What To Do If It Rains After Staining Your Deck 4.8/5 (260)
This post was updated on August 20, 2025
Hi, I am Scott Paul, a leading exterior restoration contractor and business owner with over 30 years of experience in wood and deck staining. My deck staining help tips on what to do if rain harms your deck staining are based on my history as a wood and deck restoration contractor for the past 30 years. See here for more info about me.
How to Protect Your Deck From Rain Before and After Staining
Wood decks are a fantastic way to enhance the beauty and value of your home while providing a comfortable outdoor space for entertaining guests and relaxing. However, they are constantly exposed to harsh elements like rain, snow, sun, mold, mildew, and pests. Proper deck maintenance is crucial to preserving its longevity and appearance. One of the biggest challenges homeowners face is dealing with unexpected rain before or after staining their deck. In this article, I’ll cover how to avoid rain on your newly applied deck stain and what to do if rain catches you off guard.
Key Tips for Preventing Rain Damage to Deck Stain
  • Rain can cause issues with fresh stain, leading to washout, blotches, or an uneven finish.
  • Once the deck is dry, inspect for damage to see if touch-ups or a full redo are needed.
  • A light second coat may help even things out, but severe cases might require stripping and restaining.
  • Sanding and cleaning can improve blotchy spots before reapplying stain.
  • Always check the forecast before staining to avoid unexpected rain ruining your hard work.
Rain After Staining a Deck: What to Do Immediately
You checked the weather forecast, and everything looked clear, so you started staining your deck. Then, out of nowhere, a rainstorm hits. Panic sets in—but don’t worry, it’s not the end of the world.
Has this happened to you? If rain interfered with your deck staining project, leave a comment below, and I’ll help troubleshoot a solution. If possible, share pictures so I can offer specific advice.
Why Rain Too Soon After Deck Staining Damages the Finish
Staining a wood deck is essential for protecting it against the elements and extending its lifespan. However, once the stain is applied, it needs adequate time to dry and cure. If rain falls too soon after staining, several problems can arise:
  • Washout Effect – Rain can cause the stain to rinse off before it fully absorbs into the wood, leading to uneven coverage.
  • Blotches and Spots – Water can create unsightly spots where the stain has been partially removed.
  • Poor Adhesion – Some stains require a curing period to bond with the wood properly. Moisture can prevent this, leading to premature failure.
To avoid these issues, let’s discuss how long stains typically need to dry and what signs of rain damage to look out for.
How Long Should Deck Stain Dry Before Rain?
The drying time for deck stains depends on various factors, including the type of stain used, weather conditions, and wood porosity. Here’s a general guideline:
  • Water-Based Stains – Typically dry to the touch in 1-2 hours but require at least 24-48 hours to cure fully.
  • Oil-Based Stains – Take longer to dry, usually around 4-12 hours before they can resist light moisture. A full cure can take up to 72 hours.
  • Humidity and Temperature – High humidity or cool temperatures can slow drying times significantly.
Always check the product manufacturer’s recommendations for precise drying times.
Next, I’ll review the time needed for wood deck stains to properly dry, discuss the signs of rain damage, and explain the best remedial measures to take.
My Steps to Prevent and Fix Rain Damage on Fresh Deck Stain
  1. Check the Weather Before Starting!
  2. Too Late, It Rained on My Deck Stain
  3. Steps to Fix a Deck Stain from Rain
  4. Popular Question on Deck Stain and Rain
  5. Ask me for Help with Fixing Deck Stain Harmed by Rain
1. Check the Rain Forecast
I know this is obvious, but always check the forest before starting. It is best never to stain any exterior wood when inclement weather is forecasted, especially rain. Most deck stain brands warn against applying their product within 12-24 hours of rain. In any case, I always place a waterproof cover or tarp over the deck as a preventative measure. But as we all know, sometimes the weather is not so predictable and people forget things. So, what do you do if it does rain on your deck shortly after staining?
2. Too Late, It Rained on Newly Applied Deck Stain
You cannot do much until it stops raining once it starts. Just let the rain continue and asses after it has stopped. Do not bother trying to tarp, as it will be too late. A light drizzle most likely won’t hurt anything, but a good downpour can be a different story. The type and brand of stain can make a difference as well. Some stains can handle rain better shortly after being applied than others.
Deck Stain Good From Rain
3. Steps to Take after it Rained on Deck Stain
Step 1: Assessing the Rain Damage
After the rain has passed and the deck has dried, take a closer look. It depends on how hard it rained and for how long. Look for little pockets, blotches, or white spots, usually the size of a dime. Any of these can indicate some damage from the rain.
Deck Stain Harmed From Rain
Step 2: Check Deck Stain Directions
Read the instructions on the stain can for recoating or adding a second coat. Once you are within the time frame recommended for a second coat, try applying the stain in an inconspicuous spot to see if it fixes the rain damage.
Note: Water-based stains generally cure in roughly 2 hours, while oil-based products usually require at least 1-3 days. Keep in mind that the curing process is often slower when the temperature is below 60 degrees (F).
Step 3: Redo Deck Stain Prep and Start Over
Applying a second coat of stain will often resolve problems associated with minor rain damage. If a light recoat does not fix the problem, you can also try using a mix of wood cleaner and a pressure washer to see if you can wash the spots without harming the stain. Or you can try lightly sanding the rain spots and recoating. Care must be taken, though, not to over-apply the stain, as this can cause other issues like flaking and peeling. If you cannot fix the problem with washing, sanding, and recoating, you may have to remove the stain with a deck stain stripper and start over again.
Extra Tips to Avoid Rain Damage Before and After Deck Staining
Choosing the Right Product
While many water-based stains will dry completely in 12 to 14 hours, oil-based products often require a day or more of drying time. I have found that stain products that deeply penetrate or absorb into the wood usually perform the best in terms of appearance and long-term surface protection. As such, it’s very important to allow this process to occur without being hindered by water.
Before choosing a wood stain product for your deck, I encourage you to visit our product reviews on DeskStainHelp.com. I also invite you to visit our interactive forum with questions, comments, or feedback.
Use a Tarp or Cover
As I noted, weather forecasts are sometimes inaccurate, so covering the deck with a durable tarp or similar material after applying stain is an important precautionary measure. Various tarp products, such as those composed of polyethylene, polyvinyl chloride (PVC), vinyl, and similar materials, are affordable and effective.
4. Popular Rain on Deck Stain Questions:
How long does the deck stain need to dry before it can get wet?
Answer: The time required for deck stain to dry and cure varies according to the stain, temperature, humidity, and other factors. Always consult with the manufacturer’s instructions to confirm the timing. As noted, be sure to check the weather forecast before getting started. The majority of stain products will dry completely within 24 to 48 hours.
What should I do if my deck looks blotchy after the rain?
Answer: If rain has caused your recently stained deck to appear blotchy, it is important to let the surface dry completely. In many cases, lightly recoating the blotchy areas will correct the problem.
If the problem persists, apply a wood cleaning product and rinse the surface with a pressure washer. If blotches are still visible, gently remove them with sandpaper before recoating the area with stain.
Can I apply a new layer of stain over the existing one?
Answer: Yes. You should gently sand the surface and then apply a fresh layer of stain. Remember to always review the manufacturer’s instructions before reapplying the stain.
Will rain ruin a freshly stained deck?
Answer: Rain may damage your deck if the stain has not dried completely, particularly if a heavy downpour occurs. Because the stain has yet to be fully absorbed into the wood, the water may wash away or significantly dilute the stain.
In these instances, the most common problems are peeling, discoloration, and spots.
How can I protect my deck from unexpected rain?
Answer: Always check the weather forecast for any possibility of rain before applying stain to your wooden deck. Consult the manufacturer’s instructions on the packaging or labeling materials regarding the time needed for drying and curing. Furthermore, cover the deck completely with a waterproof cover or tarp as a precaution.
How do I know if my deck stain is ruined?
Answer: When a freshly stained deck is exposed to rain, it may ruin the stain. As noted, large areas of discoloration, blotches, or spots are common indicators of a need to recoat the surface. Based on the circumstances, you may need to clean and lightly sand the surface before reapplying the stain. However, using a deck stain stripping product might be necessary if the water damage is more extensive.
Will rain ruin a newly stained deck?
Answer: Yes, if the stain has not fully dried or cured, it may permanently damage the deck stain.
How long does deck stain need to dry before rain?
Answer: This varies based on stain brand, type of stain, and weather conditions. The average is 4-12 hours but can be put to 24-48 hours.
What if it rains 12 hours after staining deck?
Answer: 90% of the time, there would be no issues.
What if it rains 24 hours after staining deck?
Answer: I rarely see any issues, but it is always possible that the weather was cold or that the stain was over-applied.
5. Want Help on Fixing a Deck Stain that was Rained on?
Share Your Experience!
By following these guidelines, you can protect your deck and ensure a beautiful, long-lasting stain finish, no matter what the weather throws your way!
Before asking if rain harmed your deck, wait until the rain stops and the water fully dries off the deck or wood. Gather some pictures and post a comment below. Make sure to include the stain brand and type of stain used.
678 Comments
Really informative article. Thank you for the info.
Why does one board on a recently stained deck puddle like this? Very odd. Does it mean the product didn’t adhere to this board?
IMG_2381
This was not new wood – about 15 years old and sanded – first with 40 grit and then 80. Cabot’s Australian timber oil was used. Sorry please remove triple post.
Bret
Bret
Stained deck with semi transparent olympic PPG stain. We live in Alaska so its been raining a lot. We stained, it dried for over 48 hours and now its raining for the next week. If you touch the stain it is coming up on our hands, shoes , and dogs feet. It is raining for the next week and can’t just wait it out. What can we do right now to fix this?
Tony
Tony
It rained all of a sudden while staining the deck using Olympic maximum semi-transparent stain
20240725_114206
John Cammalleri
John Cammalleri
Sorry, forgot to add photo.
John Cammalleri
John Cammalleri
Hi Scott. First of all, thanks for all the valuable advice you provide. I’ve had my deck restained, and it looks great, EXCEPT:
there are darker areas around the perimeter, where a hand brush was used. (Photo attached.)
How do you recommend we fix that? Do we need to sand and redo? If so, do we still need to use brightener? The deck was cleaned thoroughly, stripped, cleaned again, then treated with brightener, before stain was applied. Hoping a sanding will suffice.
John Cammalleri
John Cammalleri
Thanks for your help. A thorough sanding is not sufficient? Reluctand to use stripper/brightener because the outer deck, railings and gazebo are fine. Don’t want runoff from stripper to ruin those.
Thanks again.
John Cammalleri
John Cammalleri
Thank you for your help. That’s what we’ll do.
John Greenland
John Greenland
I’m using Arborcoat over oil primer on cedar shake siding. How long until it’s rain ready? I’m in Maine and it rains so often that I’m grabbing every chance I get to finish. The primer is all dry for several days but I have areas that still need 2 coats of finish.
Patti
Patti
We had a new deck built with cedar wood and the contractor applied the first coat of stain yesterday. Forecast looked good, but we had an unexpected rain last night. Based on my reviews of your site, it looks like we need to make sure it is totally dry before applying second coat but not sure how long to wait and do we need to be concerned about water spots that may come through? We also need to sand out a few overlap spots. Contractor was not overly experienced with staining so looking for advice.
We used Pittsburgh Paramount – Luxury Finish + Sealant; Satin – Semi-Transparent. The rain beaded up nicely on the deck but now unsure if we need to do any type of prep before we give it a second coat of stain. Thanks for your help.
Patti
Patti
I’m confused by your response. I’ve never heard of not staining new wood right away??? The stain soaked in and seemed dry before the rain.
Patti
Patti
Hi Scott – what grade of sandpaper do you recommend. We’re doing a little research and it looks like it will involve a 2-step sanding process?
Pat
Pat
Hi Scott
I stained my decking brown 4 days ago and it rained about 12 hours later and I noticed that the rain water on it was brown. I swept all the water off and when it’s dry it’s fine but as soon as it gets wet the water turns brown again! I can’t let my dogs walk across it and they get wet brown paws. What can I do please?
Many thanks in advance for your advice
Pat
HI Scott,
I plan on painting a shed with Cabot Solid Color acrylic stain and sealer. I had the medium base (1808) tinted to match previous color. I’ve had luck using deck satin on vertical surfaces. Shed is 18 years old and in good shape. Looking to freshen it up. I don’t have a lot of free time to do projects like most of us. My question is on any given day this week rain is predicted in the afternoon/early evenings. Temperatures mid 80’s to low 90’s. It seems dry time would be 4-5 hours maybe 6 before rain is predicted. Is this enough time or do you think I’ll run into problems. Project is in the Dutchess county.
I’d appreciate any advice.
Be Well
GiGi
GiGi
Will the morning dew mess up my deck stain if it hasn’t dried completely
I used Valspar solid with the primer built in.
It’s been 5 hours since I finished it and it’s still wet 🤦‍♀️
Jeremy
Jeremy
I used Thompson’s WaterSeal Clear Wood Sealer on my deck and started 10am yesterday and finished around 12pm. It’s now expected to rain this afternoon around 4 or 6 pm. That would be about 30 hrs. The can said to allow 48hrs. Will I still be ok?
Dori
Dori
Hi. I just had my deck stained with Benjamin Moore Arborcoat. The contractor filled in holes and knots with some sort of wood filler/ epoxy. It has rained almost every day since the work was done. I checked the deck today and noticed that the filled in holes are mushy and the stain has bubbled. Will the areas eventually harden?
David Lee
David Lee
hi, i cleaned and prepared my deck and then it rained before i stained. do i need to re-clean and re-apply more wash/prep before applying stain?
Li fan
Li fan
Hi Scott, I used Thompson’s wasterseal stain and sealer all in one semi-transparent for a deck. After 12 hours rain started. Is that a problem? Here were pictures from the rain.
li fan
li fan
Thanks. What does white spots look like?
Mary P.
Mary P.
We stained on Monday. It is now Thurs and I’ve noticed white spots where water from my plants have occurred. the water is pooling and doesn’t seem to be evaporating. Will these white spots go away? Does this mean every time it rains we will have spots all over the deck. Thanks or any advice you can give.
Mary P.
Mary P.
Thank you for your quick response.
Pam
Pam
hey! So I power washed and sanded my deck. Rinsed it off with the hose. Leaves are falling here in Ny and its starting to get cold. Can I Paint on the oil primer two coats and then wait until the spring to put on the Arborcoat waterbased solid stain in the Spring?
Jenifer Gregory
Jenifer Gregory
I power washed rails/ privacy feature deck and let it dry 48 hr. now it looks like rain might start in a about 12 hrs, chance increasing over next 2 days. I only have upright wood to stain as deck floor is composite. it’s water base semi trans.should I chance. my time is limited to have time. n (tried in may, power washed then rained forever and then got too hot forever). live in midwest and cold weather weather next . it might be 3-4 wks before I will have time to stain again. will I need to re prep again?
Jenifer
Jenifer
Thank you . It’s behr semi Do you think I can chance it if the rain is supposed to start about 10 to 12 hours from now?
Alyson
Alyson
Hi Scott, I put on my first coat of Behr’s solid wood stain yesterday and finished around 2pm. I woke to very chilly temps, 36 degrees and dew all over the deck. After it dries out, can I put plastic over it and apply a second coat tomorrow, or do I have to wait longer due to the dew? I was hoping to apply a second coast this afternoon, or is this too soon?
Alyson
Alyson
Great! :) Thank you. But then is it okay to be staining in direct sun, even if the temps won’t be going up higher than 64 degrees?
Alyson
Alyson
Thank you again Scott!
Denise
Denise
I pressured washed my deck, let it dry and then used Flood CWF-UV Clear. Temperature was in the low 60’s. Roughly 24 hours after application, I noticed the deck was still wet and unfortunately it started to rain heavily. What do you suggest?
Denise
Denise
Is it safe to apply more stain if needed after it thoroughly dries?
Nick
Nick
I stripped, sanded, and brightened my 256 PT deck, and finished 2 days ago. I planned to stain it tomorrow with TWP 1500 – Cedartone. The original weather forecast was that it would be clear for 48 hours. Now the forecast has changed, and rain is expected about 36 hours after staining. Should I hold off or go ahead and stain the deck.
Nick
Nick
Nick
Thank you for the quick response.
Katie
Katie
I sanded our deck and put the first coat of Cabot Deck Correct on it yesterday. About 4 hours after application some unexpected rain came in. It rained pretty steady for a few hours but never seemed to be a heavy driving rain. Most areas seem to be fine but there are some white marks and just one board that has some bubbles as shown in the picture. Do you think the rest of the deck will be ok to put the second coat on after everything thoroughly dries and I can just sand and start over on the board with the bubbles? Any idea of what causes the white spots? Thanks in advance for your advice!
Andrew
Andrew
Hey! Thanks for doing this. I am sure we are fine, but just wanted confirmation that everything is good, so I don’t drive myself crazy. I did 2 coats of Behr premium waterproof 100% acrylic which says rain resistant in 4 hours. After a forecast of no rain, we had a random really hard 1 hour rain about 22 hours after 2nd coat was applied. The first pic is about 3 hours after the second coat (no rain) and the second pic with more shade is 24 hours after the heavy rain (50 hours after 2nd coat). Thanks for your help!
Andrew
Andrew
Thank you, sir!
Ruth
Ruth
We had some dew drip down from an overhang the night we stained and found this the next morning. We used Messmer’s UV+. Should we try and add more stain to these spots, sand the boards down and stain them again, or something else? Thanks!
Lillian
Lillian
Is it better to use a brush vs a roller ti stain your deck?
I want to know your opinion. Personally I am liking a brush😎
Candy
Candy
Hi, I put a first coat of stain on a deck yesterday when it wasn’t calling for rain. The forecast has now changed with a 70% chance of thunderstorm tomorrow, starting about 48 hours after I finished. I was going to put on 2nd coat today but then it will only be about 36 hours before it might get rained on. Thinking I should hold off on the 2nd coat, hope the first holds up well, and then do a 2nd when there is less likelihood of rain. Does that sound right? Can I do the 2nd coat several days after the first?
Laurie Jones
Laurie Jones
Live in SC where we have quick hard rains every other day to relieve the heat. Can I use a oil based stain and cover the deck with a large tarp to protect it? I am in a timeframe to get this done. I could put up bases to hold the center of the tarp up so the center isn’t weighted down.
Laurie Jones
Randy T
Randy T
Hired a company to paint house and stain deck. They pressure washed, sanded, then stained with Cabot Australian Timber Oil. It rained two hours later. Water pooled on the wood. It looks awful, splotchy and scaly. The pics show it several days after staining was done. Contractor thinks “more stain”, I had to stop them and ask them to go get educated before doing anything. That’s what I’m trying to do here…
What an awesome resource to be able to ask the opinion of others to figure out what to do, thank you!
Randy T
Randy T
One more question if I may, could something else have caused this condition or is it rain water for sure? Thank you in advance.
Randy T
Randy T
Sorry to ask more questions… the contractor had the crew pressure wash the stain off the wood instead of sanding. The wood looks “fuzzy” and I see lines in the wood from the pressure washing…
How deep of doo-doo am I in?
Randy T
Randy T
Pics
Hey Scott – I just stained my deck w Cabot Australian. It was starting to cure last night. Rained this morning and feels wet to touch and coloring looks as though I just applied the stain. Assuming i’ll Have to re do but is there a chance after it dries it will cure and be okay?
thnx Steve
Hey Scott – thnx! It diaries and seems to have cured although there are a couple of washed out/ faded spots. Can I spot stain the areas washed out or just give the entire deck a second coat? Thanks again for your help
Sharon
Sharon
We hired a local handyman to paint our deck. Trying to beat the rain, he waited only 24 hours before painting. It then rained 12 hours after he finished. He used a Sherwin-Williams product. There also seems to be sap bubbling up, as well. What should we do next? Can these spots be sanded and recoated?
Nicholas
Nicholas
Hi! What an amazing resource! Thank you so much!
We stained our new cedar deck a few days ago with Olympic Semi Transparent Semi Solid Atlas Cedar Oil Stain and it rained about 12 hours after… we attempted to tarp and dry the rain as it happened… then it rained again about 12 hours after that…
Now that it’s dry it looks like there are some dry spots near the knots in the wood… do you think I should apply another coat of the stain?
Karin
Karin
Hi, First, thank you for your article. I’ve waited till the rain dried off the deck before asking my questions. I painted using Cabot solid stain over semi- transparent which was applied 2 years ago to a deck which had been left untreated for 3 years (the deck is about 5 years old). I stained in the evening when the sun was not on the deck, weather was in the 80s, paint had just been mixed at Lowe’s, deck was properly power washed and dried, and no product was applied to the deck surface before staining. Within 2 hours of staining the deck it began to downpour. (the weather app said no rain) It rained hard for 15 minutes (as we ran around in horror trying to tarp the deck LOL). This morning the deck was wet and paint could be scratched loose with a fingernail. After baking in the 90 degree sun I tested again at 1PM. It is now very solid paint, dry to the touch, but slightly tacky if I leave my hand on the hot deck for a minute, and appears to have no bubbles or flaws. My questions; How do I know it’s fine or needs to be stripped? Am I able to apply a second coat over Cabot solid stain because the wood soaked in the first coat as fast as I could roll or hand paint it and the surface shows small splits. The pictures are from 1:00 today, they show the edge of the stain that was painted last (I’d run out of stain) and the deck’s entire surface. Thank you so much for your help.
Karin
Karin
Wow! Thank you for your quick response. Guess I dodged a huge problem.
Karin
Karin
Scott, I know this isn’t the right thread but you were so helpful with my rain questions, I have one more. I painted all the rails and posts with Olympic solid stain we had left from painting the house. My thought was it would match nicely however with 10 people living here it became very obvious that the flat stain holds fingerprints very very well. I want to paint in a higher gloss but Lowe’s paint counter can only suggest Cabot solid stain over the Olympic, but it is also a flat sheen. Is there a more washable option for me? Thank you
Karin
Karin
Ok, I researched & noticed you recommend Restore a Deck. Would that be more washable than the Olympic stain? Would it be safe to apply another coat of R.A.D or Cabot over the existing 2 coats of the Olympic which were applied 3 days ago? The Olympic really isn’t washable & I’ve put so much work into the deck that I hate the thought of not being able to wash dirt off the rails. Thank you
Karin
Karin
I took your advice and tested the Cabot solid stain in white over the existing stain. It definitely has a slight sheen in comparison to the Olympic but is not glossy (which is fine). Would you consider Cabot a quality brand? I didn’t see your recommendations till after I purchased & applied 4 gallons of the Cabot and it had rained on the newly stained deck brining me to your site. BTW, you were right, the deck is just fine :)
Karin
Karin
I forgot to mention the rails and posts are white.
Kelly Stokes
Kelly Stokes
We had a contractor stain our new cedar deck and he used Sherwin-Williams semi-transparent Super Deck with two coats. It’s been more than 24 hours (more like 36) and it rained this morning and now lighter areas are showing where some of the puddles were. Photos attached. Also there are marks on the steps where our dogs go up and down the steps. What should we do now?
Kelly Stokes
Kelly Stokes
Thank you. After the rain the sun came out and the deck dried. The spots appear to be gone but of course not the marks on the steps. We’re debating putting treads on the steps.
Dan Butler
Dan Butler
I used Cabot semi solid stain on my deck yesterday with rain in the forecast for tonight. It started raining this morning and now it’s going to rain all day. When I touch the wood it’s like the stain is wet again. Is there anything I can do?
Mace Matthew Colodny
Same happened to me…
ANY SUGGESTIONS ???
Kim O
Kim O
What is the best stain/sealer for my newly built white pine shed? I’m get overwhelmed with all the information I’m reading
Rich
Rich
I used Cabot correct deck stain 1st coat and it looks like it’s going to rain after 6 hours of drying time. Should I cover it with a tarp or just leave it alone
Dan L
Dan L
i have treated my deck of old boards with cleaner and water sealer. The i added a stain sealer on top, and it is looking good -unchanged after heavy rain. will the stain color last?
Deborah
Deborah
My can of stain got water in it sitting on the porch is it still good??
Carla Coon
Carla Coon
Our deck is Huge over 600sf not including the front porch deck and one by a pond. I have been successfully maintaining it for thirty years with CWF-UV recoating every 2-3 years. Whether they changed the formula (I suspect they did) or wether it just could not take any more stain, it needed to be stripped and sanded. It has been a grueling job for one woman with a power washer, a belt and palm sanders. I used Sherwin Williams Super Deck in semi-solid. We live in upstate NY and our area gets a lot of rain. It’s been a dance coordinating last coat sanding and putting down finish I can tell you! The job has been done in sections. Due to the windows of weather opportunities between rains and needing the boards dried before sanding, I could only manage one coat on each section. It should have had 2. Can even tell it needs 2. It just couldn’t happen not even in the week.
My question is can I safely do a second light coat in the fall four months later? Will it adhere or will it just sit on top and flake. I’m so afraid of the latter. This is my first time using a semi-solid.
Derrell
Derrell
I applied first coat to all of my wood yesterday and it looks great so far…its been about 17hrs drying but this morning it was still a little oily. I was planning to apply the 2nd coat of stain sealer today but now itsraining. My wood boards are underneathmy deck and was getting wet so i wiped them with a cloth and propted them up so rain could run down and not rest on. Is this ok? And when will i be able to apply 2nd coat?.
Ruth Leuenberger
Ruth Leuenberger
Handyman used messmers oil for ipe deck. He said it would rain the next day but wouldn’t be a Problem. Rainingvhsrd 12 hours later. Deck seems to have oil mixing with the rain. Will deck need to be redone? He also did not wait half an hour to wipe off excess in some places he just coated and wiped is this a problem?
Louise
Louise
Had deck stained just over 24 hours ago. Will chlorine affect the color of used on gutters?
Kitty Couch
Kitty Couch
If I keep the porch wet can I clean my house around it with water & bleach? Will it effect it right away or will it take days to show up? Thanks so much I never thought this would be a problem till someone said you can’t get bleach on stain decks…
Pattie Lessel
Pattie Lessel
My deck has milky places all over it after the first rain after staining
It was several days so I don’t know what could have caused it
Please help
Cher
Cher
This was posted as an answer to question. This is not the right answer. They asked about a porch that has a roof.
Barbara
Barbara
How can we cleaned a stained deck
Barbara
Barbara
Will hit the deck work on a stained deck with black mould on it
Michael Lanich
Michael Lanich
So I cleaned and brightened my deck but the last week has had some random light showers, so I haven’t had the 72 minimum window to let the deck dry, stain and cure before more rain comes.
I was wondering whether I could get some plastic sheeting to cover the deck and rails when I know it’s going to rain so that the deck doesn’t get soaked again and I can uncover it when it’s nice enough to allow it to continue drying or even start staining if it’s already dry at that point?
s.g
s.g
Deck stain was applied yesterday. As it’s drying, I am noticing the following:
1. some lines in a portion of the deck
2. some fuzzies and white residue – these came about during the prep, but I expected them to be gone after staining
(The person applying the stain did walk across a couple of times holding a rag wet from water, or holding the paint tray/brush with stain in it . A push mop with a rag tied around it with a string at each end was also used to wipe the floor of any excess stain. Not sure if any of this might be related)
My questions:
1. Any idea why the lines are there and how to fix it?
2. What to do about the fuzzies and white residue – Will this go away on its own in a few weeks?
s.g
s.g
1. There was actually a grill there with wheels that they moved, so that would make perfect sense. I might need to ask them to sand that section and re-stain there, will that work?
2. Could you please clarify your second response – what does not go away, the fuzzies or the white residue/spots around the knots? What caused this and how do I fix it?
Catherine McLeod
Catherine McLeod
We stained our covered deck with oil based stain. It became very foggy and had tons of moisture on it. It dried in some areas but is super “shiny” in others and seems sticky still in the shiny areas. It’s now been 5 days of nice weather. What do we do….. thanks for your help!!
Catherine McLeod
Catherine McLeod
Is there a mineral spirits product you would recommend?
Catherine McLeod
Catherine McLeod
Mineral spirits didn’t work. Some parts are still “sticky” and shiny. What’s next ? Do I have to sand it? Could I put a clear sealing coat over the whole thing and then it will all just be shiny : )
Corrie Ariens
Corrie Ariens
Oh and I do plan to use one of your recommended brands when we redo next spring. Unfortunately I came across your website after the fact! Oh well! Lesson learned!!
Corrie Ariens
Corrie Ariens
We live in western Washington state and applied Australian Timber Oil to our deck that has not been maintained since being built about 14 years ago. We cleaned it and pressure washed it first and allowed it to dry. Of course it rained that night. The sections under the roof seemed to fair okay and are dry but the sections that got rained on are still kinda tacky. Even after drying all the way. When it rained really hard over the weekend the water seemed to seep into the stain and it created a yellow kinda film on the top that I could scrape off with my finger nail. Is there anything I can do to get rid of the sticky parts to keep excess dirt and grime from collecting over the winter? I know this is most likely a start over in the spring situation but it’d be nice if it wasn’t sticky all winter. Thanks for any advice. I’ll attach pics of the dry deck. The lighter spots are where the yellow film forms when it’s wet.
Shannon
Shannon
Hello, similar story to others here: I think unexpected rain might have messed up the deck seal we applied. Either that or I was a bit heavy handed in applying the deck seal.
It’s a new deck and we used Behr transparent deck seal. It rained maybe 6-8 hours after we sealed the deck. It was overnight so I couldn’t tell how hard it rained but there was water pooled on the deck the next morning.
Question is: should we pressure wash and re seal it or is it okay for the upcoming winter? What do you recommend?
Shannon
Shannon
Sorry I thought the pictures were loaded! Here they are.
Shannon
Shannon
Notice in some areas the colour is more saturated and shiny despite it feeling completely dry.
X
678
