🏆 Top Picks Summary
- Best Overall: TWP 100 or 1500 Series
- Best for Old Decks: Armstrong Clark
- Best Budget Option: Restore-A-Deck
- Best Penetrating Oil: CUTEK Extreme
| Product | Type | Durability | Ease of Maintenance | Key Strength | Best For |
| TWP 100 | Semi-Transparent (Oil) | 2–3 Years | Easy | Proven performance, deep penetration | Most decks |
| TWP 1500 | Semi-Transparent (Oil, Low VOC) | 2–3 Years | Easy | Better VOC compliance, similar performance to TWP 100 | VOC-restricted states |
| Armstrong Clark Wood Stain | Semi-Transparent (Oil) | 2–3 Years | Easy | Excellent oil penetration + conditioning oils | Dry, aging wood |
| Restore-A-Deck Wood Stain | Semi-Transparent (Water-Based) | 2–3 Years | Very Easy | Simple prep system + easy recoat | DIY homeowners |
| CUTEK Extreme | Penetrating Oil | 2 Years | Very Easy | Deepest penetration, no film buildup | All Wood types |
| Defy Extreme | Semi-Transparent (Water-Based) | 1–3 Years | Moderate | Strong UV resistance with zinc nano-particles | Sunny/high UV areas |
- Best Overall Deck Stain: TWP 100 Pro Series — A deep-penetrating, oil-based semi-transparent stain that offers excellent durability, easy maintenance, and consistent performance for up to 3 years.
- Best Semi-Transparent (Water-Based): Restore-A-Deck Semi-Transparent Wood Stain — A user-friendly, UV-resistant stain that can be applied to damp wood, allowing prep and staining in one day.
- Best Oil-Based Alternative: Armstrong Clark Wood Stain — A penetrating oil formula that conditions aging wood while providing long-lasting protection and easy reapplication.
- Best for VOC-Restricted States: TWP 1500 Series — An EPA-registered preservative with strong UV and mildew resistance, ideal where traditional oil-based stains are limited.
- Best for UV & Mildew Resistance: Defy Extreme Wood Stain — A water-based formula enhanced with zinc nano-particles for superior UV protection and mildew resistance.
- Best Semi-Solid Stain: TWP Pro Series Semi-Solid — Offers richer color, excellent UV blocking, and better coverage while still allowing some wood grain visibility.
- Best Solid Color Stain: Restore-A-Deck Solid Color Stain — A durable, breathable coating that resists peeling and works well for older or heavily weathered decks.
- Best Deck Resurfacer: Gulf Synthetics Deck Revive — A thick resurfacing coating designed to restore heavily worn or damaged wood surfaces.
*Free Shipping Included
✅ How I Rate Deck Stains
- Durability in real-world conditions
- Ease of application and maintenance
- Resistance to peeling and wear
- Overall long-term performance
- Wear and tear after 2 years
- Oil-Based:
- Deep penetration
- Easier maintenance
- Water-Based:
- Better UV color retention
- Faster drying
1. TWP 100 Series
2. Armstrong Clark Wood Stain
3. TWP 1500 Series
4. TWP Pro-Series Semi-Solid
3. Defy Extreme Stain
Type: Oil-Based Semi-Transparent- Durability: 2–3 Years
- Maintenance: Easy recoat, no stripping needed
- Best For: Most decks (pressure-treated, cedar)
- Why It Stands Out: Deep penetration and consistent long-term performance without peeling
My Test Deck Stats
Deck Square Footage: 2100
Consumer Star Ratings:
- Type: Water-Based Semi-Transparent
- Maintenance: Very easy, simple prep system
- Best For: DIY homeowners and quick projects
- Why It Stands Out: Can be applied to damp wood, allowing prep and stain in one day
My Test Deck Stats
UV Exposure: 50% Full Sun
- Type: Oil-Based Semi-Transparent
- Maintenance: Easy reapplication
- Best For: Older, dry, or weathered wood
- Why It Stands Out: Contains conditioning oils that help restore dried-out wood
My Test Deck Stats
Deck Square Footage: 600
- Type: Semi-Solid (Oil-Based)
- Durability: 3 Years
- Maintenance: Moderate
- Best For: More color coverage with strong UV protection
- Why It Stands Out: Rich color options while still allowing some wood grain to show
My Test Deck Stats
When Tested: August 2023
Deck Square Footage: 800
UV Exposure: Deck in full sun
- Type: Oil-Based Semi-Transparent (Low VOC)
- Maintenance: Easy
- Best For: VOC-restricted states
- Why It Stands Out: EPA-registered preservative with strong UV and mildew resistance
My Test Deck Stats
Deck Wood Type: Cedar
Deck Square Footage: 400
- Type: Water-Based Transparent
- Durability: 1.5–2.5 Years
- Maintenance: Easy
- Best For: Maintaining a natural, “bare wood” appearance
- Why It Stands Out: Unique formula designed to preserve the natural color of new wood while still offering UV protection
My Test Deck Stats
Stain Color Used: Chesnut
- Durability: 2 Years
- Best For: High UV and mildew-prone areas
- Why It Stands Out: Zinc nano-particles provide superior UV protection and mold resistance
My Test Deck Stats
Stain Color Used: Cedartone
- Durability: 1-2 Years
- Best For: DIY users and quick, forgiving applications
- Why It Stands Out: Extremely easy to apply with no back-brushing needed, but shorter lifespan than higher-end penetrating stains
My Test Deck Stats
- Type: Penetrating Oil
- Maintenance: Very easy (clean and reapply)
- Best For: Exotic hardwoods (Ipe, teak) all wood types
- Why It Stands Out: Extreme penetration with no film buildup, making long-term maintenance simple
Scott’s Pro Tips: Although CUTEK® Extreme is more expensive than many penetrating oils, the performance was very solid. There was no peeling or significant wear, and the coating should be easy to maintain, as it fades naturally and can be refreshed without stripping.
My Test Deck Stats
Deck Square Footage: 1000
How Many Years Tested: 1 Year
Stain Color Used: Walnut
Semi-Solid Deck Stain Review
- Consumer Star Ratings:
Best Deck Stain for Old Wood
- For new pressure-treated wood, wait until the wood has weathered and is able to absorb stain (typically a few months), then prep and stain.
- For older pressure-treated decks, proper cleaning and brightening will restore the wood and allow for better stain penetration.
- If you want to maintain cedar’s natural look, use a lighter or natural-tone stain.
- If you want longer UV protection, choose a slightly darker tint, as it will hold color longer.
- Wood Condition: New, weathered, or heavily worn
- Desired Look: Natural grain showing vs solid color
- Maintenance Preference: Easy recoat vs long coverage
- Climate: Sun exposure, moisture, temperature swings
✅ Deck Stain Types Explained
- Transparent/Clear Sealers: Natural look, less protection
- Semi-Transparent Stains: Best balance (most recommended)
- Semi-Solid Stains: More color, moderate maintenance
- Solid Color Stains: Maximum coverage, higher maintenance
Transparent Stains
Solid (opaque) Stains
2. Long-Term Durability
3. Deck Condition
4. Climate Concerns
- Film-forming coatings on older decks
- Over-applying stain
- Choosing based on color alone
- Skipping prep
- Not preparing your deck: Failing to clean your deck or remove old, flaking, or peeling stain from your boards can prevent a fresh coat of stain from adhering properly. See my Deck Cleaning Guide for best results!
- Over-applying stain: You may think more stain equals more protection from moisture, mildew, and sun damage, but that’s not always the case. Too much stain can prevent the product from penetrating your deck boards. As a result, it may form a film on top of the wood that peels or flakes off over time. See my How to Stain a Deck tips for the best results.
✅ Best Deck Stain FAQs
Quick Tip:
What is a deck stain?
⏳ Durability & Maintenance
🎨 Appearance & Color
🛠 Application & Usage
🆕 New Deck Questions
- Smooth wood: Wait ~3 months
- Rough wood: Can stain once clean and dry
- Kiln-dried wood: Wait 1–2 months
- Deck Location: Michigan
- Wood Type: Cedar
- Mold/Mildew?No
North Carolina, lake gaston
multiple situations:
boathouse #1 full sun, new pressure treated pine, lots of mold (but prior wood was in poor condition, neglected)
boathouse #2 full sun, about 10 year old deck, some mold, unsure of when stained last
deck on house, partial sun, mold, unsure of when stained last–have power washed and used deck-brite
Jeff, I would look for the TWP 100 Series for these decks.
Stained our pressure board deck with Benjamin Moore deck stain. Used before and was great. Unexpected shower and now it is spotted and a mess. How do we fix this?
Most likely you will need to strip it all off down to the bare wood and start over for this. Sorry to hear about this 🙁
Deck Location State: Maryland
Full Sun
New Deck
Mold or Mildew Issues: low
Reason for Previous Stain Failure: New
Yariv, please read Staining New Decks
Georgia
Full / Partial Sun
Pressure Treated Pine – 10 years old
some mold/mildew
Time to re-stain, needs new coat
Originally used TWP and liked it
Seeing some splintering and cracks in the wood
Brian, if you liked the TWP then I would stay with it. Make sure to prep well first by cleaning and brightening the wood.
Does the same generally hold true for wooden garage doors? Here are my specs:
Live in Cornelius NC (Lake Norman area)
Full sun after 12 noon through evenning
3 1/2 years old
Stained when house was build and nothing done since then
Looking for long lasting, hopefully more than 3 years
Daniel, in general yes. We do not do many garage doors but we have used TWP and Defy on them in the past.
NW New Jersey(Sussex), Full sun with Awning covering partial area, 5 years old, some mold from leaves from the winter, Use stain a year after putting up deck(Treated wood), semi transparent stain used 2 years ago, now peeling and wear areas. Power washed it to remove peeling areas and clean it. Want to use either water sealer w stain or stain. I don't even care if it isn't stained just want to protect it, It will look antique. 🙂 Just don't want to have to do it again next year. Some areas that are not high traffic were peeling also. It is 15×30. If you could give me suggestions I'd appreciate it..
Carol, I would look at Armstrong Clark or Defy Extreme.
Deck Location: Heber Utah, elevation 8500 ft. Dry summers, cold heavy snowy winters
Partial Shade
Pressure treated Pine
No mold
stained 2 years ago (not by us) and not sure how it was prepped
Would a paint rather than stain be a better product?
Matt, we are not fans of deck paints. They always peel and you will never get the natural wood look back. Prep well then stain with TWP or Armstrong Clark.
Minnesota
Full Sun
Redwood (guessing deck is at least 25 years old if not older)
No mold problems
bought the house 3 years ago and it seems to have a semi transparent (or solid can't really tell) I don't believe anything has been touched on it for at least 10 years. I also have to a do a privacy fence that is cedar.
I also had to replace a couple of deck boards and used cedar to do that
I would like to be able to buy something that I can get locally ( not have to order it online) I am also looking for it to match the color of my windows (sandstone)
What should i use to clean it and what stain do you recommend!?
Tom, stains that we use and suggest come pre-tinted and cannot be color matched. You would need more of a paint type stain to match your window trim.
Location: Northern California Cascade/Sierra Nevada forest
Exposure: Full sun, partial sun & shade – east, west & south facing
Wood type: brand new redwood deck, 1 year old, 2600 sf
Mildew: yes
Reason for previous stain failure: deck boards stained, all sides, before installation & second coat of stain added after installation resulting in a spotty, shiny appearance; after winter snow, leaves & pine/fir pollen, the deck now has significant areas of dark mildew.
Questions:
1) Okay to use pressure washer to remove mildew? What are appropriate nozzle & psi settings? Or, should we use a stiff deck brush –2600sf deck, so would prefer to use pressure washer if it won't damage wood
2) Need to use a specific deck cleaner or is 1/4c bleach to 1 gal. water okay? What deck cleaner?
3) Protect deck again this year or wait till next year? We would like to keep the clear warm/light redwood deck color if possible. What would be best to achieve this: a clear finish sealer or stain? Currently considering Duckback SuperDeck sealer with UV protection….
Thanks for any suggestions you have!
lflarson, you need to strip off the old stain that was over applied and applied to soon. Super Deck is a penetrating stain and if it dried shiny then you will get many issues with mold and peeling. SuperDeck also has a tendency to turn black from our experience. Strip and brighten with the RAD Products then stain with Armstrong Clark or TWP 1500.
Montana
Full Sun
Rough Cut Fir
No mold or mildew – its really dry here
Previous stain was 5 years ago and was inconsistent in application
Montana, clean and brighten the wood for the prep. Look at TWP 1500 or Armstrong Clark.
Deck Location State: New Jersey
Partial Shade – Northern Exposure
Wood Type: Cedar – 15 years old
No Mold or Mildew Issues
Reason for Previous Stain Failure: Wholesale Peeling of Benjamin Moore Semi Transparent Stain after 8 months.
Sanding entire deck down to bare wood to remove old stain so Cedar should absorb new stains well.
Chris, after the sanding use a deck cleaner to help open the wood grain for the stain. Try TWP 1500 or Armstrong Clark.
St. Louis, MO
Full sun
Pine
1 year old, never treated/stained yet
No mold
Barb, prep with a deck cleaner and wood brightener. Stain with Defy Extreme or TWP 100.
What is TWP and where can I purchase some? What is the best deck cleaner also?
Maureen
Maureen, TWP is a wood preservative and can be purchased at local stores or online. Best to ask the manufacturer for a dealer.
Albany NY
West facing. Full afternoon sun
5 yr old deck previously treated twice with Thompson's-deck floor and railing
Faded, no mold.
What is the best pre-stain treatment?
What is the best stain
Thanks for the advise
Carol M, remove any remnants of the old Thompson\’s. Use a stain stripper if needed otherwise a deck cleaner. Both need to be brightened when done. Look for TWP 1500 or Defy Extreme Stain.
Great website.
1. Colorado-elevation 6000'
2. Full sun after 12:00
3. Redwood
4. No mold or mildew
5. Intense sun in summer, snow and freezing conditions in winter
Deck is less than a year old. I used an oil-based transparent stain that has 99 percent UV protection. Water repellency did not last long. Deck boards have numerous cracks. Would prefer to use transparent or semitransparent. What do you recommend? Thanks for your help.
Janice, try Armstrong Clark or TWP stains for this.
Colorado, Denver area
full sun
red wood
12 years old
haven't retained in 6 years or so, desperately needs to be re-stained
power spraying to clean
would appreciate knowledge on what stain would be best to re stain that would last a long time and preserve the wood
mic, TWP 100 or Armstrong Clark.
Southwest Virginia
Deck faces Southeast, so shady in AM, then Full sun after around 11am or so.
Pressure Treated Pine, new home (installed about 2-3 months ago)
No mold issues currently
As with many other posts on this board, I have a pine deck that needs it's first stain. It was quite weathered, but is now cleaned and ready to go once the weather cooperates. I'm located in Toronto Ontario. The deck is full sun.
I got excited about TWP but then learned about 15 min ago that it isn't available in Canada… Is my best option to ship some Defy Extreme (butternut) into Canada? Has anyone done this and can comment? I want something that will last (obviously), and hate seeing the poor Behr etc. products in my neighbourhood. Is this a suitable stain for my situation?
Please help!
Steven, might want to look at the Armstrong Clark as well.
Sun/Shade : full shade in am, full sun pm on most of deck
Wood : 19 year old pt pine
mold/mildew : yes
Last stained 5-6 years ago, Superdeck brand tung oil-based transparent, retained color well, overdue for new coat; wood in good shape except for top rails which are cracked, need replacing, so will have some new wood
Gayle, look at the Defy Extreme or TWP 100.
Southwestern Ohio
Partial (70%) Shade
Replacement deck installed July, 2012. Has not been stained/ sealed
Heavy mold – live in woods
Previous deck failure due to poor stain absorption/ Mold
I am currently considering the TWP 1500 Series, Defy Extreme Stain and the Armstrong Clark Stain, but am open to other suggestions as well. All replies will be sincerely appreciated.
Terry, prep well then try the Defy Extreme since you have mold issues.
Saratoga Springs, New York
Partial shade
Pressured treated pine
No
New wood never stained 1 year old
What cleaner do I need and do I need to use brightner?
Marrianne, try the Restore A Deck Kits for the prep. Stain with Defy Extreme or Armstrong Clark.
Massachusetts
shade
25 year in good condition pressure treated
mold
stained 3 years ago
pressure wash
Kathy, TWP 1500 or Armstrong Clark.
Atlanta, GA suburbs
Full sun
20 year old deck base w/2 yr old deck posts, rails, & balusters (new sides – was lattice). PT Pine.
No mold/mildew issues
Re-stained about 3 years ago with Behr Semi-Transparent (looked awful – like 100% paint)
Took forever with deck cleaner and pressure washing to get it all off. 'New' side materials never been stained.
Lori, look at TWP 100 for your area.
Hi There
Looking for a semi-transparent stain. Thanks for your help!
Interior BC mountains, temperate, rainy, almost coastal
Partial Shade
Douglas Fir
New Deck
New Deck
Kevin, please read this article: Staining New Decking
Northern Minnesota
Full Sun
Treated pine
No mold or mildew
Deck is 8 years old and was never stained or treated. It is gray and I want to maintain the wood grain, but add some color.
Katie, clean and brighten the wood first then stain with Armstrong Clark in Amber or TWP Honeytone for a light color.
Piedmont NC
1 hr sun/day
old 5/4 treated pine deck
no mold problems
plan to get rid of 3 yr old behr (5 yr guaranteed) by striping and brightening which is is peeling and lost it's water resistance
Bobj, look at TWP 100 for this or Defy Extreme.
1. San Diego
2. Full Sun
3. Redwood
4. No
5. Had UV damage, turned grey. Would like the redwood to keep its natural color, so no tinting.
Brandon, no tinting means no UV protection from graying. You must have a tint for this.
Any comment on Behr deck over resurface. Getting ready to re-stain 22 year old deck. have used CWR and now can't find it. Delaware, part shade to full sun, pressure treated pine, no mildew, time to re-stain 2years old
Mavem, in our opinion I would stay away from any deck stain made by Behr. None of them seem to work as of yet.
Chicago
Full sun summer full shade winter
Cedar
No mildew issues
Unable to purchase old stain
Pat, look for TWP 1500 or Armstrong Clark.
We need to re-stain our new deck and want advice on which product to use for our area:
1. Maryland
2. Full sun
3. Pine
4. No
5. Wood not holding stain color, like the wood soaked up the stain and its back to bare.
Thanks, theresa
Theresa, how new is this deck and what brand of stain did you use before.
Deck Location State: Massachusetts
Full Sun, Partial Shade, Full Shade: Full Sun: noteworthy seaside
Mold or Mildew Issues: Yes
Reason for Previous Stain Failure: Unknown… not sure how long ago done (I just bought the house 15 months ago)…but there is greying of wood, some green wood parts, splintering and of course peeling
Crystal, strip off the old stain and clean the deck. Apply a wood deck brightener when done. Stain with Armstrong Clark or Defy Extreme when done.
1. Location – Southern Pennsylvania
2. Morning Sun – Afternoon/Evening Shade
3. Wood = Pressure Treated
5. New deck – Never stained
Staining New Decks.
1.Deck Location State: Minnesota
2.Full Sun
3.Wood Type: Cedar
4.Mold or Mildew Issues: No
5.Reason for Previous Stain Failure: Peeled
Adrian, remove the old peeling stain first. That can be done by using a stain stripper and or sanding. Brighten the wood when done. Stain with the TWP 100 or Armstrong Clark.
Atlanta Georgia
Full sun
Cypress deck floor
Cedar railings
No mold
New deck / no finish
Looking to use a clear stain to enhance the natural wood tones.
Jim H, please read this article: Staining New Decks. I would look at the Armstrong Clark in Amber
Deck Location State: Missouri
Covered deck, stairs ends have partial to full sun
Reason for Previous Stain Failure: Stain peeled, turns grey where full sun
Roger, make sure to prep to restore the natural wood color. Stain with TWP or Defy Extreme.
Prep the surface with a deck cleaner. Stain with TWP 1500 or Armstrong Clark.
What is the best stain for: Virginia, Partial Shade, Pressure Treated Pine, No Mold or Mildew Issues (yet), New Deck (installed a little over 3 months ago), carried at Home Depot/Lowe's if possible.
Stephanie, HD and Lowes does not carry any quality stains. We would never put their products on one of our customer’s deck. Look for high end paint stores or lumber yards to carry a better stain. Please read this about Staining New Decks
Ok. What brands then would you recommend that would be available at a high end paint sore or lumber yard?
Stephanie, I do not know what is available at your local stores as they vary. If you let us know what they carry we can narrow it down for you.
NJ
Full Sun
8 year old Mahogony
Minimal Mold
Maintenance Stain
*looking for clear. used a color once, and took away from natural appearance
Vinnie, a clear will prevent graying. You need color for that. If you are okay with that then use Defy Extreme Clear or TWP 1500 Clear.
Northern Virginia
Full sun for part of it; covered portion is partial shade
New deck
Julia, Please read this article Staining New Decking
Full Sun Summer, Full Shade Winter
Cedar
No
Unable to purchase old stain/sealer
Pat, strip off any remaining stain then brighten the wood. Look at the TWP 1500.
Kansas
Partial Sun
3 year old deck pressure treated pine
No mold yet but it is possible
Never stained but professionally sealed
I would also like to stain my fence that is the same age and never been sealed. The fence boards were cedar and the 2×4 and 4×4 frame was treated pine. I will be staining the playground equipment too that is two year old cedar. I would like to use the same stain on all of it.
Michael, I would clean and brighten all wood to prep with the Restore A Deck products then stain all with the Armstrong Clark in a semi-transparent or semi-solid color.
Eastern Massachusetts
Pressure treated pine.
Deck was built one year ago and has never been treated.
Faces north – gets afternoon sun.
No mold or mildew yet.
Nancy, prep with a good quality deck cleaner followed by a wood brightener. Stain with the Armstrong Clark or Defy Extreme.
I am looking for a deck cleaner that will not "fuzz" up the wood. I cleaned two decks last summer with 1/2 strength ADP deck cleaner. One deck was 15 years old PTP and been stripped. The other deck was 6 month old, never stained PTP. Both old and new wood got the fuzzies and had to be sanded before staining. After staining and curing some deck wash accidentally got on the stained new and old wood and again, the fuzzies occurred on both woods (now stained .) I now need to clean my stained deck from salt and sand due to heavy snows and am terrified I will get fuzzies again on the beautiful finished deck. A pressure washer was never used. Is there a cleaner out there that will not lift the wood fibers? I have friends who wash their deck, year after year, and this never happens to them! Thanks! Nancye
Deck Location State: Connecticut
Reason for Previous Stain Failure: n/a
Nancy, cleaners and stripper work by softening the wood grain to you can wash or the dirt, old stain etc. The side effect of all cleaners in you can get the \”fuzzies\”. We use deck cleaners like Restore A Deck and Defy Wood Cleaner. They are less aggressive but you may still some side effects.
Georgia
Full Sun on parts, partial shade to shade on others
Pressure Treated Pine (some of deck is older and pretty splintered, new deck is 5 years old)
Mold or Mildew Issues: Yes, gets slick in the fall/winter
Previous Stain – wore off with time/pressure washing
contractor recommended Restore but I've read reviews and not going that way. prefer natural look, also need to know how often/when to maintain/reapply.
also – any idea of $1000 to restain 1500 sq ft of deck is reasonable? what would I expect him to do for this? (e.g., sanding, cleaning, etc.)
Alexi, $1000 to restain 1500 sq. foot is very inexpensive. We personally charge $1.50-$2 per sq. foot for the entire process. I would look at the TWP or Defy Extreme for this.
Deck Location State: chicago illinois
Reason for Previous Stain Failure: Peeled and turned dark in color on back porch front porch has never been stained
Allan, strip the back. Clean the front. Brighten both. Stain with Armstrong Clark or TWP 1500.
New York – 40 miles north of NYC
Full sun
1 year old deck
Pressure treated yellow pin
Has been pressure washed
Looking to slightly darken the color of the wood (semi-transparent) & protect while preserving grain
Colin, TWP 1515 Honeytone or Defy Extreme in Natural Pine.
Deck Location State: Illinois (Chicago)
Full Sun AM then shade late afternoon
Wood Type: western red cedar
Reason for Previous Stain Failure: Peeling. Sherwin Williams last 2 years. Will be poower washing deck to remove most of not all old stain. Deck includes railings and lattice.
Art, Look for Armstrong Clark or TWP 1500.
Because what I used in the last and because I am not going to strip the deck, do either of these come in a solid stain?
No they do not.
So what becomes my best solid Stain suggestion?
Help, what is the best stain for my deck?
9 year old deck that spends a lot of time in the shade during the winter. Previously treated with linseed oil and oil stains.
Answers to 5 questions:
1 North Carolina
2 Part shade/ part sun
3 Pressure treated pine
4 Mold mildew yes and algae
5 Peeled – Behr stain, need I say more
Jeff, strip off the remaining Behr stain. Sand lightly if needed. Brighten the wood. Stain with TWP 100 or Defy Extreme.
1. WV
2. Full Sun on one deck, full shade on the other
3. Pressure treated pine
4. No
5. Peeling
Lindsay, you must remove all of the remaining stain the neutralize with a wood brightener. Once prepped correctly, stain with Defy Extreme or TWP 100 Series.
Deck Location State: Virginia
2.Full Sun, Partial Shade, Full Shade: Full Sun
3.Wood Type: Pressure Treated Pine
4.Mold or Mildew Issues: No New
tennie, please read Staining New Decks
