Strip or Clean the Deck
Gemini Restore-A-Deck Kit
Hi! I had a deck rebuilt 5 years ago with fir. I live in VT where the deck is covered with snow most of the winter. The deck is on the south side of the house and in direct sun all summer.
I believe the new deck was initially improperly stained with oil based translucent stain over the raw (dry) wood with no preparation. Within months, the deck was covered with black splotches. Since then, it’s been cleaned and re-stained, again with translucent stain, and always looks terrible. See the photos.
You will need to strip it all off down to the bare wood and restain. Use this kit for prep:
Good Morning Scott –
Hi Scott.
Strip and brighten for sure.
We used Rymar stain
Thanks so much, Scott
No need.
Thanks you!
Thank you for your help!
Here are photos of deck
Thank you for your tips.
In the PNW
Thanks again
A couple questions:
Thanks for any help
Or strip the whole thing?
See attached
Pressure wash.
