TWP 1500 Stain Review Updated 2026 4.6/5 (21)
TWP 1500 Series Review in 2026
Here at DeckStainHelp.com we take pride in the fact that we have become the Internet’s go-to site for all things exterior wood and deck restoration related. Hearing from our customers who have used TWP 1500 stain in the past, their decks have held up to the test of time and weather after this harsh winter. It is also one of our top go-to stains for our restoration business. As always, we appreciate your input, so feel free to leave a comment below and pictures of your completed projects if you have them.
TWP 1500 Series Deck Stain Review
TWP 1500 Review
TWP 1500 Stain RatingsImportant Note: This is our 2nd Review of the TWP 1500 Series. Our first review of the TWP 1500 Stain was started in 2010 and completed in 2012.
See Here for First Review: TWP 1500 Series Review
TWP 1500 Series Preservative is an  Oil-Based EPA-approved wood enhancing preservative that stops structural damage and exterior wood rot on treated or previously treated above ground wood surfaces such as fencing, decking, roof shakes, wood siding, and log homes.
*Note: TWP 1500 and the TWP 100 are the only deck stains registered by the EPA as a wood preservative. TWP 1500 is compliant in all US states while the 100 Series is not.
TWP Deck Stains – 1500 Series Review
TWP 1500 Stain Deck Stain Scores (1-10)
For the pine deck, we used the TWP 1530 Natural. This is not a “clear” but rather a traditional cedar color in our opinion. The manufacturer stated they made this color in the 1500 Series to match the color of the TWP 101 Cedartone. This allows for an easy switch from the 100 Series for consumers who are in a low VOC state.
The wood grain was highlighted naturally with the 1530 Natural semi-transparent tint. The TWP 1500 does not mask or film on top of the wood grain.
Preventing UV Graying at 2 Year Mark: 8.5
Excellent at preventing UV graying at the two-year mark.  For the vertical railings, the TWP 1500 lost very little of the color. For the horizontals, we saw close to 80% color retention.
Same results as last time and one of the better products for preventing color fading
Wear/Tear and Peeling: 8
The TWP 1500 penetrates deep into the wood reducing the chance of wearing. We find that the TWP 1500 Scored well here for a low VOC oil-based stain.
Note that when staining brand new wood with TWP, we have found that it is best to let the wood season in the elements for at least 3+ months. Once it is weathered, we prep with a deck cleaner and wood brightener to enhance the stain penetration. Only 1 coat of the TWP 1500 for new smooth wood.
Cost Per Square Foot: 8
TWP 1500 Series cost us $43 per gallon. Coverage for the TWP 1500  on the pine deck was close to 150 square feet per gallon for the first coat and 250 for the second coat. We used 5 gallons for the 450 sq. feet.
No mold in the sunny areas of the deck floor. There was some mold growing on top of the TWP around the railings. This was close to a pine tree though and may have been the cause.
This result is normal with TWP products as they contain an EPA registered fungicide and a mixture of natural and synthetic oils.
Ease of Application: 8
TWP 1500 series applies fairly well. It is slightly thicker than the 100 Series so you do need to be careful, not over-applying. Make sure that all puddles that have not been absorbed in 30 minutes are wiped down. Best to apply with a stain pad. Attach this to a pole and “work” the stain into the wood. You can spray as well but you will need to back wipe for an even appearance. The TWP 1500 also takes a little longer to dry. Closer to 6+ hours. We have noticed that rain will not affect the 1500 Series as long as the stain has an hour or two to absorb.
Color Shifting (darkening) after 2 Years: 10
The 1500 Stain did not “darken” in color at the two-year review. This is excellent for an oil-based stain as many of the other brands have a darkening problem.
The Difficulty of Reapplication: 8
TWP 1500 Series can be reapplied with a minor cleaning first with a good quality deck cleaner. We have found that the TWP can be easily removed if needed with a deck stain stripper as well.
Overall Score TWP 1500 Stain at 2 Year Period: 8.44
TWP 1500 Series is one of the better wood and decking stains and is one of our top choices. As contractors, we really like stains that penetrate deep into the wood and can be reapplied without sanding. TWP 1500 fits this and more by adding excellent UV and mold protection. Maintaining TWP 1500 every 2-3 years is easy.
$69.99
$264.95
$315.00
$329.00
More Info: TWP 1500
Cost: $46.99 per Gallon, $234.99 per 5 Gallon Pail
Stain Type: Semi-Transparent – Oil-Based
Available Colors: 1500 Clear, 1501 Cedartone, 1502 Redwood, 1503 Dark Oak, 1504 Black Walnut, 1511 California Redwood, 1515 Honeytone, 1516 Rustic, 1520 Pecan, 1530 Natural
Coats Required: 1-2 Coats. “Wet on Wet”. Only 1 coat on new smooth wood.
Coverage Per Gallon: 150-250 sq. ft for the first coat. 200-300 for a second coat if applied.
Dry Time: 4-12 Hours
VOC Compliant: 350 Compliant in all States (Registered as Wood Preservative by EPA)
Deck Wood Type: Pine Treated Decking
Deck Square Footage: 450 Square feet
UV Exposure: 50% Full Sun, 50% Shade. South Exposure.
Natural 1530*All products tested and results are from our experience as wood restoration contractors. We offer no guarantee of similar results. Take into consideration that results may differ due to different wood types, exposure to UV radiation, and natural weathering.
TWP 1500 Series Deck Stain Photos
341 Comments
I am getting ready to stain 6,720 sq ft of cedar fence in Texas. I have selected TWP 1500 or Ready Seal as my stain choice. i read the reviews on the color fading and the low coverage area per gallon, on the Ready Seal and that makes me want to go with the TWP. That being said, most of these reviews are dealing with deck (horizontal) staining, and i will be staining mostly vertical boards, with the exception of the stringers. The problem i have with TWP is it is not readily stocked in my area. A few stores have a few gallons here or there, but I am looking specifically at the 1516 Rustic and only one store stocks it in gallons, while a second store can get the 5-gallons in about a week at the price of $210 per 5 gallon. I have found some online sites that will ship the TWP at a reasonable rate, but I am concerned about starting a stain project and not having all the stain I need on hand , or readily available once the job starts. There is an endless supply of Ready Seal mahogany in my area, but based on your reviews I am leaning towards the TWP. Question – on rough cut cedar, new wood, do you think it will take 2 coats of TWP? and are your estimates of coverage pretty close on every project? You mention 150-250 sq ft – 1st coat, then 200-300 for second coat. thank for the assist.
Clay
Clay
I had a deck built a in Texas last July – the builder stained it with Cabot shortly thereafter. It's been a disaster. Peeling EVERYWHWRE, 80% or more loss of color. Just completely dissatisfied.
If I were to Gonwith TWP – do I need to have the person doing the staining strip the stain first – or just pressure wash it really well?
Brian
Brian
I applied this to a new deck that had been aged a year to dry out. I used the Gemini restore-a-deck in preparation. Now two months later, I have Black Mold growing and it's quickly getting worse. I'm really not pleased with that outcome in such a short period of time.
Brad
Brad
I'm new to this site but I've already found the information here to be quite valuable. I have a 15 year old cedar deck that I had previously stripped and restained with a horrible Wolman stain. It pealed after one winter and I've regretted it since. I have now stripped the deck and railing system down to bare wood and sanded it. I plan on using TWP1500 to restain. I have some rotted floor boards and I am replacing them before I stain. I think I need to use some wood stripper on them and then use the cleaner/brightener on the whole deck before I stain. My question is you've stated not to stain new decks for 4 to 12 months but I don't want to leave my deck sit over the winter before I stain it. Can I just stain the new boards along with the rest of the deck? Also, should I apply one or two coats of the TWP1500? Thank you.
Brad
Brad
I think I prefer the option of one coat now and another next year. Will it provide as good of a finish if I do it that way? Can I apply the second coat first thing in the spring? Thank you
ken
ken
I am trying to repair our 17 year old pressure treated deck and gazebo. It has been stained with behr solid stain water based redwood color. We are currently scraping and sanding off the peeling stain. Can we then stain with TWP1500? Your recommendations please.
Jin
Jin
I leave in MA. Actually I bought TWP1500 a year ago, and I stripped the existing stain on my deck, and I applied two coats of TWP 1500. The color was redwood and I loved it.
However the last winter was horrible in terms of weather. During the winter time, I noticed that stain was lifted by ice built by frozen snows. So now, I can see light spots here and there. Have you ever heard about this kind of story?
What will happen if I reapply one coat on the existing stain after deck cleaner? Thanks
Jilly
Jilly
Hi I live in Ontario Canada. Plan to stain (for the first time) our three year old pressure treated wood deck. What are the steps I should take in preparing the deck before I use the TWP. Thanks
Alfred
Alfred
Plan to stain deck next month (Sep 2015) for first time (deck built May 2014) with TWP 1500 honeytone or pecan. Live in Centerville OH (outside Dayton), and understand we need to use TWP 1500 vs. 100 for Ohio. Eventually, probably next year, I'll put lattice to cover deck opening between deck and ground. For now though I want to paint or stain the 6×6 posts. Deck is about 950 sf, so there are quite a few posts. We have dark brown/mocha composite trim on our pine PT deck, so I want to paint or stain the posts the same shade of dark brown/mocha. Believe it would give it a cleaner look. Question: Am I okay to paint the 6×6 PT posts? They'll eventually be covered by lattice, which will also be dark brown. I'm leaning toward painting them with either Behr Premium Plus Ultra Exterior paint or Behr Marquee Exterior paint. Had good luck with Behr exterior paint on our shed. BUT … is there a reason I should NOT paint the posts, and should stain them instead? And IF stain is recommended, is there a stain you'd recommend? Hoping to paint them in the next week or two, so thanks in advance for any responses/input to this issue. -Al
Alfred
Alfred
Thanks for the stain recommendations. Couple more related questions: *(1)* Should I also use cleaner/brightener on these lower posts? (Hadn't planned to on these lower posts, which will eventually be covered by lattice.) *(2)* Do I need to power wash these lower posts? (Again, hadn't planned to since they're going to be covered by lattice within a year or so. Was just planning to ensure they're washed/hosed-down clean before staining.) *(3)* I have a total of something like 25 posts, and was just planning on staining the lower posts closest to the outside of the deck, and not stain the lower posts underneath the deck towards the middle of the deck … they're pretty hard to get to. That okay?? Thanks again for inputs! -Al
Erick
Erick
At a crossroad between TWP 1500 and Armstrong Clark semi transparent stains for my cedar sided home. Purchased samples of each and applied to sample boards. Both apply well and look good. TWP 1500 seems to bead water better than AC when test sprayed with water but not sure that is a reason to choose one over the other. Any reason to pick one over the other at this point or just pick based on preferred color? Thanks!
Erick
Erick
Longevity of either brand is almost the same?
I followed all of your steps for prepping my deck before I applied TWP 1500. When I applied, I left a wet edge as described on the container. I also applied the second coat "wet on wet" as described on the container. The weather was perfect – 72 degrees and no rain for 4 days. There a places on the deck where the stain is still tacky. The reading I've done says I probably applied too much stain. Help! What should I do? I'm worried that the stain is going to peel .
james
james
I am building a new Boat dock out of pressure treated wood. It is very hot here in Texas, 103 or so. Builder has said to stain the deck immediately because this new pressure treated wood dries out very quickly and will warp and split. The walkway out to be boat house and part of the deck will be in direct sun all day. Should I stain it immediately as he suggests? Also, what product would you recommend?
Aaron
Aaron
I am going to be staining a new decorative cedar fence, built about 6 weeks ago, using TWP 1501. It is rough sawn and the wood is fairly clean, only a bit of sand that has splashed onto it with rainwater. Does the fence need to be prepped in any special way prior to staining? I have noticed those who are staining decks are using a deck cleaner and wood brightener prior to staining. Is this necessary/recommended with a cedar fence, and if so, what product(s) do you recommend? Thanks for all the helpful information!
RF Schanda
RF Schanda
I have a new pressure treated pine deck that is 20 feet high off the ground and has a stairway down to the ground. The underside is visible so I need to treat all sides. What's the best way to apply stain/sealer in this instance?
Don
Don
I am purchasing KDAT pressure treated lumber. Is it advisable to seal the entire board [top & bottom]? If so can I use the TWP 1500 right away to seal the underside before installation?
Skip
Skip
After reading these reviews and comments I went with TWP 1500 and am very disappointed.
My PT deck is partially in the sun and partially covered. It has been only 6 weeks since applying per the manufacture's directions and the portion of the deck in the sun is already fading and has lost probably 50% of it color.
The deck was cleaned with a hydrogenated bleach (similar to the Defy product recommended elsewhere on the website) , sanded and cleaned again with a hydrogenated bleach followed by a brightner. The cleaning took place twice because I found out per this website the sanding should occur than the cleaning so I got into step with the recommendation herein.
Darlene Wasicki
Darlene Wasicki
We purchased a home 1 year ago in the mountains of Northern Colorado. The previous stain has worn out in high traffic areas and from pet "stains". We were considering using a "deck-over" product, but after doing research it seems none of them really do what they promise. There are some small cracks in the deck and scrapes from shoveling snow. What would you recommend we use?
Ann
Ann
We have a Massaranduba deck installed 11 years ago. The deck (porch) is covered, but faces south and we get a lot of sun on the outer edge of the porch. We live near Charleston, SC, so we also have a lot of humidity. Initially we applied Penofin – Brazilian Rosewood oil. The nice appearance didn’t last long. About 3 or 4 years later we sanded the porch and applied Cabot Australian Timber oil – Mahogany Flame. That was 8 years ago. Our deck looks pretty bad. In fact, it looked bad after 1 year of the Cabot stain.
What stain product do you suggest? Will it be better than the two products we have already tried so far?
And what cleaning product do you suggest?
Would you clean after you sand?
What grade sand paper would you use?
Thank you for any help.
Ann
Ann
Where can buy TWP 1500?
Is there a color chart? I guess I would get Redwood or California Redwood.
Where do I get Restore A Deck?
Thanks for your help.
kurt
kurt
I've got a hot tub room with plywood for a backer. I'm going to put cedar on that. Should I stain the plywood before putting the Cedar on it? If so what stain should I use. I live in Minnesota.
Thanks in advance.
kurt
kurt
Which stain would you recommend for staining the Cedar in the hot tub room.
Shawn
Shawn
I have a brand new (one-month old) cedar deck. I saw TWP 100 requires 4-12 months to weather the wood. How about TWP 1500? Does it also require 4+ months before staining? Someone told me cedar is ready to stain right after the installation is done…
Shawn
Shawn
Reply to  Shawn
Thanks for your reply. How about Armstrong Clark stain? Is it good to apply it now or still wait a little longer? Thanks!
Aaron
Aaron
I have a newly constructed cedar fence and have questions regarding the finish. Is it necessary to allow the wood the dry for several weeks prior to staining? What strain would you recommend? I would like to maintain the natural and rich wood cedar color. Thanks
Brian
Brian
Reply to  Aaron
I have an cedar fence in my backyard, I will only use TWP stain on it. I used a pump-sprayer to apply. I used 15gal. for 300 ft. of fence. I used the natural cedar-tone color. The cedar soaks up the stain with little or no back-rolling needed. It has held up Fantastic. It still looks really good after 10 years of extreme weather conditions in Nebraska. This is by far the best stain on the market.
Matthew Corrigan
Matthew Corrigan
Looking to stain a pressure treated deck that has had olympic semi transparent stain put on twice before. Can I just apply this new stain on top or do I have to strip it down first? I assume I'm going to clean and lightly sand the deck. Thought I would use a deck repair paint but they all have terrible reviews.
I am installing a covered tongue and groove porch floor in illinois. It is recommended that this flooring be sealed on all sides before installation. The wood is pressure treated pine that was kiln dries after treatment, so it is dry. Can I apply TWP 1500 prior to installation and if so what if any prep work has to be done?
Jerry
Jerry
I have a new cedar fence and live in Central New Jersey. It was installed about 8 months ago. I was thinking of going with the TWP 1504 (Black Walnut). I was wondering how much stain I would need to do both sides. I have about 55 sections of fence to do. Also, what would you recommend besides the TWP? Thank you
Jerry
Jerry
It's 6 x 8, so it's 96 square feet per section.
96 x 55 = 5,280 square feet
Ferdinand
Ferdinand
I have a 410 sqft deck that is about 10+ years old. The wood is Brazilian Hardwood, either Ipe or Cumaru and in great condition. However we did use Penofin Hardwood Stain (Brazilian Rosewood Oil) twice in the last 9 years and you are correct, it turned black at many spots. We now like to get a professional painter in who recommended the following three options (based on photos of the deck): 1) Ready Seal 2) Armstrong 3) TWP.
Any thought from you expertise which one would be most suited for Brazilian Hardwood?
Ferdinand
Ferdinand
Reply to  Ferdinand
Thank you for your reply. On your review site you have 2 products listed:
1). https://www.deckstainhelp.com/armstrong-clark-wood
2) https://www.deckstainhelp.com/armstrong-clark-stai
Which product are you referring to in your response above and also which of the 3 types do you suggest for the Brazilian Hardwood: Trans parents, Semi-Transparent, and Semi-Solid Colors?
FERDINAND
FERDINAND
Thank you for the additional information. I also have hardwood wood furniture on my deck. It is Jansen -Jarrah, made out of Australian Jarrah wood. I would like to take care of the furniture and deck at the same time. Would you also recommend Armstronk Clark for this type of furniture? The manufacture recommends Cabot Stain -Australian Timber Oil, but I have read bad references about their latest products. Please advice.
Todd
Todd
My 600sq' deck had sun frog transparent finish sealer on it and was let go for many years. The surface was slippery and I just was given a pressure washer. I used fairly high pressure and the deck looks great now but needs a new coating. Unfortunately, from some comments I read, it looks like I shouldn't have pressure washed it so high with water alone, but it's too late now. Where do you recommend I go from here.
ALP
ALP
We have been trying to make up our mind between Penofin or TWP stain for our deck, and we got our answer by accident.
We picked up samples of both and we put 2 stain samples of Penofin on 1 board on our deck and 2 stain sample of the TWP on the other board. I put the same amount stains on both boards. It rained during the night and when we check the samples in the morning there was quite a bit of beading on the board with the TWP stain. On the board with the Penofin stain there was no beading at all. This really surprised us. I thought this might help other people who are trying to make up their mind.
Patrice
Patrice
I am from Northern Colorado and we are looking to restain our back deck. We had it done 2 years ago and didn't even last 6 months by a certain company who I think did not do a great job. So I want to order a sample to see who it looks like on but not sure if we need the TWP 100 or TWP 1500 what do you suggest. The deck faces west and gets non stop sun/rain/snow and have 3 year old twin boys who are constantly playing on the deck? Also there is nothing left of the previous stain do we need to strip & sand again or is washing restore/brightener enough? Thanks in advance
Chuck
Chuck
I have a cedar deck in south Texas which was constructed in 2007. I put down several applications of "big box store" stains over the last 8 years. I'm now sanding to bare wood the horizontal surfaces which have peeled although the wood is in good shape and the vertical surfaces are fine. What stain would you recommend and any other preparation recommended prior to staining? Thanks.
Karen
Karen
Hello, thanks for all the great info! We own a lake house in Michigan with extensive decking. Previous owner built the deck just last year and stained with Flood CWF-UV oil based staid in cedar tone. Sides and rails look good but floor needs restaining. I pressure washed with water and it's pretty clean just has areas of wear. Would the TWP 1500 be good to restain? Do I need to remove all the old stain or can I just touch up? What color would be comparable? Thank you!
Karen
Karen
Thanks for the info! Gull Lake in southwest lower Michigan. Do you know what color that would be comparable to the cedar tone of the Flood for the TWP? The sides of the deck are stained and still look fine, so trying to find something very similar so I don't have to restain everything. They are separated by a white border so it doesn't have to be an exact match, just close. Also, how long do I need to let the wood dry prior to application?
Karen
Karen
Thanks! We're about 45 minutes south of Gun Lake- great area! If we stick with the same Flood stain, can we just go over the existing without stripping? Just thinking we may do this just for this summer and then redo the entire deck next year, as we are having all our siding replaced next month.
Todd
Todd
Enjoyed your site, very informative. Looking to clean and reseat my deck this year. I live in central AL and was considering using the Restore a deck cleaner and brighter followed by TWP 1500 stain (haven't decided on color). Considering where I live I am making the right choice?
R Guttilla
R Guttilla
Hello, We have a cedar deck that was put down in 2002. We used one of your "worst" deck stains two years ago and the deck peeled. We have sanded the horizontal deck boards. We live on Long Island, harsh winters. After sanding do we need deck cleaning and brightening? Also, after sanding does the deck have to "weather" for awhile? We have had lots of problems with deck staining. This time we want to do it right.
M Fleming
M Fleming
Best stain for new deck that's seasoned approximately 6 months. I'm in upstate S.C.
Larry
Larry
Hi, I really appreciate the help you provide on this site! I followed your information to reseal my deck. I live in Southwest Ohio, in the Cincinnati area. I used Restore a Deck stripper and brightener to clean and prep the wood on my deck, followed by 1500 TWP natural this past Fall. So far, it looks good. I was wondering what I should do now? It still looks good. There are a couple of spots that I might retouch, but over all, it looks good and repels water. It made it through a tough winter and want to properly take care of it. I appreciate your suggestions. Thanks!
Conrad
Conrad
I had Flood CWF- UV clear stain applied to deck 4 years ago. Is it a good stain to reapply?
thank you in advance for answer.
Robert
Robert
I live in N.E. Alabama and built a deck last year ( Sep.). I am trying to decide which application of stain to use, any advice?
Elizabeth
Elizabeth
I have a 20 year old pressure treated deck that has had Sikkens SRD on it. It was peeling so we stripped, neutralized and sanded followed by a light power wash. It's ready for a finish but we are having trouble deciding what to use. If we go with TWP 1500 how will we know if we need 2 coats.
Elizabeth
Elizabeth
And would you recommend the TWP 1500 for our Vermont deck that is in good condition considering that we don't want to have to go through such an exhaustive process next time? Thanks so much
peter
peter
im trying to get reviews on the Penofin hardwood stain for my pressure treated decking
James
James
Staining/Sealing a new cedar fence in Texas. Fence has weathered unstained/unsealed for the past 6 months and is starting to grey. Wondering what would be the best approach for this fence. I feel like it needs to be cleaned and cleaner/brightener would be no problem, but what stain to use is the question. I can't decide which is better, the TWP 100 or 1500 and whether to use one coat or two. Any suggestions would be greatly appreciated.
ROwens-SoldierFence
ROwens-SoldierFence
Reply to  James
I just moved to Michigan from Texas, I have been using Wood Defender Brand products while there. Love them and they will not fade out nearly as fast as ready-seal.
Alan Long
Alan Long
Hello, my deck is in dire need of staining. I was stained with what looks like a redwood color stain many years ago, before I bought the house. I have replaced some of the pressure treated deck boards and a few railings so they are still bare in color. I've been reading about the numerous stains on the market of which their is plenty and I am thinking TWP 1500 might be a good stain. I live in illinois, will I have any problem putting this stain on the current deck. It is very faded in all but a few places.
Any advice/recommendations is greatly appreciated.
Rosanna
Rosanna
We used 1500 TWP natural two years ago after using restore a deck stripper to remove old stain and brightener. this was based on your recommendations and we were very pleased. We need to put another coat of twp down. the TWP natural was a little more red than we wanted. We would like to use a TWP that has less red in it. Can we make a change like this without removing all the old stain? We are thinking pecan would be better.
Brandon
Brandon
Hello, great site! I used the TWP 1500 Cedartone 2 years ago on my pool deck. Deck is made of severe treated pine. Today, after about 2 years, the color is pretty faded. I have a plastic bin to hold the pool tools, and the stain under it looks great. The stain on the railings also looks good. My guess is the sun did a number on it, but the stain should have held up a little longer than that. What is your opinion of me giving the deck floor a good pressure washing, and applying a coat of stain over what has been there for 2 years? Thanks in advance!
Brandon
Brandon
Cool, thanks for the info! Any particular solution for cleaning? Or is a water only pressure wash sufficient?
Daisy
Daisy
love your site!
We have a 30 year old deck in NY. The railings/spindles seem to have been painted at some point (peeling severely) but the actual deck has never been treated (full of splinters). Is TWP 1500 the appropriate product? Do I need to just sand and pressure wash or will I also have to use some sort of cleaner and brightener as well?
todd
todd
I used bm aborcoat translicent on a new pt deck last year. Mold is growing under the arbor coat. Bleach did not touch it . I am in central virginia. What should i use to get off? What stain should i go with this time. I want a lighter color.
Jozef S
Jozef S
Great Forum, the best on the web for the topic.
I have a deck that was painted 5 years ago with Scherwin Williams Solid Deckscapes stain. It looks beat down.
I want to use the TWP1500 to go over it.
Can I just pressure wash it and paint over it? or what do i need to do prior to putting on TWP1500? its solid
how to do this right so it looks the best? i dont want to sand it …do I have to?
Jozef S
Jozef S
ok…..so what stain would you recommend to go over the solid….so i dont have to take it off? which brand and type?
jozef s
jozef s
I checked yesterday for flood stains…none available in my area…and cabot also not available…whats the next best one??
jozef s
jozef s
believe it or not Sikkens not available either……any others? how about superdeck ?or other?
S. Dee
S. Dee
We finished a mini-deck stairs to bottom yard. New redwood. This product was superior to the Behr we put on the legs. (15 years ago I loved Behr, but it is not the same formula now.) Used 1530 natural. Project sat 3 months before staining. So we re-sanded all areas, except legs. Used 4 inch brushes, husband and me, took 5 hours. 8 x 10 area with rails and stairs. You must wipe as you go. Do not leave drips or puddles. Love the out come. Oh, and take care of the oiling rags properly. They started to combust in the yard overnight.
Andrew
Andrew
I have a large pressure treated pine fence and live in Charleston SC. There is some issue with wetness from the woods behind the house. The fence was previously treated with a solid stain and I have pressure washed and sanded it and removed all of the old stain. Do I also need to use a deck cleaner and brightener or could I get away with the pressure washing and sanding?
Would TWP 100 or 1500 or Clark semi-solid work best for this application? How many coats do you recommend?
Diane
Diane
Have a 6 year old deck. Never treated. Power washed twice. Last wash yesterday. It has lattice and railings. Which is best stain. Live in southern Illinois with usually humid summers. we usually have fairly mild winters, although last two have been more severe
Thank you..
Efrem
Efrem
We have a brand new PT pine deck, 3/4 of which is covered by an awning. We live in South Florida and get a lot of rain and wind so even the covered areas get wet often. We also have constant high humidity, which promotes mold growth. I've been reading your reviews and am considering the TWP 100, would you recommend something else instead?
aj4
aj4
Just sanded down log cabin made of poplar; washed with tsp, bleach and water, power washed then put 2 coats of penetrete. Now need a stain. We are in NY. What would you recommend? I think we need a semi translucent. Would love a 1 coat brand. Thanks!
aj4
aj4
Thank you so much!
Ken
Ken
Great site, good information and highly addictive. I live in Buffalo, NY and just had a deck installed with treated pine about 1 month ago. My contractor is insisting that I "put something on the wood" before the weather changes. Oddly enough, when I asked what he used on his own deck, he shared that the product he last used was terrible and wouldn't recommend it to anyone. Of course, it was one of the lower ranked stains in your reviews. I see that the AC products are recommended for new wood, but there seemed to be a higher level of concern from other posters regarding drying and potential staining of clothes with that product. I have built-in benches so i'm willing to err on the side of caution and go with a different product. From what I've read, it seems like TWP 100 is not allowed in NY, so TWP 1500 is the way to go. Although winter is coming and I have an urge to stain this new deck (with its new wood smell), from what I've learned on this site, should I just do nothing and wait until next spring to prep/stain? Thanks.
Ken
Ken
Thanks for the quick reply. Yes, I read the article. I was planning on waiting until May or June of 2015, prep use a RAD kit, then use the TWP 1500. During this first winter, when it's feasible, should I remove snow from the deck or does it not matter?
341
