:
- Deeper penetration into wood
- More natural aging and wear
🧠 Expert Tip
My Cons: They do not penetrate as well as an oil-based product can. They are slightly more complicated to apply as they dry quickly. They can be prone to peeling and wearing. *Restore-A-Deck Wood Stains and Defy Wood Stains are the only exceptions I have used successfully. They penetrate the best of all water-based stains, nearly as well as an oil.
Oil-based Wood Deck Stains
Oil Based DeckStain
Oil-based decking stains have been around for 30-40 years and have traditionally been what all stain manufacturers produce. Oil-based stains are typically made up of natural and synthetic oils. Many contain oils, such as Linseed Oil, Paraffin Oil, Tung Oil, Rosewood Oil, Etc.
✅ Oil-Based Deck Coatings (Penetrating Oil Stains)
- Appearance: Natural-looking finish that enhances wood grain
- Wood Grain: Visible (varies by transparency level)
- Protection Level: Excellent water resistance, moderate UV protection (with pigment)
- Best For: Most exterior wood decks, especially older or weathered wood
- Maintenance: Easy—can be cleaned and recoated without heavy stripping
👉 When to Use an Oil-Based Deck Coating
- You want a natural wood appearance with enhanced grain
- The deck is older or has been previously stained
- You prefer easy maintenance and recoating
- You want a coating that is less likely to peel
⚠️ Downsides of Oil-Based Coatings
- Slower drying times compared to water-based products
- Can attract mildew in humid or shaded areas
- VOC restrictions in some states may limit availability
- Requires proper application to avoid over-penetration or darkening
🔍 Oil-Based vs Water-Based Deck Coatings
- Oil-Based Coatings:
- Easier to maintain and reapply
- Rich, natural finish
- Water-Based Coatings:
- Faster drying
- Better UV resistance retention
- Lower VOC and easier cleanup
🧠 Expert Tip
✅ Deck Resurfacing Coatings (Restoration Coatings)
- Appearance: Thick, opaque coating that fills cracks and hides wood grain
- Wood Grain: Not visible
- Protection Level: High surface protection, seals and bridges damaged areas
- Best For: Severely weathered, splintered, or structurally sound but worn decks
- Maintenance: Moderate to high—can peel or wear unevenly over time
👉 When to Use a Deck Resurfacing Coating
- The deck is heavily weathered, splintering, or rough
- Previous coatings have failed and the surface is uneven
- You want to extend the life of the deck without replacing boards
- The wood is still structurally sound but cosmetically worn
⚠️ Downsides of Resurfacing Coatings
- Can peel or crack over time, especially in high-traffic areas
- Difficult to remove once applied
- Requires extensive prep before application
- Not suitable for newer or healthy wood
🔍 Resurfacing Coatings vs Solid Deck Stains
- Resurfacing Coatings:
Thicker, designed to fill cracks and restore damaged wood - Solid Stains:
🧠 Expert Tip
My Cons: So far, most of these product types have failed miserably. They peel after the first Winter and cannot be removed with a deck stain stripper. Sanding, scraping, or even the replacement of the wood is needed. There are many reviews on our site and other sites with angry consumers and product failures. Class action lawsuits are being filed against Rust-oleum Deck Restore and Olympic Rescue-It. Behr Deckover has the same issues as well. Only a couple of these products seem to work. Consider the Gulf Synthetics Deck Revive if you want one of these coatings. See this link for more info, articles, and reviews on these coatings: Deck Resurface Coatings.
✅ Solid Color Deck Stains
- Appearance: Opaque (paint-like finish)
- Wood Grain: Hidden
- Protection Level: Maximum UV protection
- Best For: Very old or damaged wood
- Maintenance: High—prone to peeling and requires more prep
My Cons: Films on top of the wood do not penetrate well, are susceptible to peeling, look like paint, and are more challenging to apply. They cannot be effectively removed with a deck stain stripper.
Solid Color Deck Stain Photos
Semi-Solid Wood Deck Stains
✅ Semi-Solid Deck Stains
- Appearance: Rich color, less grain visibility
- Wood Grain: Partially visible
- Protection Level: Higher UV protection
- Best For: Older decks with imperfections
- Maintenance: Moderate—can build up over time
A Semi-Solid Deck Stain will only show a small amount of wood grain as it contains a high amount of pigment. Only a limited number of manufacturers offer semi-solids, which can be both water-based and oil-based.
My Pros: They provide excellent UV protection. However, if they are water-based, they are prone to peeling. Look for oil-based semi-solid stains only.
Semi-Solid Deck Stain Photos
✅ Semi-Transparent Deck Stains
- Appearance: Adds color while enhancing grain
- Wood Grain: Clearly visible
- Protection Level: Moderate UV and water protection
- Best For: Most decks
- Maintenance: Easy to clean and recoat every 2–3 years
These are my favorites, but the primary key is that it must be a penetrating semi-transparent stain. Semi-transparent deck stains contain pigments that highlight the natural grain while sealing the surface. Both water and oil-based are available.
My Pros: They offer average to better-than-average UV protection, show natural grain, and have very good penetration. In most scenarios, they can be cleaned and re-coated easily and removed with a deck stain stripper.
My Cons: Most water-based versions perform poorly compared to the oils. Many states with Low VOC laws have limited quality oil-based stains available. You may need to buy online if you live in a low VOC area.
Transparent Wood Deck Stains
✅ Transparent Deck Stains
- Appearance: Clear or very light tint
- Wood Grain: Fully visible
- Protection Level: Low UV protection
- Best For: New wood, premium hardwoods (ipe, mahogany)
- Maintenance: Requires frequent reapplication (annually in many cases)
Transparent deck coatings look the most natural as they contain minimal pigment. The average life of a transparent decking stain is about one year. Mostly oil-based only are available.
My Cons: Below average UV protection. Typically, it needs to be re-coated annually.
Clear Wood Deck Finishes
Clear Deck Sealer
✅ Clear Wood Sealers (No Color Added)
- Appearance: Completely clear with no pigment
- Wood Grain: 100% visible (natural look)
- Protection Level: Low UV protection, good water repellency
- Best For: New wood, hardwoods (ipe, mahogany), and users wanting a natural, unstained look
- Maintenance: Requires frequent reapplication (often every 6–12 months)
👉 When to Use a Clear Wood Sealer
- You want a completely natural, “no-color” appearance
- You want the wood to gray
- The deck is covered or has minimal direct UV exposure
- You are okay with more frequent maintenance
⚠️ Downsides of Clear Sealers
- No UV protection
- Faster graying in full sun
- More frequent maintenance than pigmented stains
My Cons: In months, the wood will gray and oxidize from the sun’s UV.
Low VOC Stains and States
Currently, 20 States and Canada restrict Decking Stains and Coatings. These states require fewer Volatile Organic Compounds to be released into the air. The lower VOC changes mainly affect oil-based coatings. By lowering the amount of “solvents” that can evaporate into the ozone, you need to increase the amount of “solids.” This can cause issues with oil-based stains, which may have drying and curing problems. A few good oil-based stains are still allowed in the Low VOC States but are not as readily available at your local stores. You may need to go online to find them and have them shipped. Examples would be the TWP 1500 Series and Armstrong Clark Wood Stains.
Current Low VOC States:
What are Deck Stains, and Why Use Them?
Deck stains protect and preserve exterior wood. They offer UV protection, water repellency, mold and mildew resistance, and more. Deck coatings come in many types of opacity and bases. Based on their VOC laws, many deck stain brands can be restricted in certain states, cities, and countries, and unfortunately, walking into your local store may produce some of the worst options available.
Difference of Non-Drying Oil vs Drying Oil-Based Stains
Drying oils are “curing” oils. This means that they actually dry on top of or just below the surface. They will also help “seal” the wood. Non-drying oils are the opposite. They never dry or fully cure but dive deep into the wood to help condition the cells. Paraffin oil (not wax) is the most common.
I prefer penetrating semi-transparent products with all these different types of products as they allow the wood grain to show. They offer better-than-average UV protection and can be easier to reapply in the future. Penetration is better for oil-based versions than water-based versions. The exceptions for quality semi-transparent penetrating water-based stains would be the Defy Extreme Stains and the Restore-A-Deck Stains.
Want Free Help Choosing Your Deck Stain Type? Ask below in the comments!
See My List of the Best 8 Semi-transparent Deck Stains
What Other Tools Do I Need?
- Personal protective equipment (PPE), such as eye coverings and gloves.
- Deck cleaner and deck brightener (neutralizer) for prepping the surfaces.
- Hose for rinsing things and hand rags for cleaning up.
- Tarps or plastic for covering nearby vegetation.
- A hammer, drill, screws, and nails for any repairs.
- A bucket with stir sticks.
- A pole sander and hand sander with sandpaper (no finer than 80 grit).
- A pump-style or airless sprayer.
- A roller and roller tray, a stain (paint) pad with a pole, or a speed mop.
- Stain brushes with either natural or synthetic bristles.
How to Apply a Deck Stain
Measure your deck to best determine the proper amount of stain needed, and buy a little extra to ensure you don’t run out. Every product is slightly different, so I always read the manufacturer’s application instructions thoroughly. This helps confirm details such as whether to apply one or two coats, the dry time interval between the coats, and any safety recommendations.
2. Surface Preparation
You may choose to apply stain with a brush, pad, roller, or sprayer. Avoid pump sprayers and stain pads for thicker or solid stains. Begin applying stain to vertical surfaces followed by floors and staircases. Apply stain to a single board at a time completely from end to end while limiting overlap marks.
After the application, allow 20 to 30 minutes for the stain to completely soak into the wood. Wipe any remaining, unabsorbed stain away to avoid blotches.
Remember the importance of checking the weather forecast before starting for any chances of rain in the next 24 hours and have tarps or plastic on hand to cover the deck—just in case.
Hi there,
I need help with picking a colour.
I have a ten year old pt pine deck that I am looking to stain in a Cabot semi-solid as I liked the way their product held up on my pergola. I cleaned the deck about three weeks ago. It has never been treated. Now I m looking for a stain that doesn’t look orange. I did my pergola in semi solid Cordova brown but it came out almost black. What is a good warm brown that doesn’t look orangy
I am sorry but we do not use Cabot stains so not familar with their colors. Look for a medium brown color to avoid the orangy color.
What is the best deck stain for the harsh Canadian climate? I am hoping for something available in Canada (so I don’t have to pay a crazy amount in shipping) that doesn’t peel. If possible, one that doesn’t need to be reapplied annually. IF the US is my only option, what would you recommend?
Not sure if there are any good stains that you can buy locally in Canada. We do not live there it seems that most Canadians are having issues finding any quality one to buy at a local store. If buying from US, try TWP 200 or Armstrong Clark.
Hi, we’re just installing a new hardwood deck (red balau, a form or meranti). We stained a sample with Penofin deep penetrating oil for hardwoods (with rosewood oil) , which claims 99.9% protection against UV damage. It turned the wood a darker color than the unstained portion. Could you recommend a clear or semi-transparent oil based stain that would allow us to see more of the reddish color of the wood? Our painter told us that all penetrating oil based clear stains would turn the color of the wood darker.
If you want a reddish tint then you will need more of a hardwood stain with a red color. Clear (no tint) will not provide UV protection. Look at Armstrong Clark in Mahogany but it is pretty red in color.
Thanks for your advice. We’ve decided on the TWP 1500 series redwood stain. How may gallons do you estimate we will need? Our deck is 1000 square feet and we plan to stain both the top and bottom of the boards as well as the sides.
Hello, did you read the TWP direction son staining new wood with their products? They want you to install, wait 4-12 months, prep, and apply just 1 coat to the exposed wood only. Most stain brands do not want you to stain all sides and they also suggest new wood to naturally weather and be prepped before applying.
Thanks! I did read the directions, but I thought that waiting for 4-12 months and prepping referred to new “green” wood, as opposed to new kiln-dried wood, which I believe this wood is. It is a hardwood, similar to Ipe, but not as hard. Do the directions still apply to this kind of wood?
Thanks again,
You still have to wait about a month or two for Kiln dried and prep with a deck cleaner and a wood brightener to remove the mill glaze.
Thanks again. You’re advice has been invaluable! One last question: What is the best way to make sure that the sides of the deck boards are stained?
You could try a stain tool or brush that gets between the boards after install.
I live in Toronto, Canada and am having difficulty finding a credible stain for my deck. We applied Behr Sem-Transparent stain 2 years ago and had to totally sand it off this year as it was peeling terribly. Can you suggest the best product sold here to refinish my deck? It’s in high sunlight from early morning till late afternoon. I’d prefer to keep it as natural looking as possible but don’t want to be resanding again in another year. I’ve found your articles very helpful and hope you can help me outl
Not sure if there are any good product sold there in Canada since the laws were changed. Many have had to go to the states to get something good and is compliant for your VOC laws.
Thanks for your help though I sure wish you had said there is a place in Canada where we can obtain a good product. We will continue to search for it here.
I too live in the GTA. I used CIL cleaner and will wait a week to stainand seeker. I was thinking if a clean oil Behr or CIL? What are you using. I want a natural look.
Hi Susan. After much research and speaking with others who have had similar experiences, I’ve decided to go with Cabot Australian Oil finish since it was recommended by a good golfing friend who put it on her deck 12 years ago and it still looks reasonably good. I purchased it at Lowes and have great hopes. Whatever you do stay away from Behr.
DON’T use the Cabot Australian Timber Oil…. they’ve paid me to re-do my deck twice because my dogs footprints have been permanently etched in the finish. the stuff is HORRIBLE. I’n the process now of stripping and sanding the WHOLE two level deck for the third time…. stay AWAY
PS-I’m in Canada too
I built a cedar deck last fall, sealed it with CWF, and this spring it is badly stained from run off of water and I think some of the asphalt roofing residue. I plan on cleaning and power washing. What do you recommend to seal it so it won’t stain again? I am open to semi or solid stain. It is south facing. I live in CT. Thank you.
Hello, you will need to strip it off and then brighten. Try Armstrong Clark in a semi-trans or semi-solid.
can you use a oil base stain over a water base stain?
No. You will need to remove the water based stain first.
How do I remove the old Cabot semitransparent water base stain patches left after power-washing, in order to apply the TW semisolid oil base stain?
Is there a water based stain I should use? My deck is 21 years old, “builder quality” not in great shape, located in NoVA, shade in the morning, sun in the afternoon. The attached pictures are of the wet deck right after it was power-washed in the rain.
Please show a picture when dry as it hard to tell from these when wet.
What are the best shades to use when you texturize paint your deck if it is A very sunny deck to avoid it getting too hot ?
Lighter colors or tones will retain less heat.
I have leftover Defy Extreme stain from 2 years ago. is this product still good to apply to a small project, or should I expect this stain to fail early?
As long as it has not hardened or become “clumpy” it should still be okay to use.
What do you suggest is the best water based semi transparent deck/covered porch stain?
Defy Extreme is the best water based semi-transparent that we have used.
I have a 15 year old cedar deck from the house we purchased a few years ago. It faces south and gets full sun. It does not seem to have ever been sealed or stained. I have started noticing some of the boards are starting to crack, peel, a few have bowed. Trying to determine if it is worth the investment of time and money to clean/ sand / replace some boards and stain the deck at this point or just let the deck deteriorate to the point of replcamaent? I live 40 miles north of NYC.
You can get some life out of the deck as long as it has not rotted. Try Armstrong Clark Stains. Prep with a Restore A Deck kit.
Is it better to sand before or after prepping the boards with Restore A Deck?
Sand before if possible.
Should I use praemer before I use solid stains ? Also I have solid old stain in my deck .
Typically no but does depend on the solid stain brand you are using. Best to follow the directions of the solid stain brand you choose.
Sorry, TWP 100
We used TWO on a new deck 3 yrs ago. Proper waiting time and professional applied with 2 coats. Traffic areas have worn completely and whole deck has faded substantially. Recommendations for recoating?? Live in ME Alabama on a lake. Thanks
We would use the TWP again as nothing will last more than 2-3 years and it is easy to clean and reapply as needed.
I was in a hurry last year and stained my cedar raised garden beds with semi transparent TWP 1500 series without doing any prep work and the stain is beginning to fade. What steps do I need to take before applying another layer of stain?
Prep with their Gemini Restore Kit and apply another coat of the 1500.
Thank you. Would you recommend their 1500 or 100 series to be a better stain?
Best to use the same series. They both perform well.
I have a 2 year old pressure treated deck, never stained. Would like to use a semi transparent tinted stain. What are your recommendations?
Look at TWP stains or Armstrong Clark. Make sure and prep with a deck cleaner and wood brightener first.
What semi transparent oil based stain would you recommend for an older pressure treated wood deck, but one that has been maintained and is still in very good condition?
Want the wood grain to show through…….live in Pennsylvania
Armsrong Clark or TWP 1500. Prep is key though. Make sure any old coatings are removed first.
I have a 20 years old cedar deck that has been coated with solid deck stain (Cabot oil based). Throughout its life, the deck has been stripped (by pressure washing) and restained about every four to five years. The last time (about three years ago), it was done “in a hurry”, and there was very little, if any, prepping of the wood after the removal of the previous stain (again, by pressure washing). The stain started fading and peeling after one year. Now I am getting ready to do the job “right”. I was wondering if I can use one of the semi-transparent stains that you recommend here, knowing that the deck was previously finished with a solid stain. I am planning on removing the stain by pressure washing, then using one of your recommended cleaners and brighteners.
Thank you for your advice and input.
You will have to remove the solid stain 100% if you want to use a semi-transparent. Pressure washing alone will not remove a solid stain 100%. You will most likely need to sand to remove it completely.
I have a 12 year old deck made out of pressure treated materials from Home Depot. It has never been treated with any product. The Deck has suffered and is in rough shape. The lumber is very dry and a number of boards are significantly cracked on the surface.
I am thinking of removing each board, turning it over, and reinstalling it so what was the underside will then be the top surface. As I am doing this I will sand what will be the new top surface. I have done this to a couple of boards and it looks pretty good.
As I am doing all this work, I would like to treat the deck to protect it. Because I am sanding the surface, I am uncertain if I need to wait before application. If so, how long should I wait before treating the deck? Also, since it is freshly sanded, do I need to use a cleaner and/or brightener?
What product will protect the best? I would like to see as much woodgrain as possible and still have it protect. I would also like to have it easy to retreat in the future. From what I have read on this site, I am inclined to use TWP 100 (Cedartone 101 or Pecan 120), or Armstrong Clark (Cedar or Natural Oak)
Material: Pressure treated pine
Exposure: Full sun 60%, Shade 40%
Mildew/mold: Minor mold next to house where it is fully shaded
Prior treatment: It has never been treated with any stain at any other treatment
How often should it be reapplied ?
Thank You
After the sanding wait 1-2 months and clean and brighten the wood for the final prep. The stain will soak in better this way. Penetrating stains like the TWP or AC will make future reapplications easier. Either one would work for you. Reapply every 2 years is normal or as needed based on your weathering.
Thank you for your information. You are a great help.
We are doing something similar to what Keith is doing. Our deck was previously treated with latex solid stain and last year we had to begin the process of removing all the old stain due to extreme bubbling and peeling in the areas of that get a lot of sun exposure – which is the majority of the deck. We did some pressure washing and scraping by hand last year and were pretty overwhelmed by how long this was going to take. We came up with the idea of flipping the boards this year; but not all could be flipped because of the way they’re cut around rails, etc. On the boards that couldn’t be flipped, we used stain stripper and a pressure washer and finally sanded to remove any remaining stain. The boards that had been flipped didn’t really need much sanding. The boards that couldn’t be flipped obviously look older, but we’re hoping the new stain will make them look fairly uniform. We’d like to go with semi-transparent oil-based stain – but do you think we can get a uniform look with semi-transparent? My husband is in a hurry to get this project over with, so I’m going to have a hard time convincing him to wait 1-2 months after sanding (as you recommended to Keith) to start staining. Can you explain if and why we should wait? And finally, is Thompson’s Waterseal Waterproofer Plus Semi-transparent Stain a product we should consider?
Thompson’s has poor reviews and will most likely peel. If you do not wait a few months and prep correctly, the flipped boards will not blend with the sanded boards.
I live in Central Oklahoma and have a large, two level deck that was last finished with Cabot Solid Color Acrylic Deck Stain. A portion of the deck that is under roof is still in good shape, but much of the area exposed to the elements is peeling pretty badly. I have read articles that suggest that the best product to use is whatever was used last, which on some level makes sense to me. Is this a decent product or would you recommend a change? What steps should I take to prep before application? I just read on this website that strippers do not work well on solid color acrylics and I really don’t want to sand the whole thing, especially since a good portion of the deck is still in pretty good shape.
the easiest thing to do in your scenario is to prep by pressure washing to remove all the stain that is peeling. You will not remove all, so reapply another solid stain like Flood Solid Stains. Onother option would be the Deck Revive by Gulf synthetics.
What is the best to use for a NC very near the ocean deck that will show the wood, but hold up to the salt air and heat? Deck not a year old yet.
TWP 100 Series or Defy Extreme Stain.
I have a new deck built in December with pressure treated pine. I live in Gulf Shores, Alabama on the beach. What should I use to seal and protect the deck? Since the deck is less than three months old do I need a special product to clean it first? I want to preserve the look of the pine and do not like the look of wood that turns gray.
Please read this for advice on new decking, wait period, and prep: https://www.deckstainhelp.com/staining-a-new-deck…
For UV protection from graying, you will need a tinted semi-transparent stain like the Armstrong Clark or Defy Extreme.
I am redoing my deck and have a question. Only the deck boards and rails are new lumber. I am using the existing frame and posts. So my wood is 2 distinctively different shades. I want to be able to see some wood grain, but don't want to 2 different shades of would to stand out and be really noticeable. Should I use semi transparent or semi solid stain
A semi-solid will show some grain and will blend the newer and older wood better than a semi-trans.
* any recommendations please for a black oil based stain to be applied to a pine timber boundary fence. Don't want it to peel or require regular re-coating.
Thanks Steve
There are not any straight black penetrating oil based stains. Closest would be the Black Walnut color by TWP 1500 Series. Might work for you.
I live in Houston Texas and need to protect my deck, I have a large deck and about 1/2 of it is old and could use a deck restorer, but the reviews are horrendous. The other 1/2 of my deck is only 2 years old. It is very humid here and we have rainy seasons mixed with very dry seasons. I am thinking a semi-transparent stain, based on what I have read so far. Any suggestions?
Prep well first and try the TWP 100 Series or Defy Extreme Stain.
Our deck is made of Epay, a Brazilian hardwood. It's beautifully colored with grain naturally. We have 2 dogs who can often bring mud on the porch so we need something to heavily protect and provide a easy way to clean. Would rather have a stain that seals and waterproofs for easy rinsing.
What is the recommendation for this?
IPE, needs to be cleaned and reapplied annually. Look at the Armstrong Clark in Mahogany or Defy Hardwood in Light Walnut.
What is the best stain for me to use? I live in NJ and have a 6mo. old mahogany porch. It has never been sealed or stained. We have a new born baby, so we want to be careful with fumes. We would like a semi-transparent stain. Any help would be appreciated. Thank you.
Look at Defy Hardwood Stain for this.
As stated many times, the action word heard is 'confusion'. Repel water. Repelling water 'can be' dangerous as it becomes slippery and also freezes on deck 'floor'. So, do all stains, water and oil base, repel if you want to add color to your deck for your aesthetics goal? We have the cedar and a gallon of dark redwood linseed oil based. Tested one plank and boy does the water just sit there. What choice is there for such a beautiful strong semi-translucent color?
I still do not know what brand touse, after disaters with Benjamin Moore ARBORCOAT premium exterior classic oil fnish eetc. b;ah blah
Horrid masses of black stains largish like masses of hair and small but obviuous and hrrid on new fir decking.
WATER?
I was told NOT to put two coats!
Have spent hours qnd three days trying ro move horrid areas down to raw wood.
UNHAPPY me.
I just spent a couple of hours in a "Paint" store yesterday which resulted in my leaving empty handed and with more questions than I had originally had upon arrival at the store. My husband and myself had decided that we needed to consider our cost in a product to be an investment in our deck and our time when it comes time to restrain and resell our deck… Thank you for the full explanation of all of the products. Our paint store failed at this much of a breakdown of the components in stains.
I have a beautiful and very large driftwood that is mounted (via rods) onto a base. I do not want to change the color, but want to show the natural color and grain!!!!!!
As we are displaying this in the front of the house, I only want to seal the wood from water, the sun (FL living)and mildew.
We were thinking deck oil (willing to retreat) but don't know of a sealing oil product that repels water, protects against the sun and mildew.
PLEASE help with recommendation
Defy Extreme Clear.
I live in Cary, NC and thinking of getting my rear deck stained. The deck has been through all the temperature variations; low 30s to high 90s. It is exposed to sun all day; morning to afternoon. The deck is almost a year old (new construction). I am wondering when is a good time to get it stained? Can I get it stained in September or should I wait until next Spring (2017). Please guide.
S
Stain this Fall. Look at TWP or Defy Extreme.
I used the Olympic rescue it and like others it has peeled up. Between using deck cleaners and scrapping it off I've gotten most of it off the floor of my deck. Is there a known way to removing this product? Some of it is not coming up, almost like it actually adhered to the wood. Could I use another resurfacer over top of the stuff that won't come up?
You should remove all first or at least 95%. Sanding will be needed.
Just had a new multi level deck built using "Severe Weather Max Top Choice Prime" pressure treated pine. I live in Alabama and we have had a month of 90 degree plus temps. The decks are in full sun most of the day. My deck builder says it is ready to stain because it has been so hot but I have reservations. This brand says wait 2-3 months, it has some kind of water repellant added in the treatment process. I talked to the Armstrong Clark owner and he said Spring should be a good time. My questions are, 1. What is the safe time to wait to stain? 2. What is the best semi transparent stain for this deck, keeping in mind I want easy reapplication and protection for this beautiful home addition.
Wait the 3 months and clean and brighten for prep. AC is a good stain for this deck.
We just applied Olympic Elite Stain to the ceiling of a new outdoor T&G pine ceiling. Is there any issues after it dries to go back and add a spar urethane over it?
No need to do this and it could be an issue with adhering.
I just used old pressure treated lumber to build a deck and then new pressure treated lumber for a pergola to go on top. All has been pressure washed and cleaned with a deck cleaner. I live in WV. I built a cat tree in one corner of the pergola. Yesterday I began staining the cat tree with Behr semi-transparent Stonehenge gray wood protector…only the cat tree. Last night I noticed so many bad reviews that I am afraid to go ahead with the rest of the pergola and deck. What should I use?
Use a different and better stain. Best to read the reviews on this site and google. Behr is not a good product.
Can I stain my 15 year old deck with minwax wood finish penetrating stain (oil base) than seal it with a clear sealer?
No you cannot do that.
Question. Which of the TWP 1500 products do you consider semi-transparent? I want to use what is best for a redwood deck but want to maintain as much of the natural look as possible.Thanks
Gregg
All of their colors are considered semi-transparent.
is it ok to stain deck if rain is predicted next day?
Depends on the brand you are using. Best to ask the manufacturer.
I work as a professional painter , and it all depends on what type of stain you are using. Oil stain will take around a full day or two to completely dry, and will be water safe within 8-10 hours after applying. Where as water based takes less time around 12 hours to fully dry , and around 4 hours to be rain safe. And nontransperent stain is just a waster of money it will ruin your deck and peel in a year or so if you live up north.
I live in Milwaukee Wisconsin my deck stain is peeling all the time what is the best thing to use in this climate
Remove the peeling stain so it is down to the bare wood. Use a penetrating semi-transparent after. Try TWP or Armstrong clark.
I'm needing information because my deck is 22 yrs old and never stained or sealed. Last year 7 treated boards were replaced . Recently deck was power washed and wow what a change. Tomorrow it will be sanded. I live in Wisconsin and deck faces east so sun and shade. Do I need to apply a wood brightener? A friend says oil base is better because you see the grain of wood. Deck is 14×16 and wondering to go with oil base or semi transparent oil base. What is TWP? I see Olympic Elite at Lowes or Cabot at Menards . Can you help? Also worried new boards from last year to match .
Yes you should lightly clean and brighten after the sanding. Use the TWP. It is a penetrating semi-transparent oil based stain.
thank you but TWP is only available by ordering and I have no idea how much I would need-deck is 14×16 with railings and wood spindles, steps-would Cabot oil or semi transparent oil work as well?
Cabot is not as good.
TWP can only get online and wondering how much I need for a 14×16 deck with railings and spindles or can I use Cabot oil or semi-transparent oil based stain that is available at Menards.
You are not going to find a quality stain at Lowes or Menards. I would contact TWP for some help.
want to use brightner-sunny today then next 3 days storms and 3 days look ok and then storms so if we wait til after 3 days of storms then do brightner and wait 48 hrs and stain but day after stain predicted storms
I’ve bought it at Sherwin-Williams.
We live in Minnesota with snow, freezing, and rain. Need to do a deck restore on the floor to fill cracks. Does anyone have a suggestion on the best oil based restore stain to use in harsh elements?
Hello, Originally I used watered based stain on my deck most of it has peeled, I sanded most all to the wood, on another of my deck since there was no peeling I sanded lightly, now I want to try and use semi transparent oil based stain on my deck, hoping if might be better than water? Would I ever be able to go back to water based stain?
You cannot applied an oi based stain over the water based stain. You should remove all of the old stain first.
We have a cedar deck and it has a few coats of Thompson's Water Seal on it from a few years ago. What type of sealer can we use without sanding down the deck and just using a proper wash on it? Something that will last a long time in hot summers, cold snowy winters.
Thanks so much
You have to remove the Thompsons to ensure proper adhesion. Use the Restore A Deck stain stripper with your pressure washing. Neutralize with the Restore A Deck Brightener. One removed, try Defy Extreme or TWP stains.
In full Florida sunlight, does dark stain contribute to warping more or less than light stain. Dark colors attract heat so does dark stain contribute to warping more than lighter stain colors?
No darker stains do not contribute to warping or not.
Excellent information. We have a mahoghany deck that we made some pretty miserable decisions with from the start, now we have completely sanded the deck and do not want to make the same mistake twice. This article pointed us in the right direction and for that we thank you.
Ready to apply TWP100 to my stripped deck. What is the lowest temperature I can apply the stain?
50 degrees.
Thanks for the great advice and thorough articles
Info cleared up a lot of my confusion as to what to put on my deck. Thanks!
Very good info. Thanks.
I loved the article. I live in South Carolina and we have a 20 yr old wooden fence that we just repaired. What brand and stain type do you recommend?
