I am Scott Paul, a leading exterior restoration contractor and business owner with over 30 years of experience in exterior wood. My IPE Wood and Deck stain reviews and help tips are based on my history as a wood restoration contractor and actual hands-on testing, all designed to present you with the top product choices. See here for more info about me.
IPE Deck Staining Tips
DeckStainHelp.com has become the Internet’s go-to site for all things related to wood deck restoration. As with all types of wood surfaces, correctly prepping your IPE wood before staining it with a penetrating exotic hardwood stain is crucial. Feel free to leave a comment with pictures and any questions below!
💡 TIP: These IPE staining tips will work for all exterior hardwoods such as Mahogany, Cumaru, Merbau, etc.
What is IPE Wood?
IPE is a gorgeous Brazilian hardwood that is becoming increasingly popular for exterior wood surfaces. This extremely dense wood is naturally resistant to decay and rot, making it a durable choice that can last for decades.
When freshly cut, IPE often appears in shades of reddish-brown and exhibits rich brown color tones. However, one drawback is its tendency to turn silvery-grey over time due to UV exposure. With proper staining and maintenance, you can prevent this and retain its natural beauty.
Best IPE Staining Tips
To maximize the longevity and enhance the beauty of your IPE deck, follow these expert tips:
1. Measure and Plan
- Measure the wood surface to determine the square footage to be stained.
- Check the coverage rate of your chosen IPE deck stain to ensure you purchase the correct amount.
- Choose a stain color that complements the age and condition of your IPE wood. Color samples are available for $10 each for the top rated IPE Stains.
2. Prep the Wood Properly
Never stain IPE wood without proper preparation. Follow these steps:
- Clean the surface using a high-quality deck cleaner such as Restore-A-Deck Wood Cleaner.
- Apply a wood brightener to neutralize the cleaner and open up the wood’s pores for better stain absorption.
- Allow the wood to dry for 24–48 hours before staining.
3. Apply the Stain Correctly
- Thoroughly mix the stain before applying.
- Use a brush, roller, pump sprayer, or airless sprayer to apply the stain evenly.
- Protect surrounding areas (plants, windows, and concrete) from stain overspray.
- Allow the stain to penetrate for several minutes, then wipe away excess stain to prevent puddling.
- Dispose of oil-soaked rags properly—soak them in water and lay them flat to dry outdoors to prevent combustion.
Maintaining an IPE wood surface can be made easy with proper IPE staining instructions. A quality IPE Wood Stain will enhance your deck’s or wood surface’s beauty while giving it lasting protection from the elements.
Note: Always follow the directions of the stain manufacturer you choose, as they differ between brands.
My Top IPE and Exotic Hardwood Stain Ratings
2. Armstrong Clark Wood Stain
3. TWP Natural Effect Hardwood Stain Review
#1 Best Hardwood Deck Stain | #2 Best Hardwood Deck Stain | #3 Best Hardwood Deck Stain |
From: $51.99 *Free Shipping | From: $83.99 *Free Shipping | From: $99.99 *Free Shipping |
Is Your IPE Deck Turning Grey?
Preventing Greying in IPE Wood
To prevent IPE wood from greying, apply a UV-resistant stain immediately after installation. Routine annual maintenance includes:
- Cleaning – Use a deck wood cleaner and gently scrub to remove oxidation, dirt, mold, and mildew.
- Sanding (if needed) – Lightly sand rough areas or splinters.
- Applying a Wood Brightener – This helps restore color and prepares the wood for staining.
- Staining with a Hardwood-Specific Formula – Use a penetrating stain containing UV inhibitors.
IPE Wood Naturally Ages from UV Exposure
When left untreated, IPE wood will naturally turn silver-grey within a few months due to sun exposure. This process is faster for decks in full sunlight.
How to Restore Greying IPE Wood
If your IPE deck has turned grey, follow these steps to restore its natural color:
- Clean & Brighten – Apply a wood cleaner, scrub gently, rinse, and follow up with a brightener.
- Allow to Dry – Ensure the wood is completely dry before staining.
- Apply a Quality IPE Deck Stain – Choose a semi-transparent penetrating stain formulated for hardwoods, such as:
- Wipe Excess Stain – IPE wood is dense and does not absorb stain like softer woods, so excess stain must be wiped off after application.
IPE and Hardwood Stained Photos
My IPE Hardwood Deck Stain Video
Final Thoughts
Consistent annual maintenance is the key to keeping your IPE deck looking fresh and preventing it from turning grey. Regular cleaning, brightening, and staining will ensure it remains protected from the elements.
Have a question? Drop a comment below, and we’d love to help! Also, check out our in-depth IPE Stain Reviews for product recommendations.
Live on Tampa Bay. Will be using 6″ x 1/2″ IPE for a top to cable railing. IPE is new. What oil/stain would you use given the saltwater and intense sun? Would you use anything in addition to the oil/stain? Thanks in advance.
Try Defy Hardwood Stain or Armstrong Clark in the Hardwood colors. Nothing else is needed. Clean and reapply annually.
Commercial Maintenance Alert, Potential job for IPE at Union Station in DC, what’s the best way to clean before staining large amounts of sf? 2 1/2 years old lots of gum, spills, grease etc. In house cleaners are using disinfectants (bleach was mentioned) on the waiting area benches and have caused discolorations. Need guidance on best cleaning practices (powerwash vs. machine scrub) and sugggestions on products to use. They say Messmers UV Plus Hardwoods was used after installation. Not too concerned of scratches (there are not too many), but we do have the ablility/tools to sand/screen if this would help prep the wood for staining.
Pressue wash with a sodium percarbonate based deck cleaner. Not sure though on the best way to remove the gum.
Great site-expert advice thx! Ipe deck was poorly finished with zar clear ultra uv protect (not for decks). I’ve been hired to make it right. Plan- Sand 80 grit square buff, RO 80 corners & rails, messmers cleaner brightener, pwash off, let dry. I want to brown it to match areas under shade with Ipe oil. Can I apply messmers clear uv for hardwoods after ipe oil? ..and does this sound like a good overall appraoch? Thx!
Plan sounds correct but you cannot apply anything on top of the Ipe Oil.
Hello, I have ipe around the pool so water from the pool that contains pool chemicals gets on the ipe deck around the pol making it lighter in color. I havent sealed it yet. My question is: would an oil base like ipe oil or a water base like Defy be better for this situation?
Does not matter nor would a stain/sealer help to prevent the chlorine from doing this. It will continue to happen.
Porch railing: built about four years ago and was told that we have to apply “milk” before we restain….. what’s he talking about?
No idea. Never heard of such a thing.
Thanks for all the useful info – but I’m still looking for a truly clear penetrating oil/ preservative. I have a 20-year old ipe deck, still looking beautiful (gray, of course), just power-washed to a nice light brown, highlighting the grain. Tried Ipe Oil, to great disappointment – heavily pigmented, it’s a nasty flat brown. I know any oil will darken the wood, but is there anything out there that adds NO color?
No color = no (or very little) UV protection. If okay with this, try Defy Extreme Clear or TWP in their clear.
Thanks – will do. Also tried the clear Thompsons’s Timber Oil, which also darkened the wood way too much.
I am installing an Ipe deck that will be totally exposed to the elements. I would like to achieve the silvery gray weathered colour. What would be the best way to allow the colour to change while trying to ensure longevity. I’ve read up on using clear sealers that will have limited UV protection. I guess that would allow the graying process to occur as quickly as possible but would it be at the expense of longevity? Lastly after the colour has reached the desired gray colour any tips for ongoing maintenance at that point?
Thank you kindly.
If you want it to gray naturally then you would want a clear sealer (no tint at all). This will let the wood to oxidize and gray naturally. Once it achieves a desired gray that you like, it is not possible to keep it that way indefinitely. You will need to clean and reapply the clear again, allowing it to naturally gray again.
Thanks very much for your reply…
Would Ipe Oil be considered a ‘clear sealer’?
No, that is tinted brown. None of the IPE coatings are true clears that I can think of. Defy Extreme Clear is a true clear and has some limited UV protection, but will gray eventually.
Last question… do you recommend wax sealing the ends? I’ve heard it causes a discolouration.
It can discolor and we do not bother. The wood will crack slightly but that is normal and not a big deal in the long term.
Our home was built about 3 years ago and the front and back porches were built using ipe wood. The builder finished the porches during chilly weather in November and used Cabot Australian Timber Oil in Natural. Our South facing front porch started fading fairly quickly during the first year leaving patchy areas of color, especially around the edges. Now the entire porch is faded with only small areas of color still showing. Our North facing backporch is covered and the color has held up pretty well, even after 3 years, except for the around the edges and steps. Even though the color on the can of Cabot says Natural, the original color of both porches was a dark reddish color. We would like to refinish both porches ourselves in a more neutral brown color. What is the best way to prep ipe wood for refinishing and which products do you recommend? What is the best and longest lasting stain for giving ipe wood a nice neutral brown tone?
When dealing with IPE, you will have to clean and reapply annually to keep up the color. Look at IPE Oil or Armstrong Clark in amber color when looking at more neutral (not red) colors.
What would you recommend on prepping porches prior to staining? The front porch is almost completely faded out to grey and the back covered porch has a lot of color left, but the edges and steps are pretty faded.
Strip and brigthen for the back. Clean nd brighten for the front. Use Restore a Deck Kits.
Have Ipe deck about 4 years old. Painter applied Cabot oil based stain and not sure if this was mistake. Water from rain is beading up on deck
When was the Cabot applied?
We had an IPE deck installed and some of the long boards are warping (concave) – no longer flat surface.
What is happening? Thank you.
Bad wood possibly. Ask the manufacturer for assistance.
Thank you – will call the place IPE was purchased from and see what they say. But, have you ever heard of this happening to IPE?
Yes it can happen.
We have 10-12 year old ipe decking above our boatdock which gets full sun and has never been cleaned, sealed or oiled previoulsy. I carefully pressure washed it (w/o any cleaning solution) a few days ago and purchased the Penofil hardwood oil. Do I need to any additional cleaning besides blowing off dust/leaves etc. before i apply the oil? Do you recommend using a brush or sponge pad or ?
If the wood is clean and you have removed the gray oxidation, then you can stain. As for application, use a extrior stain pad. You may want to review the Penofin before applying.
Do not use Penofil unless you want brain damage and your Ipe is never exposed to sun, rain or wind. The product does not penetrate anything other than brain cells.
Amen to the response about Penofin. Don’t use it if your deck is outside. haha
Does it help to sand hardwood deck? If so, sand before or after cleaning and brightner.
Sanding will reduce the stain\’s aility to penetrate into the wood grain so we advise against it.
Hello I used Ipe oil on my new deck. Just after installation. The deck is 95% cover by a roof. It rained about three weeks after application and some areas got wet. Those areas seemed to have run a bit and left a stain where they ran. The stain looks it has a slight sheen in the borders and the wood is lighter in the areas it got wet. I spoke with the company they said it must been dirt or some contaminant not their product. I can't believe it could be dirt the deck is do new and I followed their instructions explicitly. I want to refinish with something different I don't trust this product anymore any suggestions?
Tony, if it washed off then the stain never penetrated into the wood grain. Most likely it was over-applied, filmed on top of the wood instead of in the wood grain, and did not cure correctly. Water and oil do not mix so if it had cured into the wood, it is not possible for it to wash off. I would suggest waiting until next Spring and prep by removing the Ipe Oil. Try the Defy Hardwood stain this time.
I have a customer who wants the boards and seams of their Ipe deck to be a noticeably different colour/shade than the interior boards. How can I achieve this and with what stains? I know I have access to Ipe Oil and Messemers.
That is not easy to do with Ipe. You can make some redder and others more brown. Messmers has two different colors that you can work with.
Our contractor only used thomasville waterseal waterproofing wood protector on our ipe deck. Will that damage our deck? No oil was used. Also, no end sealer was not used after they cut the ends. Can we apply sealer after a month?
You have to remove the Thompsons first before applying the Ipe Oil. Strip and brighten and then stain.
Have a new Ipe deck about to be installed. Should it be cleaned/stained before install on all sides?
No. Install, let weather for a few months and then stain just the exposed area.
Can you explain the reason for this? I’m not disagreeing; I’d just like to understand, because I had the same question. Thanks.
New wood needs to season first. A few months to slightly gray and the prep will remove the mill glaze and an oxidation so the stain can properly soak in. Staining all sides is not needed or helpful. Only need to stain the areas that are exposed.
I'm build an ipe deck. Checked out the ipe at the local lumber yard. Looks like they had two different batches. The 16ft had a reddish brown color and the 18ft were brown. I'm using both lengths – after staining with a brownish stain – will they look similar?
The stain enhances the natural tones of the wood. The two different batches will mostly likely show a slight difference when stained.
We have a brand new IPE ceiling above a covered patio. Live within 2 miles of the coast in San Diego. The ceiling will not get direct sun. Do we need to let it season? Do we need to clean it now or before we finish? Which is best – an oil finish or a stain with a sealer to get the longest life out of the finish. Thanks so much!
Use a stain that is designed for your wood type. Ipe Oil or Armstrong Clark in Amber tint. Yes you should clean first.
We have a deck put in in March 2016. Stain we have for Eli wood is flays seafon ship n shore waterproofing. Is this okay to use
Sorry but have no idea as to what stain you are using. Never heard of it.
I'm re-staining an IPE deck. I've already stained a small area of the deck a couple of days ago just to see how well it stains. when I begin doing the deck next week should I just start where I left off or should I go over what I already did?
Going over will darken those areas so they stand out. Starting where left off should be okay unless you did not leave a very distinct stop, as any overlapping will be noticeable.
I've used Ipe Oil on new ipe wood. After 1 month, still beautiful. However, the odor of the ipe oil is very strong, and obnoxious to most people. After 3 weeks the stench got to be tolerable. Is there a stain that does not smell so bad?
Try Defy Hardwood Stain. You will need to remove the Ipe Oil with a stain stripper first.
The guy at Dixieline recommended australian timber oil by Cabot. Is that the same or similar to ipe oil? I can't find anyone who sells ipe oil locally but want to use the correct oil . Thanks
Not the same color or the same performance. Buy online if you cannot find locally.
In reference to using a hardwood like Cumaru (and ipe?) you advised 'If you want it to gray, a clear sealer will help to prevent mold, etc. "
Which clear sealers will have the mildecide and not significantly retard the graying?
TWP 1500 Clear or Defy Extreme Clear.
Just finished a new home with cumaru decking. Two questions: 1) Any specific product you'd suggest that would best enhance the cumaru color? 2) If I want to just let the decking gray, do I need to apply any sealer at all? Thanks.
Try Armstrong Clark in amber to enhance color. If you want it to gray, a clear sealer will help to prevent mold, etc.
Used cabot ato last year. Porch deck appears splotchy in color. Just power washed yesterday. Suggestions for a glossy sheen in a red tone. Previous homeowners had it looking beautiful.
You cannot use a gloss finish on exterior wood. It will peel, blister, attack mold, and make it extremely hard for you to remove when it does all this. Try Armstrong Clark in Mahogany after removing all of the Cabot first.
Thank you for the suggestion on ipe oil. My contractor has messmer's on site, will that also look more brown than red? Thanks again.
Which stain would you recommend for ipe if I want rich brown tones as opposed to red? Thank you
Ipe Oil has a brownish tone.
Would messner's also result in a brown tone? That is what the contractor has on site. Thank you
A lighter brown, but yes.
How long will the treatment last?
Used Woca before, very expensive and last about 3 months
Depends on the stain brand. Ipe wood typically requires reapplication every 9-12 months.
What is a good oil to use for a ipe wood deck
IPE oil or Armstrong Clark in Amber or Mahogany.
What is the best application method.
Exterior stain pads.
We live in South Carolina, our deck is screened with an open area unscreened porch below. So we stained last week in good weather and a week later it's been raining and quite humid but it hasn't gotten wet since it's covered. But some of the boards appear to be sweating oil, we used the Armstrong Clark in Mahogany after using the restore a deck cleaner and brightner. At what point should the excess stop seeping out. We have wiped throughly twice. It looks great other than still waiting to but our furniture back down. Any advice?
I would contact Armstrong Clark about this for some advice.
Bought the ArmstrongClark in Mahogany. What temperature restrictions are there for application? I see you recommend exterior stain pads so we'll get those too. Any other application tips?
50 degrees is the minimum temp for applying. Do not back wipe any excess. Apply one light coat and allow it to soak in as it dries.
Is a water based stain or an oil based stain recommended for the Ipe deck wood?
Oil will soak in deeper.
Which AC stain color is best for a very dark brown (almost black) on Ipe? Will the same stain color look the same on tigerwood, or would we have to choose a slightly lighter color to get a contrast?
AC does not have a very dark brown/black color. Colors will look different on IPE compared to Tigerwood. Not sure though if the contrast will be that different though. Try to get some samples to test.
mold continues to be problem an my brazilian hardwood deck using penifin treatment what is best product to remove mold any ideas to prevent mold
Strip and brighten with the Restore A Deck Stripper. Once it is removed, try the Defy Hardwood stain to help prevent the mold.
Thank you for your post-highly informative.
just got my deck finished and stained on July 2nd, 2015. In the winter, temp. can get to -40 frequently with over 200 cm of snow. Is there any protection i should use regarding winterizing my deck?
No need to do anything else.
How long does it last or how often should this be done?
How long does which product last? Typically IPE needs to be reapplied every 6-12 months depending on the stain you use. we find that the Armstrong Clark in Mahogany holds color the longest but it is \”rich\” in color when applied.
I have an IPE deck-about 7 years old-that I power wash every year and re-apply Cabot's Timber Oil. There are some spots that don't get much sun that look like they have "extra" oil that I can't get off either with a cleaner or a power washer or scrub brush. Any thoughts/recommendations? Brand of cleaner?
Try a deck stain stripper and pressure washing. Use the Restore A Deck Stripper.
Thanks for your helpful review! Regarding prep; I have new Tigerwood that, judging by water beading, has mill glaze. Will the product you recommended (Restore-A-Deck Wood Cleaner and Wood Brightener) remove this? I had planned to use Penofin 1st Step but it is more difficult to find than expected.
It will but you should also let your new Tigerwood weather for 2-3 months first, then use the RAD Kits for the prep.
Tiger wood trim & railings, Ipe Deck.
I would also let it sit for 2 months full sun 3 months shaded. I have been thru many of the products talked about here.
For me I have finally settled on the Penofin products. 1st step & hardwood stain. I love having friends & neighbors tell me how gorges my Deck is. But it took a lot of failed tries & hard, time-consuming work to get here. If there is only one thing you take away from all this. It should be put in the time to get it right the first time & maintain it. Hard wood requires twice a year maintenance. But once you do it a couple of times. It is easy.
Seven year Old Deck completely striped & redone four times. Good Luck with Yours. Oh also in New York
We had an Ipe deck installed in 2013 and used Ipe Oil. As it faded after just a couple months, we stripped the deck last year and used AC. We didn't like the orange color, so wanted to go back to Ipe Oil. This spring, we stripped it again with Restore A deck and about a week later applied Ipe Oil. It looks awful! Some small areas look nice, but many areas are whitish and there are areas with small spots. What went wrong and how do we fix it? Thanks!
Not sure. Could you post picture in our forum area?
Posted.
my pipe was just put down three weeks ago. Is there any issue sealing it now?
Yes. Let is season for a few months and prep first with a deck cleaner.
I live in southern Ontario Canada and am soon to be building a decent size fence around my yard. The posts and rails are to be 6×6 sienna pt lumber and the vertical boards are to be 1"x10 pine. I want to stain a lite colour like cedar before attaching the boards. Question is which armstong product would you recomend and is staining right away a good idea. The pine is kiln dryed.
If rough saw and kiln died you can stay right away. Look at the Amber color in the AC.
I am still left w/questions. When we purchased Ipe the wood yard said to put a coat of its oil on the wood and it wood be all we would ever need. Not so much the truth. I've had to pressure wash the dirt and mold that built up in the oil off the deck at the end of the first year and then again each year since.
Now we are looking at staining and sealing the deck. But I'm left undecided as to the best option to choose. I have already pressure washed the deck and just ordered the cleaner and brightener. But what is the best stain/sealent for a pool deck in NE FL. And how long can we expect it to last?
IPE needs to be done at least once a year. Some stains will not even last that long. Try the Armstrong Clark in the Mahogany color.
I have an Ipe deck that was finished 7 months ago with Minwax Tung Oil Finish after being sanded down. It does not look good – greying and either dirt or mildew. How would I take the oil off and refinish with Ipe Oil by Deckwise? I live in SC so we have a lot of humidity – is Ipe Oil the right choice? I am open to suggestions. Thank you.
Yes IPE would work well. Make sure you understand that you will need to reapply annually, sometimes sooner with IPE wood. Make sure to prep well.
How should I prep? Stripper or cleaner? I want to be sure the tung oil comes off.
To be safe strip, pressure wash then brighten.
We are installing a new IPE deck and my contractor says we need to finish all four sides before it is installed. I was under the impression that IPE wood needs to be installed with no stain on it and let sit for a few months before stain can be applied? Which is correct?
Not your contractor. Best to follow the advice of the stain brand you are using.
I used Ipe Oil on our deck and have been a little disappointed in the color (fading a fair amount after only a couple months). I am interested in trying Armstrong Clark. Is just cleaning enough or do I need to strip the oil first before applying the new product?
You would need to remove/strip first. It will be easy enough.
Our IPE deck turns gray in 12 months.
We've tried Penafin oil.
What sealer would be best? How long would it last?
Half-day sun, mold, Hawaii.
IPE requires annual application. Nothing will last longer. We usually use the Armstrong Clark in the Mahogany or the Ipe Oil.
The last four years I have applied Messmer's stain with a brush. This year I am going to try Armstrong Clark's stain and I see everywhere it can be applied with a sponge pad. I'm thinking of trying this. I've also read to wipe any excess off–I haven't had this issue before (I don't think!).
I'm wondering what I should wipe it with? I'm concerned that a rag would leave "fuzzes" in the wood.
Any thoughts would be greatly appreciated 🙂
Heather
AC actually says to not wipe off the stain the same day, just allow it to absorb into the wood grain.
My IPE is 18 years old and its starting to turn gray. I have never stripped it before. I was going to stripped it with my power washer and apply a clear waterproofing sealer. Will this bring back it's natural color. Suggestions are welcome. The deck only get about 5 hours of sun a day ( 9 AM to 2PM) and we live in new jersey.
You need a stain or color in the sealer if you want to prolong the UV graying. Clear will not offer this.
i love the color of ipe when it is wet. will ipe oil give me that finish?
Similar but slightly browner.
Have an ipe deck coated with One Step and tend to agree with previous comments made about this product(long drying time, covers grain etc.). Now looking to clean and brighten deck and coat it again. Can I move to a new coating if deck is cleaned? I initially chose this one cause the claim was no need to strip in between coatings. Would this be true if I moved to another product?
You need to strip if you want to change brands. Brighten as well. Some stains are easy to clean and recoat. The better the stain penetrates, the easier it is to reapply the next coat.
I have a large IPE deck, 2/3 screened in an 1/3 outside (approx 30ft by 15 ft). It was completed 3-4 yrs ago, and the contractor used Australian timber oil. He didn't know what you noted above, that the oil needs to be wiped away, and had to use steel wool or sand paper to get rid of the excess. It worked well enough I guess.
The inside still looks pretty good actually. We probably should have stained at least the outisde many times since, but have not. We are looking to do that now. I hired a new painter to do it, who said he will clean and sand (not sure if that is good) the wood and satin with whatever we want to match the insde portion. What would you suggest we use to stain (match) and on the cleaning? Are there any problems with this approach?
Mike B, Use the Restore A deck products on the prep and the Armstrong Clark in the Mahogany for the stain.
Can you apply stain if the IPE wood was treated with oil for years?
Linda, as long as you prep correctly first.
