🏆 Top Picks Summary
- Best Overall: TWP 100 or 1500 Series
- Best for Old Decks: Armstrong Clark
- Best Budget Option: Restore-A-Deck
- Best Penetrating Oil: CUTEK Extreme
| Product | Type | Durability | Ease of Maintenance | Key Strength | Best For |
| TWP 100 | Semi-Transparent (Oil) | 2–3 Years | Easy | Proven performance, deep penetration | Most decks |
| TWP 1500 | Semi-Transparent (Oil, Low VOC) | 2–3 Years | Easy | Better VOC compliance, similar performance to TWP 100 | VOC-restricted states |
| Armstrong Clark Wood Stain | Semi-Transparent (Oil) | 2–3 Years | Easy | Excellent oil penetration + conditioning oils | Dry, aging wood |
| Restore-A-Deck Wood Stain | Semi-Transparent (Water-Based) | 2–3 Years | Very Easy | Simple prep system + easy recoat | DIY homeowners |
| CUTEK Extreme | Penetrating Oil | 2 Years | Very Easy | Deepest penetration, no film buildup | All Wood types |
| Defy Extreme | Semi-Transparent (Water-Based) | 1–3 Years | Moderate | Strong UV resistance with zinc nano-particles | Sunny/high UV areas |
- Best Overall Deck Stain: TWP 100 Pro Series — A deep-penetrating, oil-based semi-transparent stain that offers excellent durability, easy maintenance, and consistent performance for up to 3 years.
- Best Semi-Transparent (Water-Based): Restore-A-Deck Semi-Transparent Wood Stain — A user-friendly, UV-resistant stain that can be applied to damp wood, allowing prep and staining in one day.
- Best Oil-Based Alternative: Armstrong Clark Wood Stain — A penetrating oil formula that conditions aging wood while providing long-lasting protection and easy reapplication.
- Best for VOC-Restricted States: TWP 1500 Series — An EPA-registered preservative with strong UV and mildew resistance, ideal where traditional oil-based stains are limited.
- Best for UV & Mildew Resistance: Defy Extreme Wood Stain — A water-based formula enhanced with zinc nano-particles for superior UV protection and mildew resistance.
- Best Semi-Solid Stain: TWP Pro Series Semi-Solid — Offers richer color, excellent UV blocking, and better coverage while still allowing some wood grain visibility.
- Best Solid Color Stain: Restore-A-Deck Solid Color Stain — A durable, breathable coating that resists peeling and works well for older or heavily weathered decks.
- Best Deck Resurfacer: Gulf Synthetics Deck Revive — A thick resurfacing coating designed to restore heavily worn or damaged wood surfaces.
*Free Shipping Included
✅ How I Rate Deck Stains
- Durability in real-world conditions
- Ease of application and maintenance
- Resistance to peeling and wear
- Overall long-term performance
- Wear and tear after 2 years
- Oil-Based:
- Deep penetration
- Easier maintenance
- Water-Based:
- Better UV color retention
- Faster drying
1. TWP 100 Series
2. Armstrong Clark Wood Stain
3. TWP 1500 Series
4. TWP Pro-Series Semi-Solid
3. Defy Extreme Stain
Type: Oil-Based Semi-Transparent- Durability: 2–3 Years
- Maintenance: Easy recoat, no stripping needed
- Best For: Most decks (pressure-treated, cedar)
- Why It Stands Out: Deep penetration and consistent long-term performance without peeling
My Test Deck Stats
Deck Square Footage: 2100
Consumer Star Ratings:
- Type: Water-Based Semi-Transparent
- Maintenance: Very easy, simple prep system
- Best For: DIY homeowners and quick projects
- Why It Stands Out: Can be applied to damp wood, allowing prep and stain in one day
My Test Deck Stats
UV Exposure: 50% Full Sun
- Type: Oil-Based Semi-Transparent
- Maintenance: Easy reapplication
- Best For: Older, dry, or weathered wood
- Why It Stands Out: Contains conditioning oils that help restore dried-out wood
My Test Deck Stats
Deck Square Footage: 600
- Type: Semi-Solid (Oil-Based)
- Durability: 3 Years
- Maintenance: Moderate
- Best For: More color coverage with strong UV protection
- Why It Stands Out: Rich color options while still allowing some wood grain to show
My Test Deck Stats
When Tested: August 2023
Deck Square Footage: 800
UV Exposure: Deck in full sun
- Type: Oil-Based Semi-Transparent (Low VOC)
- Maintenance: Easy
- Best For: VOC-restricted states
- Why It Stands Out: EPA-registered preservative with strong UV and mildew resistance
My Test Deck Stats
Deck Wood Type: Cedar
Deck Square Footage: 400
- Type: Water-Based Transparent
- Durability: 1.5–2.5 Years
- Maintenance: Easy
- Best For: Maintaining a natural, “bare wood” appearance
- Why It Stands Out: Unique formula designed to preserve the natural color of new wood while still offering UV protection
My Test Deck Stats
Stain Color Used: Chesnut
- Durability: 2 Years
- Best For: High UV and mildew-prone areas
- Why It Stands Out: Zinc nano-particles provide superior UV protection and mold resistance
My Test Deck Stats
Stain Color Used: Cedartone
- Durability: 1-2 Years
- Best For: DIY users and quick, forgiving applications
- Why It Stands Out: Extremely easy to apply with no back-brushing needed, but shorter lifespan than higher-end penetrating stains
My Test Deck Stats
- Type: Penetrating Oil
- Maintenance: Very easy (clean and reapply)
- Best For: Exotic hardwoods (Ipe, teak) all wood types
- Why It Stands Out: Extreme penetration with no film buildup, making long-term maintenance simple
Scott’s Pro Tips: Although CUTEK® Extreme is more expensive than many penetrating oils, the performance was very solid. There was no peeling or significant wear, and the coating should be easy to maintain, as it fades naturally and can be refreshed without stripping.
My Test Deck Stats
Deck Square Footage: 1000
How Many Years Tested: 1 Year
Stain Color Used: Walnut
Semi-Solid Deck Stain Review
- Consumer Star Ratings:
Best Deck Stain for Old Wood
- For new pressure-treated wood, wait until the wood has weathered and is able to absorb stain (typically a few months), then prep and stain.
- For older pressure-treated decks, proper cleaning and brightening will restore the wood and allow for better stain penetration.
- If you want to maintain cedar’s natural look, use a lighter or natural-tone stain.
- If you want longer UV protection, choose a slightly darker tint, as it will hold color longer.
- Wood Condition: New, weathered, or heavily worn
- Desired Look: Natural grain showing vs solid color
- Maintenance Preference: Easy recoat vs long coverage
- Climate: Sun exposure, moisture, temperature swings
✅ Deck Stain Types Explained
- Transparent/Clear Sealers: Natural look, less protection
- Semi-Transparent Stains: Best balance (most recommended)
- Semi-Solid Stains: More color, moderate maintenance
- Solid Color Stains: Maximum coverage, higher maintenance
Transparent Stains
Solid (opaque) Stains
2. Long-Term Durability
3. Deck Condition
4. Climate Concerns
- Film-forming coatings on older decks
- Over-applying stain
- Choosing based on color alone
- Skipping prep
- Not preparing your deck: Failing to clean your deck or remove old, flaking, or peeling stain from your boards can prevent a fresh coat of stain from adhering properly. See my Deck Cleaning Guide for best results!
- Over-applying stain: You may think more stain equals more protection from moisture, mildew, and sun damage, but that’s not always the case. Too much stain can prevent the product from penetrating your deck boards. As a result, it may form a film on top of the wood that peels or flakes off over time. See my How to Stain a Deck tips for the best results.
✅ Best Deck Stain FAQs
Quick Tip:
What is a deck stain?
⏳ Durability & Maintenance
🎨 Appearance & Color
🛠 Application & Usage
🆕 New Deck Questions
- Smooth wood: Wait ~3 months
- Rough wood: Can stain once clean and dry
- Kiln-dried wood: Wait 1–2 months
- Deck Location: Michigan
- Wood Type: Cedar
- Mold/Mildew?No
Wisconsin (southern part)
Full sun
New deck built last summer
No mold issue (one part of deck will have a fair amount of shade
Never stained.
I was told by more than one person that its wise to stain with an oil based stain the first time then later on use a water based stain.
James, stay with an oil based stain. No need to switch. I would look at the Armstrong Clark for this newer deck. Make sure to clean and prep properly first.
Here is an example deck:
1.Deck Location: Bellingham, Washington
2.Partial Sun / Partial Shade
3.Wood Type: Pressure Treated cedar
4.Mold or Mildew Issues: Yes, mild on underside.
5.Reason for Previous Stain Failure: Age! and along with it pealing. We bought and moved into our 1o year old house last fall, and now it is time to clean & up brighten up the deck. The wood and supports are still in good shape and strong (no dry rot). But deck seriously needs stain and sealant. Need to get a couple of years out of the current deck yet. Future plans are to move to synthetic decking.
John Mc, prep with a good quality cleaner and wood brightener. Use a stain stripper if you have an old coating. As for the stain, Defy Extreme or Armstrong Stain.
We just re-surfaced an 1800 sq. ft. deck in Central Virginia with Kiln dried #1 pressure treated pine (DuraPine). The deck surrounds an above ground pool and receives 8-9 hours of direct sun each day. Only very mild mold/mildew issues on the north facing verticals, which can be expected. The previous surface, which was installed in 2000, seemed to fail mostly due to poor wood (ie: cheaper #2 pressure treated pine with many more knots and higher moisture content). We originally used Behr semi-transparent stain, with a maintenance coat on the horizontal decking surface every year or two. The Behr worked well for several years but seemed to lose effectiveness over the last 4-5 years. The verticals are still coated with the Behr and look fine. The new surface was just completed two weeks ago. Should we wait a couple weeks and apply Armstrong Clark or TimberOil or wait 4-6 months and apply TWP? I like the reviews of the TWP but my contractor told me not to wait too long before treating the new surface. I appreciate your recommendations.
Mike, I would wait a couple of months and apply 1 coat of the Armstrong Clark stain this year with a maintenance coat in 12-24 months after.
New York (Long Island)
Partial Sun
New Deck
Pressure Treated Lumber
No Mold
Attached to pool
Lenny, Please read this about New Deck Staining
After your last tip was such a great success, I would like to ask for help again:
Location: British Columbia part of the Rocky Mountains.
Long but not too cold winters (max -20 Celsius), hot, arid summers.
Deck exposed to full sun.
No mold, dried up growth of moss? in gaps
The Deck is older (+10y), never treated, wood unknown, guesses are cedar or tamarack
THANKS!
Susanne, do you want to buy locally or have it shipped from the States. It seems that you are limited to what is available in Canada.
If you have a recommendation for something good here in Canada, I go with that. If shipping is possible and the product is worth it, I will consider it too. I am also in Oregon in a couple of weeks and could bring something from there….I just want the best for the deck…;-) And easy application would be nice too…
THANKS!!
Susanne, you are limited I think and I am not sure what you can get there. I would look for the Armstrong Clark. Works well and applies easily. Might want to contact them to see if you can get it in Oregon.
Thanks! Armstrong was what I used on the old house in California and I liked it a lot. Will see if I can get it in Oregon. I was searching for stuff that's available here and is "eco"friendly and stumbled upon this: TimberSoy Natural Wood Stain have you heard about it or even have any experience with it. It's a US product.
Any opinion?
Never heard of TimberSoy.
Pacific Northwest – Vancouver
Full sun
Red cedar
Mildew + 8 months of rain
Brand new
David Mak, New wood needs to weather. Please read this article: New Deck Staining
Central North Carolina
Full sun
New Pressure treated pine
Some mildew
New deck
Johnw, Please read this article: Staining New Decking
Philadelphia suburbs (PA)
Mostly shaded
22-year old cedar deck and siding that has weathered to gray color in some areas. Structurally still very solid.
Mold/mildew in most shaded parts
As far as I can tell, never treated with anything
Thank you very much!
Newtecher, this deck is very old and dried out! Make sure to clean and brighten the wood first. For the stain Armstrong Clark would help restore the lost oils in the cedar and protect as well.
SW Connecticut, inland
Full sun
Ipe
mildew can be a problem
new deck just installed
Michael, the IPE should weather for a couple of months then prepped with a deck cleaner. Look for the Armstrong Clark Stain in Mahogany or Amber. IPE will need to be stained annually.
1. Wisconsin
2. Partial shade
3. Pressure treated pine
4. Yes
5. First time
Steve, How new is the deck? Might want to read this: New Deck Staining
Deck Location: Virginia
Full sun
#1 wood
No mold or mildew
New deck so nothing has failed yet
Kandice, Please read this article: Staining New Decks
1. Western MD
2. Partial Sun (wooded area)
3. 20yr old Pressure-treated pine
4. Yes
5. Mold/mildew buildup was significant when we purchased the house 2 years ago. Power washed to remove old (I have to assume the original) stain and mildew last year; looking to clean and stain this spring.
Thanks for any advice!
Bryan, since you have a mold issue you would want a stain that does not promote the growth. I would look for Defy Extreme or TWP 1500.
Maryland shore (Bay)
Partial shade
heat-treated southern yellow pine
minor mold
wood too dry within 1 year, checked and splintered
Cherie, Maryland is a low VOC state so you are restricted to what works well. Defy Extreme or TWP 1500 should work for you.
We live in Michigan and our deck is about 25 years old, structurally sound. It gets full sun,is pressure treated pine, has mold and mildew problems , and problem with stain peeling. We clean and restating the deck every other year, and have tried various products including behr, defy, Olympic.
Doreen, At this point you would need to make sure to remove all the old coatings 100% as it seems you may have a buildup of different products. This can be done with deck stain strippers and or sanding. Once removed we would look at the TWP 1500 for this very old and dried out wood.
Deck Location State: Michigan
Full Sun, Partial Shade, Full Shade: Full Sun
Mold or Mildew Issues: little bit…. not too bad
Reason for Previous Stain Failure: Peeling, turned grey
Steve, TWP 100 Series is what we would suggest. Make sure to prep well first with a deck cleaner and wood brightener.
Thank you! Keep up the great work.
Hello!
NE Ohio
Shaded in summer, partial shade/sun in winter
Pressure treated I pine – 10 mos old
No know mold issues
Hasn't been treated with anything.
Any advice would be greatly appreciated, thanks!
Dan, You need to prep the wood first before applying the stain. I would look at the Restore A Deck Cleaner Kits for this. As for the stain, I would suggest Defy Extreme or Armstrong Clark.
Thank you for the quick response – a few follow up questions.
Really just trying to understand the choice between the two recommended products.
1- I understand the Defy is a water based, while the Armstrong is oil… how does that translate into application and performance? I seem to see a lot of people recommending an oil based stain as opposed to the water.
2- After the initial application – what kind of maintenance/upkeep should I expect?
3- Also, i'm curious – why is TWP not recommended for my situation?
Thanks again!
-D
Dan,
1. Oil based stains do penetrate better and are typically easier to apply. Performance they would be very similar.
2. Typically requires a coat every 2 years or so.
3. TWP is a very good stain but it does not penetrate newer wood as well. You are borderline with being new so it may work just fine.
Virginia beach Virginia full sun 2 weeks old possibly mold nothing applied to deck as of yet
Tommy, Please read this and Staining New Decks
NE Tennessee
Full Afternoon Sun
Brand New Deck-Built 4 months go
old deck did get slight mold
We do have dogs 2 small 1 lab that will be walking on deck several times a day to go outside
How should we prep & what clear stain/sealer should we use?
Anne, clear offer little to no UV protection. You must have a tint for that. Due to the traffic you want a stain that penetrates very well into the wood. less chance of wear. Prep with a cleaner and a brightener. Let dry then stain with Armstrong Clark or TWP 100.
Thanks! Should we go with TWP 100 over the 1500?
The TWP 100.
State- Michigan
Wood – pressure treated pine
Location – full sun
Mold mildew issues – some
Reason old stain failed – not kept up / replaced wood last year
Jan, prep first then look for TWP 100 Series. Works very well for Michigan.
Kingston, Tn
2700 sq. ft. deck & wrap around porch
90% full sun or partial
2 year old deck no prior stain
Log home stained with Woodguard buckskin stain.
Needs to be cleaned first and would like to know what would be the best products to use. Then would like to stain a cedar color and would like it to be a penetrating stain. Which stain would give me the best UV/mildew protection and wear for area. Mildew and green growth on everything here in TN. and need something that will last and not cost me my first born.
Lauren, Big Porch! Prep with the Defy Cleaner/Brightener or Restore A Deck Products. Penetrating stains are best for wear. Defy Extreme does an excellent job with preventing mildew. I would look at that first, then TWP 100 Series.
I'm driving out to Houston to clean and stain a deck. It has a semi transparent gray stain on it now. Can I just power wash it? Also which TWP should I use, the 100 or 1500? The house is blue so think we want it to do it a shade of gray again.
Jan, it would best to strip and brighten the wood with the pressure washer. This would prep the wood properly. The TWP 100 Series is the only one that comes in gray colors.
Houston
Full sun
New pergola about to be installed.
Cedar, we would like to stain it chocolate brown
Prestain before assembly? Or stain in place?
Neil, Is the wood smooth or rough? This depends when it can be stained.
It's rough, thanks
Neil, if rough wood then you can stain right away. Armstrong Clark makes a nice chocolate brown color called Oxford Brown. TWP makes a Dark Oak color.
New York, Orange county
full sun
no mold
4 year old deck that has been stained with Behr No. 400 transparent 2-3 times but it seems to 'lift off' every season. I am not a big fan of Behr prods. They are recommending stripping it then using their wood prep then staining again but I am open to other ideas and different brands
Liam, they are correct on the stripping. You need to remove the Behr and start over with a penetrating oils based stain. I would look at the Armstrong Clark Wood Stain for this as it penetrates deep into the wood.
Northeastern Nevada (Elko)
Full sun
10 year old deck
no mold
it has had different stains on it. last year I sanded it down and applied superdeck. This year I pressure washed it and the stain came off. I have not yet tried to put anything else on.
Mitch Woods, I would look at the TWP 1500 for this.
Monica, Do you know what options you have locally for stain brands? I believe you can get Defy or Armstrong Clark shipped to you.
I was going to have my new cedar deck stained last year, but all the information when researching left a hugh "not a clue'
feeling! So now here in Western WA. enjoying our first sun for a long time, I again need help. I am looking for a semi transparent stain so grain can show, also would like to see good semi's with a little color (blue) in it. But most of all I need your information on what is the stain that you recomend for 1/2 deck in rain, snow, sun, with back 1/3 covered. I am older
and disabled so don't want to have to do again every year, but will if needed. Live alone, 1 dog that spends most of her time with me; kids grown,etc. Local friends what me to put on one that did not do well in your research, but popular here.
Thank you so much, jill
Jill, I would look at the Armstrong Clark Stain for this newer deck. Make sure to clean and prep the wood first.
San Luis Obispo County, California
new and sanded redwood decking.
I am replacing part of a redwood deck and refinishing another. I am either planing or sanding off the existing finish.
Half of the deck is in the full sun. the other half is covered by a shade structure covered with shade cloth.
The joists in the portion of the deck being replaced rotted out at the butt joints and where the joists were sistered.
The climate here is dry nine months of the year. Mold is not an issue.
I am looking to stain the deck to the classic redwood red color.
Phil Keys, I would let the new wood weather for a time then prep with a deck cleaner. For the stain, I would look at Defy Extreme or Armstrong Clark.
Deck Location State: Georgia – Atlanta Area
Full Sun, Partial Shade, Full Shade: Full Sun, very intense in the summer
Wood Type: Cedar (railing only) Deck is AZEK Full Composite
Reason for Previous Stain Failure: Used just a clear oil sealer on new railing last year. Did not last – need better protection,
Mark Beers, clean and prep to remove the old clear sealer. I would use TWP 100 or Defy Extreme in one of their colors. Clears will not last very long from graying.
Sorry – a clarification – I used Cabot Australian Timber Oil in a Cedar Tone. Might as well have been a clear oil for all the protection I got. I have ordered some sample colors in TWP 100.
Alabama
Shade/Full Sun
Cedar/Cypress/Untreated Pine
No mold
New outdoor furniture
I build outdoor furniture & I am looking for a oil stain to use. Just want the best product to offer my customers.
Doug, the issues is that most manufacturers want you to let the wood weather before you apply a stain to new wood. I would assume that you want to stain it right away. This will not last nearly as long. If it is was us, I would look at Armstrong Clark stains for this. It penetrates new wood better then most.
1. Cincinnati, OH
2. Partial Sun (south-facing)
3. Pressure-Treated Pine
4. Mildew (privacy siding/fence)
5. 20+ year old deck—we don't know when it was last stained
Leigh, do you see any remnants of old stain? If so you would want to remove that first. If not then use a deck cleaner and brightener to prep. Once dry I would stain with Defy Extreme Stain or Armstrong Clark for this very old deck. We would lean to the AC as it helps condition dried out wood.
Southern Ontario Canada
Full Sun
Pressure Treated Softwood
Mold – No
Deck is untreated, new July 2012
Great web site! Any suggestions much appreciated (prep products too if recommended).
Ryan, not sure what you can buy locally. Other Canadians had issues finding decent products locally. I would look for Armstrong Clark stain for this newer deck. Restore A Deck products would prep well.
Redwood Deck, Full Western Sun, Some mold on Northern side.
In Kensington, Ca near Berkeley
My previous painter put BM hardwood stain on it, and it destroyed a lot of the wood.
I have someone who power washed it, and now wants to put Cabot stain on it. Will that work?
Mary, I would look for TWP 1500 or Armstrong Clark. Both will be better then the Cabot.
Deck Location State: Minnesota
Sun: hot Afternoon sun in the summer
Mold or Mildew Issues: no
Reason for Previous Stain Failure: I built the deck in the fall of 2011, it hasn't been stained or treated yet
Jon, you would need to clean and brighten the wood to prep. This will restore the natural color before applying the stain. I would look at Defy Extreme for this. Other option would be TWP 100.
Deck Location State: Evergreen, Colorado at 8,000 ft.
Full Sun, no overhang, facing southeast to southwest, subject to snow and rain
Wood Type: Peeled Pine logs for posts and railings; redwood decking
Reason for Previous Stain Failure: Decking is 11 years old. Peeled logs for railing and posts are NEW; redwood decking needs thorough R&R and will be sanded first.
We have new, natural, peeled pine log railings and posts that have been protected by copper caps since they were installed last November but we’re now planning on staining with better weather in the coming months. Please advice on a clear or partially pigmented solution for the new wood.
Separately, the original redwood decking, while structurally sound, is grayed and is flaking old stain due to a few years of no maintenance.
Thanks for your insights, Phil
Phil, lighter colors will always fade faster then darker colors. Going with a light pigment may require an annual application of stain on the flooring due to your high UV index and weather. if we were doing the job, we would look at the Armstrong Clark Stain as it penetrates into newer wood better.
Deck Location: San Mateo, CA
Exposure: Full Sun
Wood Type: Redwood
Mold or Mildew Issues: No
Reason for Previous Stain Failure: Faded and attracted dirt – 1.5 years (brand new deck at that time)
Previously used: Superdeck Semi-Transparent (Redwood)
Looking for a new stain to use and also what product to use to prep the deck before applying the stain?
Craig, Strip and brighten the deck with the Restore-A-Deck products. This will easily remove the SuperDeck and restore the wood. I would look for the Armstrong Clark or TWP 1500 for this deck in CA.
hi i am restaining an existing cedar deck in the interior of BC, Canada. This deck recieves full sun in summer and is covered in snow in winter. We presently do not have mold issues. the present stain cannot withstand these conditions and is cumbersome to reapply
the propertyis in an restricted development, and Silkens – Butternut ( warm light brown color) is the prescribed stain. i am looking at twp and have recieved samples of Cedartone, Rustic and Dark Oak. Individually these stains are not close. combining dark oak and cedartone start to get us closer. I was wondering if pehaps Pecan or another color would be closer. I have phoned twp and they could not help me. does anyone have any thoughts before i purchase every sample and become a chemist!. Much thanks!
jackspratvan, sorry but we personally have never used or seen that particular Sikkens color. Maybe Honeytone with a little bit of Dark Oak?
6yo pt pine
Covered deck (full son on edges)
No mold issues
Stained annually with Behring water based. Peeling and wood splitting (no uv protection?)
Change to oil based? Strip or sand first?
Tired of staining, I would strip first then sand off any if needed. We are not surprised with you Behr failures. In general an oil based stain will penetrating better, minimizing your peeling. I would switch to the Armstrong Clark Stain as it penetrates extremely well.
Looking for a deck stain.
Live in Extreme Southern Louisiana
High heat and humidity.
Pretty much full sun
High Traffic/Pool Deck
9 months old.
HELP!!:)
I have a pattern in the deck and was thinking about trying to use 2 colors for effect. Any help tips to complete this process appreciated.
Kristie, You will need to start by cleaning and brightening the wood. This will prep the wood for the penetrating stain. Since this is a newer pool deck, I would suggest a deep penetrating wood stain such as Armstrong Clark.
Phoenix, Arizona
Full Sun
Douglas Fir
Brand new installation
Brad, please read this about new decks: Staining a New Deck
Vancouver, British Columbia, Canada
Full sun, covered glass roof over deck
Brand new CEDAR deck, fir posts
no mildew issues
first time staining our new deck!
Asia, please read this for some advice about Staining New Decks
page was 'not found'…???
can you please advice:)
Asia, please try now. The link worked for us.
when did you stain this deck, I live in White Rock area – have also new cedar deck – wanting some info on product to use – how was it applied, etc.
Carine, what \”deck\” are you asking about?
What would be the right stain?
Dallas, TX
Full Sun
Cedar Fencing – Built 2007 – first restain
no mold, but slight discoloring on heavy sun side
Adam, I would clean and brighten the wood first then stain with a good quality stain such as Armstrong Clark or TWP 1500.
Lansing, Michigan
Full Sun all day
7 year old cedar deck/ 800 sq. feet
no mold
Has been cleaned and stained 3 times/nothing seems to last more than 1 year..Two years ago prepped with deck cleaner/pressure washer with soft nozzle and then stained
Gray and looks like crap
Would be interested in using a darker color for it to last longer. Need a good cleaner and stain
Robi, prep with the Restore-A-Deck products then stain with the TWP 100.
Southern MD
Full Sun (western facing)
New build
Pressure treated
No mold issues
Just would like to know your suggestion on stain and application time, Thanks
Eddie, please read this for more info on Staining new Decks
New Jersey
Full sun
pressure treated pine 25 yrs old deck with some newer boards
little mold
used Cabot solid color acrylic Grey color…
stained 2 yrs ago…older boards did not hold up well
Phil, since you have already used a solid color stain you will need to stay with that unless you want to sand the entire deck. I would look for Flood Solid Color Deck Stain after you prep the wood by removing all the mold, dirt and loose stain.
Seattle, Washington
Full sun
Ipe 5 years old not previously stained, left to gray
No mold nor mildew, attracts algae
No previous stain
Barry Craig, clean first with a product like the Restore A Deck Kit. I would use the Armstrong Clark Stain in the Mahogany color or Amber color.
What would be the right deck stain for a:
ocean front deck,
North Carolina,
full sun,
10 years old.
Haibo, I would look at the Defy Extreme Stain or TWP 100 for this PTP deck in NC. Make sure to prep properly first.
What is the best stain for my boat dock?
1. Texas
2. Full Sun
4. New wood – no previous stain
Can you recommend a couple of stains? I am interested in a clear tinted stain.
Kim, Please read this article on New Deck Staining
Thank you. There do not seem to be any dealers near me, so i guess i will have to find a way to get some to test for color
John, did you contact the manufacturer for a possible location?
Location: northern California (SF east bay area), climate 90's in the summer and dry, some freezing in winter
50% of the deck gets full sun, 50% gets filtered full sun since it has a mesh cover.
Redwood deck, 20 years old, pressure washed and re-stained every spring with a semi-transparent stain
Mold/mildew issues are very minimal
Looking for semi-transparent stain that can last at least two years on horizontal surfaces. The covered area fades a lot less, but the full sun area needs refinishing every year. The vertical surfaces and seem to last 3 years. I have been using Superdeck (by Duckback) semi-transparent stain until last year when I could no longer buy it locally, and then switched to Cabot semi-transparent with the same results.
Would truly appreciate your opinions. Thanks.
Richard, Have you tried Armstrong Clark wood stain? It is made in northern California. Great product!
Sun: Partial – deck faces the west, but is completely covered – some rain/snow gets to deck, but not much
Wood type: Pressure treated pine
Mold/Mildew – not yet – deck is about 6-7 months old
Reason for failure: N/A
I hope to stain deck when warmer weather arrives – it will be close to one year old at that point. Looking for a deck that will allow the texture of the wood to show. I don't mind the lighter pine color (the ceiling of the deck has a lighter pine wood). More interested in protecing the wood than chaning its color. I've used Thompsons and Wolman on a different deck, and have been very dissaponted. Any help would be very appreciated!
Jon, I would look at Defy Extreme in Natural Pine color of TWP in Honeytone. They are the lighter tints but still offer UV protection.
