TWP 1500 Series Stain Review 4.4/5 (24)
TWP 1500 Series Stain Update 2026
We find that the TWP 1500 Series Stain to be the best performing oil-based deck stain on the market.  We personally use the TWP 1500 Series Stain on deck restorations every year in the Midwest and is one of our go-to brands.
TWP 1500 Stain Rating
TWP 1500 Series Deck Stain Ratings
TWP 1500 Series was introduced in the Summer of 2010 as the replacement for the TWP 500 Series. TWP 1500 stain is a semi-transparent oil-based wood preservative registered by the EPA. The only deck preservative that is currently registered as an exterior wood preservative.
TWP 1500 Series is designed for all exterior unfinished wood. It has excellent UV resistance from graying. It is mostly used for exterior wood decking, wood fencing, log homes, cedar sided homes, etc. TWP 1500 comes in 10 colors that allow the natural grain of the wood to show through.
TWP Stains – 1500 Stain Rating
TWP 1500 Series Deck Stain Scores (1-10)
– TWP 1500 Series had a beautiful rich look to the wood. The wood grain was highlighted naturally. 1501 Cedartone color was slightly brown for a traditional cedar color.
– Excellent at preventing UV graying at the two-year mark. One of the top stains that we have tested in terms of absorbing the UV radiation that causes oxidation of the wood.
Wear/Tear and Peeling: 9
– Very good at preventing peeling. TWP penetrates deep into the wood. This seems to reduce any chance of wearing or peeling at the surface.
TWP 1500 Series
TWP 1500 Series
Cost Per Square Foot: 8
– TWP 1500 Series cost us $194.99 for a 5-gallon pail delivered. This breaks down to $.35 per foot for 2 coats of stain on our 400 square foot deck. We still had 1.5 gallons left when done. The coverage for the TWP 1500 was close to 200 square feet per gallon.
– Of all of the oil-based stains we tested, TWP offers the best protection against mold spores that are known to grow in oil-based stains. This is most likely due to the oils used in TWP’s stains. They do not use linseed oil but rather a mixture of natural and synthetic oils.
Ease of Application: 8
– For an oil-based stain, the TWP 1500 series applied well. We did notice that you need to back brush any puddles to ensure an even application. This is normal for most of the stains that we have tested. TWP 1500 Series did dry to the touch in 6 hours and we were able to put the furniture back on the deck the following day.
Color Shifting (darkening) after 2 Years: 9
– The 1500 series did not “darken” in color like other oil-based stains have been known to. TWP actually lightened up slightly at the 2-year mark. This gave the wood a more natural-looking feel.
– TWP 1500 Series would be an easy stain to reapply. A normal wood deck cleaner would be used to remove some dirt and grime, prepping for another coat.
Overall Score TWP 1500 Series at 2 Year Period: 8.5
– TWP 1500 Series (and 100 Series) have been known to provide tops in terms of durability and color retention. They have always been one of the best stains and are one of our top choices. Little to no fading on the railings. The deck surface faded to about 75% of the stain’s initial color after 2.5 years.
$69.99
$264.95
$315.00
$329.00
More Info: TWP 1500 Series
Cost: $46.99 per Gallon, $234.99 per 5 Gallon Pail
Stain Type: Semi-Transparent – Oil-Based
Available Colors: 1500 Clear, 1501 Cedartone, 1502 Redwood, 1503 Dark Oak, 1504 Black Walnut, 1511 California Redwood, 1515 Honeytone, 1516 Rustic, 1520 Pecan, 1530 Natural
Dry Time: 4-12 Hours
Deck Square Footage: 400
1501 Cedartone
TWP 1500 Series Deck Stain Photos
525 Comments
Michael Murphy
Michael Murphy
We could not be happier with the 1500 TWP Cedar tone. We love the way it looks. It was easy to apply,
Brian
Brian
13 years ago
Hello… I live in Portland Oregon, and have about 2100 sq ft of cedar fence that i want to treat. I power-washed the fence 2 weeks ago. I am trying to decide between TWP 100, TWP 1500, and the Defy Extreme Stain. I am hoping to spend the time now to stain the fence, this way it will only need a re-application every 2 years or so.
Which stain would last the longest? Since this is a fence, not a deck, will 2 coats be needed, or can I go with just one coat for economical reasons. Any help you can provide would be appreciated!
Chas
Chas
13 years ago
Great site. I found you after a popular consumer site recommended Behr #1 but nobody seems to like it. We're in western PA (a low VOC state) with an older deck, last treated 3 years ago: cleaned and brightened with Behr products, stained with Wolman DuraStain semi-transparent, which is "alkyd/acrylic water-based." No peeling, but the stain is fading on horizontal surfaces, the wood is dried out, and we're getting some greenish spots (moss?). Much of the deck gets full sun for a few hours a day, but we have long, moist winters. Reading your recommendations, I'm thinking that either Defy Extreme or TWP 1500 would be best for us. Do you have recommendations for stain and for prep products? Thanks very much.
Denis
Denis
13 years ago
Need advice for untreated Cedar deck around hot tub
Partial sun depending on time of day
My Deck is 1 year old and we have not stained it. It turned grey and some parts have some green mold. I want to stain the deck and make sure I use the right stain. The local company here suggest Sikkens SRD but from what I read its not the most resistant. We want a semi transparent stain that is durable in our climate. We do use the deck in the winter also and remove some of the snow to get to our hot tub.
Which stain do you suggest? I live in canada but I can get stuff shipped to VT which is 20 minutes from my place.
Do you recommend cleaning with a cleaner and power wash, the sanding before applying stain?
Dan O
Dan O
13 years ago
Reply to  Denis
Denis, do NOT use the Sikkens SRD. I live in Ottawa and used the Sikkens for years. Every spring my Cedar deck would be significantly darker, the walking areas would have lost their finish, and there would be mold on the underside of the railing. It was recommended to me by a very reputable local company and so for years I assumed it was my fault and I would strip and restain trying to improve my technique. It was finally the review on this site that showed me it wasn't my fault at all, the Sikkens just does that. I refinished in July with the TWP 1500 and will report back in spring on how it survived a Canadian winter. The one tip I would give about the TWP is that I used the Natural and found the colour a bit orange for my tastes. If I were to do it over again I would probably get the Honeytone.
PeterN
PeterN
13 years ago
Reply to  Dan O
Hey Dan, Where did you get that TWP-1500? I'm also in Ottawa and can't find it anywhere…
bob
bob
13 years ago
Can I mix TWP colors to try to get a color that is not offered?
Ferreira
Ferreira
13 years ago
North West New Jersey
Partial shade, full sun
New deck ( 5 months Old)
PTW from Lowe's
Hi, i need your advice about cleaning and brithner the new preasure treat wood before stain whith TWP 1500 ( if this a best choice for stain).
Ferreira
Ferreira
13 years ago
Thank you, but I forget to tell you, its only for sidings, shingles deck has composite floor
Barb
Barb
13 years ago
My pressure treated deck was installed last October and has withstood an Ohio winter and intense summer heat. We have no shade and the deck is starting to dry out. I got samples of timber oil( but did not say it was by Woodrich as your article said). When I called the OPW Sealer store, I was told the TWP 1500 was the best thing to use. Not to use the timber oil or other. I had to send for more samples from TWP so I can get the color right. I really have a short time frame to seal this deck since I just cleaned it and will be leaving for several weeks. Help…What do you suggest.? i am very confused. the deck is 16x 33 feet. and has top and bottom rail only (vertical rails are black alum. rods. ) I plan to stain the footers but do I also treat the cross beams that are under the deck?
Barb
Barb
13 years ago
Thanks for your advice.
Steve Johnson
Steve Johnson
13 years ago
Hello, I am about to put down new cedar for a deck in Minneapolis, MN. It will probably be the end of August by the time it is finished. If I need to wait up to 2 months before I stain, it will put me into October/November, and by then it will be too cold to properly stain. Is there something I can do to apply the stain sooner (sand, etc), or am I better off waiting until Spring. We typically get some nasty winter weather up here. Also, what would you recommend for a starter stain? TWP or Armstong Clark?
Cheryl B
Cheryl B
13 years ago
Thanks for the reply. We have used TWP stain for years and think it's the best product on the market. That's why we purchased the newer product for our new deck. I know you said wait a year but our early Spring was incredibly hot and the new boards were already starting to split from drying so we knew it was time to get a sealer on them. They were also already starting to turn grey.
That said, temps were good but pollen in North Georgia at that time of year is always bad. We took this into consideration and applied on the two days when it had settled "some" and after a good rain. I think you hit the nail on the head though with the pollen! OH, and we do not have trees near the deck but we do live on a wooded lot.
We'll get it prepped again and try a fall application. Thanks for the great feedback. I will keep you posted.
Cheryl B
Cheryl B
13 years ago
Applied TWP 1500 to a new deck in March 2012. The deck was competed in early October 2011, and had plenty of time to season. (Atlanta area). Deck was cleaned with TWP deckwash and allowed drying time as recommended. It's now August and the deck is full of mildew and most of the stain finish is worn off, decking, handrails, even the posts. Any suggestions as to what caused the problem and what we shold do to correct?
Roseanne Sullivan
Roseanne Sullivan
13 years ago
I have a two month old redwood deck. Even though redwood is supposed to be resistant to rot, the previous redwood deck rotted. Any ideas why that would happen?
What should I do to stain and protect this new deck? How do I calculate how much to buy? Must I have it cleaned and brightened first.
Partly shady, San Jose, no mildew. Gets into the 100 + temperatures in my neighborhood.
13 years ago
I used Flood CWF-UV (water base – clear) on the railings of the deck. It has been about 7 years since it was last painted. Do you think TWP will adhere and cover that?
13 years ago
I live in Green Bay WI and I have a 15 year old deck which I just stripped down to wood. I am thinking about the TWP 1500 which manufacturer seems to feel is better than 100. It seems like the 100 has a track record (20 years on market) whereas the 1500 is relatively new. Should the fact the 1500 is a new product keep me from using it?
Also, I did not strip the railing. It has only been treated twice in 15 years. Can I just apply the TWP treatment over the unstripped railing? It seems that stain on railing holds up pretty well.
13 years ago
Looking for your recommendations to stain a log garage & cabin. Location is central Michigan (30 miles north & 20 miles west of Lansing)
The garage is 923 sq ft made of pine logs & is 26yrs old. The cabin is a combination of 30 yr old pine logs & 120 – 125 yr old ash logs (total 1576 sq ft) . The pine log section of the cabin is about 300 sq ft. The pine logs are mildly checkered, moderate weathering while the ash logs are very dry, checkered, variable weather exposure all with a vertical orientation.
Previous power-washing & staining was performed in 2006. I believe a water based stain was used but I have no way of knowing what specifically was used as those involved are no longer available to ask.
All of the surfaces will be power washed, the caulk will be removed and re-caulked, any cracks will be filled. The work is being performed by a company that is experienced in working with log home. They are NOT thrilled about using oil-based stains. Based on comments on this site, I've been leaning toward TWP 1500 series. A relative has suggested using a solid oil based stain.
BTW, we used TWP 100 Rustic stain on the deck and everyone is very satisfied.
Your thoughts would be most appreciated.
Alice
Alice
13 years ago
TWP 1500 Series was introduced in the Summer of 2010 as the replacement for the TWP 500 Series. How can the test be done in June 2008?
When Tested: June 2008
Gordon
Gordon
13 years ago
Instructions on the can say not to paint if rain is expected within 48 hours. We seldom have a 48 hour period without rain, so I had to take a chance. Naturally, about 4 hours after I finished, it rained. I tried to cover the area with plastic, but it was already wet. What effect is this going to have on the stain?
Perry
Perry
13 years ago
Reply to  Gordon
Can u believe it rained on me too….I blew All the water off but am seeing white spots on the wood. So what kind of problems am I looking at??? Hard to predict the weather and rain in south Florida…..re-coat the whole deck? Clean the area and recoat the problem areas? Of all the days to rain
Gordon
Gordon
13 years ago
How long should I wait before walking on deck stained with twp 1500? Product information on this site says dry time is 4-12 hours, but Gemini's product Information site says dry time is 24-72 hours.
Jim Wray
Jim Wray
13 years ago
I have a house with a deck that is about 4 years old. Pressure treated wood. It has started to grey and I'm ready to stain it although I would prefer to just paint it over. Apparently, that's not recommended. It will be pressure washed with a mildew treatment and then stained. Since I live in Maryland I will have to use the TPW 1500. Is that recommended course of action? Any other prep work?
13 years ago
I have a 10 year old cedar deck. just replaced some of the rotted floor boards and sanded off the peeling stain with my orbital palm sander. Have previously used Behr cedartone semi-tansparent. Will the TWP blend in well with any of the old stain that i was unable to remove?
13 years ago
What if I used a solid stain?
13 years ago
Does TWP make a solid stain? What about the True Value Woodsman UV 7338872 stain?
13 years ago
Besides price, What is (are) the difference(s) in TWP 100 and 1500 series… 9 year old redwood fence… Dallas, TX… Thanks
Bryan L
Bryan L
13 years ago
Hi – great site! I have a one year old PT deck that I applied Ready Seal to. It was a great product, very easy to apply, but has faded significantly just as you write in your review. My question is since RS is so penetrating/non-film forming, can I apply another penetrating stain (like TWP or Defy) over it without stripping? I wish I'd read your review of RS last year!
mike b
mike b
13 years ago
hi, need help on color , have a redwood deck want i to look light and natural , should i use natural or california redwood,thanks what does wet on wet mean
Pesaro
Pesaro
13 years ago
I used TWP 1500 for the first time and it is fantastic! I took the recommendation from this website. My deck(16 years old) has never looked so good.I used Restore-A-Deck stripper and brightener and took it down to bare wood. After letting the deck dry for a couple of warm days I started the project.. I used a stain pad for all of the edges first. I then used a Solo, 2 gal stainless steel sprayer with the flat fan spray. I sprayed a section about 6 ft wide, the whole length of the deck(22ft). I used a stain pad with a long handle and back brushed the section.When that was complete, I sprayed another 6 ft section the full length and back brushed as I did the first section. Now the time was up and I sprayed the first section with the second coat and back brushed it.I sprayed the third section,back brushed it and sprayed the second section with the second coat.I kept alternating with this pattern until the deck was complete.
When all sections had a second coat and let it sit for a while, I used a new,dry paint roller on a handle and blotted up any puddle or wet spot. I did that several times. It was dry in a day and it looked terrific.The color is rich and water just beads up like I have never seen on my deck.Every time I walk outside, the color and richness amazes me.
The Solo sprayer was a life saver. It also did a great job and put stain between the boards.
bscharf
bscharf
Reply to  Pesaro
Wondering how the TWP 1500 has held up over the last 2 years…I am about to use it for my deck here in NJ>
Vince
Vince
13 years ago
Can a mildewcide be added to TWP 1500 ? Comments ?
13 years ago
TWP recommends wet on wet 2nd coat. What does this mean exactly? Is it better to wait to put the second coat on? and if so, how long? Thanks!
Bill Blum
Bill Blum
13 years ago
But you are walking on a Oil Based wet deck floor. Sounds stickey, messy and not right. What am I missing?
Pavel
Pavel
13 years ago
I just stained my railings with Sikkens SRD "natural" but I would like to stain the deck floor with TWP 1500. Can you recommend the closest color match (I'm thinking either Natural 1530 or Honeytone 1515). Getting samples shipped to Canada is pretty expensive.Thanks!
Catherine Stevens
Catherine Stevens
13 years ago
Please help!! I have a 34 year old "Real Log' (Lincoln Log type) cabin in Western North Carolina. Previously stained with a water based stain 8 years ago. Would very very much like to use TWP to preserve and protect the yellow pine logs. I would really appreciate a step-by- step preparation process with specific materials, cautions, and the manner in which to determine if 90% of water based stain has been removed. Have had some wood rot in peak (due to improper chimney flashing) where I'm planning on addressing with Popular bark siding in lieu of total log replacement of my D-logs. Thank you for your expericenc and expertise.
13 years ago
Hi I am looking for the best stain/sealer for these conditions. I have a 1200 square foot pressure treated deck. It's 10 year old and still in pretty good condition. I have treated it every few years… I think the last time was about 2 yaers ago… and some of it 3 years ago. I have pressure washed it with bleach and lomax. It is pretty good at this point but I was going to go over it again with??? What do you recommend? There is the slightest bit of old finish in a few spot and a few spots that appear to be too black. I am in Pa and this deck is under 2 large maple trees and wet leaves often sit on it too long over the winter. I want something that never has to be stripped… I just want to clean it and reaply.
Earl Wilson
Earl Wilson
13 years ago
We are in the process of building a.large deck using pressure treated lumber. We are looking at TWP 1500 deck stain. How long should we wait before staining the deck? What product would you recommend we use for the Northeastern part of Oklahoma? How should we prepare the deck for stain application?
Steve S
Steve S
13 years ago
One more question if I may – I used TWP 1500 on the deck floor but not the railings. I did not strip the railings and spindles as I did to the floor b/c my plan was to use a solid on this as a covering. I do plan to do some sanding / cleaning but not stripping. What product would you recommend for this? I was thinking sikkens? We want a dark railing coupled with the Rustic Oak TWP. Thanks again!
Steve S
Steve S
13 years ago
I'm so thankful for this site – saved me loads of aggravation from going with another product that seems to fail. I just put down TWP 1500 Rustic Oak on my PTL deck. Looks great! It's just shy of 400 sqft and it took two gallons for one coat. Wood was really dry. I used a pressure sprayer & backed brushed it. Good method however the fan nozzle on the sprayer seemed to form two streams on the outer part of the spray. I guess the thickness of the stain causes this? It was a bit annoying but back-brushing helped.
Anyway – is it okay to stick with this one coat until next year or should I apply a second in another month or so? I'm in northern NJ.
GuinnessToast
GuinnessToast
13 years ago
Location of Deck: South East PA
Deck Wood Type: Cedar from Lowes
Deck Square Footage: Total of 500 sq. ft. Two levels, 2' and 3' off of ground.
UV Exposure: Full Sun from Morning til Sunset
How Old: 3 years old
Stain Color Used: Olympic Maximum Canyon Brown
I have a few questions:
1. What should I use to remove what is left of the current stain? Looking for something that would be plant and pet friendly. I do have a power washer.
2. Would TWP 1500 work well with my cedar and full sun?
3. Do you recommend 1 or 2 coats of TWP?
4. Next year when the sun and snow take its toll, do I need to power wash again or can I just re-stain with a paint pad? 5. What do you recommend if I would like to bring out the natural color of the cedar?
Thank you in advance for your help. Rob
Chuck
Chuck
13 years ago
I'm preparing to purchase some TWP 1500 but first want to make sure I understand the coverage spec. Does the 150-200 sq ft of coverage per gallon account for the required two coats or is that spec representative of a single coat?
Ken Peterson
Ken Peterson
13 years ago
I recently purchased a 2002 Lincoln Log Home and the logs are not looking to good with the previous protection(dont know what it was), peeling in some places and molding in others. I've been told to get it pressure washed thoroughly and have it protected with the TWP. Questions: Is this the best way to go, and how long will the TWP last for before I should or would need to protect the house again? 1 or 2 coats?
bill
bill
13 years ago
is TWP ok to use on a new deck built of treated lumber?
Vince
Vince
13 years ago
Hi. I am planning on staining my cedar deck with TWP 1500. I removed old stain with a deck stripper and then pressure washer. I then power sanded the deck twice with 100 grit sand paper and then followed up with a deck wash/brightner. Intending on letting it throughly dry 10-14 days before applying stain. Was told that I should sand again with 60 grit so as to open up the pores of the wood as 100 grit is too fine. Is this true and if so do I need to rewash/brighten after I resand or is it ok to just remove all dust via air blower/compressor? My deck is in Ontario, Canada so I hope that I can actually get TWP 1500 shipped up to me as there are no quality stains available in Canada. (best product here is Sikkens)
Bill
Bill
13 years ago
Is TWP 100 OR 1500 safe to use on a mahogany table?
Kim
Kim
13 years ago
i have put down a new 800 square foot deck (550 greenheart, 250 purpleheart) and intend to use TWP 1500 honeytone to stain all of it in another month or two (thanks for the advice). At that point the idea is to wash with a cleaner /brightener, lightly sand, allow to dry and stain when 2 days of no rain is expected. Is this the right sequence? Deck is in Caribbean so rain and moisture for half of the year and high temperatures all year. any thoughts on cleaner? thanks in advance
Ken
Ken
12 years ago
Why only a sing;e coat on new wood? I am about to stain new cedar shingles (3-stories of vertical surface) and I intend to apply several coats since the cost to set up scaffold is pretty high. I want a good durable coating. I recognize I will have to re-apply every 3-6 years, but hope that by doing a good job we can get closer to 6 than 3.
jeannie
jeannie
13 years ago
I used twp-100 three years ago and i'm debating on twp-100 again verses the twp-1500 i'm in wisconsin and plan on using a brightner after power washing, which one would be best? I took a sample of both in the cerartone but there is little difference other than the 1500 is seven dollers more a gallon.
Cheryl Taylor
Cheryl Taylor
13 years ago
I have a hardwood deck that was sanded and had TWP stain applied last year. It is time to restain and I am told I need to strip the existing stain then use a cleaner then use a deck brightner. is it not possible to just powerwash the deck and then restain it with more TWP?. If not, what steps do I need to take. I stain the deck twice a year due to the density of the wood and don't want to have to do all those steps every time if I don't have to.
Thank You,
Cheryl
Anthony
Anthony
13 years ago
I just purchased TWP 1500 in cedartone for my new cedar deck. I am located in northern New Jersey. I hope this was a good choice for my location, can you comment? We do get a good amount of snow/rain and the deck gets a lot of sunlight as well. What kind of prep should I do? The deck has been up for 3 weeks and has been washed through rain storms already, and I have lightly sanded the railings to a smooth finish, is this good enough?
bscharf
bscharf
Reply to  Anthony
I also live in NJ (Central)….trying to decide on deck stain and wondering how the TWP 1500 has worked out for you over the last 2 years….please reply.
Andrea
Andrea
13 years ago
Just wondering if this product applies better with brush or would spraying be an option? Thanks. Great forum 🙂
Sara
Sara
13 years ago
Hi, I have a cabin in Northern Minnesota and have a cedar deck that I pressure washed in preparation for staining it. The deck is about 6 years old. As I looked over the stain reviews and comments, I think that the TWP brand is the one I should use unless you suggest otherwise….My question is whether you would suggest the 100 or 1500 series. And concerning color, if I want the stain to match the "naturalness" of the cedar as if the wood was wet, what color would you suggest?
Thanks for your help.
13 years ago
Do the tints of TWP 1500 hide the grain of the wood? I have PTW on the deck surface that's just recently been stripped. It's not ipe or mahogany but I'd still like for the grains to show. Will the cedar tint allow for this or should I go for the transparent? The house is barn red so I don't want to clash the colors either. Thanks again!!
Barb
Barb
13 years ago
i used thompson water seal on my deck last year after power washing off Behr..never to use that again… this year we flip over our deck boards and wash with wolman cleaner…deck looks & feels brand new again! now time to protect it…my husbands is leaning toward TWP 1500…is it ok to use sense i clean the deck with a different product? thanks Barb ; from Iowa
vickie
vickie
13 years ago
It was suggested to us to apply a waterproofing product on top of our newly applied TWP 1500 series – left me wondering why?
Also, one coat or two -what is the determining factor? We are on the central coast of California – mild weather – redwood deck and walkways in sun mostly.
vickie
vickie
13 years ago
I thought it was a weird recommendation – what about the number of coats?
vickie
vickie
13 years ago
Thanks for your help – one last question. The wood areas were stained last week. Is it best to put the second coat on now or is it alright to wait?
Amy Foote
Amy Foote
13 years ago
How often does the 1500 need reapplied? Does it do anything to help reduce the heat absorbtion often felt on a wood deck? If it doesn't do you have any recommendations that do?
13 years ago
Full Sun
1 yr old deck, applied WoodMaster Wood Protectore (Oil based product)
Faded badly
Just cleaned with Wolman deck brite and power washer.
Are most stains at a local Home Depot type stores junk?
Can a water base stain be applied over a oil based product?
Crmn
Crmn
14 years ago
I have a 16 year old deck, with cracks and green mold. Last time I stained it 5 years ago using Cabot semisolid in redwood color. Cabot semisolid started to crack and wear off in less than a year (about 5 months).
I live in Northern Virginia, The deck has shade in the morning and full sun in the afternoon. I don't know what wood was used by the builder 16 years ago.
I just bought a gas pressure washer (which I am still learning how to start), Olimpic Deck Cleaner and Cabot brightener from Lowes, and started to clean the deck. It is more difficult than I expected, so I will have to apply cleaner and powerwash a second time.
What deck stainer should I use when I finish cleaning the deck? Can i apply semitransparent after I used semisolid 5 years ago? I am considering TWP 1500 or Armstrong Clark semisolid or semitransparent?
13 years ago
Reply to  Crmn
Call me and I will be sure to take care of you. I'm in Warrenton. Don't use Olympic deck cleaner, it is bleached based and will destroy your fibers and eventually kill everything around it (plants, etc.) and is time consuming to rinse. I've used TWP1500 on several customers and its top notch. Never use a semi solid or solid stain. Its too difficult to remove and quite frankly is not as attractive as a semi-transparent which at least still shows the natural wood grain (enhances it actually). PlanetGreen PowerWash. "A" rated on Angie's List!
rosella burke
rosella burke
14 years ago
I used the Restore a Deck stripper and Brightener on my 10 year old deck. Most of the old stain came off but there is a little here and there that would not come off, even with repeat applications. I was going to order the TWp 1500 stain to redo the deck, but just noticed that it says for exterior untreated wood. Can I still use this, and if not, what stain do you suggest? I live in upstate NY which gets very cold. The deck is on the north side of th house so it gets sun later in the afternoon. Thanks.
trackback
[…] our top overall scores. It is too bad that this product is not available in all 50 states but the TWP 1500 Series performed nearly the same in our test results and can be obtained in all states. If you are looking […]
1 2 3 5
525
