I am Scott Paul, a leading exterior restoration contractor and business owner with over 30 years of experience in staining cedar decks. Most of the wood decks we have worked on have been western red cedar, and when new, you should take care to use a proper wood stain. See here for more info about me.
Best Stain for New Cedar Wood Deck
I appreciate you visiting Deckstainhelp.com, your go-to source for the latest deck restoration news and trending topics through 2026. If you are looking for honest deck stain ratings, look no further. In this updated article, we offer suggestions for how to prepare and stain a new cedar deck. Feel free to leave a comment below.
My Tips for Choosing a Cedar Deck Stain
Are you trying to find the best cedar wood and decking stain? Here are a few things to consider when comparing options and how to stain your brand-new cedar.
- Weather the Cedar Wood
- Prepping New Cedar Wood
- Is your Cedar Rough-Sawn
- Choose a Penetrating Wood Stain
- Compare Best Cedar Stain
- Watch My How to Stain a New Deck Video
- If you have questions on New Cedar Stains, ask me below.
For more options beyond cedar-specific stains, see our full list of the best deck stains available today.
1. Weather the New Cedar Deck
Many types of cedar are used for exterior surfaces, with Red Cedar being the most common. We recommend waiting 3+ months to stain new smooth cedar wood surfaces to allow the wood to weather, creating an ideal porous surface that will hold the stain better. (Always follow the stain brand’s directions, though.) After the weathering, all new cedar wood should be cleaned and brightened for the prep. This will remove any oxidation and mill glaze.
2. Prep New Cedar Wood
Prepping new cedar wood is important to stain life and performance. It should be cleaned using a sodium percarbonate wood cleaner to remove mill glaze and other contaminants that may have infiltrated the wood during construction.
Once the new cedar wood has been cleaned, it will appear darker. While the wood is still wet, apply a wood brightener to restore its original color. Brightening wood after it has been cleaned will also open the wood pores, allowing the conditioning oils to penetrate better.
Proper cleaning and brightening will ensure the best stain for new cedar wood will perform as expected and provide lasting beauty.
3. New Rough Sawn Cedar Wood
Rough-sawn wood is not used for horizontal decking surfaces but rather for vertical surfaces such as fencing, wood siding, etc. This side of the wood is very absorbent and does not have a mill glaze. As long as the wood has a low moisture content, it can be stained immediately.
4. Use a Penetrating Wood Stain
Many wood stains have difficulty penetrating dense wood like cedar. If a stain does not penetrate the wood, it will remain on the surface and become susceptible to peeling and flaking. The best wood stains for new cedar are deep-penetrating wood stains that are thinner in viscosity. Stains for new cedar wood should dive deep into the wood to condition the wood cells and protect from UV fading and moisture damage.
Armstrong Clark Wood Stain
We like a couple of different stains for new cedar wood. One is Armstrong Clark Wood Stain. It comprises both drying and non-drying oils that break apart throughout the application process. The non-drying oils dive into the new cedar to condition the wood’s cellular structure, while the separated drying oils cure on the exposed surface to not only lock in the conditioning oils but also protect the surface from natural weather exposure.
Restore-A-Deck Semi-Transparent Stain
Another similar stain best for new cedar wood is Restore-A-Deck Semi-Transparent Stain. This water-based wood and deck stain penetrates deep into new cedar wood and decks. This cedar stain conditions the wood cells while providing water and UV protection. The Restore-A-Deck Semi-Transparent Stain brand promises easy application of good penetration into new decking.
My Pro Tip: Restore-A-Deck Semi-Transparent Stain can be applied to damp wood on the same day as prep!
4. Best Deck Stains for Cedar
See our best cedar stain options in the table below. You can click on the links to read the full reviews for each.
Best Water-Based Deck Stain  for New Wood | The Easiest Applying Deck Stain for New Wood | Best Oil-Based Deck Stain for New Wood |
Months to Weather New Wood: 3 months for both semi-transparent and solid stain colors. | Months to Weather New Wood: 2-3 months for transparent and semi-transparent colors. 12 months for semi-solid. | Months to Weather New Wood:Â 4 - 12 months for all TWP Series and Colors. |
5. Staining a New Deck Tips Video
6. Need Help? Cedar Staining Questions?
Please ask below if you have questions about my article or need tips and advice for staining a cedar deck. Just post a comment below and include as much information as possible.
I'm installing an aluminum railing with 4×4 cedar posts. The cedar posts are green but have been milled on 4 sides to a smooth sanded finish.
As the posts are green I plan to store indoors over the winter to dry before staining. How long should I plan for drying. I live in BC so the house indoor RH is probably 60-70%. I plan to check with a moisture meter. What % mositure do you recommend and how deep should I check into the wood.
Also can I skop the cleaning step and just brighten and stain when ready.
Great column – thanks in advance for your advice.
You need to let the wood season outdoors after the wood is built. Typically a few months. It is not just about moiety content. It needs to oxidize some then clean and brightened for prep. Less then 12% moisture content.
Just installed (October 20th) a new red cedar deck in southern New York (Hudson Valley) and looking for advice on whether or not to start putting finish on now or wait until the Spring. We see so many different opinions on this. The last two winters have been very cold with quite a bit of snow. What are the best steps for preparing the deck for a clear finish and what products would you recommend for the prep work and a final clear finish that will show the natural color of the wood?? Thanks!
We would wait until Spring. Clean and brighten for prep and stain with Armstrong Clark brand.
I'm so glad you posted this. We are about to install a new cedar deck in Alberta, Canada where we typically get lots of snow and cold winters. The cedar is being delivered and is freshly milled. We've had an unusually warm, beautiful fall, so the deck is going to go down next week. Our contractor is advising that the cedar will be fine over the winter because of the oils in it, and it will give it time to dry in place and breath over the winter and to stain it in the spring (he recommends Sico). It's a big investment, so I wanted to come online and do some research and make sure we are getting good advice.
DeckStainHelp, is there any additional advice you can give or comments you can make. Thanks in advance for any help!
You can wait until Spring, prep then stain. Look at Armstrong Clark stains.
Is there a link you can send that talks in more detail about what we need to do to prep? I've heard the comments on here about cleaning and brightening, but what do you need to do to achieve that?
Is it ok that the boards will be going down and no stain or protection will be on the sides or the bottom?
No need to stain the undersides: https://www.deckstainhelp.com/staining-undersides-…
Deck Cleaning Tips: https://www.deckstainhelp.com/deck-cleaning-tips/
Would you entertain a brand new (installed two days ago) kiln dried eastern red cedar wood fence stain question? (Missouri) if so, Is the mill glaze only on the smooth boards-On the Two by Fours and possibly the post? The pickets are rough sawn so there is no mill glaze on them therefore the pickets would not be need to be cleaned and brightened before staining? Can this fence just be stained right away with no prep? It seems like I read on Twp website that rough sawn fences can be stained immediately without any prepping. Thanks!
Yes mill glaze is only on the smooth boards. On the fence, what percentage of the wood is rough cut and what is smooth wood? If it is mostly rough then we would go ahead and stain.
hi I have a cedar deck that was done in july 2015 I just was having someone seal and stain and went with a semi transparent brown from Sherwin Williams . the company that was applying it tried using a brush and also tried a pad. the wood was not taking it right and had to put two coats and dried horrible. not only is it all streaky but doesn't allow you to see the beautiful wood grains. is there a way to get it off and bring it back to its original form? thanks
You will need to sand it all off to fix this. Stripping may remove some but not all.
We've had a new cedar deck installed about 3 weeks ago. Were told to wait until spring to stain. Also told to use water based product like Cabot in semi transparent color. So confused after reading your article. Any thoughts? Concerned about winter as we live in Chicago suburb. Thnks!
Waiting is fine at this point in the season. Stay away from the water based stains. Use a penetrating oil based stain next Spring like the TWP or Armstrong Clark.
Thank you. What is TWP?
https://www.deckstainhelp.com/tag/twp-stain/
Almost finished installing a kiln dried cedar deck in NE Ohio. Your article, "Staining a New KDAT Deck" says that you can clean, brighten & stain right away. Yet I did see your reply to a question on kiln dried cedar that said you should "not stain new wood right away, even kiln dried. You still have to let the wood weather for a short period of time and prep correctly first. I would wait, prep and apply a light coat of the stain after a couple of months." In a few weeks, the weather may not allow prep and staining, and we will need to wait till spring (April or May). Would you wait till Spring, or prep and stain now? Thanks for your help and this valuable website.
We wait about a month for light oxidation then clean and brighten for the prep when dealing with new KDAT. Hard to say what would be best for your based on the Winter. If you do it now then you may need to redo in the Spring but at least it will be protected through the Winter. Make sure if you do apply now that you apply an extremely light coat of the stain.
Just had a new cedar deck installed. Our builder recommends TWP or Olympic stain. We live in Michigan and understand that TWP wants us to wait 4 months before applying stain. Should we do TWP now before winter and avoid the 4 month recommendation as it will be January (middle of winter) when it's 4 months old? Should we use Olympic instead? Or should we just wait until spring after winter to apply? So many questions! So sorry!
Use the TWP and wait until Spring. Olympic will have issues as well if applied now.
I'll do that! Thanks for the timely response. What would need to be done in the spring before it's stained? Cleaning?
Clean and brighten.
I installed a red cedar deck in May/June of 2015, cleaned it and applied Thompson's clear sealer. Needless to say, it did not perform well. A couple spots have some mildew and it holds dirt horribly. So I plan on cleaning the finish off and am looking at a different finish. I love the natural red cedar coloring and want as clear of finish as I can find. What product can you recommend?
TWP Honeytone or Defy Extreme stains.
You mention applying brighter while wood is still wet. Do I let the brightened dry before going to suggested stain?
Yes the after brightening you will have to let the wood dry for 48 hours before staining.
Just installed a new tongue & groove (5" boards) red cedar ceiling on a large covered terrace in NE Ohio. Ceiling is protected from direct sunlight, rain & snow. Any specific product or application recommendations for this type of installation? Previous wood ceiling was painted, but decided to do stained wood for the replacement. Prefer a rich medium tone brown color that does not accent the red & has NO orange tones. Great site & very helpful! Thank you in advance for your consideration & reply!
Use Armstrong Clark in Rustic Brown. Lightly prep with a deck cleaner and wood brightener to remove any milk glaze.
Thanks! Need 2 gallons of product based on square foot coverage. Is it possible to mix 2 colors of stain to obtain a custom color? And what if they are different transparencies (Rustic Brown Semi Transparent with Oxford Brown Semi-Solid)?
Yes you can mix two different colors in the AC. We have mixed semi-solids with semi-transparent colors before but take note that the semi-solid will dominate in color since it has more pigment.
Good to know! More solid is my preference, to minimize appearance of knots & some grain patterns.
Hey there! We just got our brand-new cedar deck installed, and I really want to hit it before the it starts getting really rainy here (Portland, OR). From the construction and people walking around on it after it rained, it is already dirty/discolored, so certainly needs a clean before the stain application. What cleaner would you suggest? And would the Timber Oil Brand stain work well right after as a stain? Lastly, how long does the stain take to dry? Thanks!
Use the Restore A deck Kit and yes on the Timber Oil Brand. Dries in a day or so.
What is the best stain for Tigerwood and can you prefinish it prior to installation
We would not prefinish. Try the Defy Hardwood Stain for the Tigerwood.
Input a huge new cedar deck in June 2015. Previous cedar lasted 15 years. It was recommended for us to use penofin. What a disaster!!! Completely black by August!! I would like a recommendation as to what to apply following the cleaner and brightened penofin suggested. I don't even know that it will work, just saying my prayers it does. I do not want to use the product again due to what has occurred. Suggestions??
Thank yiu
Strip and brighten for prep not clean. You need to remove all of the Penofin. Try the Restore A Deck Stripper. Try TWP or Defy Extreme.
AC in a semi solid color like Oxford brown would that still show wood grain? We want it to look like wood still not painted on. The rustic brown wouldn't be dark enough I don't think
Yes it will still show the grain and does not look like a solid stain. Might want to get some samples from them.
Put a new cedar deck on, did not treat first. it rained for days, and it actually looked like a wave. Had to removed, dry out, and plan on staining now. It looks like stain only lasts a few years before you need to re treat? What would be the best method to get longer life out of what you pain on? Does this stain get brushed, sprayed, or wiped on?
You cannot get longer life then 2-3 years on a deck surface. First time staining does not last quite as long as future applications either as the new wood is not very absorbent. Use a stain pad for applying. Just one coat this year and another in 12-18 months.
I completed construction of a new cedar deck 3 weeks ago near Cincinnati, OH with wood that was purchased about 6 weeks ago. Yesterday I stained the deck using Amaretto Woodrich Wood Tux after cleaning and brightening with Woodrich products. I did not notice that I used Wood Tux rather than Timber Oil until tonight. The only reason I started looking into it was because of the uneven absorption of the stain, the tackiness of the stain, and the very grey areas around the knots. I know it's only been stained for one day but the finish is very unsatisfying. My questions are:
1. Is Wood Tux generally not recommended for new cedar?
2. Should the finish even out over time…meaning does it simply take much longer for the Wood Tux to dry verses the Timber
Oil?
3. If the finish can't be expected to even out what is the best product to use to remove the Wood Tux?
4. If removing the Wood Tux is the way to go, what should I then use to refinish?
Thank you for your advice. This website has been a great resource.
1. It will have a hard time penetrating new wood.
2. Probably will not even out.
3. Strip and brighten with Restore A Deck Products but you may want to wait until next Spring as it can be difficult to remove a newly applied stain.
4. If you wait until next year then use the TWP stains.
We just finished our cedar deck here in Gordon Wi, and are looking at stains that leave somewhat of a wet look, without a severe darkening effect. We want the cedar to look enhanced to colored. I've used Australian timber oil on other species of wood and love the way it wears……what I'm afraid of is flaking and cracking on the deck floor and top rails….
Try Timber Oil Brand in Warm Honey Gold or Armstrong Clark in Amber. Clean and brighten for prepping.
Built a new outdoor shower out of Wester Red Cedar in southeastern Ontario. The shower has a small deck portion (8'x5'), walls (fence board laid horizontally) and a pergola style roof. I do not want to be bothered with staining or sealing every couple years. I understand that I will lose the natural looking tones and it will grey. Ideally I would like to keep the warm natural colours if possible but I don't want to choose the wrong stain that is too dark or too orange. I am seeing a lot of orange-y coloured stain and and reading about many stories where the stain was just outright ugly. I imagine I will have a hard time staining the joints now as I already built the darn thing. The shower is 30 days old now. Should I just let the whole thing age naturally? Do i need to put on a sealer? Is it worth trying to stain if I will have a hard time getting in the joints anyway? I dont want blotches of stain.
Should I just wait a year and then decide? I spent muchos $$$$ on this damn thing and would hate to screw it up now either with the wrong stain, no stain, or black and mildew-ey boards.
Advice would be appreciated.
You can wait until next year, clean and brighten for prep and stain with Armstrong Clark in Natural tone.
We have a new cedar deck and its been out about 3 weeks and probably a bit at the lumbar store as well. So my question is we are going to clean and brighten (best to buy each individual or is there a good two in one brand?) And then seal with one of the two above stains you recommended. Which is better for snow/cold winters (ND) and then full sun West side. Of house in summers. I've read you said only one light coat the first time too and then second the next year. We plan to do a dark brown stain and probably will have to order online. Is it best to order directly from Armstrong or Timber oil or anywhere ok. Thanks for your help.
Not possible to have a true in one cleaner and brightener so you will need two products. The ingredients would cancel each other out. Try the AC in Rustic Brown or maybe even Oxford Brown.
Thanks!!
can I cover it with plastic, a new cedar deck, while I wait a year or so to stain it. Will it help from turning grey fron the uv rays
Do not cover it. You want it to season exposed.
one more follow up question, if I use the armstrong clark "natural" that is available locally, next year can I use rustic brown? will it take the new color next year fine since its darker on top of the natural? I'm worried just waiting for the shipping we'll loose our sunshine and our chance to do it 🙂
You can but you will need to use both a deck cleaner and wood brightener for the prep first.
just finished building a covered 200 sq ft cedar deck in portland oregon about 4 weeks ago. Only the edges will have exposure to sun and rain. The rain is getting started but we have some forecasted 4-5 day gaps of sun still before its all rain for the next 9 months, will that be enough time to seal? How can we test it to see if its dry enough to seal? And how much time does it need to have before the next rain? There's no mill glaze, water seeps right into the wood but it has gotten dirty and has water spots already from the rain in the last week. WIll the wood brightener you talk about take care of both so then we can seal? How much time in between the brightener and the sealer?. Wer'e planning on Armstrong – dark brwon, but can only find it locally in "natural", does it matter where we order it from online, or is there an easier way to find it locally?? (I've just been calling around to deck and lumber yards). Armstrong is one that can just be reapplied over itself every few years without stripping and sanding correct? LOVE YOUR SITE! THANK YOU FOR ALL YOUR RESEARCH!!
There is always mill glaze on new smooth cedar boards. Make sure to not skip the prep. You need both a deck cleaner and a wood brightener for the prep. AC is a great stain and would work well for this but make sure to aonly apply a light coat for the first time staining.The Rustic Brown or Oxford Brown will hold color much better then the Natural.
Just recovering a fully covered deck with cedar deck boards. from the suggestions here, letting it live for a few months may make sense.
Any suggestions for dos and dont's over the upcoming winter that will help our deck be the best.
Just leave alone for now and prep and stain in the Spring. It will be fine through the Winter.
I built a new cedar deck a year ago. Now I see that I should have stained it right away. The deck is on the south side of our house with no shade. The deck is graying of course and showing some cracks. I understand that i need to use a deck cleaner before treating, and have read that the TWP products are my better choice for stains. My question is, if I use the TWP product, which is the better choice, 100 or 1500? Or is there another brand I should use? I'm concerned about water getting in the cracks in the winter, freezing and splitting the wood.
TWP wants you to wait 4-12 months for new wood to season and that includes cedar. Use the 100 id allowed in your state. If not use the 1500/
A Thompson's water sealer ruined my cedar deck, Can I strip that off with a solvent. And revive my cedar deck? It has been about 2 years.
Solvents will not remove it. You can try a deck stain stripper but you may need to sand as well.
i just installed a NEW large 25x30ft Alaskan red cedar deck. Full sun in the afternoon. Nebraska weather. high humidity and hot in the summer and cold low humidity in winter. Are you sure i need to put a brightner on new cedar after cleaning with
sodium percarbonate wood cleaner to remove mill glaze ?
Yes you need to brighten after the cleaning.
what do I use on a cedar deck that one year old and never stained
Much enjoying your site. I have a 15 year old cedar deck. 2 years ago my brother and I sanded it down and refinished it. My brother convinced me to go with some linseed, lemon oil concoction he made up and for the rest of the summer the deck looked absolutely stunning with a deep rich glow. The following summer however was a different matter as the whole thing turned super ugly blotchy black over the winter (who knew oils were so tasty to molds). I have now sanded it down again and was wondering why you would recommend washing and bleaching over simple sanding? My wood finishing knowledge tells me the last thing you want to do to wood it get it wet and open up all the grains to be exposed to the elements (not to mention that it kills much of the natural beauty). Or is this the trade off for highest penetration of preservative?
You want to open the grain as much as possible so the deck stain absorbs deeper. Better wear and tear this way on outdoor wood. It will not harm the natural beauty in any way.
Hello, just finished installing a new cedar deck (14×18). I've read that I have to clean/seal/stain right away…however I will be away for the next few weeks and Won't be able to. Is this bad for the wood? And where (Canada) is it recommended to buy the stain … A hardware store or paint store? I want to do two different colours. One darker stain for the border and then lighter for the inner. Any suggestions?
It is fine to wait. Not sure what stain brand you are referring to.
In the process of building a large 24×12 ft, covered red cedar deck in northern British Columbia . Extremely disappointed today when preparing the decking with B Moore Arbourcoat Natura transparent (f- 623 10)…once gorgeous cedar boards now look prefab and artificial and definitely a darker , almost painted brown colour. Stopped at doing one side of boards and will sit these boards face down on the deck. Ill be returning the other two gallons of stain that i bought. Looking for a few diff suggestions . I Want to retain the beautiful , natural look of the cedar. Dont want an orange tone. …is there a decent clear out there? Limited in buying options here and brand availability here…..but may be able to get the right stain shipped in….help!!!
Look at Armstrong Clark brand.
Did you have any success? We are about to build a cedar deck and my biggest concern is finishing it and it having that awful orangey-brown tinge to it that looks so fake and takes away from the beautiful natural tones. Also live in BC and can't seem to find the Armstrong-Clark brand.
Hello! We live in central Illinois. Just put in a new cedar deck. We love the variation in wood color when it rains on it and would love to get that look after its treated. I put Flood brand uv blocking clear natural tone on the railing aND it looks all orange. Is there a truly clear product that will provide uv and water protection?
No a clear will not provide UV protection. Try a light \”natural\” tint like the Armstrong Clark Natural. Take in mind that the lighter you go, the quicker it fades. You may have t do this every year.
Hi i live in the U.K (we have a lot of rain and some sun if we are lucky!). I had a western red cedar deck installed about 4 weeks ago and treated it with Owatrol Seasonite (not sure if this is a familiar brand for you?). But after four weeks the deck seems to be greying, i've noticed it starting to get lighter patches almost white looking.
Is there anything i can do to keep it looking new or how it looks when it is wet?
You need a deck stain with a tint to block the UV. The product you put on will not stop UV graying.
we are having a cedar deck installed – the company is staining the deck for us but we have to supply the stain. I want a beautiful red cedar deck – I also want a stain that will last 5+ years before I have to do the entire thing again. We have been told that Sherwin Williams is great, also got a few great reviews on 'One Time Wood', and I was looking at Lowe's for their stain variety. Can you tell me which is best and why? and Why to stay away from other types?
There is not such thing as a stain that will last 5 years and any company that says otherwise is not be honest. 2-3 years is the most you will get.
I will be installing a new deck skirt and building a new privacy fence using cedar 1×6's.
Should I clean and brighten, let dry and then stain with Twp right away before installing or should I install first?
If install first, should I let it all weather for 4 months or so and then clean, brighten and stain in place?
Install, let weather for 4+ months, clean/brighten then stain. That is what TWP would want you to do with their stain. Just one coat the first time as well.
In the next week I will be resurfacing my deck with Cedar. Should I clean and stain the planks before I lay them down or after?
Robert
After and make sure to prep and follow the directions of the stain brand you are using as to new wood.
Can I just sand a new cedar deck and apply the timber oil brand or the armstrong clark brand sealer to it? It has dryed out for 1 week. I suppose the oil based products are the best to use. I do not wish to apply a stain to it.
You would be better off with the Timber Oil brand if you want to do it now. AC wants you to wait 3 months. Clean it lightly after sanding.
Rebuilding deck railing with white cedar. I have the opportunity to stain it before installing. Since it’s cedar, can I wash off the mill glaze, let dry, stain (looking at TWP 1500) then install or should I install the whole the new railing, wait a month or two, clean with deck cleaner (looking at restore-a-deck), then stain? The former seems easier to do while disassembled but will the latter give better results? Both options seem viable reading through your articles and comments but since I have the choice I’d like to pick the better one. Thanks for any help!
With TWP you will need to install, wait 4-12 months, prep and stain. Best to do this.
Got a new deck and I want to stain it cedar with a shiney finish. Can I do that is it possible?
That is not a good idea. It will peel and blister: https://www.deckstainhelp.com/why-deck-stain-canno…
How long should I wait to apply the stain after the deck has been cleaned? Does the wood need to be completely dry?
2-3 days. Needs to be completely dry.
Slightly OT, but cedar wood-related. I live in southeast PA; I bought some cedar decking planks to make planter boxes. I love the smell of the cedar, but also want to preserve the longevity of the wood given my intended purpose for them. Is it possible to get the best of both (keep the cedar smell and stain the wood), or am I left to choose one or the other? What would you recommend, and what should I use? Thanks!
The cedar smell goes away no matter if stained or not. Stain with Defy Extreme or TWP 1500.
Great! Thank you!
I installed 1×8 cedar channel underside of 2 nd floor deck. What stain I should be using
Try the Armstrong Clark stain.
I had a knotty cedar deck installed 2 weeks ago- it's pollen season and very bad here in NJ right now- everything is covered in it and no rain in sight. want to clean, stain and seal the deck asap – so I suppose in another couple weeks it would be better. I an torn on what brand of cleaner and stain/sealer to choose. The deck gets full sun most of the day, and have a dog that is a bit rough running on it, so I need a little color for UV protection but want to keep the reddish cedar color as much as possible. I would welcome any advice.
Try the Armstrong clark in amber color. Prep with Restore A Deck Kits.
We built a cedar deck 12 months ago and live in southeastern Ontario. We have just sanded the deck to get rid of the mill glaze, can we stain it right away or should we wait a few days? Do we need to use any sort of cleaner or brightener as well? Also, should we expect to have mill glaze again next year?? Home Depot says we may.
Wait a few days and make sure the lightly pressure wash with a deck cleaner. This will remove the sand dust and \”swell\” the wood pores so the stain absorbs a little better. Brighten as well when done. Mill glaze is one and done. It does not come back.
I'm having a new Red Cedar Fence installed in one week (It's December and I'm in the northeast) my question is, the linear feet of my fence is 345', are you saying I have to clean and prep this fence in it's entirety prior to staining? That is A LOT OF FENCE. Is it at all possible to just wait until Spring and then go about staining it?
If the wood is rough sawn (most fences are) then no need to prep. If smooth (like deck board) then yes you should prep. This removes the mill glaze allowing the stain to penetrate better. Waiting to Spring and you will still need to prep.
I have a two year old cedar deck that I have sanded down with an upright orbital using 36 grit the to remove the previous stain (Sherwin Williams) and also remove some of the claw marks in the wood from dog claws and level out slight cupping in some of the boards. Can I go right to staining since it is down to fresh wood or do I still need to use a cleaner, then brightener before staining? Thanks.
A light cleaning to remove sand dust would help the stain absorb deeper.
Ok, so no need to use a cleaner and/or a brightener at this point? I would rather not do if not needed but at the same time, if it would help I would do.
You can but you do not have to. Main thing is to remove dust and a good rinse will do that.
I went with the TWP 100 series.Their specs call for a coverage of 100-200 sq ft per gallon. I have 500 sq ft of deck and in was only able to get one coat of the product on in 4-5 hours and used only one and a half gallons of product. I painted each board with a brush then backbrushed each board before moving on to the next one. I'm hoping this would be adequate but I see that their recommendation is two coats wet on wet. Prior to staining I washed the deck with a hose 1 1/2 days prior and squeegied any excess water away. We have have good warm temps around 80 degrees during the day so I feel confident the wood was nice and dry. Should I be considering a second coat at this point? And does it concern you that I was only able to get a 325-350 sq ft per gallon coverage rate?
New wood does spread much farther. Best to leave alone and do a light cleaning in Spring to remove dirt and apply another coat then. I will work better this way since you did not apply wet on wet.
Hi, We have built a new porch and the interior walls are cedar (not the outside, nor the floor). We want to preserve the color. Some of the cedar is smooth, some is rough-hewn. What kind of sealer should we use?
Look at a lightly tinted color in the Armstrong Clark for this.
Sorry, I'm a little confused and just need some clarification, want to make sure I do this right!! We have just built a new 18 x 22 cedar deck on the back of our house and aren't sure when to stain it. At the top of this article you mention that cedar is a wood that can be stained right away, but in your article about new decks in the comments section you give the advice for people to wait several months prior to staining their new cedar deck. Should we wait or go ahead and stain now? Thanks for a very informative web site.
Sorry about that. It really depends on the stain brand that you decide to use. Most will want you to wait and prep correctly first. This article may help more: https://www.deckstainhelp.com/staining-a-new-deck/
We normally always let it season to be safe.
My south facing front porch and steps have just been completed. My builder says that the wood is pure grade cedar, not kiln dried. I live in Vancouver, British Columbia so we have a lot of rain in the fall and winter (and spring, sometimes!) months. It is now September 8 and luckily there is a period of dry weather over the next week. I'm limited to Canadian available products like Penofin, Sikkens, Benjamin Moore. Would you recommend I stain it now? Which product? What kind of preparation do I need to do? (do I use a wood cleaner and brightener?) I've spoken to so many people in paint/stain stores – and they all have different answers! Help! Please reply ASAP.
Clean and brighten for the prep. Of those stain, look at Sikkens SRD.
I have a Western Red Cedar Fence that waws just installed a week ago. I'm looking to stain with a semi-transparent. What are some good options as far as stain brands. I want to get away from Home Depot and Lowe's. Is Sherwin Williams a decent pick?
Stay away from SW, Look at TWP or Armstrong Clark.
I have a 12 month old cedar deck that I am getting ready to stain for the first time. I used restore a deck to clean and brighten. After I was done and dried it was clean but very fuzzy. I used a low pressure (40 degree) nozzle and kept my distance from the wood, but it must have been too much. I then sanded the entire surface. It looked great at first, but now after a few days of rain, the deck looks really dark – almost black in some areas. There are also areas with little dots on it. When it dries there are grey streaks already on some of the boards. It was cleaned and brightened less than two weeks ago. I plan to stain with TWP Honeytone. Will it look dark and bad if I stain now? What other prep do you recommend? Thanks much.
You might want to brighten again. The sanding may have caused an issue. What did you sand with?
I used a random orbital flooring sander with 80 grit paper.
I would brighten again to see if that takes care of the blackness.
Thanks for your help. Looking closer it looks like there are also mold spots on some of the boards. Also, the edge of some of the boards are already greying (it has only been a couple weeks). Do you think it would help to use a bleach mixture to kill the mold? Do you think anything needs to be done about the new greying before staining – will it show through?
Yes you should prep with a deck cleaner and wood brightener to remove the graying and mold spots. Only use bleach as a last resort.
Don't use any tone color on cedar,use a clear or natural,or it will look like barn paint on there,the streaks are from the water,you should stain or oil after sanding right away before it get wet,
