Restore-A-Deck Wood Stain Review 4.6/5 (53)
Hi, I am Scott Paul, a leading exterior restoration contractor and business owner with over 30 years of experience in exterior wood decking. My Restore-A-Deck Wood stain review is based on my history as a wood restoration contractor and actual hands-on testing, all designed to present you with the top deck stain tips. See here for more info about me.
Restore-A-Deck Semi-Transparent Deck Stain Review
Restore-A-Deck Wood Stain is a water-based penetrating stain designed to provide good color retention while still allowing the wood to breathe. It is a newer generation stain compared to traditional oils and is designed to be more environmentally friendly while still delivering solid performance.
From my experience restoring decks since 1993, Restore-A-Deck performs best for homeowners who want a balance between ease of use, durability, and longer-lasting color. It does not penetrate as deeply as oil-based stains like TWP, but it makes up for that with better UV resistance and more consistent color.
In 2017, our first full year using the Restore A Deck stain, we had no performance issues and saved a tremendous amount of time by prep and stain on the same day. We will continue to offer the Restore A Deck Semi-Transparent Wood Stain as one of our go-to decking stains for the 2026 restoration season.
Overall, Restore-A-Deck is a very good choice for those looking for a low-maintenance, water-based stain that performs well across a variety of wood types.
Note: Restore-A-Deck Semi-Transparent Wood Stain can be applied to dry or damp wood. Applying to damp wood allows you to prep and stain on the same day, saving you a tremendous amount of time.
8.63 Overall Rating Restore-A-Deck Stain
🔹 Quick Verdict
Restore-A-Deck Wood Stain – Quick Review
  • Best For: Homeowners wanting better color retention and easy maintenance
  • Not Ideal For: Those wanting maximum penetration on older wood
  • Type: Water-based penetrating stain
  • My Overall Rating: 8.63/10
Restore-A-Deck is one of the better-performing water-based stains I have used. It offers solid durability and color retention while still being relatively easy to maintain. This is one of the easiest products to apply, and it’s featured in our list of the best deck stains for most decks.
Restore-A-Deck Semi-Transparent Wood Stain is an advanced, water-based, semi-transparent stain formulation designed to penetrate deep into wood pores for maximum protection and longevity. Restore-A-Deck Wood Stain protects the wood from harmful UV rays and damage caused by water penetration. Restore-A-Deck Semi-Transparent Wood Stain is safe to use, has a low odor, and is easy to clean up with soap and water. It is ideal for all wood types including pressure-treated pine, cedar, fir, or redwood.
Recent advancements in water-based wood stain technology have allowed the active ingredients in the Restore-A-Deck Stain to offer better UV protection, excellent penetration into the wood grain, and the ability to apply to damp wood. All this is available in five beautiful semi-transparent colors highlighting the natural wood grain.
RAD Wood and Deck Stain will increase all exterior wood surfaces’ life, appearance, and durability. With the easy-to-apply and maintain Eco-Safe formula, you’ll be able to finish faster and enjoy your exterior wood or deck for years.
Restore-A-Deck Wood Stain Ratings (1-10)
How I Rated Restore-A-Deck Semi-Transparent Wood Stain
My Restore-A-Deck Semi-Transparent Wood Stain review contains an 8-step process and the final average score. Each step is on a scale of 1-10.
  1. The appearance of Restore-A-Deck Semi-Transparent Wood Stain after Application
  2. Preventing UV Graying
  3. Peeling or Wearing
  4. Cost Per Square Foot
  5. Preventing Mold and Mildew
  6. How Easy was the Restore-A-Deck Semi-Transparent Wood Stain Application
  7. Color Shifting
  8. Ease of Reapplication
  9. Restore-A-Deck Semi-Transparent Wood Stain Final Score
8-Step Review of Restore-A-Deck Wood Stain & Sealer
1. Appearance After Initial Stain Application: 8
The Restore-A-Deck wood stain color we used was the Semi-Transparent Light Walnut. The initial appearance was a rich brown with a hint of red (see pictures below) after drying. The Restore-A-Deck Stain penetrated extremely well into the wood grain on our test deck. No surface film on top of the wood.
2. Preventing UV Graying at 2 Year Mark: 9
Restore-A-Deck had little to no fading at the 2-year mark. Excellent color retention should be achieved through years 2-3 as well based on initial pictures and testing. See below for a picture.
Restore A Deck Stain One Year
3. Wear/Tear and Peeling: 9
4. Cost Per Square Foot: 8
We applied two coats to our 150 sq foot deck, including all railings and steps. Less than 1 gallon was used for this at a total cost of $40. This equates to $.30 a square foot. Very reasonable pricing and better than most other top brands.
5. Preventing Mold/Mildew/Algae: 10
Like other water-based deck stains, the Restore-A-Deck Wood stain will not promote mold or mildew growth. This is one of the primary advantages of using a water-based coating. At the 1-year mark, the deck showed no signs of any mold or mildew.
6. Ease of Application: 9
Our favorite aspect of the Restore-A-Deck Wood stain is the ability to stain and prep on the same day! We tested this by cleaning and brightening the wood with the Step 1 and Step 2 Restore A Deck Cleaner/Brightener Kit and then applying the RAD stain 1 hour after the prep. The wood was visibly wet on a few deck areas and damp to the touch throughout. The Restore-A-Deck actually applied more easily to the damp wood than any other water-based stain that we have used previously. We also found that the coverage was better when applied to damp wood. In theory, the stain will absorb better when applied to damp wood. The water “swells” the wood pores and “pulls” the stain deep into the wood as it dries.  Applying to damp wood will also help avoid potential issues with Applying a Deck Stain in Full Sun.
See before and after pictures below.
7. Color Shifting (darkening) after 2 Years: 8
As expected, the Restore-A-Deck stain darkened very little and did not shift color. See the picture at the 2-year mark above.
8. Difficulty of Reapplication: 8
The Restore-A-Deck will be an easy clean and reapplication as needed.
Overall Score Restore-A-Deck Stain at 1-Year Period: 8.63
– The Restore-A-Deck is an awesome exterior wood stain and has shown the ability to outperform other water-based and oil-based wood stains. Restore-A-Deck’s 3-Step system allows you to save time and money when restoring your exterior wood and decking. No other system that we have used or tested has allowed the ability to Prep and Stain in the Same Day. If you are looking for the future of exterior wood and deck stain, consider the Restore A Deck Wood Stain and their prepping system.
$51.99
More Info: Restore-A-Deck Wood Stain
Cost: $47.99 per Gallon,  $219.99 per 5 Gallon Pail. Products ship free on their website.
Available Colors: Natural, Cedar, Light Walnut, Dark Walnut, Cottage gray
Coats Required: 2 Coats. “Wet on Wet” for older wood. New wood = 1 Coat.
Dry Time: 2-4 Hours
Cleanup: Water
More Info: Product Data
Manufacturer: Restore-A-Deck
UV Exposure: 50% Full Sun
Light Walnut
🔹 Pros and Cons
  • Easy to apply with consistent results
  • Better UV protection compared to most oil-based stains
  • Holds color longer than many penetrating oils
  • Low VOC and environmentally friendly formula
  • Easy to clean and recoat with proper prep
  • Does not penetrate as deeply as oil-based stains
  • Can sit more on the surface if over-applied
  • Requires proper prep to avoid uneven absorption
  • May not perform as well on very old, dry wood compared to oils
🔹 Best Wood Types for Restore-A-Deck
Best Wood Types for Restore-A-Deck Wood Stain
  • Cedar: Very good color uniformity and protection
  • Pressure Treated Pine: Excellent overall performance when prepped correctly
  • Redwood: Good color enhancement and durability
  • Very old, dry wood – penetrates very well
  • Hardwoods (IPE, Cumaru, etc.) – excellent color retention
🔹 Real-World Testing & Photos
Restore-A-Deck Wood Stain – Real World Testing
Below are examples of Restore-A-Deck Wood Stain applied to different wood types and how it performs over time.
  • Always apply to clean, properly prepped wood
  • Do not over-apply, as this can lead to uneven drying
  • Apply thin, even coats for best results
  • Back-brush or pad for uniform coverage
  • Applying to damp wood is easiest
  • Recoat every 24 months depending on exposure
  • Clean and brighten the wood before reapplying
  • Avoid letting the coating fully wear off
  • Light maintenance coats will extend the life of the finish
🔹 Who Should Use Restore-A-Deck?
Who Should Use Restore-A-Deck Wood Stain
  • You want better color retention than traditional oils
  • You prefer a water-based, lower VOC product
  • You want a stain that is relatively easy to apply and maintain
  • Your wood is in good condition and properly prepped
🔹 FAQs
Restore-A-Deck Wood Stain – FAQs
No, when applied correctly, it penetrates and wears naturally without peeling.
Is Restore-A-Deck oil or water-based?
It is a water-based penetrating stain.
Yes, as long as the wood is properly prepped to allow absorption.
It performs better than most oil-based stains in terms of UV protection and color retention.
🔹 Final Thoughts
Restore-A-Deck Wood Stain is a solid choice for homeowners looking for a balance between durability, color retention, and ease of use. While it does not penetrate as deeply as traditional oil-based stains, it offers better UV protection and longer-lasting color.
From my hands-on experience working with deck stains for over 30 years, this is one of the better water-based options available, especially for newer or well-maintained wood.
If you prep the wood correctly and stay on top of maintenance, Restore-A-Deck can provide consistent and reliable results without the issues associated with film-forming coatings.
866 Comments
Brandon
Brandon
Richard & Irene Garipoli
Erin
Erin
Irene Garipoli
Irene Garipoli
Reply to  Erin
Erin
Erin
Reply to  Irene Garipoli
Elaine Booth
Elaine Booth
Steven Murillo
Steven Murillo
Ken Tidwell
Ken Tidwell
Ken Tidwell
Ken Tidwell
Will do.
Ken Tidwell
Ken Tidwell
Here are some photos.
Tina
Tina
What shade color is this
jean eustice
jean eustice
Ken Tidwell
Ken Tidwell
Reply to  Ken Tidwell
Some more photos.
Deck Finishes, Stains, Sealers,
nancy robitaille
nancy robitaille
Is this stain good for a swimming pool deck?
Allen
Allen
I am about to purchase and install 1 x 12 cedar boards and strips from Lowes and do board and batten siding. It states it is cedar, am not sure if it is “technically” western cedar or? Anyhow, the boards appear to have a slightly rough texture to them, not rough sawn perhaps, but not smooth either. Anyhow, I would like to have a nearly clear finish with maybe a little darkening color to it, however. A few questions. What product(s) do you recommend? And when can I apply it? I’m thinking it would be easier to apply before installing OR should I install and let it set for a period of time??? Would it need a cleaner – brightener? I guess, long story short I need full directions for this scenario, lol… Located in Southern Tennessee
Allen
Allen
OK, about how long in this current Tennessee weather you think?
Allen
Allen
What sealer, cleaner, etc. do you recommend best to use in this scenario
Allen
Allen
To apply the RAD semi-transparent stain on a verticle wall (Board & Batten cedar), what options are there to apply it? Brush only or can one spray it on someway or?
Judy Earthman
Judy Earthman
our front deck gets to 120 degrees in morning sun, is RAD semi-transparent going to prevent UV damage in this situation
Vern Kuhn
Vern Kuhn
Where can it be purchased?
Claudia McDiarmid
Claudia McDiarmid
So fed up with having to sand and restain my deck floor every Spring with Benjamin Moore semitransparent stain. Have done all the correct steps. Never had this problem with oiled based stains years ago.
Fletcher Smith
Fletcher Smith
I have a 10′ x 15′ deck made of treated pine. It is 25 years old. It was sealed once with Thompson’s Water Seal 20 years ago. I recently cleaned it with a high pressure (2,000 psi) washer. Water only. It came remarkably clean. All the graying is gone and the wood has its original color. I would like to use either a clear or very light brown RAD stain. At this point do I need to do anything else to prep before staining or can I simply wet the deck and apply stain?
Fletcher Smith
Fletcher Smith
[IMGcomment image[/IMG]
Fletcher Smith
Fletcher Smith
Images attached correctly this time.
Nate
Nate
Reply to  Fletcher Smith
that looks like a great power washed and dried surface to stain, looks plenty well enough prepped to me, good job pressure washing and not making stop/start marks
We’re in “Nawthun” Mississippi & built our 11×13 treated pine deck in August of 2018, so it’s had about 8 (rainy!) months to air out. We’ve purchased a gallon of the cedar-tint RAD stain & want to apply it soon, before things get too hot around here. The deck planks still look practically new, but we’re planning to first clean them with plain water & a stiff brush. Under these circumstances, is it really necessary to also use the brightener?
Thanks for the quick response, but maybe my question wasn’t clear:
1. We built the deck only 8 months ago.
2. Cleaned it yesterday & it now looks virtually new.
3. We’ve purchased ONLY the stain.
Is the project REALLY knackered if we don’t spend another $60 on cleaner & brightener?
Thanks again for your attention!
Frank Delfino
Frank Delfino
Can i get a close match to Behrs “Forest Green”
s may
s may
If I am planning to sand down the deck (cedar), do I need to strip/brighten before using the stain?
Jeanette
Jeanette
We are adding a new deck onto our home in Georgia. The summers are extremely hot and humid. Will this product work well in the high/humid conditions.? How long do we need to wait before we can stain? We are using PT decking boards. What prep would be necessary since we are using new boards?
Jason Hart
Jason Hart
Have new Cypress Siding and Pressure-Treated Pine Deck – both kiln dried. Do I need to wait a couple months to apply Restore-A-Deck like some other products? And is the prep-kit still needed on new wood? I also note it comes in Natural and Cedar – I assume Natural would not preform with UV as well as Cedar due to less pigment? Thanks!
Jenny Godwin
Jenny Godwin
Hi. Can this product be applied to treated wood? If not, what is best for treated wood?
We replaced deck floor with composite. This is for the deck walls. Thank you!
Jenny Godwin
Jenny Godwin
Reply to  Jenny Godwin
tzk
tzk
I used Behr clear stain 7 months ago on a brand new deck, it looks horrible now, gray, peeling, rough, I need to redo it all over again, and thought about trying this brand. What do I need to do to get it ready? what does the prep involve? Do I need to sand it? hopefully not that will take hours. thanks
Bob Christensen
Bob Christensen
We used to restore a deck system on “new” treated lumber that was almost 2-years-old. Unfortunately we have had significant pealing especially where it was exposed to direct sun. How do we recover from this crisis? I don’t understand what went wrong? The prep, bleach and staining was done over two days in October 2018, we are in SE Iowa.
I had new pressure treated deck installed last August. Approximately 20′ x 30′ (600sf). I had planned to clear seal and let deck grey naturally. After reading your site comments, I am considering using light stain for UV protection. What do you recommend regarding color and amount of product?
Jennifer T
Jennifer T
We have an older deck that looks like it had a semi-transparent stain put on many years ago. It is definitely not paint – can see all of the wood grain. We would like to use RAD. Do we need to strip the deck before using RAD?
deckrail
deckrail
We replaced our deck railing last March. Was told to wait 6 months to stain. Unfortunately, last year was a very wet year in WV (we are about 90 miles NW of Washington, DC) and we could not get the railing stained last year.
What should I do to prep the wood and which stain (probably want a semitransparent) would you recommend for our area. Deck is pretty much in full sun all day.
The wood parts are the frame for the top and bottom (2×4’s) and the 4×4 posts. The middle section is made from cattle fencing which we primed and painted black (no wood spindles). We get to enjoy the view so much more with this than with the wood spindle.
Thanks for your assistance.
Purchased the sample package. Thoroughly cleaned a small area and applied all 4 colors to the damp boards. 2 hrs later looked at the sample area and they all looked the same with very little tint. I’m glad to have purchased the samples because after all the positive reviews I almost purchased the 8 gallons needed to stain my deck. So much for positive product reviews on the internet.
Carolyn
Carolyn
My water base stain was red maple. Which product should I use. An where to purchase. This restore a deck stain.
Carolyn
Carolyn
Deck was water based last year,why is it slippery especially when wet
Carolyn
Carolyn
Reply to  Carolyn
I used water based and deck is slippy what shall I do
Carolyn
Carolyn
Reply to  Carolyn
I used Sico water based deck was power washed and sanded prior to deck was originally oil based
We live in central Indiana and had a new cedar fence installed in late Sept 2018. We let it weather over the winter and would like to prep and stain it with RAD cedar stain this Spring (2019). The fence is 6’ tall and 120’ long totaling 720 sqft on one side. Since it is new wood, I gather it will take two coats of stain. I plan to spray it on and back wipe it with the stain brush you sell. My question is: How much cleaner, Brightener, and stain should I buy?
How Much Cleaning / Stripping / Brightening should be necessary if using Restore-a-deck over Olympic Maximum that was applied in 2015? The Olympic still looks pretty decent, but after readying mixed reviews and your review, I am thinking of switching. There has been No pealing, some fading, But is not exposed to full noon sun in most areas (covered). Present color is “Tobacco” which we really like and so also struggling to find a similar color – Dark Walnut?
Also I am torn between an Oil or Water based. But I guess for an oil I would almost have to fully remove the Olympic? There are a whole lot of tight spots in the deck that would make full removal and sanding impossible. I have narrowed it down to 3 of your top choices: Armstrong-Clark / Restor-a-deck / or TWP 100. Thoughts?
Debbie
Debbie
We had a cedar pergola built in September. It is still unfinished. I wonder if this product would work. If so, will I also need to prep?
Dan
Dan
Compared to other products, what makes this product ECO SAFE?
Dan
Dan
Kimberley Brooks
Kimberley Brooks
We did our deck 8 months ago, old wood but had never been stained. We did everything the instructions said from prep to stain and it took over 50 man-hours for our 600 sq foot deck. Now… it looks awful. It is peeling and dried looking everywhere. Pics are from now. We went with the highest rated stain and paid quite a bit more for it.
Stain Flash Dried in Sun
Kimberley Brooks
Kimberley Brooks
Thank you, I wonder if having it too hot outside means the first coat dried too soon (we did the 20-4- miute, erring on the side of 20, but still HOT outside in July, een in the early morning), so then it had this result. What is the optimal temperature range? Most of that time was prep so it is disheartening now to see this. What steps do we need to redo the horizontal surfaces? The vertial surfaces are all find, which is a relief because that is all the fine rails and spindles. Thank you!
Robin Rose
Robin Rose
I’m contemplating getting Restore-A-Deck and using the Natural. If I decide I want a darker stain when I add the second coat as recommended in 12 to 24 months, can I use a different color? Or would is look wonky? Thank you.
Robin Rose
Robin Rose
And prepping before reapplying is true for staying with the same color or going darker, correct?
Thomas Elliott
Thomas Elliott
Where can I buy Restore-A-Deck Wood Stain?
Thomas Elliott
Thomas Elliott
Paul
Paul
I live in the Oakland CA hills and have a large redwood deck. The deck is over 10 years old but it’s very good quality redwood and in decent shape. It was power washed, cleaned, and stained 4 years ago; I believe Superdeck was applied. The new contractor wants to clean and sand the decks, and then use Behr Premium but I read the reviews and now I’m very skeptical. Since Restore-A-Deck is highly recommended on this site I’m considering asking the contractor to use it instead. My question is that I don’t see a redwood natural color offered. The RAD website shows a natural color but it’s very light. I want the natural redwood color to show; will the RAD “natural semi-transparent” color stain do that? If so, there needs to be a redwood sample used with to show that.
JTB
JTB
Any reason why the Light Walnut was recommended versus the Cedar stain? I have a redwood deck that has been sanded and treated with wood cleaner and the Cedar stain from RAD looks like it’s closer to a redwood color but hard to tell. Any feedback is helpful. Thanks
JTB
JTB
Thank you! Purchased Light Walnut. Now just need to ensure we nail the application.
Vicky Marquardt
Vicky Marquardt
Where did you buy the restore a deck stain?
Stan
Stan
I used this stain last Spring and so far so good. No issues at all and is holding the same color as when applied. Question though. When it is time to reapply, do I have to prep with the Restore A Deck 2 part system again?
Stan
Stan
Thanks. Do I need the Brightener or the Cleaner for the prep when reapplying.
bob rosen
bob rosen
Because of all the rain this summer in the Northeast I’ve never gotten a chance to treat some of the cedar wood I’ve replaced on my deck. Is it safe to go through a winter without treatment? If not, then what is the lowest temp.I can apply to the deck? I’m assuming 50 degrees F but what about the cold nights? Will the product dry properly?
Ruthellen
Ruthellen
Can you add color to Restore aDeck Wood Stains
I noticed that Restore a Deck says that the product can be used on hardwoods such as mahogany, but does not warrant the product for use on such hardwoods. They say that if used on hardwoods, you may have to reapply every year. Has this been your experience for use on mahogany, or do you find that reapplication every year may not be necessary. I live in Massachusetts. Deck is in the shade mostly from October to March and partially in the sun in the summer months.
DaveS
DaveS
I had a contractor stained (sprayed) my 2 year old deck with Ready Seal approximately 15 months ago. I had it pressure washed (using low pressure) about 2 months ago. I want to change to Restore A Deck as I live in NC and a water based product will work better in this humid climate.
The deck looks good and since it’s been washed recently, will I need to do any prep before I apply Restore A Deck product?
Guy M
Guy M
Can restore a deck stain be used on ipe wood?
Donna
Donna
We purchased redwood at extra cost for our deck and applied Sikkens as recommended by the lumber store. It did not even last a year, mold and mildew appeared and worn out places. Next we tried Sherwin Williams super deck product and was told we should expect it to last three years. Once again barely over a year and we have worn out places and mold. We live in Georgia hot and humid, on a lake. Our deck is barely 6 yrs old and we are looking to redo it for the 3rd time. Please help!
Stephanie Conticchio
New deck installed early in the Spring, 2018 in Maryland. Husband got antsy and coated it with a clear sealer about 2-3 months later. Water still beads up on it. Do we have to strip it to apply a stain sealer now that we are prepared to pick a product to acheive the appearance we’d like?
Yo Krob
Yo Krob
Where can I purchase this product in Toronto Canada?
i have used a deck cleaner AND later power washed our pine pressure treated wood deck in order to get algae stains off deck but can’t seem to get them completely off all areas. Can I still stain or do i need to sand first? I don’t know what stain was used previously.
michele gorcey
michele gorcey
Hi
Is it better to use the Cedar color vs the Natural for UV protection? I have read with stains its more effective to use one with a color. Thanks. Its for a new Cedar fence, smooth.
michele gorcey
michele gorcey
Gail Van Acker
Gail Van Acker
Where can I buy this stain at? I live in Shepherd mi
Craig
Craig
Put a new deck on December 2017 and let it weather for 10 months. I cleaned and then brightened the wood according to the directions. Waited 24 hours and applied the Reatore a Deck walnut stain with a stain brush 2 wet on wet coats. It looked while it was wet but after it dried it looks terrible. Very uneven colors and a splotchy look. I have used TWP and Ready Seal on other deck with out any problems. i wish I had went with one of those this time.
Sue
Sue
We applied restore a deck
After stripping our deck disaster with Sherwin Williams deck scapes. Looks great now.
KevinM
KevinM
Reply to  Sue
What color stain did you use? We are trying to figure out a color. Looks great by the way
Sue
Sue
Reply to  KevinM
Natural
Roy Smith
Roy Smith
will this work on a teak deck
RONALD Elkin
RONALD Elkin
I HAVE a home with cedar shingles that were stained Olympic water repellant oilstain solid color about 15 years ago …..They have held up very well What would you reccommend I use for a stain this time around?
When could I put this product on a new pressure treated deck
Sarah
Sarah
Our deck was put in this week (pine). How long do we really have to wait to stain it? We are in Florida. Lots of rain and sun this summer.
jeanne vinette
jeanne vinette
how long does the deck need to dry after stain application before getting wet from rain?
With staining an old oak wood dock, is it unreasonable to expect that each board would be uniform in color? Or due to the age of the wood, would there be differing shades over a large area? If there are these lighter boards, is there a way to fix them to be more evenly colored. Light Walnut was the stain using Restore a Deck staining. Dock was pressured washed first, then stained over a few days due to the amount of area to cover. Thanks
Here are the pics. Thanks
Thank you for the response. Appreciate your input and we’ll probably add another coat next year.
JG Hicks
JG Hicks
Planning on sanding deck to bare wood totrmove multiple applicationss of solid stain. Do you recommend cleaning and brightening before application of RAD stain. Deck is covered with 3′ of snow during winter. Also, do you recommend two coats?
866
