Behr (Advanced) Deckover Review 2026 2.3/5 (682)
Behr Advanced Deckover Review
  2. Preventing UV Graying
  3. Peeling or Wearing
  4. Cost Per Square Foot
  5. Preventing Mold and Mildew
  7. Color Shifting
  8. Ease of Reapplication
3. Wear/Tear and Peeling: 4
4. Cost Per Square Foot: 1
6. Ease of Application: 2
Where To Buy: Home Depot
Cost: $45 per Gallon
Coats Required: 2 Coats.
Dry Time: 8-24 Hours
Cleanup: Water
Manufacturer: Behr
UV Exposure: Full sun
Behr DeckOver Video Review
5 47
4 60
3 140
2 160
1 275
5 163
4 154
3 131
2 93
1 141
5 85
4 76
3 94
2 122
1 305
5 38
4 14
3 35
2 46
1 549
5 123
4 100
3 109
2 93
1 257
5 111
4 66
3 83
2 89
1 333
822 Comments
Russ
Russ
Cathy
Cathy
Reply to  Cathy
Conestler Green
Conestler Green
Leslie E
Leslie E
Lisa Fryar
Lisa Fryar
Reply to  Leslie E
Mick
Mick
JOHN
JOHN
Reply to  Mick
Alice Jones
Alice Jones
Reply to  JOHN
JOHN
JOHN
Reply to  Alice Jones
Eric
Eric
Alice Jones
Alice Jones
Reply to  Eric
Boquist Yvonne
Boquist Yvonne
8 months ago
I bought our house with a 6 year old deck protected with DeckOver. We have to remove the deck due to extreme rot. The pictures of pealing paint looks just like my deck!!
My other house had a 20 year old deck protected with Thompson’s Water Seal. No rot!
IMG_0160
dennis
dennis
can solid colors be tinted to match siding better. can not find one of your colors that look good with siding color
John bartlett
John bartlett
What do you think about applying mad dog deck fix over deckover? The deckover was applied by the homeowner about 6 years ago. Was peeling in about 25 percent of surface area. I power sanded it yesterday. Thx
John bartlett
John bartlett
Thanks for your response.
Patrick
Patrick
what concrete deck
paints are best? DeckOver is buffling.
Daniel Mulligan
Daniel Mulligan
Bought the deck over texture and had it in the garage one gallon and when I opened it 6 months later it was completely hard. Took it back and was told no refund cause it sat too long. It was brand new.
John Mayes
John Mayes
This crap ruined our deck. We’re in the process of trying to remove it. Been a month of scraping and sanding. Never buy Behr products!
John Mayes
John Mayes
This product is pure crap. Seems after one year started peeling and retaining moisture. Looks like replacement is the only option. This should be taken off the market.
John Wagener
John Wagener
Have you ever heard of anybody successfully thinning deck over. I have had a problem with it setting up if it wasn’t used within the first several months of purchase. Instead of throwing the whole five gallon bucket away as a total loss has anybody ever tried to mix it with other deck paint to give it a little more grit and to use up at least a portion of that wasted 5 gallon of deck over
I put Deckover on in June 2018 a month later heard of lawsuit. Home Depot was still selling it. By December 2018 started peeling in sheets. I filed a claim in May 2019. Pictures and receipts. Kept calling nothing. I tried on the website said it’s closed. In May 2022 tired of waiting for my check. I called several of the lawyers involved only one called me back. I had to call Northern District court of Illinois. I finally got my check.$259.00 8 gals I bought. I need to replace wood which it rotted. No cost of sq ft they were supposed to pay. $4 per SQ foot I have approx 500 SQ ft deck. This new Advance Deckover seems like same formula reduced to a 1yr warranty. From reviews and photos and another 2002 lawsuit of $160 million. There exterior products are garbage,
Jay
Jay
The problem with this stuff is that if moisture get past it (as in, nail/screw holes or cracks in the coating, it traps it there. It snowballs from there. More cracks/rotting lead to more and more deterioration. I had to replace about 25% of my deck boards after 5 years. Maybe if you re-coat it every year it will last. Idk
I am shocked to see there aren’t any comments about how hot it gets. We can not walk on the deck barefoot (the dogs are miserable too) without it blistering our feet. It’s not summer yet, either. We chose ‘sable’ because it was a lighter color. When contacting Behr, their solution was to send us two gallons of a lighter color. It took five to paint our deck.
Reply to  Chris
Yeah. It is SUPER HOT. Cannot walk barefoot on it at all and my dog used to enjoy lying in the sun on the deck until I painted it with this. :(
I pressure washed and sanded all the stuff that could peel off. After sanding can apply a different stain or does it all have to come off and be bare wood? Can you stain over the deckover stuff that is not peeling?
Even if I’m using the same deckover stuff?
Marie
Marie
I used behr deckover 2 yrs ago can I apply a new coat
Chandra Prasad
Chandra Prasad
I used deckover on my shaded patio and followed instructions carefully. After 2 years it’s been peeling. Can I patch the peeling areas or do I have to clean off the entire patio and start over? I used the Behr deckover and primer.
Melanie
Melanie
We applied deck over last year and today I am walking on my deck and my foot falls through a board. This stuff rotted our deck! We applied this to a deck that was in good shape, we were just tired of using Thompson water seal every year. Wish I would have just used Thompson water seal.
Ro Fiser
Ro Fiser
Reply to  Melanie
I did the same after 2 mo shy of 2 years. My foot fell through a deck board to the ground. I can’t believe I put this crap on my beautiful deck! I started peeling back the top coating and all wood surfaces were damp and or wet! It’s so dangerous!
Pauline
Pauline
Every dirty paw print or foot print shows up on the deck and it doesn’t wash off. Always looks dirty. What can I do to correct this?
Sue Wise
Sue Wise
This is the worst product I have ever used. It disappointed me because it is Behr. It only lasted one year and only peeled and came off in the areas that got exposed to moisture and sun. (?!) I tried to take it off of the areas where it didn’t peel and it’s stuck like glue. I’ve tried pressure washing and sanding to no avail. Because I used this product, I am now going to have to REPLACE all the wood on my 40’ x 9’ porch. I only wish Behr would compensate me for this product and the work and expense it has caused me.
Kevin Miller
Kevin Miller
Deckover requires two coats. Can I apply one coat one weekend and the second coat the hext weekend?
Jeffrey Peoples
Jeffrey Peoples
I bought a 5 gal. bucket at the beginning of the pandemic. A year later decided it was safe to be around my mother and went to her home to paint her deck. The bucket had never been opened and it was a hugh mass of rubber. It was like putty. Had to go buy another 5 gal. Bucket. Ran out and had to go buy another gallon to finish. Stored the paint on a shelf in the utility room. This was in May of 2021. Went back in Sept. to finish up by painting some wood railing and the paint had turned to the same rubbery consistency. The top was hammered on the can tightly and it still turned to an unusable glob. Certainly does not last like the company claims it does.
Tracey G
Tracey G
Wish we had found this website before buying and using DeckOver.
By far the WORST!!! product I have every used.
We followed all of the instructions to the T. We sanded the deck, then cleaned it with the recommended product, filled the gaps that were more than 1/4″ with wood filler – we should have filled even the small ones. Even with dabbing the screw holes and small joins, DeckOver DID NOT fill them.
In addition, the viscosity (thickness of product) was extremely inconsistent between pails. Thick as mud in one, runny in another. One pail would cover a large amount of space and then the next didn’t even do a 1/4 of what the previous pail did.
Finished product looks HORRIBLE! Colour is not even, very patchy, and we made sure the deck was thoroughly coated and no patches showed threw.
WHAT A WASTE OF TIME AND MONEY!!!
Christopher C.
Christopher C.
I used Behr’s old formula Deckover with no problems. Last summer I repainted my stoops and stairs with the so called Advanced formula. I can echo every ones negative comments about this product. It didn’t stand up to one winter and there is no patching it. It’s almost as if there is a solvent in it preventing it from binding to the wood. I have been applying paint, stains, etc. for over 60 years, both professionally and for myself. I have never experienced a worse product.
Sandra Higgins
Sandra Higgins
We bought the deck over paint, followed directions to a tee and it has to be the worst product ever at an expensive cost. The attached picture is in its 2nd season after application. It began peeling/flaking in the 1st season. I would not recommend this product. My question is there a solvent to help get this off of my deck. This was extremely a lot of work to apply.
Sandra Higgins
Sandra Higgins
You have got to be kidding me. Both my husband and I are in our late 60s and this work is back breaking. Our deck is huge. We applied 15 gallon of deck over. We do not have the funds to hire it out and the deck was only a year old when we applied it. Very disappointing 😞
Raymond Drake
Raymond Drake
Can lumber with Deckover on them be burned?7
Lisa Fryar
Lisa Fryar
All you can do to fix Deckover is tear off your deck. Tried 3 different times, 3 coats each time by seasoned contractors. You owe me 3 new decks and a gazebo Behr and Home Depot.
Terri Myers
Terri Myers
Terrible product. So much peeling…the more we pressure washed, the more it came up. Our deck is a mess
Sheldon
Sheldon
This product is horrible. Did our deck and our gazebo. Floors rotted in the gazebo and now the deck railing. Did everything as directed. This was all new wood. Had to sand the decking and treat with another product due to this one peeling up like everyone else’s.
Robert Folks
Robert Folks
I have had the deckover on my deck for over 17 years without any issues or problems. In the 17 years I have had to recoat twice or once about every 5 years. Holds up well and I have had no issues with any peeling. Product is not the easiest to apply but that is understandable given its consistency. The product filled the cracks nicely and I have had no problems with any trapped moisture. I powerwashed the deck and waited 5 days to make sure there was no moisture trapped in the wood.
Is there any kind of sealer or clear coat I could apply over the Advanced deck over product?
Kelly
Kelly
I was wondering the same thing too, and was really hoping there was a sealer I could apply before all my inevitable peeling starts. I was already 3 gallons in before finding these reviews, so was already too late. I feel like I’m standing as the target on the firing line over here. This sucks
Phill
Phill
I have a client who needs a product like deck over. All I see here are horror stories. Is there a product that actually works?
Raymond Paquet
Raymond Paquet
J’ai fait un commentaire destructeur pour l’avoir appliqué sur mon bois. J’avais remis mon bois à neuf après l’avoir totalement sablé. Cela n’a pas plus tenu, déjà après le premier hiver, j’ai vu des manques.
Par contre sur mes tuiles de ciment, c’est tout le contraire. Les tuiles ont été lavées à pression et j’ai appliqué au rouleau très facilement, le but n’était pas de boucher les cracks, mais simplement d’en appliquer un couche uniforme. Il est posé depuis l’été 2015 et je le nettoie avec mon appareil à pression et il tient toujours.
Je l’ai appliqué sur les tuiles de mes 3 patios.
Jim Wadley
Jim Wadley
It would have been easier to spread maple syrup in Vermont in January. The consistency is like mud. Getting a smooth finish is impossible. Followed the directions step-by-step. Totally regret using this and now I am stuck.
tracey wilson
tracey wilson
We used behr premium deck over in the russet color and it ruined our deck! Not only did it fade to a pink color in a few years (we have full southern exposure), but it traps moisture and rots the wood after a few short years! The stuff just peeled off in sheets and the boards were wet underneath even though it hadn’t rained for days. Plus the stuff gets so hot in the sun that your feet burn right through your shoes. We are in the process of cleaning, scraping, sanding and puttying this mess now. We will prime it with Rustoleum clear deck primer, then paint with Kilz porch, floor and deck paint (sad it only comes in 1 color, gray). Do you think this will work over the crappy Behr premium deckover?
I’d give this product a ZERO rating. It looked nice when we first put it on, but what a disaster now!!! See the photos below.
Lisa
Lisa
Reply to  tracey wilson
I agree. This product sucks. Same problems
Sarah Hay
Sarah Hay
Peeling fucking disaster what a highly expensive crap product. I am so pissed, Behr you have ruined my deck!!!!!
Dkbl
Dkbl
I put this on my deck last August 2020 and was so thick I needed a lot. It took me a considerable amount of time and money to apply with a roller as well as hand brush. It is May 2021 and snow is melted and my deck looks like a disaster – peeling all over and just horrible. They advised me to rent out a sander/grinder from HomeDepot (more money and time) to do it again. Why would I want to, especially after reading all of these comments as it is clearly an issue with the product!
Molly Gold
Molly Gold
I used Behr Deckover 5 years ago on our back deck. It appeared to work out ok. However I used it Again 2 summers ago with their “ New and Advanced “formula and I was stunned to find it was rotting the good pressure treated wood underneath! Like the other reviews I read it was coming off in big damp sheets holding the moisture. Instead of protecting the deck it was ruining the wood. I bought an unopened gallon and am returning it to research a different product. Buyer Beware!!
Eugene Robinson
Eugene Robinson
I expected WAY BETTER from BEHR Deck Restore paint. This is THE WORST deck paint I have ever used. It peeled up within months after application on new wood as well as pre-washed decking. Absolutely horrible!!! Do NOT buy this paint! You will be sorry and have wasted HOURS of your time.
Mccabe
Mccabe
Terrible product, peeling and lifting after a year. 2nd time it has not met expectations. First time we requested warranty – restrained after refinishing and using Behr cleaning products as recommended (again!) – same results! Will NOT use this product again.
Gabe Jackson
Gabe Jackson
Is there an active lawsuit against this product? Its the worst product I’ve ever used. Absolute money pit. Will ruin your deck.
I’ve had Behr Deck Over on for about five years. Did a light touch up after two. Had an eight inch patch peel on railing. Deck portion had no problems. I just cleaned it with detergent and a brush today and only discovered two dime sized chips.
george dunwoody
george dunwoody
HI I getting ready to pressure wash and sand my deck. its about 500 SQ FT. My thought was to use Behr Deckover but after reading all these reviews I’m a bit afraid to use it. ANy other suggestions? Some spots are cracked pretty good so I thought Deckover would be the solution. Any help or suggestions???
Charolette Davis
Charolette Davis
Do not use it . Do not use it. Do not use it. All of the reviews are true.
1 9 10 11
822
