How to Remove Mold and Algae From Decks 4.5/5 (19)
Removing Mold and Algae From Decks
Deckstainhelp.com is your number one source for deck staining tips and trends on the internet in 2026. Mold and mildew can be problematic for your wood decks, see below for why this happens and what you can do to prevent it. Leave us a comment if you’ve encountered mold and mildew on wood decks.
Moldy_Deck_StainLearning your deck has attracted unwanted mold and algae can be disheartening but it is not the end of the world. These contaminants can be removed to reveal a beautiful surface once again. How to remove mold and algae from decks is a common question asked by homeowners. But with the right knowledge, it can be done over a weekend with no problem.
The key to removing mold and algae from decks is using a quality deck cleaner. Deck cleaners are designed to loosen debris like dirt and gray wood fibers and also rid the deck of contaminants like mold and algae. If the proper cleaner is not used then the mold and algae will continue to grow and will reappear in no time. A deep clean is necessary to get to the root of the mold and algae spores. Not only will a good deck cleaner remove these problematic pollutants, it will also help deter them from coming back so quickly. This is especially important if you are staining the deck. Improper cleaning can mean mold and algae get trapped below the new deck stain and begin to eat away at the wood causing rot and decay.
Apply the deck cleaner thoroughly to the surface as directed. Allow the cleaner adequate time to work. Remove the loosened soil and contaminants with a pressure washer or scrub brush. This should remove any mold, algae, mildew, and graying to reveal clean bare wood. Once the mold and algae have been removed from the deck it can then be stained if desired. Certain deck stains can actually help prevent mold and algae from returning so quickly. However, over time if the pollutants reoccur simply wash the deck again in the same manner. Normally every couple of years the deck should be cleaned for maintenance. The key is to not let mold and algae take over but to clean it often enough to prevent it.
New: Best Cleaner for Mold & Alage on Deck Stains
More information on Removing Mold & Mildew on Decks
The Best Deck Cleaners for Algae Video – DeckStainHelp.com
43 Comments
Kinsey
Kinsey
5 months ago
I have a semi-Frankenstein deck due to contractor issues. The oldest boards are ~5 yrs old, & it has never been treated. I’m in NC.
Details:
  • 16×10’ pressure treated pine, wood never treated.
  • Floor boards: Super weathered. Minimal sun due to walnut & oak trees, which are a playground for squirrels and covered with nut pieces in the fall. Not splintery, but not entirely smooth either.
  • Railing: redone 1.5 yrs ago, still pine colored.
  • Steps (but not rail): boards replaced spring 2025
Current state:
Handyman did RAD cleaner & brightener a couple weeks ago; I suspect poorly rinsed & brushed. Majority of it looks clean, but several spots are clearly green when wet, which I assume means algae. It isn’t very noticeable dry, slippery when wet & I could scrape it off with my fingernail.
Debrief:
The handyman followed manufacturer instructions for mixing & dwell time, but it looks like he used a pump sprayer and/or hose with minimal water pressure due to failed/leaking vacuum breaker (fixed now). I also don’t think he had a proper deck brush and used an old dollar store broom I keep outside to sweep leaves. Might that account for results?
Next steps?
Cleaner & brightener:
  • Can I just apply to the algaed areas? (Doesn’t look like an issue on the vertical surfaces or steps)
  • I’m planning on DIY this time—
Cleaner: oxygen bleach+dish soap+borax
Brightener: oxalic acid
 I found something for the oxalic so I wouldn’t have to get powder & mix it.
It’s marketed as cleaner that’s effective for mold-algae-mildew. Since the deck has already had RAD treatment, would oxalic be effective enough on its own? It would be great to eliminate a step.
Sanding: If minimal fuzzing, is it necessary to sand everything?
I wondered if there are a options—any with fewer steps or milder manual labor. I’m recovering from a shoulder injury (non-dominant side), and if one approach would be easier on it, would be great.
  • Could I forgo another clean/brighten cycle & just give everything (or part) a good sanding?
  • Or get by with just cleaner and brightener without sanding—or else just a light hand sanding so I don’t have to get ahold of an orbital sander? ( I do have a palm sander, tho).
Stain: Using Armstrong Clark Natural Oak.
  • Where is the risk of splotchiness, and what can I do to mitigate?
  • Given the floorboards & railing are starting out a different tone, I realize there will be a difference when stained. Will two coats help mask or minimize that?
I’d be grateful if you could advise on a protocol. Thx!
Heidi
Heidi
7 months ago
We have a 6 year old deck that has been cleaned and stained with restore a deck products. this is our third cleaning and our boards have a green hue to them we have actually cleaned the deck twice with the cleaner and scrubbed with a brush and power washed. Will this green color ever come off ? Should we strip? or just re stain the boards ? Is there any other product we should use?
Heidi
Heidi
7 months ago
Our deck has a lot of shade and not much sun. Could it be that the green is deep in the wood ?
IMG-20250920-WA0007
IMG-20250920-WA0005
IMG-20250920-WA0003
IMG-20250920-WA0001
Heidi
Heidi
7 months ago
Does this algae hurt the wood or just the look of the wood? If you use the stripper do have to use the cleaner again as we already used the cleaner?
Thanks Heidi
McKeever
McKeever
What to do if you’ve used Rustolem Restore and it’s failing?
Frank
Frank
How do I remove the mold and mildew off my deck without stripping the actual stain on the wood?
Serge
Serge
Cedar Deck couple weeks old.
Black stains all over. Was coated with Tompson water seal, black spots appier, than sanded and I apply penitrating oil, two weeks later , the same
Serge
Serge
With electric sander that use sanding paper, a part of it i used a planner
james lynch
james lynch
After neutralizing pt deck, if the wood still has a grayish tint, although much cleaner, is there cause for concern before staining? Thanks.
james lynch
james lynch
After cleaning pt wood I can see green coloring when wet, does this mean it isn’t dead? I am beginnin to think I have better chance of ridding the world of original sin than this green stuff….
james lynch
james lynch
Thanks for the quick reply. Any suggestions on the most economical approach to staining spindles? Ever tried using hand spray bottle or is sponge better? If deck stain dries can I reapply if needed?
Denise York
Denise York
Help, I need to get the mold or algea out from in between the floor boards on my deck? What do I use?
lisa
lisa
The sides of the wooden planks that you see when you look down.
Roger
Roger
What deck stain would you recommend for composite decking they all claim to be the best
Tami Phillips
Tami Phillips
I don’t want to remove my stain. I just want to remove the algae. We stainted our deck just last year.
Joyce Richards
Joyce Richards
Can u stain over the mold
Josh Pritchett
Josh Pritchett
Is it necessary to scrub each spindle during the cleaning process or just spray w/ cleaner and wash off?
Liz
Liz
What products are best used to clean and stain a boat dock to prevent contamination of lake?
What if the deck has been stain d and a couple of months later the mold shows up
Now what can be done?
Is a 50/50 mix of bleach & water a good algae & mildew remover?
aud
aud
great summary but why don't you list products that actually work? we bought the recommended deck cleaner at Menard's have been scrubbing for two days, and still there are mildew and algae stains in teh wood. would like to know the names of some products!
43
