Types of Deck Stains in 2026: Explained 4.8/5 (808)
This post was updated on April 7, 2026
Hi, I’m Scott Paul, a seasoned exterior restoration contractor and business owner with over 30 years of expertise in exterior wood care. This article is one of my favorites because it breaks down all the different deck stains available, giving you the insights you need to make an informed choice. If you’re researching wood and decking stains, this is a must-read. Learn more about me here.
✅ What Are the Different Types of Deck Stains? (Quick Answer)
Deck stains are categorized by how much pigment they contain and how they interact with the wood. The four main types are:
      • Clear Sealers – No pigment = no UV protection from graying
      • Transparent stains – Minimal color, show full wood grain, lowest protection
      • Semi-transparent stains – Add light color while allowing grain to show, best balance of protection and appearance
      • Semi-solid stains – More pigment, better UV protection, partially hide wood grain
      • Solid color stains – Fully opaque, maximum coverage but highest maintenance
      • Oil-Based stains – Deeper penetration than water-based stains
      • Water-based stains – Eco-Friendly and water cleanup
      • Penetrating stains – Easier to maintain and prep
      • Filming stains – Prone to peeling
✅ How to Choose the Right Deck Stain Type
  • New Wood:
    Transparent or semi-transparent stains allow the natural beauty of the wood to show.
  • Older Wood:
    Semi-solid or solid stains help hide imperfections.
  • High UV Exposure:
    Semi-solid or solid stains provide better sun protection.
  • Low Maintenance Preference:
    Semi-transparent penetrating stains are the easiest to maintain over time.
Over the past 30+ years, I’ve worked with countless deck stain brands and types. Having tried them all, I’ve seen some excellent options—and others that didn’t hold up to their promises. While the landscape of deck stains has evolved due to changing manufacturers and stricter VOC laws, there are still top-quality options available in 2026. The key is knowing where to look.
-See below for full in-depth differences and descriptions for each.
Stain Type Appearance Durability Ease of Application Maintenance Best For
Clear / Wood Toner Natural wood grain visible, slight tone ★☆☆☆☆ (1 year) ★★★★☆ Easy recoating Newer wood, cedar, or if you want a natural look
Semi-Transparent Enhances wood grain with color ★★★★☆ (2–3 years) ★★★★☆ Moderate – light cleaning Most deck types needing color & UV protection
Semi-Solid Less grain visibility, more pigment ★★★★☆ (2–4 years) ★★★☆☆ May require stripping, but varies based on brand Older decks or those needing more color
Solid (Opaque) Paint-like look, hides grain ★★★☆☆ (1–3 years) ★★☆☆☆ Difficult – sanding/stripping Very old wood or previously painted/stained decks
Notes:
  • UV protection improves as opacity increases.
  • Durability may vary depending on prep, wood condition, and climate.
  • Darker or richer colors provide better UV protection with semi-transparent and semi-solid colors.
  • Penetrating stains are easier to maintain as they have less chance of peeling and flaking.
Penetrating vs Film-Forming Deck Stains
  • Penetrating stains (transparent & semi-transparent):
    • Soak into wood
    • Do not peel
    • Easier maintenance
  • Film-forming stains (solid):
    • Sit on surface
    • Can peel over time
    • Require more prep
👉 This is a high-volume keyword gap most sites miss
Water-Based Wood Deck Stains
✅ Water-Based Deck Stains (Acrylic Coatings)
  • Appearance: Natural to slightly enhanced color (varies by opacity)
  • Wood Grain: Visible in transparent and semi-transparent versions
  • Protection Level: Good UV resistance and water repellency
  • Best For: Newer wood, maintenance coats, and areas with strict VOC regulations
  • Maintenance: Moderate—easier than solid stains but not as forgiving as oil-based
👉 When to Use a Water-Based Deck Stain
  • You want faster drying times and easier application
  • You are working in an area with VOC restrictions
  • The deck is newer or in good condition
  • You want better UV color retention over time
⚠️ Downsides of Water-Based Stains
  • Do not always penetrate as deeply as oil-based stains. *Restore-A-Deck Wood Stains and Defy Wood Stains are the only exceptions I have used successfully. They penetrate the best of all water-based stains, nearly as well as an oil.
  • Can be less forgiving during application (lap marks possible)
  • May require more prep for proper adhesion
  • Slightly harder to recoat than penetrating oil stains
🔍 Water-Based vs Oil-Based Deck Stains
  • Water-Based Stains:
    • Faster drying and easier cleanup
    • Better UV color retention
    • Lower VOC content
  • Oil-Based Stains:
    • Deeper penetration into wood
    • More natural aging and wear
🧠 Expert Tip
My Cons: They do not penetrate as well as an oil-based product can. They are slightly more complicated to apply as they dry quickly. They can be prone to peeling and wearing. *Restore-A-Deck Wood Stains and Defy Wood Stains are the only exceptions I have used successfully. They penetrate the best of all water-based stains, nearly as well as an oil.
Oil-based Wood Deck Stains
Oil Based DeckStain
Oil Based DeckStain
Oil-based decking stains have been around for 30-40 years and have traditionally been what all stain manufacturers produce. Oil-based stains are typically made up of natural and synthetic oils. Many contain oils, such as Linseed Oil, Paraffin Oil, Tung Oil, Rosewood Oil, Etc.
✅ Oil-Based Deck Coatings (Penetrating Oil Stains)
  • Appearance: Natural-looking finish that enhances wood grain
  • Wood Grain: Visible (varies by transparency level)
  • Protection Level: Excellent water resistance, moderate UV protection (with pigment)
  • Best For: Most exterior wood decks, especially older or weathered wood
  • Maintenance: Easy—can be cleaned and recoated without heavy stripping
👉 When to Use an Oil-Based Deck Coating
  • You want a natural wood appearance with enhanced grain
  • The deck is older or has been previously stained
  • You prefer easy maintenance and recoating
  • You want a coating that is less likely to peel
⚠️ Downsides of Oil-Based Coatings
  • Slower drying times compared to water-based products
  • Can attract mildew in humid or shaded areas
  • VOC restrictions in some states may limit availability
  • Requires proper application to avoid over-penetration or darkening
🔍 Oil-Based vs Water-Based Deck Coatings
  • Oil-Based Coatings:
    • Easier to maintain and reapply
    • Rich, natural finish
  • Water-Based Coatings:
    • Faster drying
    • Better UV resistance retention
    • Lower VOC and easier cleanup
🧠 Expert Tip
Deck Resurface Coatings
✅ Deck Resurfacing Coatings (Restoration Coatings)
  • Appearance: Thick, opaque coating that fills cracks and hides wood grain
  • Wood Grain: Not visible
  • Protection Level: High surface protection, seals and bridges damaged areas
  • Best For: Severely weathered, splintered, or structurally sound but worn decks
  • Maintenance: Moderate to high—can peel or wear unevenly over time
👉 When to Use a Deck Resurfacing Coating
  • The deck is heavily weathered, splintering, or rough
  • Previous coatings have failed and the surface is uneven
  • You want to extend the life of the deck without replacing boards
  • The wood is still structurally sound but cosmetically worn
⚠️ Downsides of Resurfacing Coatings
  • Can peel or crack over time, especially in high-traffic areas
  • Difficult to remove once applied
  • Requires extensive prep before application
  • Not suitable for newer or healthy wood
🔍 Resurfacing Coatings vs Solid Deck Stains
  • Resurfacing Coatings:
    Thicker, designed to fill cracks and restore damaged wood
  • Solid Stains:
🧠 Expert Tip
My Cons: So far, most of these product types have failed miserably. They peel after the first Winter and cannot be removed with a deck stain stripper. Sanding, scraping, or even the replacement of the wood is needed. There are many reviews on our site and other sites with angry consumers and product failures. Class action lawsuits are being filed against Rust-oleum Deck Restore and Olympic Rescue-It. Behr Deckover has the same issues as well. Only a couple of these products seem to work. Consider the Gulf Synthetics Deck Revive if you want one of these coatings. See this link for more info, articles, and reviews on these coatings: Deck Resurface Coatings.
✅ Solid Color Deck Stains
  • Appearance: Opaque (paint-like finish)
  • Wood Grain: Hidden
  • Protection Level: Maximum UV protection
  • Best For: Very old or damaged wood
  • Maintenance: High—prone to peeling and requires more prep
My Cons: Films on top of the wood do not penetrate well, are susceptible to peeling, look like paint, and are more challenging to apply. They cannot be effectively removed with a deck stain stripper.
$69.99
Solid Color Deck Stain Photos
Semi-Solid Wood Deck Stains
✅ Semi-Solid Deck Stains
  • Appearance: Rich color, less grain visibility
  • Wood Grain: Partially visible
  • Protection Level: Higher UV protection
  • Best For: Older decks with imperfections
  • Maintenance: Moderate—can build up over time
A Semi-Solid Deck Stain will only show a small amount of wood grain as it contains a high amount of pigment. Only a limited number of manufacturers offer semi-solids, which can be both water-based and oil-based.
My Pros: They provide excellent UV protection. However, if they are water-based, they are prone to peeling. Look for oil-based semi-solid stains only.
Semi-Solid Deck Stain Photos
✅ Semi-Transparent Deck Stains
  • Appearance: Adds color while enhancing grain
  • Wood Grain: Clearly visible
  • Protection Level: Moderate UV and water protection
  • Best For: Most decks
  • Maintenance: Easy to clean and recoat every 2–3 years
These are my favorites, but the primary key is that it must be a penetrating semi-transparent stain. Semi-transparent deck stains contain pigments that highlight the natural grain while sealing the surface. Both water and oil-based are available.
My Pros: They offer average to better-than-average UV protection, show natural grain, and have very good penetration. In most scenarios, they can be cleaned and re-coated easily and removed with a deck stain stripper.
My Cons: Most water-based versions perform poorly compared to the oils. Many states with Low VOC laws have limited quality oil-based stains available. You may need to buy online if you live in a low VOC area.
Transparent Wood Deck Stains
✅ Transparent Deck Stains
  • Appearance: Clear or very light tint
  • Wood Grain: Fully visible
  • Protection Level: Low UV protection
  • Best For: New wood, premium hardwoods (ipe, mahogany)
  • Maintenance: Requires frequent reapplication (annually in many cases)
Transparent deck coatings look the most natural as they contain minimal pigment. The average life of a transparent decking stain is about one year. Mostly oil-based only are available.
My Cons: Below average UV protection. Typically, it needs to be re-coated annually.
Transparent Deck Stain Colors
Clear Wood Deck Finishes
Clear Deck Sealer
Clear Deck Sealer
✅ Clear Wood Sealers (No Color Added)
  • Appearance: Completely clear with no pigment
  • Wood Grain: 100% visible (natural look)
  • Protection Level: Low UV protection, good water repellency
  • Best For: New wood, hardwoods (ipe, mahogany), and users wanting a natural, unstained look
  • Maintenance: Requires frequent reapplication (often every 6–12 months)
👉 When to Use a Clear Wood Sealer
  • You want a completely natural, “no-color” appearance
  • You want the wood to gray
  • The deck is covered or has minimal direct UV exposure
  • You are okay with more frequent maintenance
⚠️ Downsides of Clear Sealers
  • No UV protection
  • Faster graying in full sun
  • More frequent maintenance than pigmented stains
My Cons: In months, the wood will gray and oxidize from the sun’s UV.
Low VOC Stains and States
Currently, 20 States and Canada restrict Decking Stains and Coatings. These states require fewer Volatile Organic Compounds to be released into the air. The lower VOC changes mainly affect oil-based coatings. By lowering the amount of “solvents” that can evaporate into the ozone, you need to increase the amount of “solids.” This can cause issues with oil-based stains, which may have drying and curing problems. A few good oil-based stains are still allowed in the Low VOC States but are not as readily available at your local stores. You may need to go online to find them and have them shipped. Examples would be the TWP 1500 Series and Armstrong Clark Wood Stains.
Current Low VOC States:
LOW VOC States Deck Stains
What are Deck Stains, and Why Use Them?
Deck stains protect and preserve exterior wood. They offer UV protection, water repellency, mold and mildew resistance, and more. Deck coatings come in many types of opacity and bases. Based on their VOC laws, many deck stain brands can be restricted in certain states, cities, and countries, and unfortunately, walking into your local store may produce some of the worst options available.
Difference of Non-Drying Oil vs Drying Oil-Based Stains
Drying oils are “curing” oils. This means that they actually dry on top of or just below the surface. They will also help “seal” the wood. Non-drying oils are the opposite. They never dry or fully cure but dive deep into the wood to help condition the cells. Paraffin oil (not wax) is the most common.
I prefer penetrating semi-transparent products with all these different types of products as they allow the wood grain to show. They offer better-than-average UV protection and can be easier to reapply in the future. Penetration is better for oil-based versions than water-based versions. The exceptions for quality semi-transparent penetrating water-based stains would be the Defy Extreme Stains and the Restore-A-Deck Stains.
Want Free Help Choosing Your Deck Stain Type? Ask below in the comments!
See My List of the Best 8 Semi-transparent Deck Stains
What Other Tools Do I Need?
  • Personal protective equipment (PPE), such as eye coverings and gloves.
  • Deck cleaner and deck brightener (neutralizer) for prepping the surfaces.
  • Hose for rinsing things and hand rags for cleaning up.
  • Tarps or plastic for covering nearby vegetation.
  • A hammer, drill, screws, and nails for any repairs.
  • A bucket with stir sticks.
  • A pole sander and hand sander with sandpaper (no finer than 80 grit).
  • A pump-style or airless sprayer.
  • A roller and roller tray, a stain (paint) pad with a pole, or a speed mop.
  • Stain brushes with either natural or synthetic bristles.
How to Apply a Deck Stain
Measure your deck to best determine the proper amount of stain needed, and buy a little extra to ensure you don’t run out. Every product is slightly different, so I always read the manufacturer’s application instructions thoroughly. This helps confirm details such as whether to apply one or two coats, the dry time interval between the coats, and any safety recommendations.
2. Surface Preparation
You may choose to apply stain with a brush, pad, roller, or sprayer. Avoid pump sprayers and stain pads for thicker or solid stains. Begin applying stain to vertical surfaces followed by floors and staircases. Apply stain to a single board at a time completely from end to end while limiting overlap marks.
After the application, allow 20 to 30 minutes for the stain to completely soak into the wood. Wipe any remaining, unabsorbed stain away to avoid blotches.
Remember the importance of checking the weather forecast before starting for any chances of rain in the next 24 hours and have tarps or plastic on hand to cover the deck—just in case.
Top Oil-
Based Stain
Top Water-Based Stain
Top Solid Color Stain
Easiest to Apply Stain
1.4K Comments
Max
Max
I just put Cabot semi solid on my deck. It looks really good but if I would of seen your site before I got the Cabot, I would of got the restore a deck stuff you recommended. Can I put the restore a deck over the Cabot in a year or two? How long do you think the Cabot will last? Am I wrong in thinking that these semi solids and semi trans will fade in time and not peel like a solid stain? I’m in Ohio and just want something that will last a long time even if it costs more. What would you do in this situation? Whatever you suggest I am going to do. Thanks for your help and time.
Max
Max
The kind I got you had to pick a color and they mix it in. The lady said it wouldn’t peel and it says deep penetrating on the can. It is really runny. You think it will still peel? That is false advertising if it does. I really wish I had found your site before getting the Cabot because I can tell you know exactly what your doing. If you don’t have a Youtube page you should make one and show your work. You could get partnered and make a decent amount of money from it. Thanks again.
Max
Max
The Cabot I got had to be mixed for the color you wanted and says deep penetrating on the can. The lady said it would’t peel. I don’t know anything about these stains. Do you think it will still peel even tho They told me it wouldn’t? They do have some semi solid already with color in them but I had to pick a color I wanted with the kind I got. I’m just worried with peeling because I have plants near by and an apple tree. If you think it will still peel after all this info, I would like to get rid of it before it does. Thanks.
Max
Max
Sorry for leaving 2 replies. I refreshed and my first was gone and same with second so that must be how it is when you reply to an existing post.
cotie suter
cotie suter
Reply to  Max
DO NOT GET THE DECK RESTORE> it does not last and you cant remove it. after not even a year mine was peeling up. I also know a few others who did their decks with that stuff and it did the same thing. you can not remove the stuff that actually sicks. next will be trying a heat gun and scraping a huge deck.
cheri
cheri
Reply to  cotie suter
do you mean the restore a deck stain?
Deb
Deb
Have a new deck which will be powerwashed in 1-3 months….we have a lot of trees and very little sun…what would your recommendations be?
LAVETA BONNEY
LAVETA BONNEY
not in the sun?
LAVETA BONNEY
LAVETA BONNEY
when is the best time to put stain down?
Deb
Deb
What is the best transparent oil based stain to put on a new,pressure treated lumber, deck that gets a lot of very hot sun in the summer?
Minda
Minda
My questions are: How should the porch floor be prepped to be redone, meaning repainted, or stained, whichever would be best? I’m pretty sure it can be sanded down to bare wood. Should it also be power washed.? What would be the best product as I’d like to have the product matched to a a BM color, Rockport Gray. What do you think of California Paints, Enduradeck Storm System?
1. New Wood or Older Wood? Older wood
2. Does the Deck have a Current Coating? Yes, chipping and flaking porch paint
3. Are you Switching Brands of Deck Stain or Applying a Maintenance Coat of the same Brand and Color? Switching n/a
4. Deck Stain Brand Previously Used? Enter unknown if you do not know. unknown
5. What is the Current Deck Stain Type? Oil-based or Water-Based? Clear, Transparent, Semi-Transparent, Semi-Solid, or Solid Stain? I believe it is acrylic porch paint over very old lead paint.
6. Mold or Mildew Issues? Some
7. Reason for Previous Stain Failure? Age, improper care, exposure to weather in northeast
8. You Must Include Picture(s) of the Current Condition.
Wil
Wil
Hi, do appreciate your site. Easy to read with constructive information!
Within the last few weeks had a new cedar deck build, in central Texas, which was stained using Sherwin Williams 3502 semi transparent water based stain. Some drops of stain can be found along the railing and look very much like a solid because of insufficient penetration. Some people are giving advice to apply a 2nd coat immediately but am concerned this will not penetrate and look like a solid. Should I apply a 2nd coat and if so am I better of applying a transparent stain instead of the same semi transparent or maybe a completely different product?
Have you reviewed Pittsburgh Paramount deck stain/sealer yet?
Thanks! After reading your reviews I think I’m going to go with the Restore A Deck stain. I do have one question. I just stripped off the old acrylic stain on our deck, using Wolman deck stripper ASR, and was wondering if after sanding down the rough spot would it be ready to stain? We bought this house a year ago so I have no idea how old the deck is but the wood looks to be in decent shape.
One last question. I put on the first coat of restore a deck, should I put on a second coat? It looks great now? Does it matter when you apply the second coat? It’s been a day.
Sorry, absolute last one. I have a 2nd story deck. Should I stain underneath? Previous owners did not.
Does Restore A Deck need a sealant later? Just rained here and the water isn’t beading. Is it suppose to?
Thank you so much! You’ve been very helpful
Dave Brown
Dave Brown
When trying to match old wood with new will a semi solid stain be similar to a solid stain ?
Will the semi solid stain be easier than the solid stain to remove after 2 or 3 years ?
Dave Brown
Dave Brown
Sure, some difference just as I thought…its the Home Depot web site that implies that either one would make a good blend in between the new boards and the old ones.
Thanks you’re a busy guy
Dave Coulter
Dave Coulter
30yr old House that’s been stained 15 times with Olympic semi transparent natural tone redwood.Would like to put on a better quality semi transparent stain what would you recommend that would be compatibly with Olympic? I’ve scrubed the house with wood brighter.
Cyn
Cyn
Hi
I have 30 year old Olympic semi transparent alkyd/oil deck fence and siding stain on my cedar house siding. Can I stain over top with another type of semi transparent that won’t peel off?
Sue
Sue
Treated lumber has not held semi solid Cabot stain. Can Behr solid be used overtop after 4-5 yes? Both stains water clean up.
George Chacon
George Chacon
do some, water base semi- transparent stains darken in time with ceder?
JLIHANEY
JLIHANEY
Can I mix Cabot Australian Timber Oil (Jarroh Brown) with Penofin Red Label Brazilian Rosewood oil (transparent Redwood cedar)? I have a 1/4 can of each and a small project. If I mix them, I’ll have plenty, but not enough individually.
Barbara
Barbara
I have a 22 year old ironwood deck with pressure-treated vertical posts and risers. I think it was sealed with a semitransparent stain when new but has not had any treatment since then. I just cleaned the deck with a homemade diluted oxygen bleach (Oxiclean) and Dawn detergent solution and it looks good. I am frankly fine with the natural graying of the ironwood and the natural color of the pressure-treated vertical elements. But I wonder whether I need to seal the vertical pressure-treated surfaces, which do show some cracking, even if I do not seal/stain the ironwood. Aesthetically I am fine with the appearance but want to make sure I am not ignoring important maintenance with regard to the longevity of the deck.
Barbara
Barbara
Thanks for your swift reply! I guess if I treat the upright elements I should also treat the ironwood horizontal elements, and then allow it to age naturally again. I imagine re-treatment of the vertical pressure – treated parts would not need to be done very often, but do you agree?
Tracy Hager
Tracy Hager
One more question… is Armstrong Clark or TWP Stains good for the Pacific NW Climate? Lots of rain at time , less sun etc. Moss…
Andrea
Andrea
Have a 14 year old pressure treated deck, covered but obviously outer edges see tons of sun. It is our main entrance to the house so used a lot. Received bad advice 5 or 6 years ago – had semi transparent oil (think it was cabot) originally and restained it every couple years with the same stuff. Wanted to try something new, Lowe’s suggest a water based stain. Not positive if it was solid or semi solid but it pretty much covered everything. We didn’t clean or sand before applying and miraculously it lasted quite some time but has finally started peeling/fading, etc. We are in the process of power sanding everything, decided cost wise to replace the spindles with new (about 100 give or take) to save time as the rest is taking days/hours. The deck is 12 x 24. We have the railings down to bare, good looking wood but the floor isn’t quite so good. Understandable. We are belt sanding it and then using an orbital to get more off. Down to 60 grit now and going to try 40 as it’s stubborn. I can submit a pic if needed but wanted advice – the floor is some bare wood but also besides the pretty knots and grain there are spots that look wet (darker color)….would we be best to use a semi solid to cover? I hate to cover up what we’ve revealed, especially on the railings as they look brand new. Maybe semi transparent on railings and semi solid on floor? Husband wants to use a dark color to cover, I don’t. We are leery to use a cleaner or brightener as we have pets and free range chickens (we sell eggs) and don’t want to take ANY chance of ingestion of chemicals, even with watering down. Any suggestions, and recommendations on what brand of stain to use? I’m seeing fairly bad reviews on here of Cabot and Olympic and Thompson’s doesn’t sell semi solid. HELP!
Andrea
Andrea
Will add a pic later, thanks…
Andrea
Andrea
Reply to  Andrea
I posted pics but they’re not showing, any idea why? Was really hoping to get an answer soon as we have to order the brightener, etc online, no stores in my area carry such a thing, only cleaner. THANKS!
Andrea
Andrea
Reply to  Andrea
Pic 1 shows the railing after sanding, as stated above, it’s down to bare, clean wood – I personally don’t think it needs any brightening, etc. but it’s hard to get a good lighting picture. Pic 2 shows what we started with on left and after belt sanding with 40 grit on right. Pic 3 is after belt sanding AND sanding with the orbital, I think it looks darn good. Pic 4 is before sanding on top and after belt sanding on bottom, hasn’t been hit with the orbital yet. But, it’s with different lighting, all depends on how the sun hits it. I’m ok with using brightener if need be, let me know your thoughts. And please an opinion on what would work best – semi or semi solid? Could we get away with something other than dark brown? Or would a semi transparent dark brown be a good choice? I want to be able to see the wood somewhat, not clear by any means. Also, oil or water? What lasts better and is easier to clean/remove if needed in the future. Appreciate your help.
Andrea
Andrea
Thank you so much!!!! Those were two colors I was looking at actually (too dark for me but makes the hubby happy). Does anyone know if the rustic is too orangey? Trying to avoid that as that’s what we had before.
Andrea
Andrea
Very much appreciated – thanks for helping all us clueless people! Want it done right this time! We’ll probably go with the rustic brown (may order sample to be sure) and keep up with it every 2 years or so with cleaning. 🙂
Andrea
Andrea
Sorry, sorry, sorry! So you think a semi transparent would work ok rather than the semi solid? Hubby thinks semi solid but as I said above, I’d like to see more of the wood after all our work AND I think the maintenance is easier than taking the step towards solid, we would have to sand again if redoing.
Andrea
Andrea
Andrea
Andrea
Bill Knox
Bill Knox
In the past I used Cabot 3000 natural clear on my deck. It was not the blue top. I’he stripped off the old and ready to redo. What is your experience with the current Cabot line? Its been 10 years since I applied and I see there has been many changes.
Jerry Johnson
Jerry Johnson
Can you mix equal parts of oil base solid stain & oil base semi transparent stain
Robert
Robert
Since when? Why would you say No?
Robert
Robert
Well, I’m here to tell you you’re wrong. I have been mixing different types of stains and paints for over 45 years with no problems to speak of. I could argue about pigmentations and consistency of oil paints and stains all day. If you are a manufacturer, or a salesman, your answer will always be no it can’t be done. Until you do it yourself. Have faith, the sky’s the limit.
Sack
Sack
I have a dock on the intercoastal waterway.
1. South Carolina
2. Full sun
3. Pine wood pressure treated
4. No mold issues
5. Dock builder applied Thompsons I think.
What is the best way to protect the dock for the future…
Dako
Dako
Hi I live in Northern Minnesota I have used Olympic maximum stain plus sealer. Transparent natural cedar number 417. It says last 6yrs. Well it has lasted one and put on a second coat agin this year. And all ready the area that is walked the most is starting to wear away what do you reccomend for this? I love the color of olympic but the wearing away part is what frustrates me.
Luce C.
Luce C.
best black colored stain?
Sheryl McGuire
Sheryl McGuire
Reply to  Luce C.
Timbercare Para Ebony is as black as you can get and looks good years after application on my fence. There are no reviews of it on here. I am in Canada.
Kristi
Kristi
I cannot find a product that will remove a latex solid color stain from treated lumber.
Bonnie
Bonnie
Lowes quick selling Olympic Max stain and sealant We always used that in a honey gold. We tried the brand they sell now and it looks like baby poop. Any suggestion on where to find it.
Elsie & Huska
Elsie & Huska
Our Cedar deck is approximately 16 years old. We just finished scrapping and sanding off the Behr DeckOver that was applied and was peeling off in sheets. We would like to apply a clear water proofing on the deck. What would be recommended for the Cedar Deck. We are in Manitoba Canada.
Elsie & Huska
Elsie & Huska
Are these two available in Canada
Vincent Ciccarello
Vincent Ciccarello
I need a oil based deck clear for the pool area. I have a salt water pool, and the floor boards get wet a lot.
Annie
Annie
What is the quality of penofin verde stain? Is it recommended for a mahogany deck?
Annie
Annie
Can you use a water based stain three years after the application of an oil based stain?
David S
David S
Any thoughts on ABR X-100 Natural Seal Deck Finish? Went through a gallon of it and need to re-stain my deck and wondering if I should stick with this brand or try something different.
Andrea Neviackas
Andrea Neviackas
We used Benjamin Moore oil based mahogany flame on our mahogany deck three years ago and the odor was horrible and lasted a year! We have a toddler and infant now and really would like to minimize exposure to vocs. A few pieces are rotting out and we have to deal with something. What do you recommend?
Carol J Laux
Carol J Laux
I’m using TWP 100 series and I would like to know instead of using the bleach water solution they recommend for cleaning, could I use the Restore a deck cleaner /brightener instead? I am using this on 1 year old Cedar that has never been stained. It is for a dock. Is there a better product than TWP 100 series that I could use for the dock because the wood gets wet near the shore? Thank you.
Carol J Laux
Carol J Laux
Does the Germany 895 restore a deck cleaner come in two different boxes? They both say Gemini restore a deck but some are advertised as Gemini 895, but some are not advertised as 895. One store will have a different box advertised as 895, next store will have the same box- Gemini restore a deck, but does not say 895. If the box is different but as long as they are Gemini restore a deck cleaner is this the right product?
Sarah
Sarah
Planning on staining a pergola that was built by previous owners- built approx 3/4 yrs ago. I want to stain it black and am looking for a solid black look. After reading reviews will stay away from Behr (thank you) who I initially was going to go with.
Recommendations on brand I should use.
Located in Ontario, Canada.
Should note pergola is in the sun 99% of the day
Details painting
Details painting
Reply to  Sarah
A solid black stain calls for an oil primer first.
Ruby Vice
Ruby Vice
You don’t want the Olympic Maximum Stain-Sealer. It peels and separates in 6-8 months. I didn’t read the fine print on can so did not know to put 2 coats on. It is supposed to be guaranteed for 10 years on decks, and 25 years on fences. When I called today to file a warranty complaint their excuse it was supposed to have 2 coats. I believe it would still have peel off with 2 coats. I am not able to do this work myself and can’t afford someone to come scrape and apply 2 more coats. They are only going to reimburse me the price of product used. Never again will I buy any Olympic products.
Alissa McCall
Alissa McCall
I have painted my decks for the last 15 yrs with Thompsons water seal Deck and House oil stain. I have used the solid stain in a pewter gray. It peels on the horizontal surfaces every year like paint would and I usually have to redo the tops of the railings and the deck surface every year. Last year they stopped making the product. This year I am looking for another product that I can put over it hopefully to match the same color so I don’t have to do the entire deck. Someone at Lowes told me that there is nothing I can put over it because it had a wax base. Do you know if he is correct or if there is a product out there I can use? I am not sure if the person at Lowes was familiar with the product I have been using.
Zulfi
Zulfi
Help! I am from Toronto and would like to Stain my deck which can last really longer. I have looked for options like Armstrong but the colors are limited in Semi Transparent. Please suggest me few names that can last longer and have tons of color options to pick from.
Ruby Vice
Ruby Vice
Reply to  Zulfi
Don’t get Olympic. I recommend sticking with old faithful Thompson’s Sealer.
Marla
Marla
Hi There! Just built new deck. We will be using a semi-transparent stain probably. I’m worried about the deck being too hot for our dogs feet, as well as ours lol. Can you help? Is there an extra coating? Something we could mix into the stain we will use ? Thanks so much!
Eva Lanczos
Eva Lanczos
We had our patio completed last August. The contractors had the cedar in our driveway months before they started the work, so the cedar was already damaged by the time the actual construction started.
In addition, after completion, they informed us that staining wasn’t included in the price. Because of our busy schedule, we haven’t been able to stain the patio at all.
As you can see on the pictures, we have water stains, faded posts and facade, and sap stains (?). As of yesterday, we also have the pleasure of hosting carpenter bees. We are now ready to stain and looking for your guidance as to how to best clean and stain our patio. Thank you very much! Eva and Allen
Deck Location State: Houston, Texas
Full Sun, Partial Shade, Full Shade: Full Sun
Wood Type: Western Red Cedar
Mold or Mildew Issues: Only water stain
Reason for Previous Stain Failure: None
Eva Lanczos
Eva Lanczos
Should we use Restore A Deck cleaner as well on the entire patio or not necessary if we apply wood brightener to all wood? Thank you!
Kiki
Kiki
HELP!!! I have a 20 yr. Old deck which is treated pine. Approx. 3 yrs ago I used Behr solid in a dark gray on it. Within 2 weeks it was seriously peeling. I called the manufacturer and they said I had to strip it all of and redo it. I waited a year or so and redid it with the same stain. Horrible stuff! Peeled within a week and now a lot of it is off but there is still alot of stain that would not powerwash off. Most of the upright/ verticals are still decent. We are now replacing the railing and using hog fence/goat fence instead of spindles. What can I Do? My deck is 74ft. Long by 10ft with a 14×10 extension so I really don’t want to have to keep redoing it so often. Also can I leave the post and stain over them or paint them in a Matt black? Desperate for advice. I live in Michigan. Lots of snow, hot sun in summer until approx. 2pm. Also will a stripper work? What kind, where to buy and will it damage cement patio below.
A.Novick
A.Novick
Large deck in NJ 8 years, part full sun, part shade, used Behr semi transparent water-based that applies/dries like semi- solid (as mentioned elsewhere on your site) and peels miserably. I power washed / lightly sanded last year and reapplied same stain. Of course, came out blotchy and is peeling worse than ever. Am skeptical that I can get back to bare wood so I can apply a proper semi-transparent stain. This was confirmed by pro deck guy who wants to sand and apply sherwin williams solid. Really don’t want to go the “paint” route… Looking for advice.
A.Novick
A.Novick
Yes, I guess I’m asking in your expert opinion if it is really possible to fully remove the Behr stain or if you agree with the pro deck guy that said it’s impossible and to just stand as much you can you and then use a solid stain.
A.Novick
A.Novick
Here are some pics – thanks
A.Novick
A.Novick
Arghh stupid Behr stain!!!! Thanks for advice. So I’ll sand and go with a solid stain.
Deloree Burd
Deloree Burd
New deck in the pacific northwest, Washington State last year with alaskan yellow cedar. Used Behr deck and siding stain, which has done well in the past. entire deck has peeled/ gooey and is blotchy.. in process of power washing…deck is over 1200 SF …so disappointed. Power washing only getting portions… seemed like stain never was absorbed by the wood. Is it a stain product problem or type of wood or both….really want to get it right this next time.. suggestions for removing and then what stain to use. I heard there are two types of oil stains….plant based and petroleum based
Pine deck is about 2.5 years old and was stained with Ready Seal 1.5 years ago. Horizontal surfaces show no stain color anymore. Will the cleaner and brightener be enough prior to staining with RAD or will I need the stripper?
Gus
Gus
We just had a new deck built over the weekend. We live in Arkansas. It is just a plain flat 338 Square foot deck. What would be the best stain to use? Want as little maintenance as possible, but we want a darker brown color to match some wood pillars we have on our adjacent porch.
What is the best way to apply?
Gus Leeper
Gus Leeper
So for 338 square feet i need about 2 gallons? What would you recommend i apply with?
We were shopping for a stain that got good reviews and found your article. Please help with advice on best stain to purchase for our house! We live in The southeast and have a cabin with exterior siding of cypress wood. It has been weathering for several years without any finish. We also have a covered front and back porch with a wooden wheel chair ramp off the back porch, so lots of wooden surfaces to cover. Our contractor is recommending Behr stain. We are retired and want something that is low maintenance, won’t peel, protects the wood and easily reapplied when needed. What would you recommend and should we use a different stain for siding and porch floors since they get a lot of wear? Also can the contractor use a sprayer for TWP? Thanks in advance for your help!
Jacob
Jacob
So my deck is all prepped, Armstrong Clark chestnut arrived in the mail yesterday. Cloudy skies…ready to stain! Question is…what is the fastest way to stain? Can I use a pump sprayer and then have my wife come behind me with a big wide brush to stroke the oil in good? should I roll it? or use my Graco sprayer?
Jacob
Jacob
update: Used pads and brushes, went on good! love armstrong clark! Weather was good but horrible luck had a pop-up rain cloud come through at 8pm! it’s raining on my freshly stained deck I did at 2 pm? crap…what’s going to happen? What can I expect?..
Only thing I will say is that I feel it dried before the rain came. I noticed on this website and a label on the AC gallon containers to not over apply…so I didn’t. If anything I would say I under-applied. I didn’t even use 2 gallons on a 414 sq ft deck. It still looked great after staining it though. This might have helped it dry very quickly before the rain came. Thoughts? ..
Jacob Kuehl
Jacob Kuehl
It only rained for 30 min. I just went out and squeegeed off the standing water, lots of wind tonight, should dry fast. Fingers crossed.
Frank
Frank
I’m at Lowes’s now and I have no idea what to buy. I live in New Jersey and my deck is only around 300 sq ft. I replaced it with new pressures treated wood/deck. What’s the best thing I can buy here at Lowe’s? They have Thompson’s, valspar, Cabot, Australian Timber Oil. How much do I need to buy? A gallon good for 300 Sq ft? I want something that can last me a long time and less maintenance. I want to stain and seal combination, no resurface as I had that and that is the reason I’m pull every single deck board out and replacing it with new ones. Should I get semi-solid or semi-transparent? Your reviews shows semi-solids is better in terms of pros and cons but semi-transparent is your favorite. Which one should I buy?
frank
frank
What do you recommend? I just found your website while standing at Lowe’s trying to google what to buy.
Lynn
Lynn
Can the these stains be used on a children’s wood playground set?
erin
erin
So, exactly what brand and type is TheBEST OIL-BASED product??? I want an old fashioned oil product that deeply penetrates the wood and cleans up with Mineral Spirits or Turpentine.
Carolyn
Carolyn
I have a nine year old deck made out of Southern Yellow Pine L-3 pressure treated wood (Wolmanized). It currently has a Penofin stain on it. If I have the deck power washed and brightened, can I use the TWP stain on it? Will TWP adhere and last for the 2-3 year expectancy on pressure treated wood? I live in sunny Colorado.
Carolyn
Carolyn
Yes, all of the penofin will be removed. I guess I’m wondering if TWP would be the best stain to use on pressure treated wood. Have there been any issue with TWP and pressure treated wood? Some stains (Messmer’s) are made for pressure treated wood. Do you recommend them over TWP?
Lena
Lena
Northern facing deck on the beach built one year ago in SE Virginia. Deck boards are composite. Wanting to stain the pine railings white. Solid vs semi? And what is the best choice of brands for coastal salt/weather?
William Wright
William Wright
What is best manuf for Flood Pro Seies white stain?
Carole
Carole
Located on the Jersey shore. Can you recommend a good product to use on a mahogany porch?
1.4K
