This post was updated on April 5, 2026
Hi, I am Scott Paul, a leading exterior restoration contractor and business owner with over 30 years of experience in exterior wood cleaning. My Restore-A-Deck Kit review is based on my history as a wood restoration contractor and actual hands-on testing, all designed to present you with the top deck stain choices. See here for more info about me.
Restore-A-Deck Cleaner Kit Update 2026
The Restore-A-Deck Cleaner Kit remains our top performer for the 2026 deck season. It is easy to work with, very cost-effective, and produces great results! Please read this article and post any questions you have in the comment area below. Our newly enhanced website now allows you to upload and post pictures of your exterior wood or deck. This will help us determine the proper prep for your deck using the Restore-A-Deck Cleaner and Wood Brightener Kits.
Below is a YouTube Video Review of the Restore A Deck Prepping kit. This is from an actual consumer and is very informative and helpful.
9.0 Overall Rating Restore-A-Deck Stain Cleaner & Brightener
The Restore-A-Deck Cleaner System is a two-step wood cleaning and brightening kit designed to properly prepare exterior wood before staining. It uses a powdered concentrate formula that is mixed with water, making it both cost-effective and easy to store.
From my experience restoring decks since 1993, proper prep is the most important step in any deck staining project. A system like Restore-A-Deck is designed to remove dirt, grime, and old stain residue while restoring the wood’s natural color and pH balance.
Overall, Restore-A-Deck is one of the better-performing cleaning systems available and is a key step in achieving long-lasting stain results.
Restore-A-Deck is the only product on the market that offers both a Step 1 Deck Cleaner and a Step 2 Deck Brightener in the same kit. Restore-A-Deck comes in a powdered concentrated formula. Each 2 lb container makes 5 liquid gallons. Pour each into a five-gallon container and add water to dissolve the powder concentrate.
🔹 Quick Verdict – Restore-A-Deck Cleaner System
Restore-A-Deck Cleaner System – Quick Review
- Best For: Proper deck prep before staining
- Not Ideal For: Skipping steps or light maintenance cleaning only
- Type: Powdered cleaner and brightener system
- My Overall Rating: 9/10
Restore-A-Deck is one of the most effective and consistent deck cleaning systems I have used. It does an excellent job of preparing wood for staining when used correctly.
How I Rated Restore-A-Deck Cleaner Kit
My Restore-A-Deck Cleaner Kit review contains a 5-step process and the final average score. Each step is on a scale of 1-10.
- Removal of Graying and Dirt
- Removal of Old Stain (if applicable)
- Ease of Application
- Restore-A-Deck Cleaner Kit Final Score
5-Step Review of Restore-A-Deck Cleaner Kit
The Restore-A-Deck Step 1 Deck Cleaner did very well at removing general dirt and grime. The deep cleaning formula made breaking down the gray wood cells easy. All mold was also removed. The Step 1 Deck Cleaner did not remove some rust stains from the furniture, but the Step 2 Brightener did.
2. Cost Per Square Foot: 10
The best on the market today. The cost to clean and brighten an average 600-square-foot deck is less than $.07 a foot. Since Restore-A-Deck comes in a powder we like, you only need to mix as much as you need. Very little waste.
3. Removal of Old Stain: N/A
RAD products are designed to clean, not remove, old deck stains. We would presume that they would remove a deck stain if it has deteriorated drastically.
4. Ease of Application: 8
RAD does not come in a liquid. You need to measure 6 oz per gallon of water and mix the entire 2 lb. container into 5 gallons. This product can be applied easily to a garden pump sprayer. We needed to make sure to mix at the correct dosage; otherwise, the powder would not completely dissolve. Testing was done with both scrubbing and pressure washing. Both worked well. Step 2 brightener does not need to be scrubbed, just rinsed with water after 10 minutes.
5. Final Appearance of Cleaning: 9
The IPE wood deck looked brand new after cleaning and drying for 2 days. We would have given this a score of 10 if it was not for a couple of minor water spots that did not come out. These spots looked to be from planter boxes.
Overall Score for Restore-A-Deck Cleaner: 9
Restore-A-Deck is a great and economical product for restoring your deck to like-new condition. We really like that the kits contained both the cleaner and brightener. This was easier than buying the products separately.
Manufacturer: Restore A Deck
Product Type: Powdered Concentrate. Kit contains Step 1 Deck Cleaner and Step 2 Deck Brightener.
Deck Wood Type: IPE Exotic Hardwood
Deck Square Footage: 500
The condition of the Deck: Heavily grayed with mold/mildew. No previous stain
How Much Product Used: RAD 300 Kit. Retails for $64.99
🔹 Pros and Cons – Restore-A-Deck Cleaner & Brightener
Restore-A-Deck Cleaner System – Pros
- Highly effective at removing dirt, grime, and old stain residue
- Brightens wood and restores natural color
- Powdered concentrate makes it cost-effective
- Easy to mix and apply
- Works well on most exterior wood types
Restore-A-Deck Cleaner System – Cons
- Requires proper mixing and application steps
- Must follow with brightener for best results
- Not a one-step process
- Can damage surrounding areas if not properly rinsed
🔹 Best Uses for Restore-A-Deck Cleaner & Brightener
- Prepping wood before staining: Essential step for best results
- Removing graying and weathering: Restores wood appearance
- Cleaning older decks: Prepares surface for new stain
- Stripping light residue from previous coatings: Helps improve absorption
Not Ideal For:
- Skipping prep before staining – this is not optional for best results
- Heavy paint or solid stain removal – may require a stronger stripper
🔹 Application Tips – Restore-A-Deck Cleaner & Brightener
- Always mix according to instructions
- Apply evenly to damp wood
- Allow proper dwell time for cleaning
- Rinse thoroughly and follow with brightener
Proper prep is the foundation of any successful deck staining project.
- Always clean and brighten before staining
- Do not skip the brightening step
- Allow wood to dry completely before applying stain
- Proper prep will improve stain penetration and longevity
From my experience, most stain failures are due to poor prep—not the stain itself.
🔹 Who Should Use Restore-A-Deck Cleaner?
- You are preparing a deck for staining
- Your wood is dirty, grayed, or weathered
- You want consistent and reliable prep results
- You are using a penetrating stain system
- You need to remove heavy paint or solid coatings
- You are looking for a quick, one-step cleaning solution
🔹 FAQs – Restore-A-Deck Cleaner & Brightener
Do you need both cleaner and brightener?
Yes, both steps are required for proper wood prep and best staining results.
How long should you wait before staining after cleaning?
Typically 24–48 hours, depending on weather and drying conditions.
Can this remove old stain?
It can remove light residue but is not designed for heavy stripping.
Is it safe for all wood types?
Yes, when used properly according to instructions.
Can you skip the brightener step?
No, skipping this step can lead to poor stain absorption and uneven results.
How often should you clean a deck before staining?
Every time before applying a new coat of stain.
🔹 Final Thoughts – Restore-A-Deck Cleaner & Brightener
The Restore-A-Deck Cleaner System is one of the better deck prep systems available and plays a critical role in achieving long-lasting stain results. It is effective, cost-efficient, and works well across most wood types.
From my hands-on experience, proper cleaning and brightening is the most important step in any deck staining project. Using a system like this will greatly improve stain performance and longevity.
If you want your stain to perform the way it should, proper prep is not optional—it is required.
An Independent YouTube Customer Review
Restore-A-Deck Cleaner Only
Hi Scott I’m staining a 2 year old cedar deck that was weathered and I managed to clean it pretty well. The deck has never been stained. I installed it myself. I’m wondering if I should use a brightener on it. What are your thoughts? As well as have you ever used C2 Guard products? Any help would be great Thank You
No on C2 and yes on using a wood brightener. It is easy and will only help.
Just resurfaced my deck with new above ground pressure treated boards . . . was told to wait 2 months for it to weather properly . . . it sounds like you recommend using the RAD deck cleaner and brightener just before I stain the deck . . . at that point, do you recommend the RAD stain (I need a light grey semi-transparent) or one of the other top brands you mention?
3 or more months of weathering and then the prep. The RAD Cottage Gray would work well or Armstrong Clark in Driftwood Gray.
Can I only purchase this online?
Melissa
Website or Amazon.
Is there a clear penetrating sealer that you recommend for use over unfinished pt wood and/or cedar? I like the natural look of wood with no color added. Is the RAD kit sodium percarborate and oxalic acid?
Clear sealers = No UV prtection from graying:
RAD prep products contain additional ingredients to perform better on wood.
I can’t find my question from before to respond back to …..sorry!
I have a back deck and the wood flooring is probably 15 yrs old. I didn’t mention the age of the floor in the first text. A few boards were replaced. It was sanded and sealed with 2 coats of Thompson water seal last fall 2023. This July I had new wood railing put on this back deck and also had a new wood floor put on my front deck.
You had asked what the back deck was
sealed with so am replying to that question. I was thinking I needed to at least take care of the back deck floor and do the new wood and railing next year 2025 but you suggested waiting and doing all in 2025. If it’s ok to wait till next Spring to do everything I’m ok with that. I was worried about trying to get it all done now because of cooler temps.
Spring will be fine to do it all.
I have two 15-year-old pressure-treated decks, and 90% of the wood for both decks was replaced about four years ago with newer pressure-treated wood from Home Depot, although I’m unsure of the exact type of wood used as replacement. The posts, ledger boards, joists, beams, and rim boards are original, while the rest is newer. I live in Ontario, Canada, where we deal with cold winters and wet rainy seasons.
The deck has never been cleaned or stained, so it became grey with some green spots. My wife saw a TikTok video recommending a 1:1 mix of pool chlorine shock and water for cleaning. I applied it with a pump sprayer, waited 15–20 minutes, then thoroughly rinsed with a garden hose. I didn’t scrub, but now the deck looks bleached white with a fuzzy top layer, and I even suffered some chemical burns during the process. Unfortunately, I didn’t know a neutralizer was needed afterward, as I’m unfamiliar with deck maintenance.
Here’s my question: Should I start over by cleaning and neutralizing with a kit like Restore-A-Deck and using a hard bristle brush, followed by sanding with 80-grit to remove the fuzz? Or should I sand first to get rid of the fuzz, then clean and neutralize before staining with a semi-transparent oil-based stain? I’m concerned that if I sand first, the cleaning process might bring the fuzz back, requiring multiple rounds of sanding, which I want to avoid. Additionally, with Ontario’s rainy season approaching, my fear is if I finish sanding after cleaning or sanding prior to cleaning (which ever you recommend), how much time do I for the wood pores to stay open before I start the staining process? So what if I finish sanding, and it rains for an entire week, do I have to sand again or clean/neutralize again prior to staining???
Lastly, because the deck is pressure-treated, there are still visible remnants of green chemicals on the wood surface. If I use a natural wood-colored semi-transparent oil stain, will those green areas show through? Also which oil based stain brand would you recommend for this specific job? Sorry for the long message, but this process has become quite confusing and overwhelming for me.
Yes, redo the prep with the RAD Kit. If needed, buff off the furring after the cleaning and before the brightener:
You can just wait until Spring if concerned about the weather. The green will show through. You cannot do anything about that. It is minor in your pictures so not that big of a deal.
Look at Armstrong Clark stain or the TWP 200 Series.
I have a new deck that is 6 months old that I am wanting to seal/stain. It is #2 treated “GC” wet (per material list) in Houston, TX. What is the best TWP product for stain/seal (100 or 1500) and what is the best prep before applying the stain/seal?
Use the TWP 100 Sereis and their Gemini Restore Kit for the prep.
Hi, I installed my cedar railings back in April 2024 and stained with Ready Seal Clear stain. There was an unexpected rain started 1-2 hours after I applied the stain which I was worried about. Seemed like the rain washed off the stain but it looked well when it’s dry. It was ok for the first 1-2 months but after some time I started to see some black spots then it got worse over time (please see the current status in the photos). There is no problem on the lower side of the railings though.
Now I’m planning to remove this mold/mildew then reapply a light coat of a Ready Seal. Should I use this RAD cleaner kit for this purpose or RAD Guard Mildew Cleaner & Preventer ? or any other suggestion for removing mold, prep and seal in my case?
Thanks in advance!!
Prep with the RAD Cleaner and Brightener if you plan on sticking with the Ready Seal. If you want a better stain, then prep with the RAD Stripper and Brightener kit and switch to the RAD Stains or TWP Stains.
Hi, I am using your Stripper, Booster and thickening gel. my deck is large cedar deck (over 1k sq ft). 2 years ago i put RaDeck semi-transparent stain on it. I probably didnt do it correctly and it was peeling up all over. I have decided to not use any colored stain in the future and just letting it turn gray then using cleaner/brightener periodically to clean it.
During my first run of stripping on a section it didnt get all of the transparent stain up. I have work to get the rest done. I did not use brightener so it is darker which I read is normal.
After I finish the entire deck. I was planning on using the stripper again to focus on where all the stain didnt come up. the first phase of stripping will take a few weekends.
4 questions.
1) is it fine to use just the brightener some time period after i use the stripper or do you have use it right after using the stripper even though I still need to use more stripper at the next weekend to remove the stain that didnt come up?
2) is it ok to wait until spring after stripping and and then do the cleaner and brightener?
3) if i just let it turn gray do you recommend just using the cleaner and brightener to clean the deck?
4) i am sure the wood fuzzies are due to not using a brightener and some from the power washer even though i try to not do it strong on the wood. I have had these before I believe they just went away over time? or will the future cleaner and brightener help remove these?
1. In your scenario, it is okay to brighten all when done with the stripping.
2. Yes.
3. Yes.
4. It should but read here for more info:
It’s been one year since I installed a brand new pressure treated deck. Is it recommended to use the cleaner and then the brightened before applying semi transparent stain? Thanks in advance.
PS: I’ve used both the cleaner and brightened in my cedar docks with GREAT results. Hoping the results will be similar with pressure treated pine.
Yes, that is correct.
Sanded to rails last year and applied one coat of light walnut stain. Can I just lightly sand and recoat? Keeping cleaner or brightener off my deck while doing the railing will be very difficult.
Sanding is not the best way to prep. Best to use the Cleaner and lightly wash. You can mix their cleaner at 1/2 strength. Rinse the rails right away and you should be okay. Probably do not need the Brightener since you have a base coat.
This is Carol again Also wondering about the Behr Deckover
It peels: https://www.deckstainhelp.com/behr-deckover-review-updated/
Can this be used on Composite Decking by name of CORRECT DECK. About 13 years old. Also read some of your articles on staining or restoring composite decking. Do you still advise TWP Semi-Solid Pro Series? You recommended for composite but when going to TWP website composite isn’t mentioned. It is hard to find definitive information on restoring Composite decking. Especially my type as company of course went out of business. It was listed as “polypropylene (one of the harder
plastics), reclaimed hardwood fiber, UV-inhibited
pigment systems and selected process additives”. from brochure.
Do you recommend TWP over BEHR PREMIUM® Solid Color Weatherproofing All-In-One Wood Stain & Sealer or Rustoleum Rock Solid. Also question Behr Deckover.
Any help appreciated.
Post some pics of the deck. Do not use Behr or Rock Solid. Both are extremely poor and you can read the reviews on our website.
I realize that you reviewed the cleaner/brightener product Restore-A-Deck Kit and liked the results. Have you also reviewed or have knowledge of “Gemini Restore A Deck” product? It appears to be touted by the TWP folks. Are these two cleaners/brighteners similar in their results?
Same product but RAD private labels for Gemini/TWP.
Need to refinish deck. Don’t know what the original finish is. Poly or stain?? When we moved in it was stained and lovely shiny finish. The wood grain was visible. I had painters refinish a few years ago, but I don’t think they did a proper job as it was never as good looking as original. I am guessing they just stained over original stain finish. I have pressure washed and used a putty knife to remove whatever they put on. It was a gooey film. Which product do I need to get deck where I can use your finish product.
Post some pics for prep advice.
Front Porch deck 45′ x 6′. boards next to house less sun bleached. It all used to be homogeneous in color with a nice sheen. I power washed and scraped up the film that was loosened. My wife wants her shiny old deck back. Thanks
You cannot use a shiny finish on a deck or porch. It will peel if you do. You want a penetrating wood stain so it does not peel.
You will need to sand this down to fix it.
i recently placed an order for Restore A Deck solid color stain but never received a confirmation email. Please let me know how to contact your sales dept to confirm my order. Thanks , David
Best to contact them directly at sales@restore-a-deck.com for assistance.
For my pine deck installed September 22, my carpenter recommends Restore a deck system. Today( feb 23) he looked at it and said i could skip the cleaner and just use brightner before staining. I saw some mention of cleaner being part of a “ ph balance”. Should i use both?
You need to clean and brighten. Brightener by itself does not prep new wood.
My deck is thirty year old redwood that was planed as well as new cedar. A Cabot UV clear stain was applied. I live in southwest New Mexico. After three months we had lots( more than last 30 years seasons) of rain. Attached are pictures of what looks like mold all over the decks, one is 700 ft, the other 144 feet. This stuff is on railings and steps as well. I’m pretty freaked out. Can you advise me how to get this off. I’m chemically sensitive and have pets so, nontoxic options? And then what type of clear protectant/ stain do you recommend. Thanks
No pics.
Ok trying again. The weird thing is I tried using a scrub brush aggressively on the redwood (it was dry) and most came up but not when I used the brush on the cedar. Also on the brush the debris looked greenish grayish brown, not black. The Cabot product was water based not the Australian Timber product. There is none of this black stuff on the vertical posts but it is on the slanted arm railing.
Strip and brighten for prep with Restore A Deck products. Stain with Restore A Deck Stain in Light Walnut or Defy Extreme for best results in preventing mildew.
Here are the pictures you asked me to post
Most of it is just dirt from the water that dries off. Some is mildew. Try cleaning with some warm soapy water (dish soap) and a soft bristle brush like one used for a car. If it is laying on top of the stain it will wash off. If it doe snot come off and is embedded in or under the stain, then you may need to strip the stain and start over.
I have a new deck built with pressure treated wood. It was left to dry for a several months before staining with a semi transparent deck stain PPG ProLuxe premium deck wood finish transparent satin. High performance for exterior wood natural 078 color. First coat looked great and second coat wasn’t applied till after the pollen season. After a time I noticed black spots and streaks on the deck. Don’t know if this is worth mentioning but the shingles on my roof has black streaks as well. I’ve spent considerable amount of money having this deck built and I’d like to use the right cleaner to remove the black stains. Please advise!
Post some pics.
My two year old large cedar deck was treated with a clear water based sealer. It looked fine when new, but rain has lifted off the sealer it spots. I am switching to an oil based clear sealer. The deck is clean but I I have “worn” sealer on much of the deck and bare cedar in some areas. What’s the best prep strategy? A deck cleaner + brightener?
No. You need a stripper and then a brightener.
can i use restore-a-deck cleaner and brightener on trex ?
The cleaner, yes. The brightener would have no effect or need on trex.
I have a deck that is treated wood and has been in place 15 years. I have occasionally power washed the deck to bring back the original wood look. The deck is in good shape and has that gray faded look. If I use Restore a Deck do I have to power wash the deck prior to applying? Will I need to power wash after applying?
You apply the cleaner and then pressure wash it off. Brightener goes on after.
Ok. Just to be clear. When I pressure wash off the cleaner is it the same as pressure washing more heavily the deck without the cleaner or is it a slight pressure washing
Not very heavy. About 8-12 inches away from the wood. More like a high-pressure rinse.
Great. So the Brightener does not require a pressure wash?
If I were to use a clear stain what would last and for how long?
Just rinse the brightener after 15 minutes. Clear sealers have no UV protection so they will gray in months. It has to be tinted if you want to protect it from graying.
My decks has been stained with the Cabot Australian timber Oil natural . I last applied it 12 months ago, Still showing water (pooling ) resistance . I have no problem with the product except my deck is much darker then I want. I need to start over -Wood is in good shape –Will the restore a deck Clarence and brightener work on the Cabot AUS Timber Oil product considering the fact the wood seems to be sealed fairly well ?
No, you would need to remove it, not clean it. Try the RAD Stripper with both additives and then brightener: https://www.deckstainhelp.com/restore-a-deck-stain-stripper-booster-thickening-gel-review/
I am miserable with my deck. The deck itself is old and many boards have been replaced. So I have kept the deck in good shape as far as the deck boards go. I started using a solid deck stain about 6 years ago. I am using a dark color, black, ebony, etc. Up until this year I have been very satisfied. But this year beginning when the weather started getting right to put new coats on my deck, I decided to use Valspar Solid Deck Stain in a ebony color. I prepped my deck like it should be. Removed all mildew, dirt, etc., and sanded the deck all over to smooth places out. Started painting my stain on my deck. I (73 years old, female, lots of energy and love to work outside.) Am by myself so I used a good brush to put the stain on with and took my time in making sure all looked good. After finishing all of my side deck I left it totally alone and did not allow any walking on it and waiting for several days to make sure all was dry. At this point my deck looked really good. BUT, after about a week or so when I start working in the yard, and the dog is running back and forth across this deck, of course there was mud, dirt, and droppinngs from trees. I of course washed it off really good. Mud stains and dirt stains and droppings from trees were still very noticible on this deck. I have never had that to happed and it looks awful and so very dull looking. I put a cleaner on the deck and took a outdoor broom and scrubbed on it and still no difference. It looks dirty all the time and is driving me crazy. So my mission has been to find something to make my deck look like new, like it always has after refreshing it for the past 6 or 7 years. I wanted to get something on my deck that would give it a sheen (look somewhat shiney) and at the very least look clean. Well I bought a small can of Rust-Oleum Stain + Polyurethane (Ebony in color) I just finished painting 2 boards to see what this looks like and it looks great. BUT I read your article that tells me NO POLYURETHANE – will not hold up!! Please, please tell me what I can do. I am so wiling to paint the whole deck over again if I can get that look of at least being clean. Still would like a shine to it. PLEASE HELP ME. I have talked to Valspar people, talked to Sherwin Williams people, etc. They basically tell me nothing I really can do about the dirt and grime.
Carol Ann Beckum
Jackson, Mississippi
601-502-6965
You can never apply polyurethane over a deck stain or on exterior horizontal wood. It will peel. No shiny coatings as well, as those will peel tp. Your only option is to try another solid color deck stain but they are not immune to dirt or mud. No stain is.
I have a painted white wood deck that gets black mold/mildew on it. I’ve used bleach based products in the past. Will any of these oxygenated products work? I usually apply with a sprayer and power wash it off.
They should.
I have just had a mangaris deck sanded. it was originally coated with a rosewood oil stain. After sanding, It came out very clean. should it still be power washed with cleaner, brightener after sanding?
For best results, yes.
I don’t have a hose hookup or a way to pressure wash my deck… any recommendations? Can you use the cleaner/brightener without long rinse afterward? Is there an alternative cleaner I could use to prep? Thanks…
No, you need water and pressure.
Another question: we are still wavering between oil-based and water-based stain. Our climate is very wet with heavy snow in winter – do you have a recommendation?… I am leaning toward RAD water-based at least for the floor, as it can be applied wet, and we seem to rarely dry out here (I have done a test section with Restore a Deck already – looks good) but I am wondering about the re-application process. Is re-application of oils significantly easier than water-based? Will the RAD require complete stripping every few years to reapply? (would oil-based like TWR 1500 require the same?). Thanks in advance!
Both TWP and the RAD stains can be cleaned and reapplied as needed without stripping. Same prep.
great, thanks.
do you recommend one over the other for wet ( and snowy) climates?
No.
Are the cleaner and brighter products safe for the rubber roof that my deck sits on?
So where can I purchase the Restore a Deck Cleaner Kit?
https://www.restore-a-deck.com/RAD-Kits-Best-Prices.html
can I use rad on cedar siding that was poorly sealed 3 years ago? would like to apply a light semi transparant stain afterward.
You may need to strip it. Post a couple of pictures.
No pictures.
Picture of cedar three years old
Your pictures are not uploading. They have to be below 4mb.
Looking to finally add stain to a pallet deck I built last summer. I used a variety of pallets so there are also a variety of wood species. Attached are three pictures. First is the completed deck while dry. Second is the deck after the rain (and the look I am going for). Third is the deck in it’s current state after power washing (without use of cleaning agent).
My next step is to sand, then I plan to either do a soap and water cleanse or use the Restore-a-deck cleaner and brightener to finish the prep. Which would be preferred?
Will the Restore-a-deck semi transparent stain give the wood the “wet” look I want?
No pictures.
2nd attempt. Also wondering if the Armstrong Clark Natural Tone Transparent Stain would be a better choice…?
Use the RAD Cleaner/Brightener kit for prep. The Natural in RAD will give close to a wet look. Same with the AC Natural tone.
First two pictures are from last summer, third picture is from yesterday.
There is sap seeping out of our 8 year old deck on certain slats. What can I do to remove it? Presently sanding deck for refinishing and sap is still there.
Nothing we know of will remove sap outside of sanding.
This is a great site and has been very helpful in helping my newbie self figure out the best way to restore a very old, mistreated deck. I do have 1 question. Squirrels have been chewing at portions of my deck. I know the stain should help to deter this, but they are getting to some portions on the underside that are very challenging to clean and stain. Is there a simple alternative you know of to deter the chewing that wouldn’t involve staining the underside? Many thanks again!
No, and stain will not prevent this from happening either. Maybe call a pest control company. They might have some ideas.
Is it ok for a redwood deck
Yes, it is.
I have a deck that that I have power washed. After I power washed 50% is down to the wood. I am planning on stripping the whole thing (as it will be impossible to just do the parts that need it), brightening, then staining. Is that correct?
I have a cedar deck that does not need to be stained but needs to be cleaned of green algae. Do I need the Brightner? TIA
Brighteners will not remove algae. Anything too aggressive will remove stain so try just water and a little bit of dish soap.
I just want to clean the deck after the winter. Pressure treated, nothing special. No additional staining or sealing. It was just stained last year and color is fine. Would i use both the cleaner and the brightner or just the cleaner?
Prep products are only to be used when reapplying. They are not used for general cleaning as you will remove some stain. Try warm water with some dish soap and then rinse lightly to clean off dirt.
I have a 450 sq/ft cvg t&g doug fur screened porch that was stained 5 years ago with Sikkens ProLuxe Ceto SPD FE semi transparent in Teak. The fully covered areas still show color while the areas nearest to the outside have greyed. Should I sand then brighten. If I sand is 80 grit the proper paper and how long should I wait to prep and stain. Pics included
Do not sand. Strip and brighten the wood for prep using the Restore A Deck Stripper/Brighener Kits. Apply one coat of Restore A Deck stain after.
I have a new pressure treated deck that has weathered for 6 months. It faces south and gets a lot of sun. It is raised about 6 feet off the ground. I want it to be gray as that will look best with the house color.
-No need to do undersides unless you want for appearance only.
-You should still at least prep and clear coat it. It will still gray but it will help to protect from rot and decay.
I want to say thanks for your website but feeling a bit overwhelmed and had not seen a question like mine posted, so I wanted to reach out. See pictures I am not sure how old the deck is but have not been great at maintaining it (that will change with your guidance!). I pressure washed it in the fall and this is the current status. My issue is that my deck currently has virtually no stain or protectant and I want to get something on it ASAP. Unfortunately my wife wants to paint our home and that will most likely cause us to change deck color/stain (once we determine paint house color). I expect that that we will paint home during summer/fall 2021. And once we pin down the color we can find a stain that matches we will stain/re-stain most likely spring 2022. So given that, I wanted to get your thoughts on what to do. Given the pictures(and I can add more) I think I can skip pressure washer again, and just use RAD Cleaner or do you recommend pressure wash and then RAD Cleaner? After that I suspect given pics/age I need to use RAD brightener? Lastly, if I just want 1 year protection so we can finalize a stain what do you recommend I do? Ideally I don’t have to repeat the process in a year and whatever I apply to protect for a year won’t have to be stripped off. Thank you
For prep, you would need both the RAD Cleaner and the Brightener while pressure washing. As for the stain, try Armstrong Clark or TWP Stains.
In 2019 I applies TWP 100 Semi Transparent Redwood stain-oil based to my redwood deck. It has performed extremely well, but showing signs of wear so it is time to re stain my deck. This year I plan to use the same TWP 100 semi transparent oil based stain again, but want to change colors because the color was too red and unnatural.
Do I need to remove the old stain first? If so, what product should I use?
Strip and brighten for prep. Use the RAD Stripper/Brightener Kits.
I ordered RAD stain stripper with the booster and thickening gel additives to remove an oil stain from cedar posts. I also ordered the RAD brightener. Your article recommends using the brightener after stripper. Do you use the brightener immediately after using the stripper and power washer, or do you let the wood dry for a few days before using the brightener? Thanks
Brightener right away while wood is wet from the stripper.
I want clean and repaint my deck. But the weather is getting cold now. So I am planning to do it next spring. what should I do keep it in good condition during winter months.
Paint is peeling off. And I want to restore and stained or paint it properly in next season. Because stripping and cleaning will take time before I paint it. so I will not be able to finish everything right now.
Please advice me what to do.
I would also like to know when I am ready to do it which cleaner and stripper will be best for it.
Thanks again.
Strip and pressure wash off what you can and then sand after. Remove what is loose. You can cover the rest.
Used your products for cleaning and brightness
Worked well… however have a few minor small spots where evidently when stain was applied at edges of deck and was missed on spread out with deck brush …is there any product you would recommend to remove the
“Too much applied stain after three days“
You cannot spot fix this.
Our 25+ year old Pressure treated wood deck was cleaned by a company, Superior Soft Wash, and I need to seal it and was considering using Restore-A-Deck stain. Some of the old stain is still visible. Since it was soft-cleaned, not pressure washed, would you recommend doing any other prep or can I just stain it using RAD semi-transparent stain.
You have to fully remove the previous coatings when switching brands.
I have the older type of Trex composite decking without the wood grain surface. What is the best cleaner for this? I have tried Olympic, 30 seconds and Duckback composite deck cleaner. The one I thought would work best and was the most expensive (Duckback) did not work well. The others were just O.K. I heard Defy was good but it is a powder you mix with warm water just like the Duckback that foams. Before I spend any more money on something that works, thought I would ask your opinion.
Peggy
The Defy should work but it really depends on how bad the Trex is. The older Trex had lawsuits due to mold and issues and they never really cleaned up well.
If you have ice and water barrier under decking what kind of cleaner can you use? Will cleaning ruin the ice and water barrier?
No, they should not. Try the Restore A Deck Cleaner and Brightener Kits.
These are pictures of a 15 year old deck in northern WI. The light colored boards were pressured washed (took way to much time) and the darker boards are what I’m dealing with. It is pressure treated lumber but it’s never been stained or painted. Will Restore-A-Deck and a pressure sprayer clean the layer/years of dirt and mildew?
Yes, it will help. Make sure to brighten when done.
