Important Note: Behr Deckover is now called Behr Advanced DeckOver. It comes in a smooth or textured finish.
Bring new life to old wood and concrete surfaces with BEHR ADVANCED DECKOVER. This 100% acrylic formula conceals cracks and splinters up to 1/4″, creating a smooth, slip-resistant finish that resists cracking and peeling. It’s available in 54 solid custom colors and is also great for decks, railings, patios, composite decks, pool decks, and walkways.
- The appearance of BEHR ADVANCED DECKOVER after Application
- Preventing UV Graying
- Peeling or Wearing
- Preventing Mold and Mildew
- Color Shifting
- Ease of Reapplication
- BEHR ADVANCED DECKOVER Final Score
3. Wear/Tear and Peeling: 4
4. Cost Per Square Foot: 1
6. Ease of Application: 2
Overall Score Behr Deckover at 2 Year Period:Â 5.5
Where To Buy:Â Home Depot
Cost: $45 per Gallon
Coats Required: 2 Coats.
Dry Time: 8-24 Hours
Cleanup: Water
Manufacturer:Â Behr
Deck Wood Type:Â Untreated Pressure Treated Pine Dock
UV Exposure:Â Full sun
Please read our article on Gulf Synthetics Deck Revive Review We believe this product has actual value if looking for these product types that actually work.
Behr DeckOver Video Review
Deck Revive Kit
A year after applying this product I found it was not only peeling off, but where I peeled it away the wood was wet – so it was sealing water in instead of repelling it. It was a disaster. Forget the waste of $ I paid for it, what I really hate is the time I spent prepping the surface (washing with a special cleaner, filling and sanding), and scraping it off most recently. After 10 hours of scraping at least enough of it has been removed so I think it will not cause more damage to the deck, even while it still looks terrible!
Yes, all Behr deck stain products are poor. They just do not seem to care.
I bought our house with a 6 year old deck protected with DeckOver. We have to remove the deck due to extreme rot. The pictures of pealing paint looks just like my deck!!
My other house had a 20 year old deck protected with Thompson’s Water Seal. No rot!
can solid colors be tinted to match siding better. can not find one of your colors that look good with siding color
Solid color deck stains for teh most part can be custom tinted.
What do you think about applying mad dog deck fix over deckover? The deckover was applied by the homeowner about 6 years ago. Was peeling in about 25 percent of surface area. I power sanded it yesterday. Thx
You cannot apply any coating over the deckover. It will continue to peel and it will create more issues. Remove it fully:
Thanks for your response.
what concrete deck
paints are best? DeckOver is buffling.
You cannot use a concrete paint on a wood deck. You need to remove the failing Behr Deckover or replace the wood.
https://www.deckstainhelp.com/will-deck-stain-peel/
Bought the deck over texture and had it in the garage one gallon and when I opened it 6 months later it was completely hard. Took it back and was told no refund cause it sat too long. It was brand new.
This crap ruined our deck. We’re in the process of trying to remove it. Been a month of scraping and sanding. Never buy Behr products!
This product is pure crap. Seems after one year started peeling and retaining moisture. Looks like replacement is the only option. This should be taken off the market.
Have you ever heard of anybody successfully thinning deck over. I have had a problem with it setting up if it wasn’t used within the first several months of purchase. Instead of throwing the whole five gallon bucket away as a total loss has anybody ever tried to mix it with other deck paint to give it a little more grit and to use up at least a portion of that wasted 5 gallon of deck over
We highly doubt that will work.
I put Deckover on in June 2018 a month later heard of lawsuit. Home Depot was still selling it. By December 2018 started peeling in sheets. I filed a claim in May 2019. Pictures and receipts. Kept calling nothing. I tried on the website said it’s closed. In May 2022 tired of waiting for my check. I called several of the lawyers involved only one called me back. I had to call Northern District court of Illinois. I finally got my check.$259.00 8 gals I bought. I need to replace wood which it rotted. No cost of sq ft they were supposed to pay. $4 per SQ foot I have approx 500 SQ ft deck. This new Advance Deckover seems like same formula reduced to a 1yr warranty. From reviews and photos and another 2002 lawsuit of $160 million. There exterior products are garbage,
Yes, they are poor.
The problem with this stuff is that if moisture get past it (as in, nail/screw holes or cracks in the coating, it traps it there. It snowballs from there. More cracks/rotting lead to more and more deterioration. I had to replace about 25% of my deck boards after 5 years. Maybe if you re-coat it every year it will last. Idk
I am shocked to see there aren’t any comments about how hot it gets. We can not walk on the deck barefoot (the dogs are miserable too) without it blistering our feet. It’s not summer yet, either. We chose ‘sable’ because it was a lighter color. When contacting Behr, their solution was to send us two gallons of a lighter color. It took five to paint our deck.
Yeah. It is SUPER HOT. Cannot walk barefoot on it at all and my dog used to enjoy lying in the sun on the deck until I painted it with this. :(
I pressure washed and sanded all the stuff that could peel off. After sanding can apply a different stain or does it all have to come off and be bare wood? Can you stain over the deckover stuff that is not peeling?
You have to remove all of the Deckover first.
Even if I’m using the same deckover stuff?
You could probably use that over your old Deckover but you will be prone to peeling again.
I used behr deckover 2 yrs ago can I apply a new coat
You should be able to after prepping correctly.
I used deckover on my shaded patio and followed instructions carefully. After 2 years it’s been peeling. Can I patch the peeling areas or do I have to clean off the entire patio and start over? I used the Behr deckover and primer.
You cannot spot fix it. You would have to remove it fully to fix and this would require power sanding it all off.
We applied deck over last year and today I am walking on my deck and my foot falls through a board. This stuff rotted our deck! We applied this to a deck that was in good shape, we were just tired of using Thompson water seal every year. Wish I would have just used Thompson water seal.
I did the same after 2 mo shy of 2 years. My foot fell through a deck board to the ground. I can’t believe I put this crap on my beautiful deck! I started peeling back the top coating and all wood surfaces were damp and or wet! It’s so dangerous!
Every dirty paw print or foot print shows up on the deck and it doesn’t wash off. Always looks dirty. What can I do to correct this?
You cannot correct this. It is a product issue.
This is the worst product I have ever used. It disappointed me because it is Behr. It only lasted one year and only peeled and came off in the areas that got exposed to moisture and sun. (?!) I tried to take it off of the areas where it didn’t peel and it’s stuck like glue. I’ve tried pressure washing and sanding to no avail. Because I used this product, I am now going to have to REPLACE all the wood on my 40’ x 9’ porch. I only wish Behr would compensate me for this product and the work and expense it has caused me.
Deckover requires two coats. Can I apply one coat one weekend and the second coat the hext weekend?
Not sure as will not use it due to all the failures and are not up to speed on proper application.
I bought a 5 gal. bucket at the beginning of the pandemic. A year later decided it was safe to be around my mother and went to her home to paint her deck. The bucket had never been opened and it was a hugh mass of rubber. It was like putty. Had to go buy another 5 gal. Bucket. Ran out and had to go buy another gallon to finish. Stored the paint on a shelf in the utility room. This was in May of 2021. Went back in Sept. to finish up by painting some wood railing and the paint had turned to the same rubbery consistency. The top was hammered on the can tightly and it still turned to an unusable glob. Certainly does not last like the company claims it does.
Wish we had found this website before buying and using DeckOver.
By far the WORST!!! product I have every used.
We followed all of the instructions to the T. We sanded the deck, then cleaned it with the recommended product, filled the gaps that were more than 1/4″ with wood filler – we should have filled even the small ones. Even with dabbing the screw holes and small joins, DeckOver DID NOT fill them.
In addition, the viscosity (thickness of product) was extremely inconsistent between pails. Thick as mud in one, runny in another. One pail would cover a large amount of space and then the next didn’t even do a 1/4 of what the previous pail did.
Finished product looks HORRIBLE! Colour is not even, very patchy, and we made sure the deck was thoroughly coated and no patches showed threw.
WHAT A WASTE OF TIME AND MONEY!!!
I used Behr’s old formula Deckover with no problems. Last summer I repainted my stoops and stairs with the so called Advanced formula. I can echo every ones negative comments about this product. It didn’t stand up to one winter and there is no patching it. It’s almost as if there is a solvent in it preventing it from binding to the wood. I have been applying paint, stains, etc. for over 60 years, both professionally and for myself. I have never experienced a worse product.
We bought the deck over paint, followed directions to a tee and it has to be the worst product ever at an expensive cost. The attached picture is in its 2nd season after application. It began peeling/flaking in the 1st season. I would not recommend this product. My question is there a solvent to help get this off of my deck. This was extremely a lot of work to apply.
Only way to remove is to sand.
You have got to be kidding me. Both my husband and I are in our late 60s and this work is back breaking. Our deck is huge. We applied 15 gallon of deck over. We do not have the funds to hire it out and the deck was only a year old when we applied it. Very disappointing 😞
Yes, it is garbage and why they have a class-action lawsuit against them.
Can lumber with Deckover on them be burned?7
Sure.
All you can do to fix Deckover is tear off your deck. Tried 3 different times, 3 coats each time by seasoned contractors. You owe me 3 new decks and a gazebo Behr and Home Depot.
Terrible product. So much peeling…the more we pressure washed, the more it came up. Our deck is a mess
This product is horrible. Did our deck and our gazebo. Floors rotted in the gazebo and now the deck railing. Did everything as directed. This was all new wood. Had to sand the decking and treat with another product due to this one peeling up like everyone else’s.
I have had the deckover on my deck for over 17 years without any issues or problems. In the 17 years I have had to recoat twice or once about every 5 years. Holds up well and I have had no issues with any peeling. Product is not the easiest to apply but that is understandable given its consistency. The product filled the cracks nicely and I have had no problems with any trapped moisture. I powerwashed the deck and waited 5 days to make sure there was no moisture trapped in the wood.
Behr DeckOver has only been around for 8 years or so. It came out in 2013.
Is there any kind of sealer or clear coat I could apply over the Advanced deck over product?
No, never top coat over a deck stain or coating. It will peel.
I was wondering the same thing too, and was really hoping there was a sealer I could apply before all my inevitable peeling starts. I was already 3 gallons in before finding these reviews, so was already too late. I feel like I’m standing as the target on the firing line over here. This sucks
Not possible to top coat and would only make the peeling worse.
I have a client who needs a product like deck over. All I see here are horror stories. Is there a product that actually works?
Yes, the Gulf synthetics works great with none of the issues: https://www.deckstainhelp.com/gulf-synthetics-deck-revive-review-2015/
J’ai fait un commentaire destructeur pour l’avoir appliqué sur mon bois. J’avais remis mon bois à neuf après l’avoir totalement sablé. Cela n’a pas plus tenu, déjà après le premier hiver, j’ai vu des manques.
Par contre sur mes tuiles de ciment, c’est tout le contraire. Les tuiles ont été lavées à pression et j’ai appliqué au rouleau très facilement, le but n’était pas de boucher les cracks, mais simplement d’en appliquer un couche uniforme. Il est posé depuis l’été 2015 et je le nettoie avec mon appareil à pression et il tient toujours.
Je l’ai appliqué sur les tuiles de mes 3 patios.
Sorry, english only.
It would have been easier to spread maple syrup in Vermont in January. The consistency is like mud. Getting a smooth finish is impossible. Followed the directions step-by-step. Totally regret using this and now I am stuck.
We used behr premium deck over in the russet color and it ruined our deck! Not only did it fade to a pink color in a few years (we have full southern exposure), but it traps moisture and rots the wood after a few short years! The stuff just peeled off in sheets and the boards were wet underneath even though it hadn’t rained for days. Plus the stuff gets so hot in the sun that your feet burn right through your shoes. We are in the process of cleaning, scraping, sanding and puttying this mess now. We will prime it with Rustoleum clear deck primer, then paint with Kilz porch, floor and deck paint (sad it only comes in 1 color, gray). Do you think this will work over the crappy Behr premium deckover?
I’d give this product a ZERO rating. It looked nice when we first put it on, but what a disaster now!!! See the photos below.
I agree. This product sucks. Same problems
Peeling fucking disaster what a highly expensive crap product. I am so pissed, Behr you have ruined my deck!!!!!
I put this on my deck last August 2020 and was so thick I needed a lot. It took me a considerable amount of time and money to apply with a roller as well as hand brush. It is May 2021 and snow is melted and my deck looks like a disaster – peeling all over and just horrible. They advised me to rent out a sander/grinder from HomeDepot (more money and time) to do it again. Why would I want to, especially after reading all of these comments as it is clearly an issue with the product!
I used Behr Deckover 5 years ago on our back deck. It appeared to work out ok. However I used it Again 2 summers ago with their “ New and Advanced “formula and I was stunned to find it was rotting the good pressure treated wood underneath! Like the other reviews I read it was coming off in big damp sheets holding the moisture. Instead of protecting the deck it was ruining the wood. I bought an unopened gallon and am returning it to research a different product. Buyer Beware!!
I expected WAY BETTER from BEHR Deck Restore paint. This is THE WORST deck paint I have ever used. It peeled up within months after application on new wood as well as pre-washed decking. Absolutely horrible!!! Do NOT buy this paint! You will be sorry and have wasted HOURS of your time.
Terrible product, peeling and lifting after a year. 2nd time it has not met expectations. First time we requested warranty – restrained after refinishing and using Behr cleaning products as recommended (again!) – same results! Will NOT use this product again.
Is there an active lawsuit against this product? Its the worst product I’ve ever used. Absolute money pit. Will ruin your deck.
I’ve had Behr Deck Over on for about five years. Did a light touch up after two. Had an eight inch patch peel on railing. Deck portion had no problems. I just cleaned it with detergent and a brush today and only discovered two dime sized chips.
HI I getting ready to pressure wash and sand my deck. its about 500 SQ FT. My thought was to use Behr Deckover but after reading all these reviews I’m a bit afraid to use it. ANy other suggestions? Some spots are cracked pretty good so I thought Deckover would be the solution. Any help or suggestions???
The Behr Deckover is horrible. If you want that type of coating, then try the Gulf Synthetics: https://www.deckstainhelp.com/gulf-synthetics-deck-revive-review-2015/
Do not use it . Do not use it. Do not use it. All of the reviews are true.
