Hi, I am Scott Paul, an exterior wood restoration contractor and business owner with over 30 years of experience in stripping and removing exterior wood and deck stains. My Deck Stripping tips are based on my history as a wood restoration contractor and actual hands-on testing. See here for more info about me.
- Deck Stripping Materials
- Choose Proper Deck Stain Stripper
- Steps to Stripping a Deck
- Brighten the Wood
- Ask Me Deck Stripping Questions
- Proper Deck Stain Stripper
- Gas-powered pressure washer
- Pump sprayer for applying
- Scrub brush to agitate
- Protective Equipment: Gloves and eyewear
- Plastic sheeting to protect plants and home
- Wood Brightener to neutralize when done
Scott’s Pro Tip: See here if you need to remove a Difficult to Remove Deck or Wood Stain.
Solid Color Stain Stripping
Deck Stain Stripping: Deck Stain Stripper Reviews
See below for my steps when we are stripping a customer’s deck
- Protect the house and any surrounding plants with plastic or poly tarps.
- Remove any patio furniture from the deck and surrounding areas.
- Prewet deck with water.
- Mix the stripper, if needed, in a bucket and transfer it to the pump sprayer if applicable.
- Apply the stripper to all flooring first. If a large deck, break it up into sections.
- Wait 5-45 minutes for the deck stripper to activate. You will know when it is working by using your scrub brush to agitate it, and the stain becomes loose from the wood. Keep the stripper from drying during this process.
- Pressure wash all deck flooring using a pendulum motion and about 8-12 inches from the wood. Rinse well when done.
- Repeat Steps 5-7 with vertical wood.
- Apply wood brightener when done. Rinse well with water 20 minutes after.
Always use a deck stain stripper. These products do 90% of the cleaning work. The power washer should only be used to rinse off the loosened grime—not as the main cleaning method.
Quick Expert Recommendations and Insights
Here are some tips we recommend you follow to make deck stain removal a swift, painless process:
- Use a deck stripper if you are working with wood that has previously been stained. If you are working with a new wood surface or there is no stain on the deck, use a deck cleaner. If you are unsure about what to do, you can ask questions below.
- Remove all furniture from the area
- Wear protective clothing, gloves, and eyewear before going near the product. Mix or use the deck stain stripper according to the directions on the label. Test a small section of your deck before applying it to the whole area, as deck stain strippers vary in effectiveness. You may need a stronger formula if it doesn’t work on the tested area. See here if you need to remove a Difficult to Remove Deck or Wood Stain.
- Apply the deck stain stripper with a pump-up sprayer in sections of 100-300 square feet at a time. Saturate all the wood with one coat then wait 10-20 minutes. If the surface is slippery, that means the stain stripper is working to break the bonds effectively. If the surface is not slippery, apply another coat of the stain stripper and wait longer.
- Using either a brush or pressure washer, remove the old stain from the deck. Take precautions to wash with the grain wood whenever possible.
- Repeat this process until all of the old deck stain has been removed from the deck. Spot strip any sections where the stain didn’t come off the first time.
- Thoroughly rinse all wood and surrounding areas
- Apply a wood brightener to restore the pH balance before staining.
FAQs
How to remove deck stain without chemicals?
The best way to remove deck stain without chemicals is to sand the deck. Where semi-transparent deck stains have faded power washing the deck and spot sanding areas of thicker stain is typically sufficient. When removing a semi-solid or solid deck stain the entire deck may require sanding, but be careful not to over-sand. Over-sanding the wood compromises its integrity and can lead to early deck failure.
Will deck stain come off concrete?
Applying a deck stain can be messy and sometimes you can spill or drip on your concrete or brick pavers that are under or around your deck. Once this happens, it is not easy to remove. We have found that using a deck stain stripper and pressure washing will remove much of the spilled stain but not always as concrete can be very porous. Another option is using a graffiti remover cleaner. You can find these at your local paint store. Popular brands at Goof Off or Mostenbocker’s Lift Off.
Here are the pictures I forgot to attached to post
See this article for tips on how to reapply a solid color stain for best results.
https://www.deckstainhelp.com/how-to-apply-a-solid-color-deck-stain/
We rebuilt our pool deck in the summer of 2023, with new treated lumber decking, posts, spindles. The deck boards were installed in June 2023 and were left until fall of 2024 to stain using Cabot Solid Color Acrylic Deck Stain. We noticed a little bit of cracking/flaking on the deck boards in 2025 but now the deck boards are in bad shape with peeling and flaking of the stain. The railing and spindles are fine as we did stain them indoors before installing them. We have to do something and don’t know where to start. Very disappointed in that we thought we had used a quality stain and waited enough time for lumber to weather.
Not sure if we want to tackle it ourselves or hire it out. Your suggestions would be much appreciated.
Apologies for piece-meal query. Here are a few pictures of the remnants of stain. I’m betting, though, that the whole thing should be stripped? Also, when I had the old stain pressure washed off, it was then treated by a company called ‘Elite Seal’ with a silicate based concrete and wood sealer he marketed as creating a ‘liquid glass’ barrier to moisture about 1/8″ below surface of wood that would prevent deterioration. I can find nothing on the company now, and what I can find about using concrete sealers on wood is not advisable, so I’m not happy. It was great at first but then the wood began to mildew and I’ve been washing it since.
Use this kit while pressure washing:
With both additives for the stripper:
https://www.deckstainhelp.com/product-category/restore-a-deck-stain-stripper-additives
I have ordered the products. The young contractor I hope to help me isn’t available until end of October. I live near Cincinnati, OH. Is this too late in the fall to start this project?
Depends on the weather and the temps.
Note: I tried just today sanding off bits of the old stain. It is too big a job for me (74, female) and occurred to me stripper would be required.
in 2017 we stained my deck and railings with Defy water based stain. The new lumber had been aged over 9 months. But it started flaking off in 3. In 2018 I had it pressure washed which removed 90% of the stain, but little bits remain between boards and rails, and in corners and on porch headers. Now we want to stain it with TWP 1500. What is the right stripper to use, and how long will this take? Total of 280 sq ft which includes all verticals.
Scott, I have a large deck (1,700+ sq. ft.) about ten years old that I will re-stain in about 10-12 days (weather permitting). I will be using TWP’s 1500 Series semi-transparent stain (Cedar color).
For context, here is the prep I have completed:
At this point, I still noticed a few small areas needing cleaning and that have retained a considerable amount of the previous stain (which I believe was a semi-transparent water-based Cabot product in a “Cedar” tone).
Here are my 2 questions: (1) Should I use the RAD Stain Stripper I have on these areas (note I have not used it anywhere else on the deck) and then Brighten, or would you recommend an alternative effort (i.e., sanding/cleaning) to get a result of “uniformity” so there will be a consistent color across my deck after I apply the new stain? (2) I’m certain the new wood I installed is too moist to accept the new stain. That said, would you NOT apply the stain on these pieces until they have sufficiently dried? My thinking is, in a few months time, I could individually apply the stain to these pieces. Thoughts?
Many thanks! – Carl
(Note: Photos attached)
The new wood cannot be stained yet.
Leave all wood as is until Fall. Strip and brighten all wood, then using this kit:
I want to remove my Cabot gold stain off my deck. Is there an easier way besides sanding it all off? What stripper would you use? Also what kind of stain would you recommend for matching my old deck with my addition I put on? Thanks
Please uplaod some pics of the deck so we can help with the prep.
It’s the stain that advertises the look of hardwood floors outside
Unfortunately, a deck stain stripper will not remove this coating. You will probably need to stain it all off.
That’s what I thought. Thanks for your help.
We have raw cedar beams and railings that we stained with Behr last year that seem to be turning yellow/orange to me. I would like to start over and use a high quality stain. Is this possible without ruining my raw cedar beams and railing?
Yes, just strip and brighten with the Restore A Deck Stripping Kits while lightly pressure washing.
We have a brand new cedar deck. We put Behr Waterproof cedar naturaltone on it and it turned orange. Need to get it off but dont want to damage new wood. Stripper or industrial sander?
Advise please
You cannot stain brand new wood: https://www.deckstainhelp.com/how-long-should-you-wait-to-stain-a-new-deck/
As for removal help, please post some pics.
Pics attached
Newly applied stain is very hard to strip and even harder when it is Behr is it is a film forming acyrlic stain. You could attempt to strip it but you may end of sanding as well to get it all off.
Perhaps we should just sand it then? Forget the stripping and cleaning steps?
Yes, you can do this. https://www.deckstainhelp.com/how-to-sand-your-wood-deck/
After we get all the stain off, could you recommend a clear coat waterproofing product for use in Canada? We would like the white cedar to remain as natual looking as possible. Thompson water sealant any good?
Thompsons is useless, and you must have a tint for UV protection from graying.
Hi
I have a 19 y.o tigerwood deck. In the early years I cleaned and stained yearly. Life got busy and now it has been at least 5 years since last treatment. My questions for you are
1. I am planning on sanding rather than chemical stripping. What order of activity do you recommend. Sand/clean/brighten/ rinse/ dry/ stain or clean/ brighten/ sand/stain?
2. Grit recommendation and sander type for tigerwood
3. What is the best stain product and color to return the wood back to its original beautiful state. Thank you!
1. Clean, let dry, sand, brighten, then stain.
2. 60-80 tops.
3. https://www.deckstainhelp.com/hardwood-deck-stains/
I had my entire deck replaced in Aug. 2023, used yella wood. It was stained with gray color stain in April 2024. I live in NW Florida where it gets very hot in the summer. Pitch began showing up as soon as summer hit. In all the years I’ve had a deck and have had boards replaced, etc., I have never had this happen. What is the best way to remove the pitch and is there any way to do it without harming the stain. Also, should I wait until cooler weather. Thanks!
Sap leaching out. It cannot be prevented and you cannot remove without without having to recoat. Sand and scrap it off and then recoat the affected boards.
Fun, fun, lol Thanks Scott!
I plan on applying the deck stripper with a brush to better control the application. I recall reading that certain types of brushes are not recommended for the application of caustic strippers. I have ordered RAD stripper, booster and brightener.
Sorry but I have never used a brush to apply the stripper. Always a pump sprayer as it is very easy.
Why is a water based acrylic sealer harder to remove and re-apply vs an oil based semi transparent or transparent? I thought a water based would be easier to simply pressure wash off every year and then re apply. I’m looking for the least maintenance possible. My deck wraps around my pool, so the least amount of stripping and sanding possible is what I’m looking for to reduce contaminants. And getting on my hands and knees to strip every thing every year is not my cup of tea.
Water-based semi-transparent stains, in general (most but not all), have a tendency to not fully soak in and create a film on top of the wood, while oil-based penetrates better and does not film on top of the wood. For a deck stain stripper to be effective, it needs to soak through the stain, softening the bond between the wood and the coating. When a coating is filming, it is harder and sometimes impossible for the stripper to get through the coating to work effectively.
The easiest maintenance is a penetrating semi-transparent stain as they can be cleaned and recoated and do not peel.
BTW, you do not get on your hands and knees when you strip. 😀
When you say “filming”, what do you mean? And in my case, with all these spots and blotches, do you think I can just take it up with my pressure washer before applying a new sealer, or do I really need to strip? If so, what stripper for a water based clear sealer?
Filming stains dry on top of the wood instead of in the wood. You have to remove or strip it. Post pics in comments for help.
We just stained our deck with TWP 1500 series and it is blotchy. Some areas look dry and some not. We applied with a large deck brush and followuped with back brushing. The first coat seemed to look dry before we began a second coat. It was longer than the recommended 10 to 60 minutes when we applied the second coat as we wanted to get a first coat on. It has been 24 hrs and it is tacky. Will it eventually dry? I tried wiping with a rag of mineral spirits but it made it a mess, pulling the stain off like a peeling sunburn.
This is a new deck. We waited a year and it was cleaned twice and had minimal 80 grit sanding 2 months prior to staining. I thought I carefully read your instructions when applying. I think one coat would have been sufficient as it seemed to quickly dry. It is very hard to judge from the instructions what the stain should look like when applying to judge what it should look like. I saw that one is supposed to wipe off any pooled areas but perhaps after 10 minutes the whole board should be wiped off? Personally I am not sure I would recommend this product as I don’t think the results are acceptable for ease of use. One coat would have yielded an acceptable outcome.
Now what? Will it dry or will it continue to be sticky and what do I do so we can use our deck?
You did overapply. Wipe it all down with mineral spirits and see if that helps. If not, you may need to remove and start over. See this article for some tips: https://twpstainhelp.com/twp-stain-is-spotty-or-shiny/
How can I remove peeling RESTORE Deck stain ? The type that had law suits because it peeled. Thank you.
Not easy but see this: https://www.deckstainhelp.com/how-to-remove-rust-oleum-deck-restore/
I have a large deck that is painted with a solid color stain (previous owners didn’t take care of this house). You can see there are two colors going on here. What do you recommend for removing absolutely all color? There are also a lot of areas with wood rot that need to be replaced. I want to get our deck back to a beautiful brown wood stained color.
Strip off as much as possible and then sand the rest as needed.
I have a large deck built with treated wood. It is partially stained with a stain that was too red. I want to remove this stain and apply a different stain, one with more brown tones. How can I prep the whole deck (stained and pressure treated) so it takes the stain equally?
Post some pics in comments for prep help.
Hopefully you can see this picture
It looks thick, almost opaque fully. What brand is this, Behr? They lie about their opacity.
Age of porch with bloody dog footprints in recent comment – 25 years
Removal of dog blood from porch,several bloody dog footprints from an injury; porch never been stained or painted, advise removal of the blood,
Sorry but not if anything will more blood if deep into the wood. Try a deck cleaner and then a wood brightener while pressure washing:
If that does not remove it, you may need to cover the wood with a solid stain:
Good Evening, I have a 20-year-old Cedar deck that I need to re-stain as so as possible. I believe after reading so many posts I should try the Restore A Deck. I’ve been trying to see if it kills grass and flowers. Any advice will be greatly appreciated.
All prep and stains can damage plants so best to cover them while working.
it’s great you’re providing this resource! The deck I am working on is a hardwood deck that has been stained with an oil semi transparent stain every year for the last 15 years. Some of the decking was black before I started this project. So far, I have used a stain remover, followed by a wood brightener. I have not achieved my desired appearance yet. Can you please provide advice on how to proceed? I have attached photos.
It looks like you “furred” up the deck from stripping. See this for tips: https://www.deckstainhelp.com/wood-fuzzies-furring-on-deck/
Just following up to say that it’s looking much better. I used the floor buffer with 60-grit mesh sandpaper and a scrubbing pad as backer on the entire deck which really helped to bring back the wood grain appearance I’m looking for. Is it ready for stain, or should I do something else before that? The look is a little inconsistent, but the stain will probably blend everything and make the inconsistency disappear.
Brighten all wood for final prep.
I had a new deck installed 3 years ago. I treated all the wood with Penofin (clear) blue label at that time. It, of course (now reading your reviews), turned to a dark gray. I used a product called Sun Frog Deck Cleaner to prep the deck for re-treatment. I was unhappy with the Penofin because water seemed to just soak into my deck and I live in Oregon and we have a lot of rain. I then saw that Penofin made a product that was a Stain and Sealer so decided I would try that. They didn’t make it in clear, so I chose the Cedar finish (it is a cedar deck). I should have stopped immediately, but with the rainy season fast approaching, I figured I just needed to get something on the wood. Now, however, I just can’t stand how dark it has made my deck. I need your advice – I have thought about just completing the deck in this Penofin so that when I attempt to strip it next year at least it will have a similar look everywhere. That is, unless there is a product that can completely remove all this freshly applied Penofin. The staining is about 1/3 completed. So, is there a product that will completely remove this fresh stain? Please tell me all the products I should use (it sounds like a brightener is another important step, that I have never used). The TWP 100 series is rated the best on your site so I will use that next time (should I get clear or cedar to get the look that you have on your banner above?). Thank you so much for your help!!
Leave as is and strip and brighen in the Spring. Use the Restore A Deck Stripper and Brightener kits.
