Strip or Clean the Deck: Pro Tips and Advice 4.9/5 (29)
544 Comments
Sue Frechette
Sue Frechette
7 days ago
Hi! I had a deck rebuilt 5 years ago with fir. I live in VT where the deck is covered with snow most of the winter. The deck is on the south side of the house and in direct sun all summer.
I believe the new deck was initially improperly stained with oil based translucent stain over the raw (dry) wood with no preparation. Within months, the deck was covered with black splotches. Since then, it’s been cleaned and re-stained, again with translucent stain, and always looks terrible. See the photos.
detail-of-railing
10 months ago
Brenda
Brenda
Part-that-looks-good-and-mostly-shaded
Splotchy
thumbnail_IMG_5839
thumbnail_IMG_5840
Brenda Spring
Brenda Spring
Good Morning Scott –
Stipped-1
stripped-fuzzy
stripped-lines
Adam
Adam
Hi Scott.
IMG_4255-RUI-Deck
Adam
Adam
Emily
Emily
IMG_0085
Alexa
Alexa
Carla
Carla
New-Deck-Colors
new-deck-error
Carla
Carla
We used Rymar stain
IMG_2977
IMG_2974
Thanks so much, Scott
IMG_9036
IMG_9043
IMG_9044
IMG_9045
Joan
Joan
Ani
Ani
Valkyrie
Valkyrie
matt
matt
Jen
Jen
Jennifer
Jennifer
Lilian Tao
Lilian Tao
Lilian Tao
Lilian Tao
Lilian Tao
Lilian Tao
Adrienne Forns
Adrienne Forns
Max
Max
Thanks you!
Max
Max
Max
Max
Amy
Amy
Amy
Amy
Thank you for your help!
R Jolly
R Jolly
R Jolly
R Jolly
R Jolly
R Jolly
R Jolly
R Jolly
Here are photos of deck
R Jolly
R Jolly
R Jolly
R Jolly
R Jolly
R Jolly
Thank you for your tips.
R Jolly
R Jolly
Mark P
Mark P
Mark P
Mark P
Ncbeau
Ncbeau
In the PNW
ncbeau
ncbeau
Thanks again
Michael Pearce
Michael Pearce
A couple questions:
Thanks for any help
Jessika Petersen
Jessika Petersen
Or strip the whole thing?
L Spence
L Spence
Shannon Stamp
Shannon Stamp
Shannon Stamp
Shannon Stamp
Reply to  Shannon Stamp
See attached
Andrei
Andrei
544
