🏆 Top Picks Summary
Top Oil-
Based Stain
Top Water-Based Stain
Top Solid Color Stain
Easiest to Apply Stain
*Free Shipping Included
✅ How I Rate Deck Stains
  • Ease of application
  • Wear and tear after 2 years
  • Oil-Based:
    • Deep penetration
    • Easier maintenance
  • Water-Based:
    • Better UV color retention
    • Faster drying
1. TWP 100 Series
2. Armstrong Clark Wood Stain
3. TWP 1500 Series
4. TWP Pro-Series Semi-Solid
3. Defy Extreme Stain
  • Durability: 2–3 Years
My Test Deck Stats
Deck Square Footage: 2100
TWP Cedartone Natural 101
Price range: $58.99 through $68.99
Price range: $219.95 through $245.95
5.00out of 5
Price range: $270.00 through $296.00
5.00out of 5
Price range: $285.00 through $311.00
5.00out of 5
My Test Deck Stats
UV Exposure: 50% Full Sun
Light Walnut
$51.99
My Test Deck Stats
Deck Square Footage: 600
UV Exposure: Full Sun
 Semi-Transparent Cedar
TWP Semi-Solid Stain
  • Durability: 3 Years
  • Maintenance: Moderate
My Test Deck Stats
When Tested: August 2023
Deck Square Footage: 800
UV Exposure: Deck in full sun
TWP Semi-Solid Cedar Mulch
$73.99
5.00out of 5
$294.95
$87.99
$374.95
TWP 1500 Series Rating
  • Maintenance: Easy
My Test Deck Stats
Deck Wood Type:  Cedar
Deck Square Footage: 400
1501 Cedartone
$63.99
$244.95
$295.00
$309.00
  • Durability: 1.5–2.5 Years
  • Maintenance: Easy
My Test Deck Stats
Chesnut
$109.99
Defy Extreme Stain Review
  • Durability: 2 Years
My Test Deck Stats
Cedartone
$59.99
$269.99
Ready Seal Wood Stain Review
  • Durability: 1-2  Years
My Test Deck Stats
Natural Cedar
Cutek Extreme Oil
  • Type: Penetrating Oil
My Test Deck Stats
Deck Square Footage: 1000
How Many Years Tested: 1 Year
Walnut
Cutek Extreme Oil
CUTEK-Extreme Premixed-Sample
Semi-Solid Deck Stain Review
Best Deck Stain for Old Wood
✅ Deck Stain Types Explained
Transparent Stains
Transparent Deck Stain
Semi-Transparent Stains
Semi-Transparent Deck Stain
Solid (opaque) Stains
Solid Color Deck Stains
2. Long-Term Durability
3. Deck Condition
4. Climate Concerns
  • Over-applying stain
  • Skipping prep
✅ Best Deck Stain FAQs
Quick Tip:
What is a deck stain?
⏳ Durability & Maintenance
🎨 Appearance & Color
🛠 Application & Usage
🆕 New Deck Questions
  • Smooth wood: Wait ~3 months
  1. Deck Location: Michigan
  3. Wood Type: Cedar
  4. Mold/Mildew?No
5 348
4 28
3 4
2 2
1 5
0 2
30.8K Comments
13 years ago
What is best stain for me:
Sun: Full afternoon sun
Wood type: Cedar
Mold or Mildew issues: Yes
Reason for stain failure: New Deck
Willie
Willie
13 years ago
Deck Location State: Georgia
Full Sun
Mold or Mildew Issues: Yes
Reason for Previous Stain Failure: Grayed, lost sheen
Willlie
Willlie
13 years ago
Can it be applied over a Cabot semi-transparent stain (applied 2 years ago) after thorough cleaning? Do you know it TWP is available in middle Georgia or Atlanta?
Willlie
Willlie
13 years ago
Thanks for your help! One last question — How does the TWP 100 compare to the TWP 1500
Manish
Manish
13 years ago
Deck Location State: Los Angeles (CA)
Full Sun, Partial Shade, Full Shade: morning sun
Wood Type: new redwood 2×6 planks (all pink, very little white)
Mold or Mildew Issues: No (mostly very dry weather)
Reason for Previous Stain Failure: New
Very confused with what to use to preserve the color and deck quality. Leaning towards oil based sealer with minimum stain the first time to enjoy the natural color and then stain it when it gets old (next year I guess).
Plan to install in 2 weeks – so should I coat before installation on all sides or just the top and sides? If just the top and sides what about the bottom?
If the products are so good – why are there no dealers/retailers around? It would be very convenient to get them and try out without waiting.
Loras
Loras
13 years ago
1. Eastern Iowa
2. Full Sun until mid – late afternoon
3. Pressure treated pine on floors and cedar posts and railings (5.5 years old)
4. No mold or mildew
5. Pressure washed and used SW Deckscapes Waterborne Semi-Transparent Cedar Bark SW3511 under two years ago. Now peeling and fading with no water beading anywhere. Looked good only for the first year.
Thinking of using TWP 100 in Pecan 120 and Restore-A-Deck stripper and brightener. Recommendations and advice?
Loras
Loras
13 years ago
Reply to  Loras
Fortunately the spindles are aluminum and not wood. Just have the 4×4 posts and upper and lower railing to strip.
Eric
Eric
13 years ago
Connecticut
Southern side-full sun (near inground pool)
Pressure treated pine – 4 years old
Mold and Mildew are a frequent issue- keep power washing away
Dark mold and mildew keep appearing- originally used Cabot oil based stain. I am really looking for something to use after washing the deck that will help with this unsightly mold and mildew. Is there a stain that will work or do I need a sealer of some sort with fungicide additive? Thanks in advance for any guidance.
Eric
Eric
13 years ago
Thank you but will I have a problem putting a water based stain over an oil based stain? Are you suggesting just cleaning the deck or actually sanding it down? Thanks
TFerr
TFerr
13 years ago
1. South Eastern Pennsylvania (Reading Area)
2. Full Sun
3. Wood Type: Pressure Treated Pine (unstained)
4. Mold or Mildew Issues: None yet
5.Three decks face south; Deck 1) built summer 2011 – 900s/f, but a portion is this deck is covered by a 16 x 20 pavilion. So this section would be considered part shade. Deck 2) built summer 2012 – 200s/f, also has a flight of stairs leading from from small deck down to the larger deck. Deck 3) 13yrs old. 12' x 14', in the summer of 2013, I will be replacing all deck boards and banisters to match the two newer decks, (PT Pine). We would like a semi-transparent covering. What cleaner/stain do you recommend? What kind of prep will be involved for all three decks? How frequently will the decks need to be recleaned and stained? Should I wait to stain the 3rd deck, (summer 2013 project mentioned above), until summer 2014?
Jeff
Jeff
13 years ago
I would appreciate a recommendation for Tigerwood to be installed at a ceiling and as wood siding on a building. Project is located in Austin, TX. Obviously the ceiling material will not receive any direct sunlight. The wood siding will be in shade, shadow, or in direct sun.
I would appreciate any advice you could give.
Ed Maxwell
Ed Maxwell
13 years ago
1. East coast Florida (near salt water)
2.Full Sun
3.Wood Type: Pressure Treated Pine
4.Mold or Mildew Issues: Yes
5.All new deck
Would prefer a semi-transparant oil stain.
Robin
Robin
13 years ago
US Virgin Islands
Mostly Sun, one shady part that is susceptible to mildew; next to pool
just replaced- new pressure treated pine
no mold yet
no treatment yet
thanks!
Robin
Robin
13 years ago
We have a home depot and a couple of local places (not sure what the local places carry). May be possible for a local hardware store to place a special order. Could you give me a preferred stain and then maybe one that is carried by home depot just in case?
Robin
Robin
13 years ago
Ok, here's what I found at the biggest local store: Olympic Water guard, Thompson's waterseal, Ace Sealtech, Woodlife classic, Flood CWF-UV, Cabot, Ace Wood Royal.
Anything worth looking at?
Robin
Robin
Robin
13 years ago
thanks!
George
George
13 years ago
Texas
Full sun some covered areas
12years old
Some mold
Never stained
Cyrus
Cyrus
13 years ago
Deck Location State: Florida
Full Sun, Partial Shade, Full Shade: Full to Partial Shade
Mold or Mildew Issues: Not Yet
Reason for Previous Stain Failure: New unstained deck, 8 months old.
Darryl
Darryl
13 years ago
Installing a new deck around pool with pressure treated pine (2×6). Full sun. Live in Florida Panhandle. I have routed the edges and sanded. Would like product that shows grain but protects well (semi transparent stain?) What product would you suggest? If I should wait a few months before applying, would I need to clean the wood? Thanks
Nicole
Nicole
13 years ago
1. Indiana
2. Full Sun in summer Shade in the winter
4. yes
5. Peeling, no more stain in high traffic areas
13 years ago
1.Deck Location State: South Central Pennsylvania
2.Full Sun, Partial Shade, Full Shade: Full Sun
4.Mold or Mildew Issues: Slightly green/yellow where deck blocks some sun on steps
5.Reason for Previous Stain Failure: Flood CWF-UV Clear
Brand new in Jan 2007. Moved into home Nov 2007. First stained in June 2011 with CWF-UV Clear after pressure washing deck and allowed to dry. Applied with brush. Never really had water bead up on surface so I think wood soaked it all up. One coat applied. Want something that is going to look nice and last. Deck is 12×16 with 2 sets of steps to pool deck. Thanks.
13 years ago
I am going to refinish my deck this Spring. However, I just had a exterior, clear cedar, beautiful wooden gate, made and installed. Is deck stain advisable for a gate?
Frances
Frances
13 years ago
1.Deck Location State: Indiana
2.Full Sun, Partial Shade, Full Shade: Partial shade
4.Mold or Mildew Issues: no
5.Reason for Previous Stain Failure: never been stained
Angel
Angel
13 years ago
1.Deck Location State: Florida
4.Mold or Mildew Issues: Yes (there is marginal mildew on the base of the deck)
5.Reason for Previous Stain Failure: Purchased home not sure , but currently the deck is in need of stain. Grey colored wood, needs to also be sanded.
Texas Stines
Texas Stines
13 years ago
My problem is not with a deck but with wood accents on a 5 year old house. I have about eight very high decorative beams that stick out on the front of the house as well as four pairs of decorative wooden shutters made from cedar. Based upon the recent construction in the neighborhood, it appears that the shutters and beams are stained very soon after installation with little or no prep. A discussion I had with a builder rep leads me to believe it was probably a Behr stain that was used but I can't be sure. We need to seal and protect the beams & shutters. The exposed top of the beams will eventually be covered by a flashing of some kind to prevent further decay as recommended by our home inspector. We want to stain the beams and shutters a medium-dark brown with just a little red in it. Since these features are very difficult to get to, we want something that will penetrate well and last several years before we have to repeat the process. Ideas?
1.Location State: Texas
2.Full Sun, Partial Shade, Full Shade: Intense Full Sun in afternoon
3.Wood Type: Cedar shutters and pressure treated 4 x 4 timbers
4.Mold or Mildew Issues: Maybe
5.Reason for Previous Stain Failure: Peeled on shutters and tops of beams but bottom & sides of beams appear to have color.
Jake
Jake
13 years ago
Live in Mesa, AZ. Deck is cedar wood, covered but gets partial west sun. There are no mildew problems, but previous stain/sealer turned dingy gray. We power washed deck down to original wood and would like to know the best sealer to keep the natural beauty of the wood and shine. Any other advise would be appreciated
Randy Berg
Randy Berg
13 years ago
Southern Indiana
Full sun
New deck – I don't know if there will be a mildew problem. Ground stay wet in the yard, so probably yes.
No previous stain failure – new deck.
Premium lumber with nice grain that I don't want to cover, but I don't want to have to refinish too often.
Barbara
Barbara
13 years ago
I have white pine wood slab steps on an outdoor stair well. Location South Carolina, full sun. Best product for clear stain, no peeling ,
MVT
MVT
13 years ago
what are the best deck stains for my deck
Tink
Tink
13 years ago
Conditions: half deck in shade; half deck in full sun during summer with a lot of rain
The deck is approximately 15 years old. Deck has previously been treated with a product like Thompsons; most recently by a Cabot solid stain that has failed.
I am having the deck stripped. I am also replacing the railing system. Once we are completed we will have some new pressure treated wood in railing and the older wood on horizontal surfaces.
I was considering Penofin, but after more reading I am thinking TWP 100 in honey, pecan or cedar might be a better choice.
I want to make sure the product can be re-coated easily as the decking exposed to the sun and rain takes a beating.
Ann B
Ann B
13 years ago
North Carolina
full sun
rough cut locust – split rail fence
built by wood on farm and want it to last a lifetime or longer
want stain and sealant for best protection
Ann B
Ann B
13 years ago
Should the minor graying be removed before the stain is applied?
S. Burgess
S. Burgess
13 years ago
1. South Carolina
2. Full Sun
3. Pressure Treated Pine
5. Previous stain now very faded and turned grey
Deck is about 6 years old. Stained by previous owner probably about 4 years ago. Very faded. Original color was red. Would like to stain with something close to dark brown.
S. Burgess
S. Burgess
13 years ago
Any need to strip old stain off, or do you believe pressure washing and using restore-a-deck would be sufficient before applying the new stain. If there is red stain still on the wood, do you believe the TWP 1503 dark oak will cover up the red? Thanks.
Carissa
Carissa
13 years ago
1. Washington State (Seattle)
2. Full Sun
3. Wood Type: Unknown – assuming some sort of Pine.
4. Mold or Mildew Issues: Yes
5. Reason for Previous Stain Failure: Bubbled and peeled
I am looking to re-stain the deck a darker color (walnut, dark oak etc) and paint the railings white… any suggestions are greatly appreciated!
ivan
ivan
13 years ago
Deck Location State: Atlanta, ga
Full Sun, Partial Shade, Full Shade: Partially full sun
Reason for Previous Stain Failure: No previous stain
I also would like some pro and cons of staining the deck white. thanks
Trevor
Trevor
13 years ago
Deck Location State: Tacoma, Washington
Wood Type: Pressure Treated, Fir (I am guessing)
It is actually for a swing set. Something that won't hurt the kids, if they get hungry…
Tim H
Tim H
13 years ago
Location – North West Alabama
Boat dock on the Tennessee River
Full sun with a cover over the boat slip
Existing dock with new replacement decking.
The old wood decking was cracked and splitting.
The stain needs to be a light color or clear so that it does not get too hot to walk on in the summer.
Brent
Brent
13 years ago
Northwest, (Eastern Washington)
Full Shade and Full Sun
Pine 20yrs. old
No Mold issues
Deck was installed a little over 20 years ago and then never sealed again.
David Wietlisbach
David Wietlisbach
13 years ago
East Tennessee in the Mountains.
Full to Partial Shade. Shade during mornings and afternoons from the surrounding trees
Some Algae and Mildew
Reason for failure: High traffic from Dogs. Plus the combinations of leaf debris and then mud tracked by the dogs clog the cracks between the planks which can then stay damp for days when the sun is not out.
I will be pressure washing it this spring and then wanting to use the best stain possible.
David,
Townsend, TN
Dave Parkinson
Dave Parkinson
13 years ago
Deck Location State: North Carolina
Reason for Previous Stain Failure: Peeled and flaked
Matt M
Matt M
13 years ago
1.Deck Location State: Jacksonville, Florida
2.Partial Shade
3.Wood Type: Pressure Treated I believe but not sure due to the fact the deck was stained when it was built about 3-4 years ago
4.Mold or Mildew Issues: Yes, on the railings around the deck and anything else in a vertical position, everything else is fine. The deck is built around 3 big live oak trees.
5.Reason for Previous Stain Failure: Not sure of reason except for maybe lack of maintaining it over the years. It's a bit greyish with some mold. The deck looks weathered. I think the deck is very much still salvageable but just needs a little TLC. Everything is still sturdy not rot or anything. Just want to know the bes product to renew it and how to go about it. I was thinking pressure washing then stain/seal
trackback
[…] most popular article, “What is the Best Deck Stain” has become the most #1 article for consumers on the Internet for deck stain questions and […]
bigdogmom
bigdogmom
13 years ago
I am having new (untreated) pine vertical board & batten siding installed on an entire house in the Colorado mountains…high altitude, lots of sun and snow. Am considering TWP stain but it advises to let wood "weather" before application. I don't want to leave the wood unprotected in this environment. What, if anything, can be used to preserve and/or treat new wood? Contractor recommends a product called Lifetime…supposedly a "lifetime" product. Ever heard of it?
Connie
Connie
13 years ago
Memphis TN
Partial Sun/Shade (mostly shade)
Pressure Treated pine (possibly)
Mold/Mildew is an issue
15+ yrs old. (It had been previously treated before we purchased, and we treated/stained it approx 10 yrs ago…not positive on whether oil or acrylic stain was used previously.)
Robert Dixon
Robert Dixon
13 years ago
North Carolina
Full sun for third of day, shaded by trees rest of time
New deck – 3 months old
13 years ago
Location = North Florida
Partial Shade
New PT Pine
No mold/mildew issues (Yet)
New Deck
Heather
Heather
13 years ago
Wisconsin
Full shade
Treated lumber
New build deck.
I would like a darker color look?
Pattie
Pattie
13 years ago
1. Location Cary NC
2. Morning sun with shade in afternoon
3. Pressure treated pine 25 years old
4. Mold and Mildew is an issue
5. Don't know what the previous stain was, well worn off in last 8 years. Has been power washed.
Will
Will
13 years ago
Guerneville, CA
What would be the best stain to use for my redwood hiking sticks? They will get used a lot so they need good UV protection as well as water protection.
Liz
Liz
13 years ago
“the best deck stains for my deck”? I live in the PNW and have mostly rain 10 months of the year. I let Dunn Lumber talk me into Pennofin and two months later I have mildew in my new cedar deck. What's a girl to do?
Sam
Sam
13 years ago
St. Louis Missouri
Full sun
Pressure treated cedar
Possible mildew issues
New deck
kramerella
kramerella
13 years ago
1.Deck Location State: Central New Jersey
2.Shaded by roof, but edges and steps bake in the sun for part of the day
3.Wood Type: Brand new mahogany floor – being laid this week
4.Mold or Mildew Issues: No
5.Reason for Previous Stain Failure: This is a brand new deck on a 175 year old house. Keeping original support beams where possible and original design. Want a historic look, but would rather stain than paint the flooring.
Heavy traffic on deck – has entrance we use. Two dogs that will tear around on the dog every day.
gary davis
gary davis
13 years ago
BRAND NEW deck in central florida built to match 6 month old dock on fresh water lake.
1.Deck Location State: Orlando, Florida
2.Full sun year round after approximately 11AM
4.Mold or Mildew Issues: No, but we are lakefront.
5.Reason for Previous Stain Failure: This is a brand new deck and dock thats 6 months old.
the one thing to note is that the dock was completed this past May when we purchased the home. the deck was just completed to match and we will be looking to pressure wash and treat the dock to lighten it for stain. we are after clear stain not solid.
gary
gary
13 years ago
I did some Googling, and it looks like The Sealer Store (Defy Stain) sells the TWP Stain brand, and has separate websites set up for whatever reason. this seems a little suspect to me.
Louann
Louann
13 years ago
We recently purchased a home on the Texas Gulf coast that has an extensive pressure treated covered deck although the deck faces south and gets a great deal of sun. The deck rails and stairs and the fencing are also all pressure treated wood (probably pine). All the wood is a lovely weathered grey, but it does not repel water (water does not bead) and there is one area where I think something was spilled and which now is much darker (almost black) than the rest…I'm thinking it's mold or mildew of some sort. I am not sure what, if anything, was ever applied to the deck. The deck, stairs and rails are 15 years old, the fence is newer, approx 5 years. I would like to seal all of it in some manner to make it more water/weather proof and to extend the life, but would like to keep the weathered look. Is that possible? What products would be best for this area? It was close to 80 today, so I think we can work on it now.
13 years ago
Deck Location State: WA – Seattle
Full Sun
Wood Type: New Ipe
I noticed you recommend TWP, A-C, Ipe Oil but not Penofin which is the only one of these available by retail around here. Curious what you think if Penofin. I've used it before on furniture without problems other than persistent odor for weeks if not months.
Mike Walker
Mike Walker
13 years ago
Deck Location State: COLORADO
Reason for Previous Stain Failure: Peeled and turned dark in color
Darius
Darius
13 years ago
Please advise what sealer/stain I should use for my deck:
1. Deck Location State: California (San Francisco Bay Area)
2. Full Sun, Partial Shade, Full Shade: Full Sun
3. Wood Type: Redwood
4. Mold or Mildew Issues: Some
5. Reason for Previous Stain Failure: This Is A New Deck
GeraStanovich
GeraStanovich
13 years ago
Boulder, Colorado
– High altitude = more uv protection?
– Winters are sunny and dry with occasional snow and ice that melts quickly (Freeze/thawing cycles)
Full Sun
– No awning, or trees to shade the deck
Wood type
– Unsure, I think its Pine.
– No
– Poor maintenance. Prior owner added the deck to the house in 2003 and refinished it only once in 2008.
1 15 16 17 18 19 263
30.8K
