🏆 Top Picks Summary
- Best Overall: TWP 100 or 1500 Series
- Best for Old Decks: Armstrong Clark
- Best Budget Option: Restore-A-Deck
- Best Penetrating Oil: CUTEK Extreme
| Product | Type | Durability | Ease of Maintenance | Key Strength | Best For |
| TWP 100 | Semi-Transparent (Oil) | 2–3 Years | Easy | Proven performance, deep penetration | Most decks |
| TWP 1500 | Semi-Transparent (Oil, Low VOC) | 2–3 Years | Easy | Better VOC compliance, similar performance to TWP 100 | VOC-restricted states |
| Armstrong Clark Wood Stain | Semi-Transparent (Oil) | 2–3 Years | Easy | Excellent oil penetration + conditioning oils | Dry, aging wood |
| Restore-A-Deck Wood Stain | Semi-Transparent (Water-Based) | 2–3 Years | Very Easy | Simple prep system + easy recoat | DIY homeowners |
| CUTEK Extreme | Penetrating Oil | 2 Years | Very Easy | Deepest penetration, no film buildup | All Wood types |
| Defy Extreme | Semi-Transparent (Water-Based) | 1–3 Years | Moderate | Strong UV resistance with zinc nano-particles | Sunny/high UV areas |
- Best Overall Deck Stain: TWP 100 Pro Series — A deep-penetrating, oil-based semi-transparent stain that offers excellent durability, easy maintenance, and consistent performance for up to 3 years.
- Best Semi-Transparent (Water-Based): Restore-A-Deck Semi-Transparent Wood Stain — A user-friendly, UV-resistant stain that can be applied to damp wood, allowing prep and staining in one day.
- Best Oil-Based Alternative: Armstrong Clark Wood Stain — A penetrating oil formula that conditions aging wood while providing long-lasting protection and easy reapplication.
- Best for VOC-Restricted States: TWP 1500 Series — An EPA-registered preservative with strong UV and mildew resistance, ideal where traditional oil-based stains are limited.
- Best for UV & Mildew Resistance: Defy Extreme Wood Stain — A water-based formula enhanced with zinc nano-particles for superior UV protection and mildew resistance.
- Best Semi-Solid Stain: TWP Pro Series Semi-Solid — Offers richer color, excellent UV blocking, and better coverage while still allowing some wood grain visibility.
- Best Solid Color Stain: Restore-A-Deck Solid Color Stain — A durable, breathable coating that resists peeling and works well for older or heavily weathered decks.
- Best Deck Resurfacer: Gulf Synthetics Deck Revive — A thick resurfacing coating designed to restore heavily worn or damaged wood surfaces.
*Free Shipping Included
✅ How I Rate Deck Stains
- Durability in real-world conditions
- Ease of application and maintenance
- Resistance to peeling and wear
- Overall long-term performance
- Wear and tear after 2 years
- Oil-Based:
- Deep penetration
- Easier maintenance
- Water-Based:
- Better UV color retention
- Faster drying
1. TWP 100 Series
2. Armstrong Clark Wood Stain
3. TWP 1500 Series
4. TWP Pro-Series Semi-Solid
3. Defy Extreme Stain
Type: Oil-Based Semi-Transparent- Durability: 2–3 Years
- Maintenance: Easy recoat, no stripping needed
- Best For: Most decks (pressure-treated, cedar)
- Why It Stands Out: Deep penetration and consistent long-term performance without peeling
My Test Deck Stats
Deck Square Footage: 2100
Consumer Star Ratings:
- Type: Water-Based Semi-Transparent
- Maintenance: Very easy, simple prep system
- Best For: DIY homeowners and quick projects
- Why It Stands Out: Can be applied to damp wood, allowing prep and stain in one day
My Test Deck Stats
UV Exposure: 50% Full Sun
- Type: Oil-Based Semi-Transparent
- Maintenance: Easy reapplication
- Best For: Older, dry, or weathered wood
- Why It Stands Out: Contains conditioning oils that help restore dried-out wood
My Test Deck Stats
Deck Square Footage: 600
- Type: Semi-Solid (Oil-Based)
- Durability: 3 Years
- Maintenance: Moderate
- Best For: More color coverage with strong UV protection
- Why It Stands Out: Rich color options while still allowing some wood grain to show
My Test Deck Stats
When Tested: August 2023
Deck Square Footage: 800
UV Exposure: Deck in full sun
- Type: Oil-Based Semi-Transparent (Low VOC)
- Maintenance: Easy
- Best For: VOC-restricted states
- Why It Stands Out: EPA-registered preservative with strong UV and mildew resistance
My Test Deck Stats
Deck Wood Type: Cedar
Deck Square Footage: 400
- Type: Water-Based Transparent
- Durability: 1.5–2.5 Years
- Maintenance: Easy
- Best For: Maintaining a natural, “bare wood” appearance
- Why It Stands Out: Unique formula designed to preserve the natural color of new wood while still offering UV protection
My Test Deck Stats
Stain Color Used: Chesnut
- Durability: 2 Years
- Best For: High UV and mildew-prone areas
- Why It Stands Out: Zinc nano-particles provide superior UV protection and mold resistance
My Test Deck Stats
Stain Color Used: Cedartone
- Durability: 1-2 Years
- Best For: DIY users and quick, forgiving applications
- Why It Stands Out: Extremely easy to apply with no back-brushing needed, but shorter lifespan than higher-end penetrating stains
My Test Deck Stats
- Type: Penetrating Oil
- Maintenance: Very easy (clean and reapply)
- Best For: Exotic hardwoods (Ipe, teak) all wood types
- Why It Stands Out: Extreme penetration with no film buildup, making long-term maintenance simple
Scott’s Pro Tips: Although CUTEK® Extreme is more expensive than many penetrating oils, the performance was very solid. There was no peeling or significant wear, and the coating should be easy to maintain, as it fades naturally and can be refreshed without stripping.
My Test Deck Stats
Deck Square Footage: 1000
How Many Years Tested: 1 Year
Stain Color Used: Walnut
Semi-Solid Deck Stain Review
- Consumer Star Ratings:
Best Deck Stain for Old Wood
- For new pressure-treated wood, wait until the wood has weathered and is able to absorb stain (typically a few months), then prep and stain.
- For older pressure-treated decks, proper cleaning and brightening will restore the wood and allow for better stain penetration.
- If you want to maintain cedar’s natural look, use a lighter or natural-tone stain.
- If you want longer UV protection, choose a slightly darker tint, as it will hold color longer.
- Wood Condition: New, weathered, or heavily worn
- Desired Look: Natural grain showing vs solid color
- Maintenance Preference: Easy recoat vs long coverage
- Climate: Sun exposure, moisture, temperature swings
✅ Deck Stain Types Explained
- Transparent/Clear Sealers: Natural look, less protection
- Semi-Transparent Stains: Best balance (most recommended)
- Semi-Solid Stains: More color, moderate maintenance
- Solid Color Stains: Maximum coverage, higher maintenance
Transparent Stains
Solid (opaque) Stains
2. Long-Term Durability
3. Deck Condition
4. Climate Concerns
- Film-forming coatings on older decks
- Over-applying stain
- Choosing based on color alone
- Skipping prep
- Not preparing your deck: Failing to clean your deck or remove old, flaking, or peeling stain from your boards can prevent a fresh coat of stain from adhering properly. See my Deck Cleaning Guide for best results!
- Over-applying stain: You may think more stain equals more protection from moisture, mildew, and sun damage, but that’s not always the case. Too much stain can prevent the product from penetrating your deck boards. As a result, it may form a film on top of the wood that peels or flakes off over time. See my How to Stain a Deck tips for the best results.
✅ Best Deck Stain FAQs
Quick Tip:
What is a deck stain?
⏳ Durability & Maintenance
🎨 Appearance & Color
🛠 Application & Usage
🆕 New Deck Questions
- Smooth wood: Wait ~3 months
- Rough wood: Can stain once clean and dry
- Kiln-dried wood: Wait 1–2 months
- Deck Location: Michigan
- Wood Type: Cedar
- Mold/Mildew?No
Thank you so very much for your kind help! I have spent countless hours researching and need to make a decision on products soon. The contractor with whom I met yesterday suggested Valspar, but they don’t have the greatest reviews. Thank you, thank you!
In which state is your deck located? Southern Illinois, just outside St. Louis, MO
How much sun/shade does your deck get? Morning sun (it gets very hot). Late afternoon shade.
What type of wood is your deck made of? I don’t know
Do you have mold or mildew issues? In some places.
Why/how did the previous stain fail? I let it go through one, too many Winters. I now have splitting and splintering.
What type and brand (if known) of stain did you use last time? I’m sorry, I don’t know.
Don’t use Valspar, terrible stain. You have a solid stain on your wood now so you will need a solid stain again unless you power sand it all off.
Hi! Glenn from Southcentral Alaska, Kenai Peninsula … I live on the coast.
More background:
Wood — cedar (kerfed decking)
Sun/Shade — moderate climate for Alaska, on south side of house, about 20″ of rain year
Mold — not really, I am religious about treating/protecting it … its in good shape
Previous Stains — don’t last long, most only a year … so of better products I used in past lasted/did there job well for few yeas but are no longer available in Alaska stores. Most recent product I used (last summer) was “Premium Wood Care, Cabot, Semi transparent deck and siding stain” [poor water resistance after about 6-8 months, seems like no resistance now] Also, leave marks on wood when you overlap
I am bit lost how to proceed. I look at various web sites and reviews and often conflicting review … some say it’s great, others say its terrible (eg. Homo Depo says Behr products are great, you reviewers say it is the worst … and you don’t seem to include any Behr products in your reviews).
In past, I was of understanding that oil-based was better that water-based and far as protecting wood, but is seems water-based products in many types of finishes have advanced greatly in recent years … especially on indoor products.
I like a clear, transparent/semi-transparent/natural stain (no paint). It is OK to gray or look weathered (kind of like it) … I just really want to protect the wood. I like to be able to apply another coat of stain with minimal prep (maybe a light power wash, no chemicals).
I am looking for an objective assessment. After reviewing you site, I am learning towards the “Restore-A-Deck Transparent Wood Stain” product. Sounds like it would last at least two years? I also like low-odor aspect that is typical of most water-based products, but am still a little nervous about moving to water-based products for outside use … but may be old fashioned.
Help! Would appreciate you insights/recommendations. Thanks in advance for your time.
P.S. tried download photos, but attachment process did not work (too large?)
We review all the Behr stains and they are not good:
https://www.deckstainhelp.com/?s=behr&post_type=post
The issue is what is available to you in AK and all of the products sold at Home Depot, Lowes, etc are not good and have poor reviews. Do you have the ability to have it shipped from the lower 48 states to AK? These are your best options: https://www.deckstainhelp.com/the-5-best-deck-stain-reviews-and-ratings/
We live in upstate NY and recently had a new porch added. They used Douglas Fir for 14’x18’ floor. Installed 6 months ago. They stained with 1 coat of Cabot ATO, only used half gallon. Floor is covered with roof but no side enclosure. Floor looks bad. Not sure if should wait till next year and have it redone? Or if that wasn’t a good choice for this floor. Any suggestions.
Post some pics.
I’m looking for the best solid deck stain near me so I can pick it up and get started tomorrow. I live in West Michigan. My deck is older and needs a durable solid stain. It is also close to the ground so moisture can seep up. Please advise, thank you.
Hello. Please help us pick a deck stain.
Deck is in central Indiana. Western exposure, lots of sun on much of surface. Newly rebuilt last year with pressure treated pine. Previous deck it replaced had some green algae growth on the shadier steps. It had been stained with TWP 200 series. Since it is pine, I don’t need the wood grain to show and am leaning toward a more opaque look, but I don’t want to use a product that will chip or peel like paint. Any advice? Thanks
For an opaque/solid stain, see here: https://www.deckstainhelp.com/what-are-the-best-solid-color-deck-stains/
In which state is your deck located? Virginia
How much sun/shade does your deck get?Lots of sun overall, a few spots significant shade
What type of wood is your deck made of?Pressure treated pine
Do you have mold or mildew issues?some algae
Why/how did the previous stain fail?cracked and peeled the first year don’t know why
What type and brand (if known) of stain did you use last time?Olympic Maximum Stain and Sealant in One Solid Color
Prep by pressure washing and spot sanding to remove any peeling stain. Use a new solid stain after. See this link for the best solid stains: https://www.deckstainhelp.com/what-are-the-best-solid-color-deck-stains/
We have a new construction home with rough cedar beams and rough wrapped cedar accents. Is there a stain combo we can do to make the wrapped cedar match the cedar beams?
You would have to test stain samples as this is not a way to answer this without actually applying the stain to see how it looks. Look ta Armstrong Clark or TWP 1500 Series.
where can I buy deck stains in ontario
Online, paint stores, etc.
Hi, We’re in Buffalo,NY. The Deck gets full Sun in summer and full shade In winter, except for a strip 1’wide that gets full shade all year. It’s pine. Mild mildew algae in the fully shaded strip. Our Deck is about three years old. Was stained the second year at the begging of summer with Thompson’s semi-transparent that began peeling by the end of summer on the decking, the uprights are still fully stained. We would prefer a semitransparent. Thanks for your help.
Post pics for prep help and that will determine the stain type going forward.
We were able to pressure was most of the old stain off the deck boards except a couple spots in the shadier areas
Unless you remove the rest of the stain by sanding, you will need a solid stain to cover what you have on the deck.
If we do sand the old stain off would TWP 1500 be an appropriate stain and would we need any other prep?
Thanks so much for your help!
Yes, the TWP 1500 would work well. Final pep with their Gemini Restore kit.
Very old weathered deck needs help. Located in NJ. Last product used was Ben Moore Arborcoat. Any solid stain/paint that might hold up better? A primer first on bare spots? Just power washed and will sand any peeling areas. Then what? Help!
Do not use a primer with a deck stain. See here for the best solid stains: https://www.deckstainhelp.com/what-are-the-best-solid-color-deck-stains/
I live in Ontario Canada, my 1 year old cedar deck gets morning sun only. There are no mildew issues but the wood greyed like there was no stain applied at all. I used Behr premium semi-transparent clear stain. What do you recommend.
Strip it all off and then try TWP 200 Series or Armstrong Clark Stains.
In which state is your deck located? Michigan
How much sun/shade does your deck get? Shade on the south side, sun on the north part (stairs are at the north side of the deck)
What type of wood is your deck made of? Pressure treated wood
Do you have mold or mildew issues? Yes, south side. Mildew
Why/how did the previous stain fail? No previous stain, has been installed for 3 years.
Clean and brighten for prep with Restore A Deck Kits and stain. Stain with Restore A Deck Stains or Armstrong Clark Stains.
We live in western Pa. Our deck is in full sun in the back of the house and completely under cover in the front. It’s about 10 years old and has been stained every few years. There are several boards that need replaced, as they have rotted. Not what i expected from what I thought was wolminized wood.
What was your question(s)?
I just built a 2-story 16’x24′ shed with 3/4″ PT subfloor covered with 3/4″ T&G non-pressure treated plywood which I intend to seal (waterproof, mildew proof). The shed will house ZTR, snow blower, OPE (outdoor power equipment), and eventually become a wood workshop. Also, I’m thinking about covering the sealed wood with RaceDeck tiles. Product suggestions?
Try something more durable like this: https://www.deckstainhelp.com/gulf-synthetics-deck-revive-review/
Thanks. Perhaps of interest consider it’s new wood:
https://twpstainhelp.com/prepping-new-wood-for-twp-stains/
TWP and New Smooth Decking or Exterior Wood
It is important to understand that new smooth wood is not absorbent enough for the TWP Stains.
Let the Wood Weather First
We are installing new deck rails of cedar. live in Colorado and will get afternoon sun. No mold or mildew issues.
You cannot stain new wood right away. See this for tips: https://www.deckstainhelp.com/how-long-should-you-wait-to-stain-a-new-deck/
I have a deck that is 5 years old. Live in Windsor Ontario Canada. I did seal the deck with a transparent stain. The deck is shaded by a large tree does get some sun. THe deck is pressure treated and showing some wear on the stairs. I would like to stain the deck so it looks better and pleasurable to the eye. What should I use.
Restore A Deck Prep kits and Restore A Deck Semi-transparent stain or TWP 200 Series.
Where can I buy the Restore-A-Deck kit in Toronto, Canada?
Buy from their website. http://www.restore-a-deck.com
What is the best stain for my deck? It is many years old. There are some pieces however that may need to be replaced. I’m interested in an oil based stain with a darker pigment.
– I reside in Minnesota around the Twin cities.
– How much sun/shade does your deck get? South facing, full sun
– What type of wood is your deck made of? Pressurized wood, I think.
– Do you have mold or mildew issues? No
– Why/how did the previous stain fail? Last done 3 years ago and needs to be repeated.
– What type and brand (if known) of stain did you use last time? Oil stain to allow the grain to come through but was proprietary to the company (roof to deck restoration)
Strip and brighten wood for prep. Try the TWP semi-solid stain: https://www.deckstainhelp.com/twp-semi-solid-pro-series-wood-and-deck-stain-review/
I live in Ohio (Cincinnati area – south-west). The deck is pressure treated wood (yellow pine, I guess). Six months old, never been stained – looks like new, not gray or white. Gets early morning sun, then in the shade for the rest of the day. Interested in a semi-transparent stain.
Do I need to clean it first? What products would you recommend?
Yes, you have to prep. See the for new wood tips: https://www.deckstainhelp.com/how-long-should-you-wait-to-stain-a-new-deck/
Thanks! What reco for a semi-transparent stain?
On the link we sent prior.
I have a new (constructed in Sept 2021) treated pine deck here in Richmond Virginia. It has gone through the “drying” period and I am ready to stain it. The deck gets morning and some mid-day sun and is shaded in the afternoon. We just purchased a gallon of Cabot’s ATO (simply based on color), but now I am reading that this might be the type of stain for pine / longevity. What are your recommendations?
Make sure to prep with a deck cleaner and then a wood brightener. Try Restore A Deck Stains or Armstrong Clark Stains.
We have a cedar deck that was only installed 3 years ago, but looks terrible due to peeling stain. We applied Pittsburgh stain/sealer twice over the past 2 summers, with the same result each time. We now realize that is a low quality product which likely contributed to the issue. We also live in Wisconsin, so it endures harsh winters and is exposed to full sun in the summers.
What product do you recommend? We plan to sand the deck prior to new application. Do we also need to do the cleaning and brightening steps?
Finally, do we need to sand the headers in additin to the main deck? Thise are the only pirtion which have remained in good condition. Thank you for your help!
You have to remove all if switching brands. Might want to strip first while pressure washing and then sand if needed after. This will be easier. Brightener would go on last. Try TWP 100 Series or the Armstrong Clark stains after.
I used Flood oil based deck stain (sierra tint) on a new deck last year. Unfortunately Flood is not available in my location now. Think about putting a clear oil based wood protector on this year. Any suggestions for product?
You cannot apply a clear sealer over a deck stain. You will at some point need to remove the Flood and switch to a different brand.
We live in Maryland
Deck is in good shape pressure treated
No mold or mildew
Present coating is Ben Moore Arborcoat
Not pealing just dull
What stain do you recommend?
You will need to remove the Arborcoat first. Post pics for prep help. Prep will determine the stain type needed going forward.
Central Illinois
This is our 2nd summer in this home, the previous owner didn’t do much maintenance if any at all, but the original owner kept up with everything.
the deck is on the North side of our home, so it gets at least all half shade all day. This side is prone to algae but the stain is holding up pretty well. The sunnier side of the deck is completely weathered.
the close up photos were taken recently in the shaded side and sunnier sides. The others are list photos from when we purchased our home.
This old stain will need to be stripped and it looks pretty thick. Strip off what you can, sand if needed, and then brighten the wood. How much or if all comes off will determine the stain type that is needed after.
Thanks! I was looking at the RAD 3 step treatment. Do you think I could start with their stripper (I would probably add both additives to get a longer soak time especially on the verticals)?
Yes, try that. If it all comes off then you can use a penetrating semi-transparent stain. If not, you may need a solid stain.
Writing about epi deck surrounding outdoor pool, upstate New York. Location gets full sun. No mildew issues. Deck received one coat of IPE OIL two years ago, and needs renewal. I’m not happy with the previous treatment. I read info on your website, and am more confused than ever. Simply put, what’s your recommendation? What’s your #1 choice? Many thanks, Robert P. S. I would like to retain the original ipe color.
See this about hardwood decks and stains: https://www.deckstainhelp.com/ipe-exotic-hardwood-stain-review/
Cedar Railing (just railing, not decking)
Maine – lakeside
Full shade on one side, Dappled sun on the other
Cedar
Previous mildew with Sikkens Cetol SRD
Deck boards peeled and mildewed. They were replaced with composite. The railings held up better, but tops got quite dark. We are rebuilding the railing and looking for stain appropriate for this same general design.
Photos attached are 2014 and 2022. Railing did not get much attention, not “cleaned” as it should have been.
For prep, try the RAD Stripper with both additives and then brightener: https://www.deckstainhelp.com/restore-a-deck-stain-stripper-booster-thickening-gel-review/
Stain with TWP 1500 Series or Restore A Deck Stains.
I should have been clear, or maybe you did understand… I will be using new rough sawn kiln dried cedar to rebuild the railing. Was hoping to stay right away by seeking out that lumber. True? Or still prep and and wait?
Rough sawn can be stained right away as long as it is dry and clean.
The wood looks shiny and lovely. The 2x4s are cabinet grade. Better than I expected for what I think they called grade c! Do I need to do something to open up the grain? Or just start staining? It just arrived today and is under a tarp in the driveway for now. Railing will be built next week. Thanks so much!
That wood is not rough sawn so no, it cannot be stained right now. See here: https://www.deckstainhelp.com/how-long-should-you-wait-to-stain-a-new-deck/
You will need to install, weather, prep, and then stain.
There is also area that is starting to break down and splinter. I bought the house in 10/18, not sure how old the deck is, but i don’t know that the previous owners had every treated it with anything.I haven’t wanted to commit to a solid stain/paint yet. Is there any stain out there that helps with the mold?
Post some pics as that will determine the prep and what stain type you can use next.
Pics
You will need a solid stain as this will not strip off fully. For prep, pressure wash with a deck stain stripper to remove the loose stain and then brighten the wood. Let dry and spot sand any more loose or peeling stain. Cover the intact stain that does not come off with a new coat of solid stain: https://www.deckstainhelp.com/what-are-the-best-solid-color-deck-stains/
Deck is in Alabama on the beach.
Deck faces south, so brutal full day sun
Pressure treated pine.
No mildew problems
Not sure if ever stained. Weathered and gray but in fairly good condition.
Clean and brighten for prep and then use a penetrating semi-transparent stain. Look at Restore A Deck or Armstrong Clark brands.
We want to refinish our OLD grey composite deck. We are in OH. What is best product to use? We are having hard time finding a high rated GREY stain.
The issue is you are in Ohio which has a low VOC law. Possibly the Restore A Deck Stain will work well with the composite. They have grays in both solid color and semi-transparent.
hi, my pine deck is 14’x32′ , I plan on putting 2 coats of semi-transparent restore a deck stain on it. my question is if it has to go down within a1/2 hour of each other and I can only reach 5 boards, can I apply for a half hour then walk on top of ir to apply second coat without negatively affecting the end results
You apply the first coat to all of the floor and then walk back on and apply the second coat about 30-45 minutes after. You can do each coat in 30 minutes or so to the floors using their deck floor brush. BTW, if you have railings, do them first and they will only need one coat.
Hi! Thank you so much in advance for your help! Just bought this house and wanted to take care of the deck because I don’t know the last time the precious owner did. I’ve never had a deck before.
Thank you so very much!
You will need a solid stain again after prep. See this for the best options: https://www.deckstainhelp.com/what-are-the-best-solid-color-deck-stains/
For prep, pressure wash with a stripper to remove as much as you can of the current stain. Let dry and spot sand any peeling areas. Cover with 2 coats of a new solid stain.
We just had our 21-year-old deck soft power washed with a cleaner as well. It had been stained 4 years ago with an oil-based stain. We would like to use water based this time. Do you think this will work? As you can see, the deck has been thoroughly cleaned! Do you recommend any particular brand or type of stain?
You still have some old stain left so redo the prep using a stain stripper and pressure washing. Brighenr after. Look at Restore A Deck products for the prep and stain.
Deck is in Connecticut.
Deck gets full Sun in the afternoon on 75% of deck.
Deck is Pressure Treated approximately 25 years old with some boards having just been replaced.
No Mold or Mildew.
Previous Stain stopped repelling water and wood cracking.
Behr Transparent Penetrating oil applied 2 years ago.
My concern is that I want a consistent color for my deck but with the new boards that would not be possible without using a solid stain. See attached photo. Unfortunately, in my area all the solid stains are water-based. I believe applying a water-based solid stain over an oil-based stain will fail in the way of peeling. Your suggestions greatly appreciated.
C.C.
You cannot stain your new wood yet: https://www.deckstainhelp.com/how-long-should-you-wait-to-stain-a-new-deck/
For prep, strip and brighten the wood after the weathering. Use Restore A Deck Kits. If you want it all to blend then you will need a solid stain.
My recently purchased 70+ year old house here in East Texas came with two side-by-side decks on different connected by a six step stairway. We designate the two decks as the Upper Deck and the Lower Deck. Each deck has different functions, environmental exposures, and traffic patterns which probably warrants separate considerations. While the two decks are in close proximity of each other, might two separate products with similar colors be appropriate?
Here are the details.
• Deck Location: East Texas
• Wood Type: Treated Pine
Upper Deck
• Sun/Shade: Full sun in the morning, mostly shaded from noon to sunset
Lower Deck
• Sun/Shade: Full sun beginning midmorning to midafternoon, mostly shaded from midafternoon to sunset.
• Other: Lower deck is next to swimming pool and experiences frequent exposure to water. Deck surface temperatures can get quite high in full sun times- too hot to stand on. Deck also abuts a concrete foundation wall on south facing wall of the house with heat and UV reflection and along with decreased air flow creating a warmer than normal microclimate.
For Both decks:
• Mold/Mildew? Yes
• How Did Last Stain Fail? Peeling, especially at frequently wet locations adjacent to the pool, under roof edges from rain runoff, and in areas of higher foot traffic. Age of deck is unknown.
Which Stain Was It? Appears to be Sherwin Williams Super Deck semitransparent mixed in April 2020 based on label attached to a gallon container former owners left behind.
Your stain looks opaque, not semi-transparent. You will need a solid stain going forward unless you want to sand this all off. Look at these solid stains for both decks: https://www.deckstainhelp.com/what-are-the-best-solid-color-deck-stains/
Make sure to prep well by cleaning and sanding off any peeling stain.
I moved into a new construction home in the Denver, CO area with a new deck that was built about 3 months ago. It is on the north side of the house and has a roof covering everything but the stairs, so it doesn’t get a ton of direct sunlight and is somewhat protected from rain and snow. What is your recommendation for stain and/or sealer? I like the look of the deck as-is so I’m ok with something more clear, but want to apply something that will be long-lasting and low-maintenance. Thanks in advance!
Thank you for the reply but also looking for best product to clean the mahogany deck.thank you
The Restore A Deck Cleaner/Brightener Kits.
What is best for cleaning and treating a mahogany deck that is weathered but do not want mahogany look, more grayish. On ocean.
You could just clear coat it so it is protected but grays naturally. Try TWP 1500 Clear or Defy Extreme Clear.
In which state is your deck located ? michigan
How much sun/shade does your deck get? afternoon full sun
What type of wood is your deck made of? new pressure treated installed last fall
Do you have mold or mildew issues? a little on one end
Why/how did the previous stain fail? Pealed in places. wasn’t bad but it was old wood and we applied solid color. want semi transparent on new wood
What type and brand (if known) of stain did you use last time? cabot solid color
See here for new wood tips: https://www.deckstainhelp.com/how-long-should-you-wait-to-stain-a-new-deck/
Try Restore A Deck stains or TWP 100 Series.
Hi, I live on Vancouver Island in Canada. I’ve just had a new cedar fence installed. My property gets lots of sun, but lots of rain as well. Mold/mildew will likely be an issue. I want a sealer/stain that is penetrating, offers really good UV protection and is mildew resistant. I like transparent stains, but from what I’ve read, semitransparent is the way to go. I like the golden look of my fence, and don”t want anything that will make it look red. I’m very concerned about it graying over time as well. Can you please suggest which stain/sealer would be best for me? Thank you so much. (I understand that I can stain/seal my new fence as soon as we have 3-4 days without rain. Is that true?)
Sincerely,
L.W.
No, you cannot stain it right away unless the wood is rough sawn: https://www.deckstainhelp.com/how-long-should-you-wait-to-stain-a-new-deck/
As for the stain to use, try Restore A Deck Stains or TWP 200 Series.
Thank you for your advice on staining my new redwood check in Northern California. I appreciate your advice to not use bleach based cleaner and to wait to stain it, but my contractor tells me that for redwood decks around here lots of people stain and seal them soon after they are installed so that the red color does not fade, and that the bleach based cleaner is essentially a sped up version of the oxidation process that waiting would do and creates a surface that will absorb the product.
Can anyone else out there speak to this bleach and stain soon method for new redwood decks built with high quality lumber? Is there a way to test the wood to see if it is ready to take the stain/sealant? Does redwood have sufficiently different properties that this might be a viable way to do this?
Your contractor is wrong and it is not based on the wood type but the stain brand you choose that determines the natural weathering time, etc. Bleach does not speed up the weathering process.
We’re in the middle of rebuilding most of an old deck and adding onto it, and I haven’t been able to find info about our particular needs:
1) For the new decking and railing, we’re using the cedartone pressure-treated lumber from Menard’s. We got this bc we have little kids and need as low maintenance as possible. We want to just do a clear sealant on it since it was colored during the treating process. I want a sealant that deepens the color, something with a bit of sheen so it looks wet. Do you have a product recommendation? And do we follow your regular guidance for cleaning and then sealing cedar (since we’re not staining) after aging it for 3 months? Is this wood going to fade to gray so we’ll need to stain it in 2-3 years anyway?
2) We’re using a solid stain on the posts, skirt, and stair stringer — something white to match the house trim. BUT we have to get this white to match on both new pressure treated lumber and the old deck posts, which are currently two different hideous shades of orange. If we strip the old stuff following your recs on this site, will the solid stain cover both new and old wood so that it all looks the same color? Is there anything unique about our situation that we need to keep in mind and might be forgetting?
For what it’s worth, we’re just west of Chicago, in a fairly rural subdivision. The deck is on the north side of the house and is mostly shaded by the house until mid-late afternoon, though there are no trees giving additional dhade.
Thank you so much for your guidance!
1. You cannot apply a sealer over a stain and adding a “sheen” to exterior wood means it will peel. You will have to remove the pre-stain and then recoat with a proper wood/deck stain in the next 1-2 years.
2. See this about the new wood: https://www.deckstainhelp.com/how-long-should-you-wait-to-stain-a-new-deck/
After, just prep correctly and then use a solid stain on all.
Asking for a bit of clarification… the new decking we wanted to just use a clear sealant over is the cedartone pressure treated wood from menards — it hasn’t been stained in the sense you’re talking about. I believe the pressure treating liquid is dyed. Does that mean we don’t need to do anything to seal that wood?
I read the article about the wait time, but nothing anywhere mentions the *cedartone* pressure treated lumber – since it’s made to not have to be stained, I’m not sure which directions to follow.
A clear sealer will not provide UV protection and the wood is most likely factory stained (PTP is not dyed), so a sealer over it will not adhere.
You need to follow the directions of any stain brand you choose going forward as to what they suggest for new wood, etc.
I need a product to protect my deck stain from getting torn up by my dog’s claws. Can you recommend anything? I am tired of re-staining my deck every spring. Thanks!
Sorry but no deck stain is immune to a dog’s claws.
Hi, We resurfaced our deck with premium pressure treated pine last November. It has had five months to dry. We live in Austin , TX and it gets full sun at least half the day, if not more. In the past, stains have peeled, bubbled, worn off, not lasted more than a year, etc. We want to make sure since we are starting fresh, we do it right the first time, but that it is a good one for Texas heat and sun. (And we are trying to do it ASAP before it is 100 degrees here). I was looking at the restore a deck, but wasn’t sure if that was the right choice for Texas. Thanks!
See here about new wood first: https://www.deckstainhelp.com/how-long-should-you-wait-to-stain-a-new-deck/
The Restore A Deck will work. Another option would be TWP stains.
I need to choose a stain/ sealant for a brand new redwood heartwood deck in Marin County California. The deck gets a lot of direct sun and is built around a swim spa. It is not very large and has a built in bench and angled steps. I would like for it to keep a red color and have a nice smooth surface I definitely, so I need something easy to reapply every couple years. What do you recommend? And how long do we need to wait to apply the stain if it is cleaned with a bleach cleaner? Can it be done after it dries in a few days, or do we really have to wait weeks or months?
You cannot stain new wood right away: https://www.deckstainhelp.com/how-long-should-you-wait-to-stain-a-new-deck/
After the wait and prep, try Armstrong Clark or Restore A Deck Stains.
Never use a bleach based cleaner: https://www.deckstainhelp.com/best-deck-cleaners/
Not happy w Sherwin Williams Super Deck/semi transparent:
Post some pics for proper prep help. This will determine the type of stain to use.
pic 1 shows peeling and pic 3 is close up peeling on stationary dock
pic 2 is our floating dock
all these taken after pressure washed by handyman as he preps for restain. He still has prep to do obviously. For some reason the stain came off easily on floating dock-not on stationary dock…?
Looks like you have multiple layers of stain? Strip and brighten while pressure washing to remove more of the current stain and then try a solid stain on all: https://www.deckstainhelp.com/what-are-the-best-solid-color-deck-stains/
In which state is your deck located? Illinois
How much sun/shade does your deck get? Full Sun
What type of wood is your deck made of? Pressure Treated
Do you have mold or mildew issues? Some – mostly around the base of the railings and on the pergola.
Why/how did the previous stain fail? It has never been stained but was clear coated 4 years ago after power washing. I will have it power washed again but do not want to use clear as I do not like the “graying.” I want to go with a transparent or semi-transparent light tint – I want the grain to show through. My deck is about 12 years old, is large and has a pergola. What would you recommend?
What type and brand (if known) of stain did you use last time? Cabot (clear)
Try Armstrong Clark Stains or Restore A Deck Semi-transparent stains.
I’m installing Fl cypress deck, I like Armstrong clark product, but not sure how the different staining colors will look. I don’t see samples so not sure what buy.
I like color in the attached pic
That is IPE exotic hardwood. YOu cannot get cypress wood to look like this. AC offers samples for testing colors. See here: https://www.armstrongclarkstain.com/samples
Hello! I’m looking for the best stain and color for my deck. As far as color I do not want anything with reds or orange. Would prefer natural or the brown color featured in the picture. I am in the process of sanding the deck.
In which state is your deck located? Nebraska
How much sun/shade does your deck get? Full sun
What type of wood is your deck made of? I am unsure
Why/how did the previous stain fail? Age and probably the type used
What type and brand (if known) of stain did you use last time? Unsure. It seems like more of a paint than a stain
You will need another solid stain unless you want to sand off all the current stain that has not come off in your prep. https://www.deckstainhelp.com/what-are-the-best-solid-color-deck-stains/
So I have about half of this deck sanded before I found this site. Once it’s all sanded can I just use Defy deck brightener and apply a really good oil based stain? I do not know what kind of wood this is but I hope to achieve the look of the Armstrong Clark Rustic Brown shown in the picture on your site. I am also looking for something extremely easy to reapply when the time comes. Thank you!
Use a deck cleaner and a wood brightener after power sanding to help the new stain absorb better into the wood. Use Restore A Deck Prep Kits. Armstrong is a great stain and is easy to reapply.
I live in Staten Island, New York, and my pressure treated deck is several years old. I previously used Olympic Maximum clear, which gave my deck a yellow coating and failed to repel water beyond 2-3 months each time I applied it. I’ve not coated the deck for the last two years, so most of the sealer is now washed away. Planning to strip whatever stain is left and neutralize as you suggested. I’m thinking of trying Ready Seal oil based semi transparent stain based on user reviews and on the availability of getting sample colors beforehand. Is Ready Seal a good choice or would you suggest a better alternative? I’m most interested in an easy to apply goof proof stain that will penetrate the wood surface and last more than a year. Thank you for your help.
Ready Seal is a poor stain that has issues with color retention and rub off. We do not like it and you will have to reapply annualy.
https://www.deckstainhelp.com/ready-seal-wood-and-deck-stain-review/
I have a 8 year old pressure treated wood that is in full sun most of the day. We would like to do white rails and semi solid or solid gray deck. I have cleared and pressure washed it. What are your recommendations ps the the square marks on deck are from outdoor rugs, will semi solid stain cover that?
After you prep corectly the wood should look much more even. Use Restore a Deck Cleaner and Brightener Kits. Semi-Solid should work for floors. Try TWP Semi-Solids or Armstrong Clark semi-solid colors. For a solid stain on the rails, see this article: https://www.deckstainhelp.com/what-are-the-best-solid-color-deck-stains/
