Strip or Clean the Deck
Good Morning Scott –
Hi Scott.
Strip and brighten for sure.
We used Rymar stain
Thanks so much, Scott
No need.
Thanks you!
Thank you for your help!
Here are photos of deck
Thank you for your tips.
In the PNW
Thanks again
A couple questions:
Thanks for any help
Or strip the whole thing?
See attached
Pressure wash.
