Best Stain For Decks in Full Sun 2026 4.7/5 (39)
Hi, I am Scott Paul. I have been staining new and old decks for over 30 years. My decking tips for the Full Sun are based on my history as a wood restoration contractor and actual hands-on testing. See here for more info about me.
  • UV rays destroy unprotected decks fast, causing fading, graying, warping, cracking, and in extreme cases, irreversible damage to wood fibers.
  • Pigmented stains act like sunscreen. Oil-based semi-solid stains from Armstrong Clark and TWP penetrate deep, offering superior UV resistance without peeling.
  • Darker stain colors contain more pigment, providing stronger UV protection. Semi-solid stains offer the best balance of durability and visible wood grain.
  • Match the stain to your wood. Use TWP 1500 Series for cedar or pressure-treated pine, and Armstrong Clark Mahogany or Amber for exotic hardwoods like IPE.
Deck Stains For Full Sun
DeckStainHelp.com has become the Internet’s go-to site for exterior wood surface restoration-related. Newly tested, Restore-A-Deck in a Day performs superior to withstand the elements when your deck is in full sun. I love to help and encourage customer interaction on our site, so feel free to leave a comment.
best deck stain for full sunOne of the biggest elements in a deck’s lifespan is sun exposure. When a deck is exposed to full sun, it can have a damaging effect that can shorten the life of the wood. Harmful UV rays break down the wood fibers and cause discoloration, graying, and fading. When a deck becomes sun-damaged, the decking boards can warp, crack, and split, causing dangerous splinters and a very unappealing look. In extreme cases, UV damage is irreversible and cannot be repaired.
KEY TAKEAWAYS: Best Stains for Decks in the Full Sun
  • Sun exposure destroys decks fast – Without protection, full sun can fade, gray, crack, and even permanently damage your deck boards.
  • Pigmented stains act like sunscreen – The best deck stains for full sun contain pigments that block UV rays and prevent premature aging.
  • Oil-based stains penetrate deep – TWP and Armstrong Clark stains absorb into the wood, offering superior UV resistance without peeling.
  • Darker colors = better UV protection – The more pigment in your stain, the more sun protection you get. Semi-solid stains provide the best balance of durability and wood grain visibility.
  • Pick the right stain for your wood – Use TWP 1500 for cedar, redwood, or pressure-treated pine, and Armstrong Clark Mahogany or Amber for exotic hardwoods like IPE.
See Below For Commons Question on Decks in Full Sun
How to Prep a Damaged Deck From Sun
Preparing your deck depends on the condition of your wood. There are three main ways to prep your decking: cleaning, stripping to remove old coatings or sanding. Which direction to go in depends on the age of your wood and current condition. For help determining the proper prep method, see this article: Clean, Strip, or Sand the Deck.
How to Prevent UV Graying for Decks?
The best stain for full sun decks is one that has a pigmented formula that acts as a sunscreen and blocks damaging UV radiation. Most of the best stains for full sun decks will penetrate deeply into the wood pores. For example, Restore-A-Deck Wood Stain is an excellent waterborne product with wet-wood technology and heavy resins to help reflect harmful sun rays. This product is handy in that it can be prepped and stained on the same day.
Sun Damaged Decking
Sun Damaged Decking
What is the Best Oil-Based Stain for Full Sun Decking?
TWP Stains also offers several different stains that protect against sun damage. They offer many different colors, but as with any stain, the darker the color (more pigment), the more sun protection it will provide. If your full sun deck has already suffered a certain amount of sun damage, then Armstrong Clark makes an outstanding wood stain that will replace the lost natural oils in the wood. These nondrying conditioning oils separate from the drying side of the formula and penetrate deep into the wood fibers to rejuvenate the wood.
$69.99
$264.95
$315.00
$329.00
What Deck Stains Offers Top UV Protection?
For the best use protection and penetrating performance, you would want an oil-based semi-solid wood stain. These stains will not be fully opaque like solid ones and will slightly show the wood grain. Use oil-based ones as they penetrate the wood grain and do not potentially peel like water-based versions of semi-solid colors.
The Armstrong Clark or TWP Semi-Solid Pro-Series in a semi-solid color will give the best UV protection of any stains that still show the wood grain.
$79.99
5.00out of 5
$314.95
$93.99
$394.95
Need Inspiration? Full Sun Deck Stain Photos
Deck Stain Types for Full Sun
When choosing the best stain for full sun decks, you must also consider the type of wood you are staining. Certain stains are better for different types of wood. For example, the TWP 1500 Series would be a great choice for a full sun deck made of cedar, redwood, or pressure-treated pine. For Exotic Hardwood decking like IPE, Armstrong Clark in Mahogany or Amber colors is a great option.
I have Cracks in My Decking. Should I Repair?
Cracks In Deck PostIt’s not an issue! Decking will continue to crack, shift, and check over the years. Do not use wood filler for exterior decking. If needed or rotting, just replace the damaged boards.
Need Help? Full Sun Deck Questions?
Want Help choosing a stain type or brand for your deck that is in full sun? Just post a comment below and include as much information as possible.
174 Comments
Megan
Megan
3 months ago
Question, We repurposed an old cedar fence into a outdoor table top. It was plained down and sanded to fresh wood. sat in our covered barn for a yr. I used Flood UV clear on all sides, table sits in a lot of sun and did not make it for a season. Bottom looks perfect. Top is weathered, gray and looks spotty. What should I do? I have heard to use a darker color and that would cover the ugly –
Megan
Megan
3 months ago
the first two are the bottom of the table with Flood UV clear and the last two are what the top of the table looks like. Flood told me to due a water test and if it is still water proof then pick a darker color apply another coat. I just don’t want this to keep happening. Maybe we just make a new table top with different wood.
IMG_8560
IMG_8559
IMG_8558
IMG_8555
GINGER
GINGER
4 months ago
HI Scott, I have a large deck in the back that also has a lower section surrounding above ground pool. It is in full sun I currently have the Super deck solid stain from Sherwin williams cool feel technology. suppose to keep deck cooler and it really goes on like paint to me. Since I need to replace some of my older decking boards I was reviewing if I should switch to another product , twp 1500 series or Armstrong. It is treated deck boards. very high traffic area.
GINGER
GINGER
4 months ago
GINGER
GINGER
4 months ago
Robert Kapraun
Robert Kapraun
i need a stain or paint to use over Valspar stain i used a year ago. the wood had been down about a year before that. the stain is peeling up bad and is so hot in sun can not walk on it
Annette
Annette
I will be building a small Douglas for deck next to my swimming also against a redwood fence what would be the best color stain that will complement the redwood fence also a stain that will protect against sunlight and water
Chuck Anderson
Chuck Anderson
Hi Scott, I just replaced my deck boards and railings last November and want to stain in the spring. We used 2×6 pressure treated lumber for the decking. The deck gets pretty much full sun during the summer and full shade in the winter months. What type of stain would you recommend? Does color of stain make a difference in UV protection?
Sherilyn
Sherilyn
Hi Scott, we are replacing our deck with Douglas fir and want to know what product would be best for a full sun deck? We are wanting to do a gray wash or a light stain with some texture to it. What product would you recommend?
Allen
Allen
Hello Scott,
Can I set up a phone call for a fee to discuss my deck?
Marcy
Marcy
I’ve sanded my deck it gets full sun but I also have a pool that the deck also gets chlorine on it best best that will not cause slippery deck when getting out of the pool
Mmmmcccc
Mmmmcccc
Will Defy Extreme work the best on our 20 year old cedar deck that we are planning to sand down and treat with a water based fire retardant? We have a high altitude very sunny exposure with some thundershowers in the summer and some snow that lays on the north side of deck in the winter. The fire retardant calls for 2 coats so it soaks in and bonds with the cellulose fibers. It recommends to be stained on top with any water based stain to protect it. Should we just do 1 coat of Defy on top this year and the second next year so we don’t risk it pealing because a second coat can’t soak in as much due to the fire retardant? Our cedar has a lot of tannin leaching and will blue up when not protected well. We don’t want to have to sand again for many years to come- can we just clean (maybe brighten) and recoat Defy for maintenance in the future without sanding? Thank you for your help!
Melissa
Melissa
I am looking for a deck stain to protect the deck around our pool that will not burn our feet when barefoot but also not toxic, low voc’s
Jacob
Jacob
Looking for suggestions on a stain that will complement the tones of our home and be natural looking. Also wanting something that is heat resistant that would allow walking on it barefoot.
Jacob
Jacob
Tried twice to attach pictures and it allows me to select a photo to upload but then doesn’t show up.
Dan Hume
Dan Hume
We need to refinish a deck and cabin at high altitude (10K with high daily UV index). Advice on prepping and best to protect wood
Gary
Gary
I have full sun deck made of Pt decking … what is best to protect it
Brad Otremba
Brad Otremba
We live in the Twin Cities metro and our deck faces the west with full sun starting around 1100-800. We just replaced our old deck, which was all cedar and stained with Penofin stain, which basically was junk. We replaced the deck with cedar railings and cedar toned treated lumber. Looking for the best stain combo for use on the cedar railings and the cedar toned treated deck lumber. Neighbor talked about Cabot’s Australian oil, unknown if it’s the same or better than Penofin. We understand that the harsh all day sun and very cold Mn winters aren’t deck friendly, but we do what we can. Seeking your advice for the best overall solution for the two different types of wood under the same conditions. Thank you
Anja
Anja
Which colour is the TWP Semi-Solid Stain that you show on the deck pictures? Does it work well with Fir? Thank you.
Janet
Janet
Hi! What would work best for a deck made of Douglas fir. It has no stain currently. Would I need to prep it with wood conditioner? What would work best for this type of wood? I am trying to keep it a natural oak color
Andy
Andy
What would be the best stain for a 4yr old pressure treated wood deck in Chicago that gets full sun, all day in the summer. It was originally professionally stained but now wanting to do it myself.
Amy
Amy
We had our 400+ sq ft deck replaced with pressure treated pine in 2020. Our deck gets full sun all day long. We have used Penofin for Hardwood Oil Stain in Transparent Natural Tone. It looks nice initially but then gets gray and dark rather quickly. It has been prepped with their cleaner/brightener and stained twice now and ready for another coat. Assuming this may not be the best stain for our situation? Do you have any recommendations that would not require annual staining? We do prefer something on the lighter side and do not want a solid stain. Would a water sealant be any help or is that just asking for peeling? If we switch stains, will that require completely removing the stain by stripping or will a cleaner/brighter be enough? Regret not going with composite.
misty hampton
misty hampton
Is a full coverage deck stain available that stays cool to touch and doesn’t burn the bottoms of feet?
Keith
Keith
Looking for a good stain/seal that can hold up to the elements. I purchased Valspar semi transparent cedar tone and it looked great for a few months. I ended up re applying a year later only to get the same results.
I have a south facing deck with no shade. I live in MO where we get every type of weather and temps from 105 degrees to below zero. I think my biggest issue is the sun. Ready to find something real that I can enjoy for awhile and that’s easy to re apply as needed.
Thanks for the help!
Keith
Keith
Thanks! I have actually sanded most of my deck down over the past week, so no luck on getting a good photo of the deck as it is. I don’t have immediate access to a power washer so I sanded the Valspar off.
Are you recommending a semi-transparent here? (I see the TWP 100 series is) I was looking at the semi-solids but if they have a tendency to peel then I am all for the semi-transparent. I like the look better on the semi transparent as well.
Chad
Chad
How do solid stains handle direct sunlight? We get triple digits in the summer and the porch is in direct sun. I am looking to use Sharkskin from Rodda. hybrid waterborne technology – cross-linking Acrylic & Urethane resins with Linseed oil to provide the ultimate in weather protection and scuff & mar resistance from foot traffic.
Robert
Robert
Is the formula for California that much different for most exterior deck stains. I have noticed as environmental regulations changed in our state that the lifespan of the stain seems to have been greatly reduced. I have heard that is the reason. Any truth to that?
Rita C
Rita C
I live in sunny warm California I have a fence in full sun for most of the day. What sun protectant sealer/stain would work the best. We get warm to 120 degree weather during the summer to freezing temps in the winter.
Linda Dotson
Linda Dotson
I live I. Pahrump NV. Looking for a wood stain that will hold up in extreme heat and freezing in the winter. Thank you
Linda Dotson
Linda Dotson
J Natas
J Natas
I live in GA and having wood columns put up in front of main door. Moderate direct sunlight. What type of stain do you recommend? Thank you for your help!
J Natas
J Natas
Thank you so much!
Jen
Jen
I live in southwest Virginia. We have a large tiered deck. The deck gets full afternoon to evening sun (11:00ish AM to 6:00ishPM) and summers are hot, winters are wet, cold, snow, ice. We replaced the upper deck in 2019 due to mold rotted wood and cracks but have not been able to stain it yet (thanks, CoVid). We’d like a long-standing stain – we’re open to any semi or solid as long it’s the best UV protection and longest wear on horizontal surfaces). Also mold is a concern (had to replace the old deck due to mold-rotted wood). – I used a Behr water + oil based combo previously and wonder if that caused it to rot so quickly. Within a few years the wood started to rot. I ah e concerns about an oil based stain due to previous experience and I’ve thought about Defy since it’s water based but unsure of how long it will remain and which product. Would also like a recommendation for a cleaner to prep before staining and how to remove possible minor fuzzies since it’s been a few years. Thank you! Jen
Have a large mangaris wood deck in So Cal… gets a lot of sun and grays quickly. I’ve used Penofin in the past but it doesn’t seem to last long. Any suggestions?
Jackie Levja
Jackie Levja
I live in Colorado and have a cedar deck that is exposed to full sun at a higher elevation and a very dry climate. We have tried TWP and Armstrong stains. Both require annual treatment. The wood on the deck is cracking and cupping slightly. Is there a better stain to try to help add moisture into the wood?
John Tulchin
John Tulchin
I am working on an ipe deck with full sun exposure at a property in the Caribbean. The deck was originally finished with Cabots Australian Timber Oil. Almost immediately the stain was showing surface scratches presumably because of poor penetration of the dense ipe material. There is also considerable fading. We’re considering Messemers and Armstrong. Which product will give the best scratch resistance and also the longest UV protection while enhancing the natural beauty of the ipe?
John Tulchin
John Tulchin
Thank you. Based on your experience will it perform better than the Amber Cabot Australian Timber Oil that was used previously as far as UV and scratching?
john tulchin
john tulchin
Based on your experience will Armstrong Clark amber significantly out perform Cabots Australian Timber Oil Amber with regard to UV protection/fading and also surface scratching? We don’t have easy access to Armstrong Products in our area but I can ship it in if it is notably superior
John Tulchin
John Tulchin
Thanks for the help. I had planned on annual recoating. Based on the initial treatment, the Cabots product will require semi-annual. I will switch to Armstrong if the expectation is that it will perform better, and assuming I can get it.
Diane strauss
Diane strauss
I live in Florida and have mostly full sun and extreme heat. We just built a dock with treated wood. What would be better to use? Clear stain or semi colour stain?.. And which one would last the longest?
Szilvia Beylik
Szilvia Beylik
Found this article while searching for wood stains for a new oak front door. I live in Southern California and the sun mercilessly beats down on this door. Everyone tells me I should paint it but I want to preserve the wood grain look. I’m guessing there really isn’t much difference between staining a door vs a deck, so I figured I’ll ask; what stain would hold up best with heavy sun exposure on a front door?
Szilvia Beylik
Szilvia Beylik
I know. But it seems deck stains are designed to withstand extreme sun, and that’s what my door is getting. Regular stains don’t advertise withstanding extreme weather conditions. So while it’s a bit of an out of the box thinking, is there a reason why I shouldn’t use a deck stain for my door?
Jeanne Keeler
Jeanne Keeler
We are in Georgia and have a large full sun 12 year old pine deck. It has been stained with Behr water based stain 2 or 3 times. We need to stain this year and want to use a better product that lasts longer. The big question, is there a product that we would not have to strip the old stain? Thank you.
Michael Boucher
Michael Boucher
First of all you’re a TERRIFIC resource. Question – new deck, full sun in GA so very hot during summer, going to use TWP semi solid. Do you recommend adding a small amount of sealant like poly/helmsman to the mix for further protection or is that asking for trouble like peeling down the road from summer heat? Thank you very much.
Michael Boucher
Michael Boucher
Thank you! I’ve seen people suggest that online and YouTube and that was my worry. Appreciate the prompt response.
Sandra Wood Forand
Sandra Wood Forand
What product should I use to re-cover wooden railings in direct sun year round that are badly peeled after first transparent stain and then solid stain? The vertical posts are holding the solid stain fine, but the horizontal surfaces peel badly.
Sandra Wood Forand
Sandra Wood Forand
Here’s the peeling solid stain on drying wood two years after application.
Sandra Wood Forand
Sandra Wood Forand
Thanks very much.
Buck
Buck
Looking for the best stain to hold up to full sun and a lot of sand. My deck is 20′ away from white sugar sand beach in N Michigan, it faces SE so sees a TON of sun, and I just can’t seem to find a stain that will hold up against the sand and foot traffic. Looking for advice. Thanks in advance!
Hi a quick question, what is recommended for sealing rough cedar 4×4 posts? I want to preserve natural look, with out linseed effect. Which transparent sealant do you suggest to use in the hot and dry Colorado climate?
Thank you, much appreciated.
William McFarling
William McFarling
I also got a bad stain with the Olympic Rescue . after 2.5 years it is mess pealing and bubbling. I have just powerwashed the deck but only the loose / bibbling places came off. What should I do before restaining over areas that did not come off. Is there a good brand product to use on top of the Olympic? Located in Central Ohio, Dorect sun in summer, ice and snow in winter. Thanks
I have a west facing dock in mid SC. 50′ pier and ramp and 20′ floater, all pine. Last year I stained it with One Time Clove Brown. Was told full sun would fade it. Looked amazing and went on great, but I’m going to put on a 2nd coat this year. No one mentioned this product. Mostly Armstrong. Am wondering if this is an Armstrong sponsored post or are their products that much better than the rest? Any feedback from anyone regarding this product. (One Time)? Like others, I don’t want to have to redo every year. Anything that can stand up to full sun? Thanks all.
Duncan
Duncan
I’ve got a south facing teak deck that has lost all of its color. The stain is pretty much nonexistent. I’m a newbie to this, are there any links to understand how to prep by stripping and brightening. In addition, any recommendations for stains. Armstrong Clark stain?
Duncan
Duncan
Wow thanks so much for your help! Can’t wait to bring my deck back to life.
Tara
Tara
Hi! I live in edmonton alberta and have a fully exposed south facing cedar deck that I seem to have to refinish every year (including the removal of the current product, sanding then refinish). Our deck has to put up with a lot… the direct sun, heavy snow & frozen conditions, rains and heat (truly a four season place). I am tired of re-doing the deck every year and have been using good quality semi transparent products without much luck. The products do not seem to handle the long cold but sunny winters…do you suggest using an oil product or maybe and non transparent finish or maybe I just let it go grey :(. I wouldn’t mind if I only had to through another coat on but the whole process of removing and redoing it is painful…appreciate any suggestions
Wallace
Wallace
I had an approximately 900 sq. ft. pressure treated pine deck with attached railings and privacy fencing built around my above ground pool in July 2020 located in Louisiana. My deck is exposed to 100% sun all year. I’m now planning to stain the deck this Spring. I’ve been researching oil based semi solid stains vs. semi transparent stains over the past few days. Both stain options has its own pros and cons, but I like the look of semi-transparent stains because it allows the wood grain to show. However, based on what I’ve read thus far I will have to keep reapplying the semi-transparent stain every year or so because of it being exposed 100% to the full sun. I would rather not have to deal with constantly staining the deck every year. Please provide some guidance to what stain option will be best for my situation. Also, would I also need to do any kind of specialized cleaning beside pressure washing the structure to prep it for staining?
Nancy
Nancy
I am looking at refinishing our deck, it is full sun I like the foolish person I am stained it black and it gets crazy hot, what color options do I have that do not get super hot with full sun exposer
Nancy
Nancy
that is the plan but I have no idea what color to choose from we have had white decks with the same issue so I was not sure if a certain type of stain or brand would be better
Curt
Curt
Thanks for this advice and help. My own experience is with TWP 1500 series, in northern california where sun is intense and temperature is over 100 for 20 days. The TWP (in cedar) goes on beautifully and looks great — for about three-six months. After that, it is faded and aged looking. I have stained and re-stained it two years in a row (with sanding, cleaning, brightening, the whole process) and it is looking bad again in less than a year. Love the product but I can’t do this every year. It’s exhausting. Do I need to go to a fully opaque stain and if so which one is good for such intense sun? Thanks again.
Carol Turner
Carol Turner
I live along the coast of North Carolina very near the ocean. My top floor deck is fully exposed to the bright hot sun and salt in the air every day. The lower deck is more shade but does get a fair amount of sun. My house is about one year old and the deck has not been stained yet. What is the best product for me to use? Thank you in advance.
Kris Balle
Kris Balle
I have a railing around my upstairs deck. It was originally stained and after a few years the grain of the wood raised so I sanded it down and applied a tinted stain and that also chipped and peeled so I painted it with a tinted stain I think, though it might have been paint. I’m enclosing a couple of photos, though I’m not seeing them here 🧐.
I’m asking for your advice on what to apply as this point. I assume I’ll have to re-sand 😩.
Thanks so much,
Kris
Sandra Burak
Sandra Burak
I live in Massachusetts and we get lots of snow, run and full sun on this deck. I would like a stain for all weather protection.
Jeff McClellan
Jeff McClellan
We live outside of Houston (hot and intense). I am building a deck using 2-in x 6-in x 8-ft #2 Prime Southern Yellow Pine Pressure Treated Lumber. I want it to last and would like it not to be too hot to the touch. What do you recommend for the stain?
Kristen
Kristen
We live in Virginia, about an hour south of DC. Our deck is in the sun for most of the day (about 10 hours). We have just replaced many of the boards on our 20 yr old deck – what is the best stain to use for a consistent look that will last longer than a year or two?
Denis Gauthier
Denis Gauthier
Hi my name is Denis! I have a question for you! I have a deck on the south side with heat from the sun 40 plus celcuis and I live in the north eastern Ontario with a cold that can reach -40 celcuis and plus! What kind of product that can last more than a year that I can use?
Yvonne
Yvonne
We installed a new cedar deck last fall and used Cabot Semi-transparent, dark pigment, oil based stain. With the winter snows the pigment basically washed off. We apparently didn’t prep it right. Weather conditions change rapidly in central Oregon. Currently the deck has been stripped with Cabot Stripper and Brightener and rinsed thoroughly. I have previously used elastomeric paint on decking in the CA desert, which has held up for years. I would like to use it here in La Pine, OR if it will hold up to the cold winter weather. Can you advise? I’m getting too old to refinish decking every year!These pictures show knots where the stain remained.
Lidia Finocchiaro
Lidia Finocchiaro
I have a brand new redwood deck in Southern California, where it is very sunny and hot. Most of the deck is in full sun all day. I am looking for something to protect it A) From the sun, B) from water (hot tub) and C) that would last the longest and require the least maintenance. Does such a thing exist? Thank you.
Jeff
Jeff
I’m sanding off old stain from a pressure treated deck what’s the best I’ve protection stain to use that still shows wood grain
Melissa
Melissa
I have a full sun cedar deck. Installed 4 years ago. Just had it stripped and prepped. Looking for something to bring out the wood grain keeping it as natural as possible. Haven’t made it through a full summer yet with TWP semi transparent. Need something that will last! Any recommendations?
Myrosia
Myrosia
We have a southwest facing cedar deck, we stained it with penafin oil three years ago and it all peeled up, it didn’t absorb at all. We live in western Canada, so have extreme temperatures (very cold in winter and hot in summer). What do you recommend? I’m sanding off the remaining stain and then plan to power wash. We have a very big deck, so I ideally do not want to re-stain every year.
Tara
Tara
What is part of my deck is in full sun, but the rest is covered by an awning? The exposed part gets sun damage so much faster. The covered part still looks brand new. What type of stain do I use and how do I maintenance it?
Suzie and Rick Lasley
We have a tiger wood deck that has turned silver in some areas that are hit by the morning and afternoon sun. We have used a rosewood oil finish that was suggested by the deck manufacturers but it barely lasts the season before graying starts all over again. Then we have to oxalic acid scrub again and reapply the oil finish. We’re looking for something less labor intensive that would give us longer lasting results. Would the Defy or the Armstrong Clark product give us better results that would last longer?
Suzie and Rick
Peggy Schlitt
Peggy Schlitt
We live at the coast and get alot of salt air and wind. We just put down a new deck using sun wood. After waiting 3 months what is the best stain or paint to use. Is paint better then stain. Also we have a dog that will be on it. I worry about scratches.
Dwight Rediger
Dwight Rediger
Great info,
I have a deck with new pressure treated pine put down in October 2019. I live in north Georgia about 45 miles north of Atlanta. What would be the best for my deck water based or oil? I’m 10 feet from an inground pool and the deck is partially covered and others parts exposed to direct sunlight. The deck is 32×30 so lots of work.
Judy
Judy
We have a 25 year deck that is 75% full sun. We have used Cabot opaque stain and each year it peels as soon as the weather starts to warm up. We power wash all loose stuff, use a cleaner but to no avail. Chicago climate. We want an opaque now simply because we do not want to strip as many spindles/seat/flooring that a 1200+ sf deck has. Suggestions on what to use for coming year?
Karen Lynn
Karen Lynn
I am having a brand new deck built this week, composite wood. Full sun exposure. I live in Maryland. I want a semitransparent sealant. I’m a 65 year old nurse and although I doubt I can treat the outside of the deck as it’s a second story level, I plan to do the main floor and rails myself and will get some help with the rest. Are the Sherwin-Williams deck products good? I’m thinking of an oil based product so it will last longer
Karen L Lynn
Karen L Lynn
well, I really want to seal it, if the sealant has a slight color that’s transparent doesn’t matter but clear is fine. I just want to apply a good product and I’m not experienced at all about doing this but I had to replace deck unexpectedly so am trying to cut costs doing it myself!!
Ron
Ron
We have pressure treated “premium” pine decks. Wood was installed 7/1/19. Our decks are right on a fresh water river. A lot of moisture. Also, part of the day is full sun, maybe 4 hours. What type of stain and colors would you recommend?
Bob Degrand
Bob Degrand
Paramount Semi Transparent stain faded within months on my cedar deck!
What is we don’t know what type of wood we have? It was already up when we bought the house.
Ray
Ray
I have a place in Spain . Last year I stained my decking and within 6 weeks it started to peel . The heat is tremendous. Any ideas how to solve this problem please ?
Ray
Ray
Should I pressure wash it then sand it down ?
Pam Luse
Pam Luse
Do I need to wait after Gemini cleaner and brightener?
Pam Luse
Pam Luse
Which is the best stain for kiln dried wood deck just finished. Extreme sun. On a lake so moisture and humidity. TWP? Armstrong Clark? Cutek Extreme? Defy Extreme? Want a semi transparent shade of gray.
My deck is 3 years old with pressure treated pine 2 years ago I let the new boards dry out for 9 months then used the recommended cleaner and brighter your site recommended it looked new again. Iet it dry for 7 days in full sun . I stained it with defy extreme it was dark brown . Now it’s been 2 years and the stain did not perform well . Now I was going to strip it and use a cleaner brighter what stain do you recommend. Give me some best choices and should I use water or oil. I live in Cleveland Ohio the deck gets full sun from morning till abou 6:30 in the eve. Also what stripper and cleaner/brighter should I use. Thanks Joe
Julie
Julie
we have a full sun deck we plan to strip and stain. do you recommend an oil based stain or water based and why? thank you in advance –
Monica Jasmin
Monica Jasmin
I have a full sun exposure deck that has been stain with a waterproof product multiple times. The deck is extremely hot to walk on. Can you use an outdoor carpet on something that is pressure treated wood that the stain has blistered and peeled multiple times? Is there an alternative after 13 years of Purcell stain?
Lil toews
Lil toews
Can deck over be applied to coloured stain.
Cheryl D Grant
Cheryl D Grant
