Deck Stripping – How to Remove an Old Deck Stain 4.8/5 (100)
Hi, I am Scott Paul, an exterior wood restoration contractor and business owner with over 30 years of experience in stripping and removing exterior wood and deck stains. My Deck Stripping tips are based on my history as a wood restoration contractor and actual hands-on testing. See here for more info about me.
  1. Deck Stripping Materials
  2. Choose Proper Deck Stain Stripper
  3. Steps to Stripping a Deck
  4. Brighten the Wood
  5. Ask Me Deck Stripping Questions
  • Proper Deck Stain Stripper
  • Gas-powered pressure washer
  • Pump sprayer for applying
  • Scrub brush to agitate
  • Protective Equipment: Gloves and eyewear
  • Plastic sheeting to protect plants and home
  • Wood Brightener to neutralize when done
Scott’s Pro Tip: See here if you need to remove a Difficult to Remove Deck or Wood Stain.
Solid Color Stain Stripping
Deck Stain Stripping: Deck Stain Stripper Reviews
*Ships Free.
Makes 5-Liquid Gallons.
*Ships Free.
Removes Solid Stains.
Failing Deck Stain
Failing Wood Deck Stain
See below for my steps when we are stripping a customer’s deck
  1. Protect the house and any surrounding plants with plastic or poly tarps.
  2. Remove any patio furniture from the deck and surrounding areas.
  3. Prewet deck with water.
  4. Mix the stripper, if needed, in a bucket and transfer it to the pump sprayer if applicable.
  5. Apply the stripper to all flooring first. If a large deck, break it up into sections.
  6. Wait 5-45 minutes for the deck stripper to activate. You will know when it is working by using your scrub brush to agitate it, and the stain becomes loose from the wood. Keep the stripper from drying during this process.
  7. Pressure wash all deck flooring using a pendulum motion and about 8-12 inches from the wood. Rinse well when done.
  8. Repeat Steps 5-7 with vertical wood.
  9. Apply wood brightener when done. Rinse well with water 20 minutes after.
  • Always use a deck stain stripper. These products do 90% of the cleaning work. The power washer should only be used to rinse off the loosened grime—not as the main cleaning method.
  • Treat the power washer like a rinse tool, not a scrub brush. Use it to gently wash away the cleaner or stripper, not to grind dirt off the surface.
  • Use a sweeping, pendulum-style motion. Work with the grain of the wood and never pause or reverse direction without lifting the wand. Failing to maintain a smooth motion can leave permanent “stop marks” in the wood.
  • Keep pressure between 1200–2000 PSI. Even if you’re using a 3000 PSI machine, distance matters. Washing from 8–12 inches away will reduce the effective pressure to a safer level for wood surfaces.
  • Exercise caution. If you’re unsure about your technique or have never used a power washer on wood before, it’s best to hire a professional. Incorrect use can permanently damage your deck.
Quick Expert Recommendations and Insights
Here are some tips we recommend you follow to make deck stain removal a swift, painless process:
  1. Use a deck stripper if you are working with wood that has previously been stained. If you are working with a new wood surface or there is no stain on the deck, use a deck cleaner. If you are unsure about what to do, you can ask questions below.
  2. Remove all furniture from the area
  3. Wear protective clothing, gloves, and eyewear before going near the product. Mix or use the deck stain stripper according to the directions on the label. Test a small section of your deck before applying it to the whole area, as deck stain strippers vary in effectiveness. You may need a stronger formula if it doesn’t work on the tested area. See here if you need to remove a Difficult to Remove Deck or Wood Stain.
  4. Apply the deck stain stripper with a pump-up sprayer in sections of 100-300 square feet at a time. Saturate all the wood with one coat then wait 10-20 minutes. If the surface is slippery, that means the stain stripper is working to break the bonds effectively. If the surface is not slippery, apply another coat of the stain stripper and wait longer.
  5. Using either a brush or pressure washer, remove the old stain from the deck. Take precautions to wash with the grain wood whenever possible.
  6. Repeat this process until all of the old deck stain has been removed from the deck. Spot strip any sections where the stain didn’t come off the first time.
  7. Thoroughly rinse all wood and surrounding areas
  8. Apply a wood brightener to restore the pH balance before staining.
FAQs
How to remove deck stain without chemicals?
The best way to remove deck stain without chemicals is to sand the deck. Where semi-transparent deck stains have faded power washing the deck and spot sanding areas of thicker stain is typically sufficient. When removing a semi-solid or solid deck stain the entire deck may require sanding, but be careful not to over-sand. Over-sanding the wood compromises its integrity and can lead to early deck failure.
Will deck stain come off concrete?
Applying a deck stain can be messy and sometimes you can spill or drip on your concrete or brick pavers that are under or around your deck. Once this happens, it is not easy to remove. We have found that using a deck stain stripper and pressure washing will remove much of the spilled stain but not always as concrete can be very porous. Another option is using a graffiti remover cleaner. You can find these at your local paint store. Popular brands at Goof Off or Mostenbocker’s Lift Off.
719 Comments
Allen
Allen
I power washed my deck and then sanded with 80 grit, but in the photo it looks like I haven’t gotten it all. The previous owner used Olympic stain, I plan on using the same stuff. At this point, does it look bare enough to just put down the new stain? Or do I keep sanding? It’s pain to get up, and it sounds like stripper won’t work.
Allen
Allen
Thank you. I am considering using Restore a deck stain stripper, would you recommend this to remove the remaining Olympic stain? I also plan to follow it up with a brightener.
Kari Collins
Kari Collins
We have a deck that was painted and part of it has some residual paint stuck on (many years old) and we have not been able to scrape it off or get it off with a power washer. We bought the house this way. I don’t know if the other portion of the deck was stained or not, but it does not bead up, as a matter of fact it gets mildew and slick. So, do I need to use the stripper or the cleaner followed by the brightener? And, what sort of sander will work to get the leftover bits of paint up?
Can I power sand my decking even though it is ridged?
I have recently moved into a house and want to strip and redo the decking. I have no idea what they have used to treat the wood, any ideas from these photos?
I have bought some Ronseal Paint Stripper – will that do the job?
Many thanks
Reply to  Tom
Photo 1
Reply to  Tom
Photo 2
Please let me know if you require any more
Thanks, can you still power sand when the wood is grooved?
Thanks, will power sand be effective even though the wood has lots of grooves?
Thanks for the advice – at least I know not to waste my time trying to remove!
Apologies for all the posts, they were not showing before.
Jesse
Jesse
Just bought our house. Some of the deck is being entirely resurfaced with new wood. Some areas are decent for a few more years. One area had a solid stain on it that looks to be very old. Most of it came off with pressure washing and scrubbing using a deck cleaner. Some areas still need scrubbed some more. See attached photo. I have two issues:
1. We bought a stain/sealer (Olympic Maximum Pearl Gray) and tested it on one support post. We do not like the outcome. I will be using Cabot Australian Timber Oil instead. How can I get this post back to clean again? It was just applied last night and I plan to TRY to strip this tonight. Since this is freshly applied, would a deck stripper get this off pretty easily still?
2. Some areas that did not completely clean from the old solid stain will be scrubbed and pressure washed again. I’m still not sure it will all ever come clean since it’s so old and deeply set in the wood. Since a lot of the stuff that did not come off is up high in the air, I’d love to find a chemical that will remove this so that I don’t have to scrub high stuff dangerously. Any ideas how I could possibly avoid significant sanding efforts?
Any help is appreciated and thanks for all the previous help this site has given me over time. It has been extremely helpful for us!
Jesse
Jesse
UGH….I had a feeling. Thanks for the help!
Theresa kelly
Theresa kelly
Just had my deck stained on Monday. The guy had taped something to a post and when he pulled it off, yes, it peeled. I can see the post underneath still has the previous stain…actually a little shiny. He was supposed to prep and stain. I could literally peel the whole post. He used Sherwin Williams superdeck. semi solid. What should I do?
Justin
Justin
When you say power sand what grit do you recommend? I’ve been trying to sand mine with an orbital. 60 grit is taking forever. Belt sander isnt very efficient either.
G.Davis
G.Davis
What is the best solution to use to remove Olympic Rescue It from a deck?
Laurie Allen
Laurie Allen
My deck is about 8 years old pressure treated wood quite large last summer, my contractor cleaned it with Pittsburgh ultra deck cleaner and restained it with Cabot semi-solid redwood stain. now everything is peeling what do we have to do to fix this? I live in Central ohio.Thanks so much for advice.
Laurie Allen
Laurie Allen
Following up had to wait for rain to stop. Two photos today.
Laurie Allen
Laurie Allen
Ok do after power sanding do we have to do anything else to prep?
Bruno
Bruno
I have just stained my deck with decking oil, and I hate the colour!! Can I remove it
It was thompson timber oil
Bruno
Bruno
Thompson timber oil
Bruno
Bruno
Reply to  Bruno
See pic
Paul
Paul
I am planning on stripping a horrible application of solid arborcoat in the spring as well as replacing some rotting boards. For the boards that are still in good shape – can I strip the arborcoat off and then apply a semi transparent stain (Flood Series) or is it hard to apply stain after a solid coat has been stripped?
Thanks for the advice!
Lee Cumming
Lee Cumming
I have just stained my deck with decking oil, and I hate the colour!! Can I remove it??
Brian Bishop
Brian Bishop
Bought our house a year ago and the deck stain is wearing out. I assume I have to strip, brighten and then stain, but wanted to double-check. You can see in the pictures that parts of the wood are grayed, while some still appear to have stain on them. In fact, the first picture shows where I had some tape on the deck, and when I pulled it up the stain came off and gray was underneath. I found a couple of Behr products in the shed (Semi-transparent weather proofing all-in-one wood stain and sealer, and transparent weather proofing all-in-one wood finisher), so I assume these are what the previous owner used on the deck. Do I need to strip, brighten and stain, or can I use wood cleaner, brightener and stain? Or, just pressure wash and stain?
Also, how many days of dry weather should there be between prepping the deck and then staining? Is 2 enough?
Thanks in advance!
Brian Bishop
Brian Bishop
One more question: The deck goes right up against the house. If I use Defy’s stripper do I need to put a barrier up to protect the house paint? The directions say to protect surrounding areas, but I assume that means other stained items you don’t want stripped. I just want to be sure. The house was just painted a few months ago with Sherwin Williams SuperPaint.
Thanks again, in advance!
Shanna
Shanna
I am so frustrated.
We worked on our porch floor for weeks stripping it with paint stippers, scraping off layers of paint and sanding to get rid of all the stain.
I put the Pittsburgh clear ultra deck sealer on and
It turned it orange, I am livid, the endless hours and money we have spent and this is the result we get.
Sanding will not take the orange color off.
Any suggestions other than freaking out on the company
Rick Smith
Rick Smith
I had a product called Deck Restore applied about 3 years ago. It is supposed to be put down in two coats .,but was not .Needless to say it is a peeling mess. I started stripping it using a power washer ,but there are sections that don’t want to come up . Is there anything I can treat it with to strip it easier.
Bob Parry
Bob Parry
I have a deck that was sealed two years ago…Pittsburgh acrylic oil Clear….but it had an orange tint to it. I wanted to remove and first used Wolman DeckBrite. This did not do a good job so we bought a deck stripper. The question is, do we need to apply another Wood Cleaner and Coating after the stripper or are we good? Right now most of the wood looks brand new though it is over 15 years old.
Heather Schmidt
Heather Schmidt
We purchased our home a year ago. It has a 25 year old deck that had a solid stain on it. We replaced several old boards. We sanded it all which took days and then used a deck cleaner. When we were washing off the deck cleaner we noticed the old stain was still peeling in some areas. Do we need to strip it as well or can we just use a brightener and then apply a solid stain? It was a reddish/brown and we are hoping to make it grey. We have invested 40+ hours (1,000 sq. ft. deck) so want to do it right the first time. Thanks for any advice!
Heather Schmidt
Heather Schmidt
what do you think is easier, sand or strip? If I strip do I need to sand again? I used a large floor sander on the floor and hand held sander on the rails. Most of it is down to the bare wood but some areas still have small streaks of stain on the floor.
cathys
cathys
I have had an accident with this product and want to remove it. Any advice on a stripping product please?
Adrian
Adrian
While sanding my deck I discovered 3 boards with damage. Right now the deck is solid 20′ boards. Should I replace the whole length or just sections of the 3 boards? Also once sanded, what is the best oil based stain that has the least amount of color in it? Thanks!
Sarah
Sarah
Help! We have a pressure treated deck that’s a few years old and my dear husband took it upon himself to stain it. I ABSOLUTELY HATE the orange looking stain. I just wanted it to remain the same colour and be weather guarded. Can this be stripped off right away? What do you suggest….aside from divorce?? Please help😡
Daniel
Daniel
Hello, I have a deck with an unknown prior coating. Not sure when prior homeowner last stained.
My plan is too strip, brighten and stain with Flood Pro Series Solid Cedar.
Do you think it will require sanding as well?
Here are some photos that may help.
Dan
Adrian
Adrian
Two years ago I put “Behr Premium semi transparent weatherproofing” on my deck. It looked terribly right from the beginning. Two years later it looks really bad. This is an acrylic stain. What can I use to strip my deck? I would prefer to use a product that can be put on, then hosed off with a pressure washer. Is there such a product? Thanks.
Adrian
Adrian
Thanks for your help. I accept that it will have to be hand sanded. What can I put on it afterwards so that I never have to deal with this again? I want to protect the deck, but I don’t need any additional color (ie stain) or anything – just protection from sun and rain. What would you recommend? Is Thompson’s water seal a good choice?
Jen
Jen
Reply to  Adrian
Crazy I have the SAME exact issue. How to get it off?! I have a painter who says he can use a Diamabrush to get it off.
Good luck! UGH :(
M. J.
M. J.
Should deck be dry before applying deck stripper?
William D. Gowen
William D. Gowen
I have a 6 year old deck with KDAT lumber. It has been stained 3 times – once by the original installer and twice since. The last two times it was stained with Behr solid color All in one stain and sealer. It looks horrible with the stain peeling in dozens of places. Even worse, the expensive KDAT lumber is rotting. Many boards will need replacing. So my question is what to do next? If I sand the deck how do I remove the old stain from the edges of the boards? Is this just a matter of hand sanding all of the spaces between boards? Also, sanding will probably not get down into the cracks that many of the boards have so do I just have to live with red opaque stain in the cracks? I’m attaching some pictures of the stain, the cracks and the deck stain that was used.
Don
Don
Boards are 13% moisture or so but joints are often 20- 23%. Should I stain or wait for 18% on all areas? Rain forecast for tomorrow! Thanks again!
Tony
Tony
I’m removing old semi transparent stain from my cedar railings. Went the wash and bright route first, took 70% of stain off but now have tough spots remaining. Not against sanding but time consuming and it’ll rain a few times before I can finish Anyhow, if I use stripper is there any concern it’ll stain/strip color off the trex floor decking I have or my new vinyl siding?
Tony
Tony
Thanks for the quick reply. I did the stripper and it did a pretty good job but now I have all this little fibers like hair coming out of the wood. Any suggestions on these? Do I just stain over it?
Don
Don
Is a staining pad better than a paintbrush for an unstained, 6 year old, pt pine deck? Maybe better for a maintenance coat 1-2 years later? Thanks!
Bethany
Bethany
We have recently stripped and sanded our deck, do we need to use a wood neutralizer before staining or does a deck wash/brightner act as the same thing?
Doris
Doris
Does the deck have to be dry before using the stripper?
We just applied a semi transparent stain on our deck last season. We live in Michigan. Is it too soon to strip the stain off? My wife does not like the color, but it is still in great shape.
Laura
Laura
I have a five year old cedar deck. It has gone from a water sealer to a ready seal oil stain(worst ever so oily). There has never been a proper prep. So I have sanded with a big floor type sander. Next I cleaned with a deck cleaner and scrubbed. Surprised that after sanding a lot of oil cane up while scrubbing. So today I want to strip and then brighten. Is this order okay? I want to strip because there are a few boards that are not absorbing the water. Should I strip the whole deck? I’m going with TWP 100. Thanks! I love your site.
Laura
Laura
Reply to  Laura
Thank you!!! Your guys have helped a single lady figure things out. Can I just rinse off stripper with hose? I don’t have a power washer. Can a apply brightner as soon as I am done rinsing off stripper? Lastly do I need to scrub stripper of can I just rinse off.
George Paul
George Paul
I have power washed off as much as possible. Is there a stripper that is pet friendly? What stain would you recommend for a redwood color?
George Paul
George Paul
I’ve read through the comments and although not ideal, if I go with another solid stain what are your recommendations?
George Paul
George Paul
I have read through the comments, although not ideal if I go with a solid stain again what would you recommend?
I have a mahogany deck that was stained with Duckback Superdeck Exotic Hardwood Stain. I sanded it down to bare wood, and plan to re-stain with a different hardwood stain–Armstrong Clark or Defy based on your reviews). Also, which do you recommend for mahogany, the Armstrong or the Defy.
Since I sanded it thoroughly, do I need to use a cleaner and/or brightener since I did not use a stripper?
Thanks. What color would you recommend for Mahogany? I’d like to keep the natural look of the wood as much as possible. The Defy Hardwood stain comes in Cedar Tone, Natural Pine and Light Walnut.
Drew
Drew
I just stripped and brightened my deck. I’m not sure what the previous owner used for stain, and there wan’t much left on the surface, so I decided to use a stripper to be safe. I power washed prior to stripping and then again to rinse off the residue and later to rinse off the brightener. Everything looks pretty good but there are areas on the deck planks that look like the surface wood fiber broke down. It looks fuzzy, almost like felt. Can I make it right by sanding? Anything else I need to do? Pic attached. Thanks. Very helpful website!
Don
Don
Is it okay to lightly sand any fuzzies after brightening? Or best to do after sanding and before brightening? Don’t want to close wood pores or add more fuzzies when sanding after brightening. Thanks again!
Don
Don
My 6 year old pt pine deck is about 384 sq. feet and 2 feet high. I stained last spring which was really wet. (Maybe should have used a moisture meter.) Cleaned, sanded and gambled on BM semi-solid. Oops! (The semi-transparent just did not provide the colour we desired.) The deck is boarded on all 3 sides by 3 boards to keep most of the critters out. There ‘s about 1/4 inch gap between the deck boards. Would it be wise to drill air holes in the boards or remove them altogether? All 3 sides or 2 sides? Could remove 2 boards on all sides since the top side boards are facer/structural? boards. 2 sides of the deck are wrapped in bushes; no railings. If I were to drill holes, how large should they be? Thank a lot!
Don
Don
Yeah, the semi-solid BM peeled. Maybe the lack of air flow was the issue? AC semi-transparent looks promising. Thank you!
Don
Don
Forgot to mention there is white stone under deck and about 18 inches of space. Same advice applies? (Remove 2 boards on all sides.) Thank you!
Don
Don
Don’s deck. Re. Ventilation issue. Thanks!
Don
Don
Don’s deck/ventilation issue. Thanks!
Kim
Kim
I want to remove semi transparent deck paint that had already started to peel off. Can you tell me the best product and way to do this please? Thanks!
Don
Don
Do I need to clean wood that was cleaned and sanded last spring? Will be lightly sanded again and brightened. Then a semi-transparent stain. Probably AC. Thx a lot!
Judie
Judie
Can the stripper be left in the sprayer overnight?
Judie
Judie
Thanks😄
Aba
Aba
We just stripped out decks and rails with pressure washer. From the looks of it, we need to sand it for all the new rough spots peeled up with pressure washer. Then water seal. Do you have any other suggestions??
Elaine Hazelett
Elaine Hazelett
We have a pressure treated deck that a handyman thought was cedar and he washed it with a clorox soap and hand sanded it to remove the old stain. However, the stains were still observable and he stained right over the decking. Now it looks blotchy and no where near what it formerly looked like. From your explanation, he clearly didn’t know what he was doing and continued to maintain that the wood is cedar which he was told it is not. Now what ? Thoughts ? E. Hazelett, Stowe, VT
Sarah
Sarah
Hiya, last year we moved to a new house and power-washed our decking which was greyish, quite mouldy and extremely slippy. We then applied Culprinol natural oak anti slip stain, but it started to peel in areas. We powerwashed and brushed hard again this year and reapplied and starting to peel again in areas and looks pretty patchy. Should we have treated/stripped/sanded the first time? We are rather naive, first time buyers so didn’t really know! Any help or step by step guide to sorting this would be appreciated…Thanks!
Mary Helwig
Mary Helwig
I painted my deck with solid stain each year…the last 3 years…never removed any stain…was peeling from the first year I started… I want to stop this cycle…please explain steps simply for me for I am new to home repairs and want to do correctly because money is tight.. thank you
Jen
Jen
I am wanting to remove two year old acrylic/oil stain I applied to a dock that now looks blotchy. Type of stain was Flood Pro series and colour was natural.
Am I still safe to use a stripper and brightener around lakes?
Jas
Jas
Thank you. Do I need to prep the rails a certain way before recoating?
Also we tried stripping an area to do a test run and there are a few small areas that where the stain would not strip off…will that be problematic when we go to restain? If we have to sand those areas prior to staining do you recommend a specific grit for sand paper?
Jen
Jen
Here are some photos of the dock
Jen
Jen
Flood is the stain type. It says natural, but as you can see from the photos had a brown tint. The dock is made from pressure treated green so I would actually like no colour or a green tint.
We redid our deck last year….sanded and stained, looked great. This year we scrubbed it with bleach and applied stain before it was thoroughly dry. Mistake! Now do we need to strip it, add brightner and re stain? In that order?
Super deck transparent
In the end, we stripped, brightened – let it dry for a week – sanded and stained…..results, an amazingly beautiful deck. We live in Washington State and after researching stains for the Northwest we used Armstrong-Clark semi-transparent stain and Andre extremely happy with it. Thank you for helping; it certainly was a lot of labor that has paid off.
L
Here you go…
Melissa
Melissa
We started staining our deck this week and hate the color. It was not at all what we expected. Is it possible to remove it with it being newly stained and not old?
Melissa
Melissa
This is what we used. I don’t have a pic of the deck. But it turned out an orange red color. We did not finish so it’s only the first coat sprayed on and still has a lot of unstained wood showing through. Any hope?
Jas
Jas
Hi, thank you so much for the advice. I am planning on stripping the deck prior to staining it, however, the rails look like they didn’t receive the weathering that the deck did, is it a bad idea to stain only the deck and not the rails? also is it a bad idea to add a new coat of stain on the rails if I don’t strip the previous stain first?
Jas
Jas
Jas
Jas
We are using beauti-tone 100% acrylic semi-transparent stain. I have attached pictures
Jas
Jas
It was supposed to be a dark (really dark) stain that still shows wood character. The spots where it stripped like it was supposed to looks like brand new wood
Don
Don
I used a semi-solid oil stain (BM) on my deck last spring/summer and it’s peeling on some boards already. Should I chemically strip what comes off then belt sand any remaining stain? (Usually I use semi-transparent but liked the colour the semi-solid provided.) Duh! Thx.
Don
Don
Yes. Arborcoat. Belt sander? 60 grit? Thanks.
Matt
Matt
I‘m about to restain my 16’ by 30’ cedar deck It has sikkens srd on it now. I’m thinking of sanding it and than applying gemini cleaner and rinse than the and brighter rinse let dry until Thursday and restain with twp 100 Thursday 2 coats wet on we. I was hoping to get your option. also Friday is and nice but Saturday is going to rain do you recommend me staining it after Saturday? Is it ok to leave it sanded and cleaned and brighten until after the rain cause suppose to get 3 days of nice weather after Saturday
Scott
Scott
I’ve read that you don’t encourage sanding a deck during prep. I have pressure washed my deck, now (based on your guidance) I’m going to use a stripper, brightener, then stain. I’d like to sand as I’d like to get rid of some of the splintering from the pressure washer (my bad).
When do you recommend I sand in this process? Before the stripper, brightener, stain?
Scott
Scott
Thanks! I haven’t been using a stripper while I’ve been pressure washing. If I sand, do I still need a stripper?
719
