Deck Stain Facts: Top Deck Staining Questions and Answers
Hi, I’m Scott Paul, a licensed exterior restoration contractor with over 30 years of experience and 10,000+ deck restorations. My answers and tips are based on my own field experience as a deck restoration contractor and hands-on product testing. See my full credentials and testing stats here.
Deck Stain Facts: Questions and Answers From a Pro
I started my career in deck restoration in 1993, and since then I have restored more than 10,000 decks. That experience led me to create DeckStainHelp.com in 2012, which has grown into one of the largest online resources for deck restoration. Over the years, I have tested nearly every major deck stain and sealer brand on the market to help homeowners and contractors find the right products and techniques for their projects.
Since launching, DeckStainHelp.com has answered more than 78,000 deck stain questions, with customized guidance for each wood and deck restoration project.
This Deck Stain Facts page is designed to give homeowners and contractors straightforward answers to the most common questions I get about deck cleaning, prep, and staining. Whether you are staining your deck for the first time or you are a contractor looking for a second opinion, start with the search below.
Deck Stain Facts - Quick Tips and Help
  • Always clean and brighten your deck before staining. Skipping prep is one of the most common causes of early stain failure.
  • Use the water drop test to know when to restain. If water soaks in and darkens the wood, it is time.
  • New pressure-treated lumber needs 3 to 6 months to dry before it can properly absorb stain.
  • Choose a pigmented deck stain over a clear sealer. Only pigmented stains block UV rays that cause graying and surface breakdown.
  • Never apply more stain than the wood can absorb. Always wipe up excess stain to prevent peeling and blotchy color.
Search by topic, product, or problem to find deck staining and prep answers.
These are the questions I am asked most often. For deeper answers, use the search above or browse the facts library below.
How often should I stain my deck?
Most decks need a maintenance coat every 2 to 3 years with a semi-transparent stain, though decks in full sun or with heavy foot traffic may need it every 18 to 24 months. Transparent stains usually need recoating every year. Railings and other vertical surfaces typically last longer than deck floors.
How do I know when my deck needs to be restained?
Do a water drop test. Sprinkle water on the deck boards. If the water beads up, the finish is still protecting the wood. If it soaks in and darkens the wood, or the deck is turning gray, it is time to clean and apply a maintenance coat.
How long should I wait to stain a new deck?
New pressure-treated lumber usually needs 3 to 6 months to dry before it can absorb stain. Some stains call for longer, so check the manufacturer’s directions. The wood is ready when water soaks in during a water drop test, or when a moisture meter reads 15% or lower.
Yes. Every deck should be cleaned before staining, including new decks. A deck cleaner removes dirt, graying, mildew, and the mill glaze on new lumber, all of which keep stain from absorbing. Skipping this step is one of the most common causes of early stain failure.
Do I need to use a wood brightener?
Yes. Deck cleaners and strippers raise the pH of the wood. A wood brightener neutralizes the wood, opens the pores so stain absorbs better, and restores the natural color. Apply it after cleaning or stripping, while the wood is still wet.
What pressure should I use to pressure wash a deck?
Keep the pressure below 1,500 PSI, use a 25 or 40 degree fan tip, and hold the wand 8 to 12 inches from the boards. Wood is soft, and higher pressure can gouge the surface and raise fuzzy fibers. Let the deck cleaner do the work and use the pressure washer mainly to rinse.
Do I need to strip my deck before restaining?
Not always. If the old stain is a penetrating stain that has faded evenly and you are using the same product, cleaning and brightening is usually enough. Strip the deck if the old finish is peeling, is a film-forming stain, or you are switching to a different brand.
Should I use a deck stain or a clear sealer?
For most decks, use a stain. Both repel water, but only a pigmented stain blocks UV rays, which is what causes graying and surface breakdown. A clear sealer keeps the bare wood look but needs to be reapplied about every year, and the wood will still gray.
Both can perform well. What matters most is that the stain penetrates into the wood rather than forming a film that can peel. Oil-based penetrating stains are a reliable choice for most decks, while quality water-based stains offer easier cleanup and faster dry times.
What weather is best for staining a deck?
Stain when temperatures are between about 45 and 95 F, check the product label for its exact range, and make sure no rain is expected for at least 24 hours. Avoid direct midday sun and hot boards, since the stain can dry before it penetrates. Early morning or late afternoon in the shade is ideal.
How many coats of deck stain should I apply?
Follow the manufacturer’s directions. Many penetrating oil stains call for 2 coats applied “wet on wet,” with the second coat going on before the first dries. Dense or new wood may only absorb 1 coat. Never apply more stain than the wood can absorb, and wipe up any excess.
Can I apply new stain over old stain?
Only if the old stain is the same product, is in sound condition, and the deck has been cleaned and brightened. Applying a different brand or a penetrating stain over a film-forming finish usually leads to poor absorption, peeling, or blotchy color. When in doubt, strip first.
Usually not. Sanding is only needed to remove splinters, raised grain, or stubborn coatings. If you do sand, use 60 to 80 grit paper and go no finer than 80 grit, because finer sanding closes the wood pores and keeps stain from penetrating.
Wood and Deck Staining Facts Library
Browse all of our deck staining, prep, and cleaning facts below.
Can Deck Stain Be Tinted
Can Deck Stain Be Tinted?
Can deck stain be tinted? It is best not to add tint to deck stain. Deck stain comes pre-tinted unless it is a clear deck sealer or transparent deck stain, which are not recommended due to lack of protection against...
Shiny Deck Stain
Deck Stain with Sheen?
Best deck stain with sheen? Deck stains should not have a shine. There are deck stains with sheen, but they do not wear well on most decks. Shiny deck stain forms a film over the wood that can easily crack...
deck stain killed grass
Will Deck Stain Kill Grass?
Do Deck Stains Harm Grass? Absolutely! It is very important to avoid getting your exterior wood and deck stain on your grass when applying. This can easily be avoided by using poly tarps and plastic sheeting to cover the grass...
Applying a stain to a deck
What is the Best Stain Color for a Deck?
What is the best stain color for a deck? The best stain color for a deck is a cedar tone deck. Cedar deck stain colors hide imperfections in the wood while allowing the natural grain show through. The best cedar...
One Gallon
How Much Will a Gallon Of Deck Stain Cover?
How much will a gallon of deck stain cover? A gallon of deck stain will cover between 150-300 square feet depending on several factors. (The average deck is 200-400 square feet.) Proper preparation – Properly prepped and cleaned wood accepts...
Valspar Stain Colors
Valspar Stain Colors?
What are Valspar stain colors? Valspar stain colors include Cedar and other natural wood tones. However, Valspar is more of a thin paint than a true deck stain. Valspar stain color Cedar was tested by DeckStainHelp.com experts and given a...
What Type of Stain is Best for Outdoors
What Type of Stain is Best for Outdoors?
What type of stain is best for outdoors? The type of stain that is best for outdoors is a penetrating semi-transparent deck stain like TWP, Restore-A-Deck, or Armstrong Clark. Penetrating stains soak into the wood to protect it against moisture...
Do You Need Two Coats of Semi-transparent Stain
Do You Need Two Coats of Semi-transparent Stain?
Do you need two coats of semi-transparent deck stain? Whether or not you need two coats of semi-transparent stain depends on several factors. Different brands of semi-transparent deck stain have different application instructions. Apply a second coat when the deck...
Best Deck Stain Brands
What Deck Stain to Use?
What deck stain to use? The best deck stain to use is a semi-transparent penetrating deck stain. The best brands of semi-transparent penetrating deck stains are TWP, Armstrong Clark, and Restore-A-Deck. These semi-transparent deck stains are easy to apply and...
Transparent Deck Stain
Deck Stain Non Slip?
Non slip deck stain? The best deck stain to use for a non slip surface is a semi-transparent penetrating deck stain. This type of deck stain protects the deck just like a solid stain but leaves the wood grain bare....
Deck Stain Looks Too Orange
Deck Stain Looks Too Orange?
Deck stain looks too orange? If deck stain looks too orange you have probably used a “Cedar” color of deck stain. These can make a deck look orange or like caramel. A deck stain that is too orange for your...
RAD Stain Photo
Deck Stain Environmentally Friendly
Deck stain environmentally friendly? Yes, there are some deck stains that are environmentally friendly, but not all. The only type of deck stain that is environmentally friendly are some water-based deck stains. The best brands for water based deck stains...
Need More Help?
Can’t find the answer you need? Ask me in the comments below. Include a photo of your deck, the type of wood, the current finish, and where you live, and I will give you my recommendation. Your question may become part of our permanent Deck Stain Facts Q&A section.
Calling All Deck and Wood Contractors
If you are a wood or deck restoration contractor and would like to contribute a Q&A to this page, email your exterior wood or deck question and answer to contributors@deckstainhelp.com.
If approved, we will publish your Q&A with a short summary of you and your business and a link to your website.
Please note: only contributor submissions sent to this address will be answered.
143 Comments
jwr
jwr
3 months ago
I have your solid stain on my deck and due to a very rainy season here I have some surface mold on the decking. What do I use to remove it?
Cindy Morettin
Cindy Morettin
4 months ago
Thank you for your quick response again. You recommended using the Rad stripper. Are you saying that the Restore-A-Deck booster & gel additives can be added to the Rad product? I am confused because the link in your *recommendation post doesn’t show the rad stripper product; rather, it shows the Restore-A-Deck products:
*”For the floor, use the RAD Stripper and Brightener kit — with the mold and the old Cabot residue still on there, add the Booster and Gel additives to the stripper. For the re-coat, go with the TWP Semi-Solid Pro-Series (30 color options); we also sell it bundled with the RAD Stripper/Brightener kit in one combo if you’d rather order it that way: https://www.deckstainhelp.com/product/twp-semi-solid-stain-5-gallon-and-r-a-d-stripper-brightener-kit/.” It reads r-a-d-stripper, etc but it is showing the restore a deck products.
Can the restore a deck additives be added to the Rad product?
Alex Morris
Alex Morris
6 months ago
Hello, I have a new deck on the second story of my house (walk out basement underneath). The deck boards are trex but the posts, rails, and joists are wood. How do I treat the wood to keep wood bees from boring into it (including the joists)? Are there any products/methods you would recommend for just the rail system and posts for staining/finishing?
Would a clear coat on the top board of the rail work or will it just flake off?
The wood is treated pine. I’m in Tennessee just north of Nashville.
Alex Morris
Alex Morris
6 months ago
Thanks Scott. Will an oil based stain keep wood bees from boring into the wood?
Adam Wright
Adam Wright
Hello
Have a question on removing Valspar Clear water base. What would be best application for removing it? The clear stain turned yellowish. Put down in June of 2025.
Thanks in Advance
Adam
Adam Wright
Adam Wright
Here are some pictures
20250918_133738
20250918_133736
20250918_133719
Glen
Glen
Two months after staining #2 pine using clear natural finish it looks great but I see something coming through that may be fungi or something. What to do? See attached photo.
IMG_20250928_102608
IMG_20250928_102653
Glen
Glen
I need to seal some rough sawn cedar posts and shutters on a home exterior that I installed a year ago. Some of it was fading from sun exposure with some gray weathered areas so I used a brightener on it. The brightener acted more like a bleach and it is now lighter colored than it was when faded and the natural color variations are now gone… is there any way to bring back the natural color variations?
Glen
Glen
Thank you Scott. So what brand of cleaner (and no brightener since I already did that)? What stain is best to bring out the natural color variations of the western red Cedar (rough sawn). I believe I will need to use a semi-transparent with some color in it since it’s so faded… The goal is for it to look like new – before sun damage. There is also an area of porch ceiling T&G cedar that still looks new. Is a clear stain or sealer best for that?, and how should I go about cleaning it first for dirt & dust removal
Judi
Judi
What size brush should I use to stain deck surrounding pool. I think 4invh is too bulky for me and do I ne d a paint tray to keep semi transparent stain mixed
Cece
Cece
I have used the information on your site to tackle staining a deck that is half old, unknown stain and have untreated pressure treated wood that’s 3 years old. We live in Vermont and I decided to use Restore A Deck because our drying windows are not dependable. With these products, I stripped the old stain from half the deck, cleaned the other half, brightened the whole thing, and rinsed throughly with a power washer. I damaged the wood a bit and had to sand off the white furiness (that’s not even a word 😀). I handed sanded the deck with a pole using 50 grit, finishing with 80. I used a belt sander on top of the rails. Then used semitransparent cedar for stain.
Now I have to figure out how to address the cedar deck and stairs that have Penofin Penetrating Oil Finish on them. The deck was not cleaned and brightened before applying. Our goal was to just preserve the cedar deck. We didn’t realize that a sealer would turn the cedar gray without UV protection. The application was not done uniformly and the deck looks terrible. When it rains heavily we get clay runoff from the bank and it does not rinse off.
I do not really mind the cedar graying, as that is what it naturally does. However, I want the deck to look better with the least amount of maintenance, since we have so much deck and it’s such a prominent part of our camp.
Is a semitransparent stain the best option for maintenance?
If so, I am not inclined to use the cedar color on the deck surrounding the camp, because I’m not crazy about the color. However, once the appropriate prep work is done for a switch to semitransparent stain, maintaining a different color from the lower deck should not be difficult, correct?
If I go to semitransparent, would I do the stripping and brightening to clear the sealer that’s on there now?
Here are pictures of the deck I stained and the deck that needs work. Thanks for your advice.
IMG_5320
IMG_5321
IMG_5322
IMG_5323
Cece
Cece
Do I need to wait for the weather to be optimal for all 3 steps to be taken without rain? Is it possible to strip and brighten and then leave the deck exposed to weather? Is this possible if I clean and/or brighten just before staining? If the deck can be exposed to rain between steps, is there a time limit for it to be left before the final stain step is taken?
Cece
Cece
I stained the deck in the picture on September 16th. I only had enough stain for a light second coat on the deck. I think the old part of the deck could use a light third coat. Can I do that directly over the current stain when I receive more, or do I need to clean and brighten first?
Thanks for your continued support with taking the time to answer my questions!
nichole vorel
nichole vorel
I used “EZ Strip” to strip the multiple coats of unknown type of paint off an older cedar deck (painted the stripper on, dwell time, then pressure washed it off). The instructions said to remove it with water and to “neutralize it with water”. So to remove any residual solvent, I then pressure washed each board, until the water ran clear from that board. However, I noticed that if I ran the pressure washer over that same board a couple of minutes later, more solvent appeared and so I would again pressure wash that board until the water ran clear. Unfortunately, the solvent continues to appear when I respray the boards. So I’m not sure what to do next? Do I need to used a wood cleaner / brightener to somehow neutralize that solvent? Or just keep pressure washing? I’m worried if there is residual stripper remaining in that old porous wood, my stain won’t penetrate properly. Thanks!
FYI: I’m from Canada (British Columbia), my deck is beside a fast flowing creek, and is full sun for a couple hours a day, but otherwise mostly shade.
IMG_8029
IMG_7973
IMG_7972
Dan Benscoter
Dan Benscoter
I have a deck at the house that’s in the sun most of the day, I used a semi transparent stain/ sealer from Pittsburg Paint but it only lasted a year before fading away, I also have a deck at the pool that the same thing happened and it gets pool water with chemicals on it,any suggestions on redoing these 2 and what to use. Thank you
Dan Benscoter
Dan Benscoter
Sorry about the pictures,it’s raining here right now. If you need ones when it dries I can send them once it dries up. Thank you
20240709_165021
20240709_165012
Dan Benscoter
Dan Benscoter
Scott this is the stain/ sealer I used
20240709_165720
Dan Benscoter
Dan Benscoter
I will get some dry picture sent to you
Dan Benscoter
Dan Benscoter
Scott here are 2 pics of the deck thats dry now,the pool deck looks the same
20240710_172506
20240710_172515
Dan Benscoter
Dan Benscoter
Thank you very much
Deb Shumate
Deb Shumate
Do you know anything about the product: Liquid Rubber, for a pool deck, it says it’s good for 10 years?
Angelo
Angelo
Oil or water based stains for pressure treated wood.
Kathy
Kathy
5 year old PT pine deck, never stained. It is about 20 yards from our lake. Have you had anyone have aquatic animal/fish problems after using restore a deck? TWP tech did say the cleaner/brightener is “harmful to aquatic animal”, according to the specs. I can’t believe the small amount that might be washed into the water would be enough to hurt anything. My family does not want to use it, but will use a dilute bleach, with sanding. I’ve read that bleach isn’t good to use, and it can do the same to the fish. Comments?
erock
2 year old deck, pine. Eastern NC. Was told to wait until following spring to stain. Original staining job was done by a local contractor using Ready Seal Exterior Wood Stain, Pecan. Dried streaky and uneven. Wore quickly and unevenly. Would like to go darker next go around.
Can you confirm what Restore A Deck products to use?
Should I wait until Spring? We’ll be only averaging highs in the 50s soon.
THANKS!
Eric
Ready Seal Deck Stain after 1 year
Teresa
Teresa
I have a brand new deck. What do I do next? When do I stain? What stain is best? Thanks for your help!
Megan
Megan
Sorry, I meant to say the brightener was Sherwin Williams Super Deck “Revive”. (In my comment posted 15 minutes ago)
Megan
Megan
I already cleaned and brightened our deck using Sherwin Williams cleaner (SuperDeck Stain & Sealer Remover) and brightener (SuperDeck Stain & Sealer Remover). I used a pressure washer to rinse these products. I was now going to sand using 60-80 grit orbital sander, however, in reading your website it seems I should have sanded before the brightener. I really would rather not have to repeat the brightener step after sanding. Is it possible to just lightly sand any visible splinters/loose shards and move directly to staining? I was going to use either TWP semitransparent or Armstrong-Clark semitransparent. Previous product was Sherwin Williams semitransparent Super Deck. It’s an older deck (~7 yrs), pressure treated wood. Thanks so much for this website and your help!
Brett
Brett
My parents have installed beadboard ceilings on their porches. They are wanting it to stay the natural wood color. Should these be sealed with a clear sealer or just leave it as it is since it will not be directly exposed to rain or sun?
Kris Evans
Kris Evans
Just spent 2 solid days sanding a 10 year old generic pressure treated lumber deck, and power washing after replacing a few rotted board sections. I let it sit a 2-3 years to make sure I could get all the pigmented “stain” off that I purchased at a big box store. I told my wife, “Never again” will I “stain” a deck with that pigmented crap that just peels up every few years. My deck is about 10-11 years old, (720 sq. ft.), hoping to get another 10 out if it. Don’t want to spend a fortune, as it may only last another 10 years (if that). What would you recommend for an “oil” stain with slight pigmentation. I was think about Penofin, but they recommend resealing quite often. Thanks
Kris
Livonia, NY
j-nette
j-nette
3 or 4 years ago (cant remember) I used the Restore-A-Deck cleaner and brighter on my 2-yr old unstained treated pine deck, then applied 2 coats of TWP 1500. Now it appears to not have any water repellant properties. It’s in full sun about 60% of day. Want to reorder TWP 1500. Was going to power wash. Should I use a cleaner or stripper product beforehand, or will TWP over TWP be ok to not strip? Also, is the 3-4 year timeline typical for needing retreatment for TWP?
Kdonehoo
Kdonehoo
Also, we want the solid stain to match the trim on the house which is sw pure white. Can I get a solid stain that you recommend in that color ?
Kdonehoo
Kdonehoo
A 6 month old deck and railing made from pressure treated pine. We want to do a 2 tone deck and railing. What solid stain would you recommend for the railing?
Also, we are struggling between Twp 100 and Woodrich oil for floors. Recommendations?
Kdonehoo
Greg
Greg
I’m wondering what should be the next step for my deck and what type of wood I have? (Pressure treated?)
I pressure washed with a 1600 psi sprayer as well as sanded some of the deck. The pressure washed section stayed grey while the sanded section turned a yellowish color.
Should I sand the rest of the deck and then I’m thinking of applying an Armstrong stain? I used a 40 grit sander which felt smooth when I ran my hand across it, do I need to go higher grit?
What should be the criteria to selecting the color?
Can I put anything from a transparent to a semi solid on this deck?
I like the appeal of the darker semi solid colors for more UV protection as well as greater concealment of imperfections but as the deck gets quite a bit of sun, the semi solid darker colors may get too hot?
Anne Edwards
Anne Edwards
Hello again..meant to mention I have been using Defy products on my PT deck over the past 5 years per your recommendation. Pleased with results. Anne
Anne Edwards
Anne Edwards
Hi Scott. Just had an outdoor table top made using Cypress lumber. What, if anything, would you recommend to seal/finish it. Prefer natural look. Many thanks. Anne
Bob N.
Bob N.
Thank you, that’s what I was wondering. So then it’s Probably going to be a “TWP” product. Which series would you recommend? Or do you have another brand that you would recommend? I’m ready to go out and buy and get going on this deck. Thank so much for your quick response! This is an EXCELLENT web site!
Bob N
Bob N
North East Ohio, would you be interested in coming down here and doing a deck? 😎
Bob N.
Bob N.
I have to agree with everybody! This site is Outstanding! My question is, I’m about ready to stain some existing and new wood portions of the deck that goes around my house. I like the things you have said about the “TWP” products (solid colors, oil type), what do you think of “One Step” besides the crazy price? I used it once on an old dock, seem to be holding up, but I’m open to trying a different product, such as the”TWP”. What are your thoughts?
tac10
tac10
This site is amazing and wished I had done the level of research provided by this site before I applied Thompson weather seal to my full sun deck. Totally failed after just one year and I had to remove it using Restore-A-Deck stripper and brightener. In any case, living in Canada, I see you outlined 4 products: Restore-A-Deck, TWP 200, Armstrong, and Defy. The deck get full sun the entire day. Which product would you recommend in my case?
Also, I don’t think you have reviewed decking oils. One in particular is Thinking the Bangkirai Natural Shade color. Totally understandable if you don’t have an opinion on this product but what do you think about decking oils vs stains in general? Especially given my full sun exposure. This product claims to have have UV protection “Ultimate protection for exterior wood with factor 12 UV filters to protect against the greying effects of UV damage.”
Also, should I shove the snow off during the winter?
blsd
blsd
I so appreciate your response. Just wondering, if I opt not to use the semi-solid stain, which of the other TWP stains would be next best? I can’t decide if I want the solid stain look. I don’t want to go against your recommendation, but I would still like options. Thanks again!
blsd
blsd
Thank you for your additional information. You have been so very helpful.
blsd
blsd
Hi!
I have an 8 year old construction heart redwood deck that was last stained in 2019 with Messmer’s Natural UV Plus Transparent stain. I know that Messmer’s is manufactured in Utah so I thought it would work well for me, although I’m not so sure I couldn’t find something better. It has held up fairly well, but I want something that might do a little better in my harsh Utah environment, cold snowy winters and hot dry summers. The deck is on the north side of my home so it has both sun and shade exposure. I have had no issues with mold. The deck itself is in good condition, although I should have re-stained last year.
I am thinking that TWP might be a good stain for the deck, but I’m not sure if the 100 series or the 1500 series? I’m thinking a water-based stain would not hold up as well, am I correct? Which stain would be the best for my area?
I realize I will need to strip/clean my deck, what recommendations do you have for products to do that?
My deck is around 400 sq ft with 3 steps skirting the deck on 2 sides. How much stain and cleaner would you recommend? With the Messmer’s, 4 years ago I used 2 gal. I’m not sure how the deck will absorb stain this go around.
I’m so glad there is a forum like this. It is so very helpful for rookies.
Thank you so much.
blsd
blsd
Thank you for your response. I am confused by the difference of a semi-solid and semi-transparent stain, the semi-solid seems like it would be more like paint, which I don’t want. I would like the deck to be more natural. Would the semi-solid provide that effect? Thanks again!
Ray
Ray
What is the best stain, preferably not a solid color, for a floating dock?
Also, what is the best prep method for a 2 year old dock where there is no access to power or water (ie pressure washer/hose) except for the water from the lake?
Thank you and God Bless!
Ray
Ray
Thank you Scott! I have not looked into this stain. The recommendations I had received so far were solid stain from Cabot. Sherman Williams Deck stain, which utterly failed with flaking on my back deck, and TWP 100, 200, or 1,500 series. I’ve been over with options to say the least! I do not have a sprinkler pump but can research one.
I was told by the dock builder that Cabot Natural was applied to the walkway when installed. But they cannot confirm their crew applied it to the dock itself. Do I need to use a product in addition to what you listed above? I’ll attach pictures. Thank you again and God Bless!
Ray
Ray
That is awesome! I am amazed by the help I’ve re here!
If I may, I’d like to lean on your experience, and yes opinion, and ask what color from either brand would you think would look good with the black railing of the dock? I know this is subjective, but I also don’t have an eye for this and know that you have done over 10k docks! So I very much value you opinion! Thank you so much Sir. As a wounded Vet, I salute you and this outstanding customer service! God Bless!
Eliza karlson
Eliza karlson
I stripped my deck with Restore a Deck stripper. I washed the stripper with a high pressure hose. The deck looked okay but railing was pretty bad. We tried stripping all again per their recommendation, then we sanded with 60 grit orbital sander and tried pressure washing. The sealer on it was a penetrating one that was not effective. The power washing damaged the wood, the deck seems okay but railings not looking good. Should we sand again in areas that have sealer and are damaged ? Brighten… not sure how to deal with it. Thank you!
Eliza
Eliza
I just used the regular Stripper, not the paint stripper. So I have to strip with paint stripper again just the railings? Will that damage the deck when it drips?. Can I sand the flat and damaged areas to even out the texture where power strip blew out the wood? Does the deck itself look good for brightening? Thanks Scott…
Don
Don
Yesterday, I used Restore a deck stripper and Restore a deck brightener on my gate and porch post. Clear vertical grain cedar. installed 15 years ago and last stained with Penofin semitransparent oil based 10 years ago. Followed all Restore a deck instructions carefully. Used a pressure washer. The porch post turned out great but the gate has black blotches and is unsatisfactory. What is your recommendation? One photo from this morning after dry time and the other two were after completing the brightener yesterday and still wet.
Don
Don
We have had darkening on all projects where we used Penofin and have stopped using it. I attached a photo that shows our 2nd porch post- which we did not strip yesterday- to show how dark the wood was at the time we started both on the post and the gate- the gate looked the same darkness as the post we haven’t done yet. Is restore a deck the best stripper option? We do have more of that left. Also, we let the brightener sit for 30 minutes. How long is better for more brightening?
M Mathew
M Mathew
Our 1-2 year old pressure treated wood deck was sealed/stained last year with Olympic waterguard transparentwood stain and sealer. The wood looks dry and we want to re-apply more stain/seal for deck maintenance. The deck itself is a little rough but not uneven. Do we need to pressure wash, sand, and then stain/re-seal? or can we just wash the deck, allow it to dry and re-seal? Ie: can we basically just layer a new stain and seal or does the entire deck need to be sanded down?
M Mathew
M Mathew
Thank you: for further reference, this is a full time exposed roof deck in Washington DC where we have both extremes of temperature.
What if we were to use the same brand? Would you not recommend that because of the quality of the product? Here are some photos of our deck.
Christa Spring
Christa Spring
What would be the best stain to use?
Deck location: South central Texas
Sun/shade 90% sun 10% shade
Wood type: treated wood
Mold/mildew: no
Will be staining a new fence and pier (4 years old)
Also, what do I use to prep the pier, it’s been grey for a while.
Christa Spring
Christa Spring
Awesome thank you! Realistically what kind of dry time am I looking at? We have high humidity & can have some really damp dewy mornings and also random rain showers. Does the wood need 2 weeks between days like that before I stain?
Christa Spring
Christa Spring
Whats the rule on how long the wood needs to be dry? We are in a pretty high humidity area and have random rain showers or super dewy/damp mornings. How long does my ages wood need to be “dry” before staining?
Ginny
Ginny
Deck location: California
Sun/shade 70% sun 30% shade
Wood type: redwood
Mold/mildew: no
Last stain: showed wear in traffic areas even though traffic is minimal
Stain: Olympic Maximum semi-transparent black walnut
Terrence Stark
Terrence Stark
So I bought a home with existing deck approx 20 yrs old with 2×6 cedar that’s rotted in various locations. Ive been replacing bad boards with treated 2×6 over past several years and applying PPG Timeless semi transparent/ semi solid water base which in some areas is going over new wood and majority over old which has several coats of who knows. This summer I replaced another 20 deck boards and all the rotted 2×2 balusters on railing that I’m replacing with hog wire. I bought RAD stripper with additives but some of the older stain looks solid which I read it will not remove so I may have to go back to solid. I want to use AC oil but if I can’t remove all of the old stain which I believe is latex will it adhere? I’d like to avoid sanding. Also the deck has new green stripes everywhere and I read stripper will make them fuzzy? I’m thinking I’ll complete the rail system for safety and wait till spring to strip, brighten and stain the deck so the treated has time to weather. Will the stripper solution remain active for 6 months or should I make a smaller quantity? Sorry this sounds so convoluted. Thankyou
Terrence Stark
Terrence Stark
The decking is stripping nicely but I can’t remove baluster marks and I’ve noticed flexible strings of what appears to be paint on some of the railing. Thanks
Terrence Stark
Terrence Stark
Okay Scott I’ve read enough that I’ll use a solid on the areas that won’t strip and go with semi transparent oil on decking. I’ll make sure whatever solid is left on has good adhesion after sanding. Maybe a two tone. Thanks again
Terrence Stark
Terrence Stark
Reply to  Terrence Stark
One more thing I keep reading is semi solid and semi transparent. What’s the difference?
Terry
Terry
Hi Scott, how much time can elapse between brightening and staining ? Also how long after applying ac semi transparent is it rain proof and frost proof? Thanks so much for your informative site
Terry
Terry
Thank you. Also, what is the shelf life of open packages of cleaner and Brightner? Thanks again.
Pam
Pam
In early March of this year, we added a lower level PTP deck to the house we purchased 2 years ago (on a lake in N. Georgia. The house is only 5 years old). The top deck already has white balusters and we just can’t remove and update. I’ve established (through your articles) the prep process and that we’ll use semi-transparent TWC or Armstrong Clark. My question involves color: do you (or do you have have anyone) who will help with color ideas? We need to tie in the white (I think). Our son (who does advertising in NYC and has the technology) mocked up one idea (also included in pics).
1. How do we “stain” white? Or does this have to be paint?
2. We need to do the actual deck floor area in a brown or cedar color, I think, because we have too much gray (hot tub will not be moved to stain)
3. Should top handrail be the same as the floor?
4. Thinking we need dark gray for all the underneath area to help it all “disappear” (we’ll plant in front of the underneath area later).
Adding pics of the deck and one that was colorized. It is NOT currently stained or painted!) Any help is greatly appreciated!!
Pam
Pam
Thank you. One more question: Should we use oil based? I’m guessing yes, but thought I’d ask. TWP 100 will penetrate better than 1500, correct? (I’m aware Georgia doesn’t have a VOC law; we used TWP in our last house) OR, is water based better here?
OK, 2 more questions: We are going to stain the sports and underneath. A 3rd color (charcoal?) would look ok, in your opinion, correct?
Stan
Stan
I am building a home in South West Colorado with a lot of exterior timbers. The timbers are rough sawed fir. The fir is clean and new. What would be the best exterior semitransparent wood stain for this project. Most of the timbers are under roof and partially protected. So all of this is vertical wood, no decks.
Thanks for your help. This area gets a lot of snow in the winter.
Stan
Stan
From reading on the website it appears one needs to wait at least 3 months before applying these stains to new wood, is this your view as well? It seems that I remember a comment that TWP may not be a good product for new wood? What are your thoughts about using TWP 1500 series on new wood?
Thanks so much for taking time to answer these questions.
Stan
Stan
Stan
Is the RESTORE A DECK semitransparent ok to put on now with rough sawn fir or do I need to wait. ?
Stan
Stan
Stan
Thanks so much. Your website and you are awesome. This has been a big help. Have a great day.
Stan
Justin
Justin
I tried staining our deck and it didn’t come out like we wanted at all. I’ve tried using Valspur Wood Stripper to remove the stain and it doesn’t seem to be doing the job. Any suggestions? Thanks.
Justin
Justin
Behr semi transparent
Justin
Justin
It was behr semi-transparent
Willie
Willie
Howlong can u wait to stain a deck after prepping
Tom Robinson
Tom Robinson
Can composite (TREX) deck be stained to different color? and should I use oil or water based? How many gallons to cover 16X32?
Jerry Brown
Jerry Brown
Hello Paul,
Just installed a new deck and screen room in May 2022 with #1 grade pine in Raleigh NC. In reading will wait 4 months before staining.
Question is for my location, what is best stain to use? semi transparent vs semisolid?
Location of deck has very shady location and will not have tremendous traffic on it.
Jerry
Jerry Brown
Jerry Brown
James
James
For pressure treated lumber do you have to stain a deck after stripping it and using brightener and can you leave it natural or does the whole stripping process destroy the treated chemical?
Craig Kohn
Craig Kohn
Does restore a deck fill in the wood where cracked
143
