🏆 Top Picks Summary
Top Oil-
Based Stain
Top Water-Based Stain
Top Solid Color Stain
Easiest to Apply Stain
*Free Shipping Included
✅ How I Rate Deck Stains
  • Ease of application
  • Wear and tear after 2 years
  • Oil-Based:
    • Deep penetration
    • Easier maintenance
  • Water-Based:
    • Better UV color retention
    • Faster drying
1. TWP 100 Series
2. Armstrong Clark Wood Stain
3. TWP 1500 Series
4. TWP Pro-Series Semi-Solid
3. Defy Extreme Stain
  • Durability: 2–3 Years
My Test Deck Stats
Deck Square Footage: 2100
TWP Cedartone Natural 101
Price range: $58.99 through $68.99
Price range: $219.95 through $245.95
5.00out of 5
Price range: $270.00 through $296.00
5.00out of 5
Price range: $285.00 through $311.00
5.00out of 5
My Test Deck Stats
UV Exposure: 50% Full Sun
Light Walnut
$51.99
My Test Deck Stats
Deck Square Footage: 600
UV Exposure: Full Sun
 Semi-Transparent Cedar
TWP Semi-Solid Stain
  • Durability: 3 Years
  • Maintenance: Moderate
My Test Deck Stats
When Tested: August 2023
Deck Square Footage: 800
UV Exposure: Deck in full sun
TWP Semi-Solid Cedar Mulch
$73.99
5.00out of 5
$294.95
$87.99
$374.95
TWP 1500 Series Rating
  • Maintenance: Easy
My Test Deck Stats
Deck Wood Type:  Cedar
Deck Square Footage: 400
1501 Cedartone
$63.99
$244.95
$295.00
$309.00
  • Durability: 1.5–2.5 Years
  • Maintenance: Easy
My Test Deck Stats
Chesnut
$109.99
Defy Extreme Stain Review
  • Durability: 2 Years
My Test Deck Stats
Cedartone
$59.99
$269.99
Ready Seal Wood Stain Review
  • Durability: 1-2  Years
My Test Deck Stats
Natural Cedar
Cutek Extreme Oil
  • Type: Penetrating Oil
My Test Deck Stats
Deck Square Footage: 1000
How Many Years Tested: 1 Year
Walnut
Cutek Extreme Oil
CUTEK-Extreme Premixed-Sample
Semi-Solid Deck Stain Review
Best Deck Stain for Old Wood
✅ Deck Stain Types Explained
Transparent Stains
Transparent Deck Stain
Semi-Transparent Stains
Semi-Transparent Deck Stain
Solid (opaque) Stains
Solid Color Deck Stains
2. Long-Term Durability
3. Deck Condition
4. Climate Concerns
  • Over-applying stain
  • Skipping prep
✅ Best Deck Stain FAQs
Quick Tip:
What is a deck stain?
⏳ Durability & Maintenance
🎨 Appearance & Color
🛠 Application & Usage
🆕 New Deck Questions
  • Smooth wood: Wait ~3 months
  1. Deck Location: Michigan
  3. Wood Type: Cedar
  4. Mold/Mildew?No
5 348
4 28
3 4
2 2
1 5
0 2
30.8K Comments
Lou
Lou
13 years ago
Deck Location State: Connecticut, Fairfield County
Full Sun, Partial Shade, Full Shade: Full Sun facing the south
Wood Type: Not sure. Just moved into the house. Started stripping the paint on it this week. The floor is a light brown/yellow; the rails are dark brown/red. We heard the deck was built in the 80s. Structurally solid, so does the wood. No rotting on visible surfaces.
Mold or Mildew Issues: Minimal
Reason for Previous Stain Failure: The last homeowner put layer upon layer of paint on it and its cracking and peeling. Wanted to start with something fresh, but the process is painstakingly slow. I don't know if I'll ever get all of the paint out of all the nooks and crannies (it was a light green). Ideally I'd like to let the grain show, but if not, I might have to go with solid stain. What do you think?
Great website btw!
Deb
Deb
13 years ago
TWP 100 or 1500 series, or Defy Extreme (and why) for a 10 yr old PTP deck, located in Atlanta, GA, previous stain unknown, redwood color (that I want to keep). Deck hasn't been stained in at least 6 yrs. Some algae on vertical surfaces, and I assume some mold. Gets full sun during part of the day. Thanks.
Deb
Deb
13 years ago
Both of the deck restoration companies that I have contacted want to use TWP 200, which I thought was for cedar shakes and shingles, not PTP decking. Any reason you can think of that this would be the stain of choice – is it easier to apply than the 1500 series? Does it come in a redwood color? Also – is it safe to seriously sand the deck before resealing? One contractor told me that it would damage the protective coating on the screws since the portion of the wood that needs to be sanded is the soft portion in the "valley" of the grain & that it would be detrimental to the wood to sand as deep as you would need to for a deck that hasn't been resealed in at least 6 yrs. (I forgot what specifically he said would be the negative effect to the wood). Thanks!
13 years ago
East Tn.
Evening sun
11 yrs old
No mold
Stained two yrs ago. Stain just disapeared. Perped with pressure washer
Tom M
Tom M
13 years ago
Deck Location State: Ohio
Full Sun
Mold or Mildew Issues: NO
Reason for Previous Stain Failure: None, New pressure treated pine
Do I need to wait and let the wood weather before I stain it?
I also have a swingset I need to seal and stain. It's in the same location, and from the previous owner only a waterproofer like Thompsons was applied. The wood is treated southern yellow pine.
13 years ago
Rochester, MN
FULL sun
10 Year Old Cedar Deck
No Mold
Just bought House, floor of deck has been pressure washed, badly. Sides have some kind of semi transparent stain that is worn out, not sure what kind of stain.
Plan on Sanding Deck floor with power orbital floor sander
Lou
Lou
13 years ago
Just purchased a home with a great deck, but needs work!
1.Deck Location State: Connecticut, Fairfield County
2.Full Sun facing south
3.Wood Type: Don't know, but it was built in the 80's and structurally solid. The previous owner laid a few coats of paint over the stain and I've been sanding it down to bare wood, which looks light brown/yellow and in great condition. 4.Mold or Mildew Issues: mild
5.Reason for Previous Stain Failure: Peeling paint
We were considering going with semi-solid or solid to help cover up some of the residual paint (light green) in the crevices, nooks, and crannies. What do you think?
Lou
Lou
13 years ago
Reply to  Lou
Oh! While we're at it, any pearls to help get that paint off? It's stubborn…
Great site by the way! I've been on this since my research began. Great resource!
john
john
13 years ago
4 year old redwood deck in Southern California, 80% full sun. I used Behr semi transparent water based deck and fence stain that claimed to last 4 years on the deck. It started chalking and disappearing in less than a year. The deck was prepped properly and applied per instructions by manufacturer. Now I have cleaned with TSP and stiff bristle brush, followed with pressure washing. The wood is in good condition but still shows some of the old stain in areas that got less sun. Should I sand the deck complete or use a stripper and then wood brightener before staining? I want to use a darker color semi transparent stain, this time an oil base even though they may discontinue oil based products completely in California in the future. UV damage is the main enemy here, who sells the best quality stain that can be re-coated without all the prep I just mentioned???
DarrylW
DarrylW
13 years ago
Reply to  john
John, if you are in Los Angeles County or Orange County, Armstrong Clark stains do NOT appear to be available for purchase/shipping. However, because of the wood preservative rating the EPA has given TWP 1500 stains, TWP 1500 is available in those two counties. That has been my very recent (last three weeks) experience with an online stain vendor. I'm going to contact Armstrong Clark directly to verify this. I was able to have TWP 1500 stain samples shipped to me.
Katie
Katie
13 years ago
Seattle, WA
Full sun
Cedar deck – 10 months old
No mold or mildew
We installed our new deck last June and waited 2 months to stain the deck (we waited for a nice sunny run of weather). We used Sherwin Williams DeckScapes and after 4 months the deck started chipping/flaking. In high traffic areas the stain is almost completely worn off. We are planning on stripping the deck to start over this summer and in addition to recommendations on stain we would love advice on if/how long we should let the deck age without stain on it before attempting to stain again.
Katie
Katie
13 years ago
Thank you very much for your reply! What products would you recommend to strip and brighten given our situation? I'm assuming you recommend Armstrong Clark or Defy Extreme for staining. Thank you for your help!
Donna
Donna
13 years ago
Which stain and preparation products and process would you recommend? Thank you.
Southeastern Pennsylvania
Shaded, wooded lot (60-100 year old red oak trees -some hang over deck)
Pressure treated pine
Original deck is18 years old
New addition to deck is 5 years old
Original deck previously stained – don't know product
Original deck and new deck painted with Sherwin Williams Deckscape Solid – 2 years ago
Mold and mildew on the north side of the original deck near the house under the shade of the roof overhang
New deck addition – paint peeling
Donna
Donna
13 years ago
Is there a particular brand of solid color stain that you would recommend for this situation?
Michael
Michael
13 years ago
Location: Western North Carolina (mountains – 3700 foot elevation)
Shade in morning, full sun midday and afternoon
Pressure treated pine, 10 years old
Some mold/mildew
Sikkens finish (film-forming) has failed repeatedly – once the wood checks the film seal is broken and then the finish is off to the races…flaking, peeling, etc. Prefer a finish which is easy to recoat – Sikkens has to be sanded off completely.
Mike P
Mike P
13 years ago
Kentucky
Full Sun
Pressure Treated Pine ( approximately 15 years old )
No mold
No longer beading water and wearing unevenly
I've used Thompson's Waterseal + tinted wood protector in honey gold every 2 years for the life of the deck, but it seems like they changed their formula several years ago and it didn't work as well. I was wondering what stain you recommend and do I need to use RAD stripper and the brightner before I stain?
Mike P
Mike P
13 years ago
Is there a particular stain you would recommend?
Steve W.
Steve W.
13 years ago
1. Central PA
2. Partial shade
3. Pressure treated pine (built 2000) – should note, deck floor is Trex, so not stained. Stain only on spindles, structural parts, and overhead pergola/shade structure.
4. Some green mold (north side of house)
5. Age. Have stained twice since built, both times with Cabot semi-transparent redwood.
Generally pleased with Cabot's longevity. Decided this spring it's due again, only to find that I am not sure I'll be able to find my old Cabot oil-based formulation.
What's your take? And with whatever you recommend, what do I do about the existing stain, which is not all gone by any means. Strip? Sand? Clean & coat over?
Jason
Jason
13 years ago
Pergolas
Phoenix AZ
Full Sun
Hand Heun Pine beams
New build no failure
Isaac
Isaac
13 years ago
I have a cedar garage door that I'm going to re-stain when I do my deck and fence this summer. Would it be the same process for stripping, brightening and staining the garage door as it is with the deck? Thanks so much, great site!
Voyta
Voyta
13 years ago
New Jersey
Two parts of the deck:
One part:
Full sun, 2 years old pressure treated pine
Acrylic paint, mold and peeling like crazy
Second part:
Mostly shaded
I just put in the new decking. I plan on stripping the paint (Citristrip) and then brightening the old wood (Woleman brightener). I plan on cleaning and brightening the new wood after letting it weather for about a month.
My main concern is what stain to use since the wood is different age and part is shaded and part is not. I'm afraid the stain will not match. Any recommendations?
Voyta
Voyta
13 years ago
Thanks so much for a quick response. That's kind of what I was afraid of. Do you have any experience with Deck Restore? They claim it will last 10 years and they have a whole palette of colors to choose from. That way I wouldn't have to worry about the new wood being lighter color.
robert
robert
13 years ago
Brooklyn, NY
partial sun
5 yr old deck
mold in the shade
no treatment, but yearly cleaning
robert
robert
13 years ago
Reply to  robert
Thank you. Do you also recommend this for my cedar siding?
Donna
Donna
13 years ago
Eastern Pennsylvania
Main deck is18 years old, addition to deck is 5 years old
18 year old planks previously stained – don't know product
Main deck and addition deck painted with Sherwin Williams Deckscape Solid – 2 years ago
Mold and mildew on the north side of the deck near the house under the shade of the roof overhang
Deck steps (addition deck) – paint peeling
Matt
Matt
13 years ago
Want semitransparent since the HOA can get a little crazy about dark colors.
Deck Location State: N. CA (Livermore)
Full Sun, Partial Shade, Full Shade: Partial Shade
Wood Type: Redwood (installed 5 months ago)
Mold or Mildew Issues: Yes
Reason for Previous Stain Failure: New construction
lisa
lisa
13 years ago
We have a 8 year old deck that has been a nightmare from the first year with stain. Every year we are applying stain which starts to peal and fade. After reading other comments I think we are really doing something wrong. We have full shade and sun. My husband is power washing as we speak so we can try aging. Do we need to strip or can we just sand? It is a two level deck so huge. Any guidance would be wonderful. We live in Ky if that helps
13 years ago
New Jersey
Full sun
8 years old, cedar
no mold, near a pool but not surrounding
BM arbor coat, semi perm, 2 years ago – peeling nightmare
semyon rubinchik
semyon rubinchik
13 years ago
1. northern illinois, chicago
2. partial shade
3. pressure treated pine (guess)
4. no
5. wood not stained; now grey and weathered
Karen J
Karen J
13 years ago
1.Deck Location State: New Jersey
2.Full Sun, Partial Shade, Full Shade: Full Sun and Partial Shade
3.Wood Type: Pressure Treated Pine
4.Mold or Mildew Issues: Yes
5.Reason for Previous Stain Failure: Turned dark in color
Cody
Cody
13 years ago
North Dakota
Full Sun (afternoon)
No
Stain faded & started cracking after just 3 years
Kimberly
Kimberly
13 years ago
Indiana
Full Sun
Treated Pine
Mold and Mildew
Stain only lasted 2 years
Laura
Laura
13 years ago
Deck Location State: Missouri
Wood Type: Cedar
Mold or Mildew Issues: No
Reason for Previous Stain Failure: Deck built in 2011, put some kind of clear-coat sealer on it. It's not flaking or anything, but the wood is graying and appears dry. Water does not bead up on it anymore.
Coach
Coach
13 years ago
1.Deck Location State: mid- Missouri
3.Wood Type: Cedar (needs to be stripped and cleaned
4.Mold or Mildew Issues: No
5.Reason for Previous Stain Failure: Peeled and poor prep work
13 years ago
San Francisco, CA
Full Sun
Redwood
25+
mold, algae, mildew (fungus? – would a sodium percarbonate based deck cleaners get rid of fungus?)
No original stain
Gwen
Gwen
13 years ago
What is the best transparent oil based stain for my deck?
Deck Location State: Atlanta GA
Reason for Previous Stain Failure: 4 1/2 years since it's been done. Grey and dark now . Wood needs protecting.
Also, painter wants to use a diluted bleach solution to remove mold and mildew. Is that good?
Can I require the painter to use the type of stain I want him to use, such as TWP 1500 or Amstrong Clark?
Gwen
Russell
Russell
13 years ago
Deck Location State: Northern Virginia/DC
Reason for Previous Stain Failure: N/A new deck constructed four months ago
Kathleen
Kathleen
13 years ago
Deck Location State: Columbus, Ohio
Full Sun, Partial Shade, Full Shade: Covered Front Porch – partial sun
Wood Type: Cedar
Reason for Previous Stain Failure: 20 y.o. cedar porch cleaned and stained 5 years ago. Showing lots of normal wear over the 5 years – graying, bare wood etc. Previously stained with a natural cedar color that was too orange. Looking for a much darker richer brown.
Jason
Jason
13 years ago
Chicago, IL
Full Sun
Western Red Cedar – Patio Table
New – water can be absorbed in wood
No mold
Some shade with trees
Jason
Jason
13 years ago
Hi, thank you. IJust one more question, are the stains mentioned such as Armstrong Clark, Penofin, Defy, etc.. safe for food such as a dining patio table I have? Obviously we use plates and do not eat right off the table, but just in case. If these are safe products, great. If not, is there a finish or topcoat I can use? Or do you recommend not using stain at all? Thanks,
Jason
Darryk Modracek
Darryk Modracek
13 years ago
Massachusetts (South Coast)
Full Sun (South Facing)
Mahogany and Garapa
2 year old deck
No mold
Previously stained with Penofin oil. Now very gray and dingy.
Raymond Hayes
Raymond Hayes
13 years ago
Northwestern NC
Partial Sun only mid-day.
About 4 years old
No mold, some algae.
Not previously stained, wood dull grey color.
Cabin is surrounded by trees but we do get a pretty regular gentle breeze down the mountain almost all the time. No mold.
13 years ago
Sunny to shady durring the day
9 year old Mahogany
No mld issues
Have tried autralian Timer Oil and Penofin and neither has lasted a year, no beading, gone back to grey, just looking for longer durability
JoAnn
JoAnn
13 years ago
Hello! My husband and I are are confused about what to do with our 15 and 18 year old decks. They were was cleaned and stained with a water based stained stain two years ago. Within months, they began to peel. Prior to this,the desks were stained with an oil based stain that lasted seven years! We live in northern KY. The decks are in shade until noon and then sun until dark. How do we prepare the deck and want is the best stain? We cannot locate a supplier for TWP within a 100 miles.
JoAnn
Kris
Kris
13 years ago
Deck Location State: Indiana
Wood Type: Untreated Pine (Brand New)
Reason for Previous Stain Failure: None, will be new
Lynne Williams
Lynne Williams
13 years ago
Great site! Would appreciate your guidance.
Location- Richmond, Va.
Mostly shade
High humidity – mold and algae issues
Used thompson's water seal several years ago. Did not last long. I recently cleaned it with Olympic deck cleaner and rinsed with a power washer. Looks a bit splotchy but I cleaned it twice. Was going to use cabot Australian oil until I found this site. How long can it sit before staining while I research my options.
13 years ago
South Eastern PA
5 year old decks (3 tiers of decking plus a fence & an arbour) all need to be freshened up
pressure treated wood, initially stained with Cabot solid a darker color 5 years ago
full on sun for most of the day then shade in late afternoon, 1 of the decks is around an above ground pool
old stain wore off on floor boards
decks get heavy traffic by humans & 3 dogs (1 insists on using deck as a restroom – which has damaged some floor boards they will be replaced & possibly the dog too)
mold yes & some greenish stuff (guessing mildew)
13 years ago
Thank you for the fast reply!
Do I need to strip & brighten the decks? If so what would you suggest? Or just would you think lightly power washing would do the trick?
13 years ago
Thanks for the prompt response! In prep will I need to just power wash lightly, or am I to strip then brighten the wood prior to staining?
Bob Simms
Bob Simms
13 years ago
Southern Illinois 25 miles north of St. Louis, MO.
Full Sun next to pool (use Chlorine)
2 years old
Pressure Treated Pine 5/4 decking boards.
Let the deck set unstained for about 3 months before I used a pressure washer to prep it.
Old stain (Behr Premium Transparent Acrylic) peeled off after about two months.
The part of the deck that lost the most stain is closest to the pool. There are lots of kids in the pool all summer long.
Howard
Howard
13 years ago
Deck Location State: Northern Florida
Full Sun, Partial Shade, Full Shade: Mornign Sun
Reason for Previous Stain Failure: New decking, dried out a few months already
Thank you in advance for your help, Howard.
jaime
jaime
13 years ago
Ohio
Full sun
no mold
new deck, aged 1yr
Kaye
Kaye
13 years ago
Florida
Full
Yes
Brand new
Kevin S.
Kevin S.
13 years ago
What's the best sealer/stain for my area?
1.Deck Location State: South Central Pa.
2.Full Sun, Partial Shade, Full Shade: Afternoon Sun
5.Reason for Previous Stain Failure: One year old deck. First time stain.
jeff
jeff
13 years ago
colorado,full sun, 20 year old redwood,no mildew issues,always had it done,now dyi,not sure what they used,last done 2 yrs ago
Lisa
Lisa
13 years ago
Atlanta GA
Full Sun in morning and midday. Full shade in afternoon.
New deck construction (less than 1 week)
No mold
I also have a new cedar fence with PTP posts. Do you have a recommendation for stain and color that will maintain the cedar' s good looks?
Alysia
Alysia
13 years ago
1.Deck Location State: Massachusetts
4.Mold or Mildew Issues: very little mildew
I currently use Cabot SPF 48 transulcent and the color is sunray.
frequencydip
frequencydip
13 years ago
Deck Location State: Southern Calafornia
Wood Type: Have a choice of Redwood or Whitewood
Reason for Previous Stain Failure: New wood, never stained
I am facing a cinderblock wall with wood. The wood will be new but must be treated for termite protection, it will likely be coated with Black Flag Termin-8 Wood Preservative, so the stain must have a red tint to cancel out the green tint of black flag. Unless the stain has built in termite control. Since its not built yet I have a choice of woods, both Redwood or Whitewood Pine Board are locally available in either Shiplap or Tongue & Groove. I can source almost any stain available in the lower 48 for this project so I am not concerned with local availability or shipping regulations. Since its a vertical wall the stain will not endure foot traffic or direct rain.
Harvey
Harvey
13 years ago
1 – Connecticut – Fairfield County
2 – Full Sun
3 – Pressure treated
4 – yes, very
5 – weather, time
1 17 18 19 20 21 263
30.8K
